TrevorOutlaw Posted November 27, 2022 Share Posted November 27, 2022 1 hour ago, BoltBait said: Check out my new plugin pack. A couple of them actually do this. (Object > Apply Mask and Object > Alpha to Gray) I thought I would pass word along that after downloading version 60 and running installer, I was informed that version 52 was available for download, so I was confused. I had to remove all the effects associated with version 52 so I could see version 60. I'll give it a whirl and see how the Apply Mask works, and if it's working as I'm thinking, then I will need to give an update to the tutorial reflecting the latest change in PDN V 5.0 Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial Link to comment Share on other sites More sharing options...
Tactilis Posted November 27, 2022 Share Posted November 27, 2022 On 11/27/2022 at 2:03 AM, TrevorOutlaw said: I thought I would pass word along that after downloading version 60 and running installer, I was informed that version 52 was available for download, so I was confused. See the note in red under the Download button warning you about this: Link to comment Share on other sites More sharing options...
pavlik1307 Posted November 28, 2022 Share Posted November 28, 2022 (edited) The program crashes when I try to open the "About" dialog box. It also crashes when I try to use any selection tool. After using the "Move Selected Pixels" tool, it crashes because the moved pixels become selected. The crash happens on any rendering device. The problem is solved by disabling the "Use hardware acceleration for UI and canvas" option. Crash logs have been sent by email. By the way, does anyone know why the integrated GPU is marked as "Performance"? Edited November 28, 2022 by pavlik1307 Link to comment Share on other sites More sharing options...
homebrew Posted November 28, 2022 Share Posted November 28, 2022 2 hours ago, pavlik1307 said: The program crashes when I try to open the "About" dialog box. It also crashes when I try to use any selection tool. After using the "Move Selected Pixels" tool, it crashes because the moved pixels become selected. The crash happens on any rendering device. The problem is solved by disabling the "Use hardware acceleration for UI and canvas" option. Crash logs have been sent by email. By the way, does anyone know why the integrated GPU is marked as "Performance"? quite simple performane use more power to do more works. older GPU like your's can't match the needs of today rendering Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 28, 2022 Author Share Posted November 28, 2022 3 hours ago, pavlik1307 said: The program crashes when I try to open the "About" dialog box. It also crashes when I try to use any selection tool. After using the "Move Selected Pixels" tool, it crashes because the moved pixels become selected. The crash happens on any rendering device. The problem is solved by disabling the "Use hardware acceleration for UI and canvas" option. Crash logs have been sent by email. By the way, does anyone know why the integrated GPU is marked as "Performance"? Do you have a crash log? The GPU is marked as "Performance" because that's what Windows identified as the "performance GPU". Ask them ¯\_(ツ)_/¯ The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
pavlik1307 Posted November 28, 2022 Share Posted November 28, 2022 (edited) @Rick Brewster Here is the crashlog when you open the "About" window: Spoiler This text file was created because paint.net crashed. Please e-mail this to crashlog5@getpaint.net so we can diagnose and fix the problem. Application version: paint.net 5.0 (α 5.0.8361.33457) Time of crash: 28.11.2022 15:36:29 Application uptime: 00:00:03.4378834 Application state: Running Working set: 197 492 KiB Handles and threads: 864 handles, 46 threads, 140 gdi, 183 user Install type: Portable Application directory: D:\Soft\paint.net.5.0.8361.33457.portable.x64 Current directory: D:\Soft\paint.net.5.0.8361.33457.portable.x64 Install directory: D:\Soft\Paint.net OS Version: Windows 10 Pro 10.0.19045.0 x64 .NET version: .NET 7.0.0 x64 Processor: "Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz" @ ~2195MHz (4C/8T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX) Physical memory: 5920 MB Video card: Intel(R) HD Graphics 3000 (v:8086, d:116, r:9), NVIDIA GeForce 610M (v:10DE, d:1058, r:161), Microsoft Basic Render Driver (v:1414, d:8C, r:0) Hardware acceleration: True (default: True) (rendering: 🚀 Performance (Intel(R) HD Graphics 3000)) Remote session: no Pointers: none UI animations: True UI DPI: 96 dpi (1,00x scale) UI theme: VisualStyleCategory=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Blue, ThemeFileName=Aero.msstyles Updates: n/a Locale: pdnr.c: en-US, hklm: n/a, hkcu: en-US, cc: ru-RU, cuic: en-US Flags: Exception details: System.ArgumentException: Value does not fall within the expected range. (PaintDotNet.Controls.PdnBanner) ---> System.ArgumentException: Value does not fall within the expected range. at PaintDotNet.Interop.ExceptionFactory.ThrowError(Int32 hr, String message, Exception innerEx) at PaintDotNet.Direct2D1.D2D1EffectContext.LoadPixelShader(ShaderID& shaderID, ReadOnlySpan`1 shaderBuffer) at PaintDotNet.Direct2D1.Effects.PixelShaderTransformBase`1..ctor(IDeviceEffectContext effectContext) at PaintDotNet.Direct2D1.Effects.LinearToSrgbEffect.Impl.OnPrepareForRender(ChangeType changeType) at PaintDotNet.Direct2D1.CD2D1EffectImplCcw.PrepareForRender(D2D1_CHANGE_TYPE changeType) --- End of inner exception stack trace --- at PaintDotNet.Interop.ExceptionFactory.ThrowError(Int32 hr, String message, Exception innerEx) at PaintDotNet.Direct2D1.D2D1DeviceContext6.EndDraw() at PaintDotNet.Controls.Direct2DControlHandler.Render(RectInt32 clipRect) at PaintDotNet.Controls.Direct2DControlHandler.RelayGdiPaintImpl(IGdiPaintContext ctx) at PaintDotNet.Controls.Direct2DControlHandler.RelayGdiPaint(IGdiPaintContext ctx) at PaintDotNet.Controls.Direct2DControl.OnGdiPaint(IGdiPaintContext ctx) at PaintDotNet.Gdi.GdiControlHandler.OnWmPaint(Message& m) at PaintDotNet.Gdi.GdiControlHandler.RelayWndProc(Message& m) at PaintDotNet.Gdi.GdiControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam) Managed assemblies: System.Private.CoreLib, .\System.Private.CoreLib.dll, Version=7.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet, .\paintdotnet.dll, Version=5.0.8361.33457 System.Runtime, .\System.Runtime.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms, .\System.Windows.Forms.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.Fundamentals, .\PaintDotNet.Fundamentals.dll, Version=5.0.8361.33457 PaintDotNet.ComponentModel, .\PaintDotNet.ComponentModel.dll, Version=5.0.8361.33457 System.Diagnostics.Tracing, .\System.Diagnostics.Tracing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread, .\System.Threading.Thread.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Base, .\PaintDotNet.Base.dll, Version=5.0.8361.33457 PaintDotNet.Collections, .\PaintDotNet.Collections.dll, Version=5.0.8361.33457 PaintDotNet.Systrace, .\PaintDotNet.Systrace.dll, Version=5.0.8361.33457 PaintDotNet.Windows, .\PaintDotNet.Windows.dll, Version=5.0.8361.33457 TerraFX.Interop.Windows, .\TerraFX.Interop.Windows.dll, Version=10.0.22621.0, PublicKeyToken=35b01b53313a6f7e PaintDotNet.Primitives, .\PaintDotNet.Primitives.dll, Version=5.0.8361.33457 System.Collections.Concurrent, .\System.Collections.Concurrent.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Runtime, .\PaintDotNet.Runtime.dll, Version=5.0.8361.33457 PointerToolkit, .\PointerToolkit.dll, Version=1.0.0.0 System.Threading, .\System.Threading.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Process, .\System.Diagnostics.Process.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer, .\PaintDotNet.SystemLayer.dll, Version=5.0.8361.33457 System.Private.Uri, .\System.Private.Uri.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives, .\System.ComponentModel.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms.Primitives, .\System.Windows.Forms.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 WindowsBase, .\WindowsBase.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 PaintDotNet.ObjectModel, .\PaintDotNet.ObjectModel.dll, Version=5.0.8361.33457 System.Runtime.InteropServices, .\System.Runtime.InteropServices.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework, .\PresentationFramework.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Drawing.Primitives, .\System.Drawing.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xaml, .\System.Xaml.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 System.ComponentModel, .\System.ComponentModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections, .\System.Collections.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.TraceSource, .\System.Diagnostics.TraceSource.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.CodePages, .\System.Text.Encoding.CodePages.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Core, .\PaintDotNet.Core.dll, Version=5.0.8361.33457 PaintDotNet.Resources, .\PaintDotNet.Resources.dll, Version=5.0.8361.33457 Newtonsoft.Json, .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Linq.Expressions, .\System.Linq.Expressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter, .\System.ComponentModel.TypeConverter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ObjectModel, .\System.ObjectModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Numerics, .\System.Runtime.Numerics.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Configuration.ConfigurationManager, .\System.Configuration.ConfigurationManager.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Specialized, .\System.Collections.Specialized.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml, .\System.Private.Xml.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Data, .\PaintDotNet.Data.dll, Version=5.0.8361.33457 System.Net.WebClient, .\System.Net.WebClient.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.ComponentModel.EventBasedAsync, .\System.ComponentModel.EventBasedAsync.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xml.ReaderWriter, .\System.Xml.ReaderWriter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Framework, .\PaintDotNet.Framework.dll, Version=5.0.8361.33457 PaintDotNet.Windows.Framework, .\PaintDotNet.Windows.Framework.dll, Version=5.0.8361.33457 PaintDotNet.UI, .\PaintDotNet.UI.dll, Version=5.0.8361.33457 Microsoft.Win32.Registry, .\Microsoft.Win32.Registry.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.SystemEvents, .\Microsoft.Win32.SystemEvents.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Linq, .\System.Linq.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Common, .\System.Drawing.Common.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Immutable, .\System.Collections.Immutable.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.ThreadPool, .\System.Threading.ThreadPool.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationCore, .\PresentationCore.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder, .\DirectWriteForwarder.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.Debug, .\System.Diagnostics.Debug.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions, .\System.Runtime.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC, .\System.Runtime.CompilerServices.VisualC.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric, .\System.Collections.NonGeneric.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a UIAutomationTypes, .\UIAutomationTypes.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 PaintDotNet.Windows.Core, .\PaintDotNet.Windows.Core.dll, Version=5.0.8361.33457 System.Diagnostics.FileVersionInfo, .\System.Diagnostics.FileVersionInfo.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects.Core, .\PaintDotNet.Effects.Core.dll, Version=5.0.8361.33457 Accessibility, .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 CommunityToolkit.HighPerformance, .\CommunityToolkit.HighPerformance.dll, Version=8.0.0.0, PublicKeyToken=4aff67a105548ee2 System.Threading.Tasks.Parallel, .\System.Threading.Tasks.Parallel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.PropertySystem, .\PaintDotNet.PropertySystem.dll, Version=5.0.8361.33457 System.IO.Packaging, .\System.IO.Packaging.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Memory, .\System.Memory.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Runtime.Loader, .\System.Runtime.Loader.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a DdsFileTypePlus, .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.12.0 AvifFileType, .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.20.0 WebPFileType, .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.12.0 PaintDotNet.Effects.Gpu, .\PaintDotNet.Effects.Gpu.dll, Version=5.0.8361.33457 PaintDotNet.Effects, .\PaintDotNet.Effects.dll, Version=5.0.8361.33457 PaintDotNet.Effects.Legacy, .\PaintDotNet.Effects.Legacy.dll, Version=5.0.8361.33457 ComputeSharp.D2D1, .\ComputeSharp.D2D1.dll, Version=2.0.0.0 System.Runtime.Intrinsics, .\System.Runtime.Intrinsics.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Numerics.Vectors, .\System.Numerics.Vectors.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Serialization.Formatters, .\System.Runtime.Serialization.Formatters.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a mscorlib, .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System.CodeDom, .\System.CodeDom.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Security.Claims, .\System.Security.Claims.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.RegularExpressions, .\System.Text.RegularExpressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a ComputeSharp.Core, .\ComputeSharp.Core.dll, Version=2.0.0.0 PhotoSauce.MagicScaler, .\PhotoSauce.MagicScaler.dll, Version=0.13.2.0, PublicKeyToken=fc6b9b7b06809481 PointerToolkit.TerraFX.Interop.Windows, .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.22621.0 Microsoft.Win32.Primitives, .\Microsoft.Win32.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Native modules: .\paintdotnet.exe, version=5.0.8361.33457 C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) C:\WINDOWS\System32\USER32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\win32u.dll, version=10.0.19041.2251 (WinBuild.160101.0800) C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.2130 (WinBuild.160101.0800) C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.2130 (WinBuild.160101.0800) C:\WINDOWS\System32\ole32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\combase.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800) C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) .\VCRUNTIME140.dll, version=14.34.31931.0 .\VCRUNTIME140_1.dll, version=14.34.31931.0 C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.2193 (WinBuild.160101.0800) C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_1474122a0ce2f241\nvinitx.dll, version=23.21.13.9135 C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\sechost.dll, version=10.0.19041.320 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\Program Files\NVIDIA Corporation\CoProcManager\detoured.dll, version= C:\Program Files\NVIDIA Corporation\CoProcManager\nvd3d9wrapx.dll, version=23.21.13.9135 C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1620 (WinBuild.160101.0800) C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\Program Files\NVIDIA Corporation\CoProcManager\nvdxgiwrapx.dll, version=23.21.13.9135 .\hostfxr.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 .\hostpolicy.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 .\coreclr.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1415 (WinBuild.160101.0800) .\System.Private.CoreLib.dll, version=7.0.22.51805 .\paintdotnet.ni.dll, version=5.0.8361.33457 .\clrjit.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\paintdotnet.dll, version=5.0.8361.33457 .\System.Runtime.dll, version=7.0.22.51805 C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.2248 (WinBuild.160101.0800) .\System.Windows.Forms.dll, version=7.0.22.51807 .\PaintDotNet.Fundamentals.dll, version=5.0.8361.33457 .\PaintDotNet.ComponentModel.dll, version=5.0.8361.33457 .\System.Diagnostics.Tracing.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) .\System.Threading.Thread.dll, version=7.0.22.51805 .\PaintDotNet.Base.dll, version=5.0.8361.33457 .\PaintDotNet.Collections.dll, version=5.0.8361.33457 .\PaintDotNet.Systrace.dll, version=5.0.8361.33457 .\PaintDotNet.Windows.dll, version=5.0.8361.33457 .\TerraFX.Interop.Windows.dll, version=10.0.22621.0 .\PaintDotNet.Primitives.dll, version=5.0.8361.33457 .\System.Collections.Concurrent.dll, version=7.0.22.51805 .\PaintDotNet.Runtime.dll, version=5.0.8361.33457 .\PointerToolkit.dll, version=1.0.0.0 .\System.Threading.dll, version=7.0.22.51805 .\System.Diagnostics.Process.dll, version=7.0.22.51805 .\PaintDotNet.SystemLayer.dll, version=5.0.8361.33457 .\System.Private.Uri.dll, version=7.0.22.51805 .\System.ComponentModel.Primitives.dll, version=7.0.22.51805 .\System.Windows.Forms.Primitives.dll, version=7.0.22.51807 .\WindowsBase.dll, version=7.0.22.51802 .\PaintDotNet.ObjectModel.dll, version=5.0.8361.33457 .\System.Runtime.InteropServices.dll, version=7.0.22.51805 .\PresentationFramework.dll, version=7.0.22.51802 .\System.Drawing.Primitives.dll, version=7.0.22.51805 .\System.Xaml.dll, version=7.0.22.51802 .\System.ComponentModel.dll, version=7.0.22.51805 .\System.Collections.dll, version=7.0.22.51805 .\System.Diagnostics.TraceSource.dll, version=7.0.22.51805 .\System.Text.Encoding.CodePages.dll, version=7.0.22.51805 .\PaintDotNet.Core.dll, version=5.0.8361.33457 .\PaintDotNet.Resources.dll, version=5.0.8361.33457 .\Newtonsoft.Json.dll, version=13.0.1.25517 .\System.Linq.Expressions.dll, version=7.0.22.51805 .\System.ComponentModel.TypeConverter.dll, version=7.0.22.51805 .\System.ObjectModel.dll, version=7.0.22.51805 .\System.Runtime.Numerics.dll, version=7.0.22.51805 .\System.Configuration.ConfigurationManager.dll, version=7.0.22.51805 .\System.Collections.Specialized.dll, version=7.0.22.51805 .\PresentationNative_cor3.dll, version=7,0,22,50606 @Commit: 00c647d63646ecc287c92f64734f438557f4a813 .\System.Private.Xml.dll, version=7.0.22.51805 .\PaintDotNet.Data.dll, version=5.0.8361.33457 .\System.Net.WebClient.dll, version=7.0.22.51805 .\System.ComponentModel.EventBasedAsync.dll, version=7.0.22.51805 .\System.Xml.ReaderWriter.dll, version=7.0.22.51805 .\PaintDotNet.Framework.dll, version=5.0.8361.33457 .\PaintDotNet.Windows.Framework.dll, version=5.0.8361.33457 .\PaintDotNet.UI.dll, version=5.0.8361.33457 .\Microsoft.Win32.Registry.dll, version=7.0.22.51805 .\Microsoft.Win32.SystemEvents.dll, version=7.0.22.51805 .\System.Linq.dll, version=7.0.22.51805 .\System.Drawing.Common.dll, version=7.0.22.51805 .\System.Collections.Immutable.dll, version=7.0.22.51805 .\System.Threading.ThreadPool.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\dxgi.DLL, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.1620 (WinBuild.160101.0800) C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.2193 (WinBuild.160101.0800) C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\MSASN1.dll, version=10.0.19041.2251 (WinBuild.160101.0800) .\PresentationCore.dll, version=7.0.22.51802 .\DirectWriteForwarder.dll, version=7,0,22,51802 @Commit: 636e2b7a00a434a354a126f510a56e16ce3c6bbc .\System.Diagnostics.Debug.dll, version=7.0.22.51805 .\System.Runtime.Extensions.dll, version=7.0.22.51805 .\System.Runtime.CompilerServices.VisualC.dll, version=7.0.22.51805 .\System.Collections.NonGeneric.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.2248 (WinBuild.160101.0800) .\UIAutomationTypes.dll, version=7.0.22.51802 .\PaintDotNet.Windows.Core.dll, version=5.0.8361.33457 .\System.Diagnostics.FileVersionInfo.dll, version=7.0.22.51805 C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) .\PaintDotNet.Effects.Core.dll, version=5.0.8361.33457 C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800) .\Accessibility.dll, version=7.0.22.51807 C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.2251_none_91a40448cc8846c1\gdiplus.dll, version=10.0.19041.2251 (WinBuild.160101.0800) .\CommunityToolkit.HighPerformance.dll, version=8.0.0.1 .\System.Threading.Tasks.Parallel.dll, version=7.0.22.51805 .\PaintDotNet.PropertySystem.dll, version=5.0.8361.33457 C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.320 (WinBuild.160101.0800) C:\WINDOWS\system32\windowscodecs.dll, version=10.0.19041.1706 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) .\System.IO.Packaging.dll, version=7.0.22.51805 C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.2193 (WinBuild.160101.0800) .\System.Memory.dll, version=7.0.22.51805 .\System.Runtime.Loader.dll, version=7.0.22.51805 .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.12.0 .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.20.0 .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.12.0 C:\WINDOWS\SYSTEM32\TextShaping.dll, version= C:\Windows\System32\WinTypes.dll, version=10.0.19041.2248 (WinBuild.160101.0800) .\PaintDotNet.Effects.Gpu.dll, version=5.0.8361.33457 .\PaintDotNet.Effects.dll, version=5.0.8361.33457 C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\PaintDotNet.Effects.Legacy.dll, version=5.0.8361.33457 C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\ComputeSharp.D2D1.dll, version=2.0.0.0 .\System.Runtime.Intrinsics.dll, version=7.0.22.51805 .\System.Numerics.Vectors.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.2248 (WinBuild.160101.0800) .\System.Runtime.Serialization.Formatters.dll, version=7.0.22.51805 .\mscorlib.dll, version=7.0.22.51805 .\System.CodeDom.dll, version=7.0.22.51805 .\System.Security.Claims.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1387 (WinBuild.160101.0800) C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.2193 C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\UMPDC.dll, version= .\System.Text.RegularExpressions.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\winmm.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.0.8361.33457 C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_1474122a0ce2f241\nvumdshimx.dll, version=23.21.13.9135 C:\WINDOWS\system32\igd10umd64.dll, version=9.17.10.4459 C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.2248 (WinBuild.160101.0800) .\ComputeSharp.Core.dll, version=2.0.0.0 C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\d3dcompiler_47.DLL, version=10.0.19041.868 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800) .\PhotoSauce.MagicScaler.dll, version=0.13.2.0 .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.22621.0 .\Microsoft.Win32.Primitives.dll, version=7.0.22.51805 ------------------------------------------------------------------------------ And here is the crashlog when using the selection tools: Spoiler This text file was created because paint.net crashed. Please e-mail this to crashlog5@getpaint.net so we can diagnose and fix the problem. Application version: paint.net 5.0 (α 5.0.8361.33457) Time of crash: 28.11.2022 15:36:35 Application uptime: 00:00:03.5362690 Application state: Running Working set: 197 468 KiB Handles and threads: 927 handles, 46 threads, 141 gdi, 175 user Install type: Portable Application directory: D:\Soft\paint.net.5.0.8361.33457.portable.x64 Current directory: D:\Soft\paint.net.5.0.8361.33457.portable.x64 Install directory: D:\Soft\Paint.net OS Version: Windows 10 Pro 10.0.19045.0 x64 .NET version: .NET 7.0.0 x64 Processor: "Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz" @ ~2195MHz (4C/8T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX) Physical memory: 5920 MB Video card: Intel(R) HD Graphics 3000 (v:8086, d:116, r:9), NVIDIA GeForce 610M (v:10DE, d:1058, r:161), Microsoft Basic Render Driver (v:1414, d:8C, r:0) Hardware acceleration: True (default: True) (rendering: 🚀 Performance (Intel(R) HD Graphics 3000)) Remote session: no Pointers: none UI animations: True UI DPI: 96 dpi (1,00x scale) UI theme: VisualStyleCategory=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Blue, ThemeFileName=Aero.msstyles Updates: n/a Locale: pdnr.c: en-US, hklm: n/a, hkcu: en-US, cc: ru-RU, cuic: en-US Flags: Exception details: System.ArgumentException: Value does not fall within the expected range. (PaintDotNet.Canvas.CanvasControl) ---> System.ArgumentException: Value does not fall within the expected range. at PaintDotNet.Interop.ExceptionFactory.ThrowError(Int32 hr, String message, Exception innerEx) at PaintDotNet.Direct2D1.D2D1EffectContext.LoadPixelShader(ShaderID& shaderID, ReadOnlySpan`1 shaderBuffer) at PaintDotNet.Direct2D1.Effects.PixelShaderTransformBase`1..ctor(IDeviceEffectContext effectContext) at PaintDotNet.Direct2D1.Effects.HlslBinaryOperatorTransform.Create(IDeviceEffectContext effectContext, HlslBinaryOperator operator, HlslEffectParameter parameter1, HlslEffectParameter parameter2) at PaintDotNet.Direct2D1.Effects.HlslBinaryOperatorEffect.Impl.OnPrepareForRender(ChangeType changeType) at PaintDotNet.Direct2D1.CD2D1EffectImplCcw.PrepareForRender(D2D1_CHANGE_TYPE changeType) --- End of inner exception stack trace --- at PaintDotNet.Interop.ExceptionFactory.ThrowError(Int32 hr, String message, Exception innerEx) at PaintDotNet.Direct2D1.D2D1DeviceContext6.GetImageLocalBounds(IDeviceImage image) at PaintDotNet.Direct2D1.DeviceContextExtensions.DrawImage(IDeviceContext deviceContext, IDeviceImage image, RectFloat targetRect, Nullable`1& imageRect, InterpolationMode interpolationMode, CompositeMode compositeMode) at PaintDotNet.Canvas.SelectionCanvasLayerView.RenderSelection(IDrawingContext dc, RectFloat clipRect) at PaintDotNet.Canvas.SelectionCanvasLayerView.OnRender(IDrawingContext dc, RectFloat clipRect) at PaintDotNet.Canvas.SelectionCanvasLayer.OnRender(IDrawingContext dc, RectFloat clipRect, CanvasView canvasView) at PaintDotNet.Canvas.Canvas.Render(IDrawingContext dc, RectFloat clipRect, CanvasView canvasView) at PaintDotNet.Canvas.CanvasControl.OnRender(IDrawingContext dc, RectFloat viewportClipRect) at PaintDotNet.Controls.InternalDirect2DControl.OnRender(IDeviceContext deviceContext, RectFloat clipRect) at PaintDotNet.Controls.Direct2DControlHandler.Render(RectInt32 clipRect) at PaintDotNet.Controls.Direct2DControlHandler.RelayGdiPaintImpl(IGdiPaintContext ctx) at PaintDotNet.Controls.Direct2DControlHandler.RelayGdiPaint(IGdiPaintContext ctx) at PaintDotNet.Controls.Direct2DControl.OnGdiPaint(IGdiPaintContext ctx) at PaintDotNet.Gdi.GdiControlHandler.OnWmPaint(Message& m) at PaintDotNet.Gdi.GdiControlHandler.RelayWndProc(Message& m) at PaintDotNet.Gdi.GdiControl.WndProc(Message& m) at PaintDotNet.Input.PointerInputProcessor.RelayWndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam) Managed assemblies: System.Private.CoreLib, .\System.Private.CoreLib.dll, Version=7.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet, .\paintdotnet.dll, Version=5.0.8361.33457 System.Runtime, .\System.Runtime.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms, .\System.Windows.Forms.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.Fundamentals, .\PaintDotNet.Fundamentals.dll, Version=5.0.8361.33457 PaintDotNet.ComponentModel, .\PaintDotNet.ComponentModel.dll, Version=5.0.8361.33457 System.Diagnostics.Tracing, .\System.Diagnostics.Tracing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread, .\System.Threading.Thread.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Base, .\PaintDotNet.Base.dll, Version=5.0.8361.33457 System.Collections.Concurrent, .\System.Collections.Concurrent.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Collections, .\PaintDotNet.Collections.dll, Version=5.0.8361.33457 PaintDotNet.Systrace, .\PaintDotNet.Systrace.dll, Version=5.0.8361.33457 PaintDotNet.Windows, .\PaintDotNet.Windows.dll, Version=5.0.8361.33457 TerraFX.Interop.Windows, .\TerraFX.Interop.Windows.dll, Version=10.0.22621.0, PublicKeyToken=35b01b53313a6f7e PaintDotNet.Primitives, .\PaintDotNet.Primitives.dll, Version=5.0.8361.33457 PaintDotNet.Runtime, .\PaintDotNet.Runtime.dll, Version=5.0.8361.33457 PointerToolkit, .\PointerToolkit.dll, Version=1.0.0.0 System.Threading, .\System.Threading.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Process, .\System.Diagnostics.Process.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer, .\PaintDotNet.SystemLayer.dll, Version=5.0.8361.33457 System.Private.Uri, .\System.Private.Uri.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives, .\System.ComponentModel.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms.Primitives, .\System.Windows.Forms.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 WindowsBase, .\WindowsBase.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 PaintDotNet.ObjectModel, .\PaintDotNet.ObjectModel.dll, Version=5.0.8361.33457 System.Runtime.InteropServices, .\System.Runtime.InteropServices.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework, .\PresentationFramework.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Drawing.Primitives, .\System.Drawing.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xaml, .\System.Xaml.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 System.ComponentModel, .\System.ComponentModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections, .\System.Collections.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.TraceSource, .\System.Diagnostics.TraceSource.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.CodePages, .\System.Text.Encoding.CodePages.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Core, .\PaintDotNet.Core.dll, Version=5.0.8361.33457 PaintDotNet.Resources, .\PaintDotNet.Resources.dll, Version=5.0.8361.33457 Newtonsoft.Json, .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Linq.Expressions, .\System.Linq.Expressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter, .\System.ComponentModel.TypeConverter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ObjectModel, .\System.ObjectModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Configuration.ConfigurationManager, .\System.Configuration.ConfigurationManager.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Runtime.Numerics, .\System.Runtime.Numerics.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Specialized, .\System.Collections.Specialized.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml, .\System.Private.Xml.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Net.WebClient, .\System.Net.WebClient.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.ComponentModel.EventBasedAsync, .\System.ComponentModel.EventBasedAsync.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data, .\PaintDotNet.Data.dll, Version=5.0.8361.33457 System.Xml.ReaderWriter, .\System.Xml.ReaderWriter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Framework, .\PaintDotNet.Framework.dll, Version=5.0.8361.33457 PaintDotNet.Windows.Framework, .\PaintDotNet.Windows.Framework.dll, Version=5.0.8361.33457 PaintDotNet.UI, .\PaintDotNet.UI.dll, Version=5.0.8361.33457 Microsoft.Win32.Registry, .\Microsoft.Win32.Registry.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Common, .\System.Drawing.Common.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Linq, .\System.Linq.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.SystemEvents, .\Microsoft.Win32.SystemEvents.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Immutable, .\System.Collections.Immutable.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationCore, .\PresentationCore.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder, .\DirectWriteForwarder.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.Debug, .\System.Diagnostics.Debug.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions, .\System.Runtime.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC, .\System.Runtime.CompilerServices.VisualC.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric, .\System.Collections.NonGeneric.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Accessibility, .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 UIAutomationTypes, .\UIAutomationTypes.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 CommunityToolkit.HighPerformance, .\CommunityToolkit.HighPerformance.dll, Version=8.0.0.0, PublicKeyToken=4aff67a105548ee2 PaintDotNet.PropertySystem, .\PaintDotNet.PropertySystem.dll, Version=5.0.8361.33457 System.IO.Packaging, .\System.IO.Packaging.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.FileVersionInfo, .\System.Diagnostics.FileVersionInfo.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Windows.Core, .\PaintDotNet.Windows.Core.dll, Version=5.0.8361.33457 PaintDotNet.Effects.Core, .\PaintDotNet.Effects.Core.dll, Version=5.0.8361.33457 System.Threading.Tasks.Parallel, .\System.Threading.Tasks.Parallel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Memory, .\System.Memory.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Numerics.Vectors, .\System.Numerics.Vectors.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PointerToolkit.TerraFX.Interop.Windows, .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.22621.0 System.Threading.ThreadPool, .\System.Threading.ThreadPool.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Loader, .\System.Runtime.Loader.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a DdsFileTypePlus, .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.12.0 AvifFileType, .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.20.0 WebPFileType, .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.12.0 PaintDotNet.Effects.Gpu, .\PaintDotNet.Effects.Gpu.dll, Version=5.0.8361.33457 PaintDotNet.Effects, .\PaintDotNet.Effects.dll, Version=5.0.8361.33457 PaintDotNet.Effects.Legacy, .\PaintDotNet.Effects.Legacy.dll, Version=5.0.8361.33457 ComputeSharp.D2D1, .\ComputeSharp.D2D1.dll, Version=2.0.0.0 System.Runtime.Intrinsics, .\System.Runtime.Intrinsics.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Runtime.Serialization.Formatters, .\System.Runtime.Serialization.Formatters.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a mscorlib, .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System.CodeDom, .\System.CodeDom.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Security.Claims, .\System.Security.Claims.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.RegularExpressions, .\System.Text.RegularExpressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a ComputeSharp.Core, .\ComputeSharp.Core.dll, Version=2.0.0.0 PhotoSauce.MagicScaler, .\PhotoSauce.MagicScaler.dll, Version=0.13.2.0, PublicKeyToken=fc6b9b7b06809481 System.IO.Compression, .\System.IO.Compression.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 K4os.Compression.LZ4, .\K4os.Compression.LZ4.dll, Version=1.2.16.0, PublicKeyToken=2186fa9121ef231d Native modules: .\paintdotnet.exe, version=5.0.8361.33457 C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) C:\WINDOWS\System32\USER32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\win32u.dll, version=10.0.19041.2251 (WinBuild.160101.0800) C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.2130 (WinBuild.160101.0800) C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.2130 (WinBuild.160101.0800) C:\WINDOWS\System32\ole32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\combase.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800) C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) .\VCRUNTIME140.dll, version=14.34.31931.0 .\VCRUNTIME140_1.dll, version=14.34.31931.0 C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.2193 (WinBuild.160101.0800) C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_1474122a0ce2f241\nvinitx.dll, version=23.21.13.9135 C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\sechost.dll, version=10.0.19041.320 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\Program Files\NVIDIA Corporation\CoProcManager\detoured.dll, version= C:\Program Files\NVIDIA Corporation\CoProcManager\nvd3d9wrapx.dll, version=23.21.13.9135 C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1620 (WinBuild.160101.0800) C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\Program Files\NVIDIA Corporation\CoProcManager\nvdxgiwrapx.dll, version=23.21.13.9135 .\hostfxr.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 .\hostpolicy.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 .\coreclr.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1415 (WinBuild.160101.0800) .\System.Private.CoreLib.dll, version=7.0.22.51805 .\paintdotnet.ni.dll, version=5.0.8361.33457 .\clrjit.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\paintdotnet.dll, version=5.0.8361.33457 .\System.Runtime.dll, version=7.0.22.51805 C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.2248 (WinBuild.160101.0800) .\System.Windows.Forms.dll, version=7.0.22.51807 .\PaintDotNet.Fundamentals.dll, version=5.0.8361.33457 .\PaintDotNet.ComponentModel.dll, version=5.0.8361.33457 .\System.Diagnostics.Tracing.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) .\System.Threading.Thread.dll, version=7.0.22.51805 .\PaintDotNet.Base.dll, version=5.0.8361.33457 .\System.Collections.Concurrent.dll, version=7.0.22.51805 .\PaintDotNet.Collections.dll, version=5.0.8361.33457 .\PaintDotNet.Systrace.dll, version=5.0.8361.33457 .\PaintDotNet.Windows.dll, version=5.0.8361.33457 .\TerraFX.Interop.Windows.dll, version=10.0.22621.0 .\PaintDotNet.Primitives.dll, version=5.0.8361.33457 .\PaintDotNet.Runtime.dll, version=5.0.8361.33457 .\PointerToolkit.dll, version=1.0.0.0 .\System.Threading.dll, version=7.0.22.51805 .\System.Diagnostics.Process.dll, version=7.0.22.51805 .\PaintDotNet.SystemLayer.dll, version=5.0.8361.33457 .\System.Private.Uri.dll, version=7.0.22.51805 .\System.ComponentModel.Primitives.dll, version=7.0.22.51805 .\System.Windows.Forms.Primitives.dll, version=7.0.22.51807 .\WindowsBase.dll, version=7.0.22.51802 .\PaintDotNet.ObjectModel.dll, version=5.0.8361.33457 .\System.Runtime.InteropServices.dll, version=7.0.22.51805 .\PresentationFramework.dll, version=7.0.22.51802 .\System.Drawing.Primitives.dll, version=7.0.22.51805 .\System.Xaml.dll, version=7.0.22.51802 .\System.ComponentModel.dll, version=7.0.22.51805 .\System.Collections.dll, version=7.0.22.51805 .\System.Diagnostics.TraceSource.dll, version=7.0.22.51805 .\System.Text.Encoding.CodePages.dll, version=7.0.22.51805 .\PaintDotNet.Core.dll, version=5.0.8361.33457 .\PaintDotNet.Resources.dll, version=5.0.8361.33457 .\Newtonsoft.Json.dll, version=13.0.1.25517 .\System.Linq.Expressions.dll, version=7.0.22.51805 .\System.ComponentModel.TypeConverter.dll, version=7.0.22.51805 .\System.ObjectModel.dll, version=7.0.22.51805 .\System.Configuration.ConfigurationManager.dll, version=7.0.22.51805 .\System.Runtime.Numerics.dll, version=7.0.22.51805 .\System.Collections.Specialized.dll, version=7.0.22.51805 .\System.Private.Xml.dll, version=7.0.22.51805 .\PresentationNative_cor3.dll, version=7,0,22,50606 @Commit: 00c647d63646ecc287c92f64734f438557f4a813 .\System.Net.WebClient.dll, version=7.0.22.51805 .\System.ComponentModel.EventBasedAsync.dll, version=7.0.22.51805 .\PaintDotNet.Data.dll, version=5.0.8361.33457 .\System.Xml.ReaderWriter.dll, version=7.0.22.51805 .\PaintDotNet.Framework.dll, version=5.0.8361.33457 .\PaintDotNet.Windows.Framework.dll, version=5.0.8361.33457 .\PaintDotNet.UI.dll, version=5.0.8361.33457 .\Microsoft.Win32.Registry.dll, version=7.0.22.51805 .\System.Drawing.Common.dll, version=7.0.22.51805 .\System.Linq.dll, version=7.0.22.51805 .\Microsoft.Win32.SystemEvents.dll, version=7.0.22.51805 .\System.Collections.Immutable.dll, version=7.0.22.51805 .\PresentationCore.dll, version=7.0.22.51802 .\DirectWriteForwarder.dll, version=7,0,22,51802 @Commit: 636e2b7a00a434a354a126f510a56e16ce3c6bbc .\System.Diagnostics.Debug.dll, version=7.0.22.51805 .\System.Runtime.Extensions.dll, version=7.0.22.51805 .\System.Runtime.CompilerServices.VisualC.dll, version=7.0.22.51805 .\System.Collections.NonGeneric.dll, version=7.0.22.51805 .\Accessibility.dll, version=7.0.22.51807 C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.2248 (WinBuild.160101.0800) .\UIAutomationTypes.dll, version=7.0.22.51802 .\CommunityToolkit.HighPerformance.dll, version=8.0.0.1 .\PaintDotNet.PropertySystem.dll, version=5.0.8361.33457 .\System.IO.Packaging.dll, version=7.0.22.51805 .\System.Diagnostics.FileVersionInfo.dll, version=7.0.22.51805 .\PaintDotNet.Windows.Core.dll, version=5.0.8361.33457 .\PaintDotNet.Effects.Core.dll, version=5.0.8361.33457 .\System.Threading.Tasks.Parallel.dll, version=7.0.22.51805 .\System.Memory.dll, version=7.0.22.51805 .\System.Numerics.Vectors.dll, version=7.0.22.51805 .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.22621.0 .\System.Threading.ThreadPool.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\dxgi.DLL, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.1620 (WinBuild.160101.0800) C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.2193 (WinBuild.160101.0800) C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\MSASN1.dll, version=10.0.19041.2251 (WinBuild.160101.0800) C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800) C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.2251_none_91a40448cc8846c1\gdiplus.dll, version=10.0.19041.2251 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1706 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.320 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.2193 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\TextShaping.dll, version= .\System.Runtime.Loader.dll, version=7.0.22.51805 .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.12.0 .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.20.0 .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.12.0 C:\Windows\System32\WinTypes.dll, version=10.0.19041.2248 (WinBuild.160101.0800) .\PaintDotNet.Effects.Gpu.dll, version=5.0.8361.33457 .\PaintDotNet.Effects.dll, version=5.0.8361.33457 C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) .\PaintDotNet.Effects.Legacy.dll, version=5.0.8361.33457 .\ComputeSharp.D2D1.dll, version=2.0.0.0 .\System.Runtime.Intrinsics.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.2248 (WinBuild.160101.0800) .\System.Runtime.Serialization.Formatters.dll, version=7.0.22.51805 .\mscorlib.dll, version=7.0.22.51805 .\System.CodeDom.dll, version=7.0.22.51805 .\System.Security.Claims.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1387 (WinBuild.160101.0800) C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.2075 (WinBuild.160101.0800) C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.2193 C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.2248 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\UMPDC.dll, version= .\System.Text.RegularExpressions.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\winmm.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.0.8361.33457 C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_1474122a0ce2f241\nvumdshimx.dll, version=23.21.13.9135 C:\WINDOWS\system32\igd10umd64.dll, version=9.17.10.4459 C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.2248 (WinBuild.160101.0800) .\ComputeSharp.Core.dll, version=2.0.0.0 C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\d3dcompiler_47.DLL, version=10.0.19041.868 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800) .\PhotoSauce.MagicScaler.dll, version=0.13.2.0 .\System.IO.Compression.dll, version=7.0.22.51805 C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800) .\K4os.Compression.LZ4.dll, version=1.2.16 ------------------------------------------------------------------------------ Edited November 28, 2022 by pavlik1307 Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 28, 2022 Author Share Posted November 28, 2022 Okay it's crashing because it's trying to use a pixel shader that your GPU can't execute. PDN is supposed to revert to software rendering in that case, but for some reason it's not. For now you'll have to disable hardware acceleration for UI/Canvas, and set the Rendering device to the CPU (although setting it to the 610M might work too -- that's definitely worth trying out). FWIW your system is very old and is below the recommended system requirements for PDN 5.0 -- performance likely will not be very good. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 28, 2022 Author Share Posted November 28, 2022 @pavlik1307, can you also post your diagnostics info? Settings -> Diagnostics -> Copy to Clipboard The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
pavlik1307 Posted November 28, 2022 Share Posted November 28, 2022 2 hours ago, Rick Brewster said: @pavlik1307, can you also post your diagnostics info? Settings -> Diagnostics -> Copy to Clipboard Spoiler Application paint.net 5.0 (α 5.0.8361.33457) Build Date 22 ноября 2022 г. Expiration Date 14 февраля 2023 г. Install type Portable Language: en-US DPI 96 (1,00x scale) UI/Canvas GPU False Rendering GPU 🚀 Performance (Intel(R) HD Graphics 3000) Remote session False Animations True Translucent windows True Windows Ink True OS Windows 10 Pro x64 (10.0.19045.0) Runtime .NET 7.0.0 x64 Physical Memory 5 920 MB CPU Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz Speed ~2195 MHz Cores / Threads 4 / 8 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX Video Card Intel(R) HD Graphics 3000 Dedicated Video RAM 192 MB Dedicated System RAM 0 MB Shared System RAM 1 568 MB Vendor ID 0x8086 Device ID 0x0116 Subsystem ID 0x16521043 Revision 9 LUID 0x0000B4E9 Flags SupportNonMonitoredFences Graphics Preemption DmaBufferBoundary Compute Preemption DmaBufferBoundary Outputs 1 Feature Level Level_10_1 Features DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precisions UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32 Maximum Bitmap Size 8192 Video Card NVIDIA GeForce 610M Dedicated Video RAM 1 986 MB Dedicated System RAM 0 MB Shared System RAM 2 047 MB Vendor ID 0x10DE Device ID 0x1058 Subsystem ID 0x16521043 Revision 161 LUID 0x0000B817 Flags SupportNonMonitoredFences, KeyedMutexConformance Graphics Preemption DmaBufferBoundary Compute Preemption DmaBufferBoundary Outputs 0 Feature Level Level_11_0 Features Doubles, D3D10XHardwareOptions DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precisions UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32 Maximum Bitmap Size 16384 Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 2 960 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000B6EC Flags Software, AcgCompatible, SupportMonitoredFences, SupportNonMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Level_12_1 Features Doubles, D3D10XHardwareOptions DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precisions UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32 Maximum Bitmap Size 8388608 Managed assemblies 94 System.Private.CoreLib .\System.Private.CoreLib.dll, Version=7.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet .\paintdotnet.dll, Version=5.0.8361.33457 System.Runtime .\System.Runtime.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms .\System.Windows.Forms.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.Fundamentals .\PaintDotNet.Fundamentals.dll, Version=5.0.8361.33457 PaintDotNet.ComponentModel .\PaintDotNet.ComponentModel.dll, Version=5.0.8361.33457 System.Diagnostics.Tracing .\System.Diagnostics.Tracing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread .\System.Threading.Thread.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Base .\PaintDotNet.Base.dll, Version=5.0.8361.33457 System.Collections.Concurrent .\System.Collections.Concurrent.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Collections .\PaintDotNet.Collections.dll, Version=5.0.8361.33457 PaintDotNet.Systrace .\PaintDotNet.Systrace.dll, Version=5.0.8361.33457 PaintDotNet.Windows .\PaintDotNet.Windows.dll, Version=5.0.8361.33457 TerraFX.Interop.Windows .\TerraFX.Interop.Windows.dll, Version=10.0.22621.0, PublicKeyToken=35b01b53313a6f7e PaintDotNet.Primitives .\PaintDotNet.Primitives.dll, Version=5.0.8361.33457 PaintDotNet.Runtime .\PaintDotNet.Runtime.dll, Version=5.0.8361.33457 PointerToolkit .\PointerToolkit.dll, Version=1.0.0.0 System.Threading .\System.Threading.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Process .\System.Diagnostics.Process.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer .\PaintDotNet.SystemLayer.dll, Version=5.0.8361.33457 System.Private.Uri .\System.Private.Uri.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives .\System.ComponentModel.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WindowsBase .\WindowsBase.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Windows.Forms.Primitives .\System.Windows.Forms.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.ObjectModel .\PaintDotNet.ObjectModel.dll, Version=5.0.8361.33457 System.Runtime.InteropServices .\System.Runtime.InteropServices.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework .\PresentationFramework.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Drawing.Primitives .\System.Drawing.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xaml .\System.Xaml.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 System.ComponentModel .\System.ComponentModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections .\System.Collections.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.TraceSource .\System.Diagnostics.TraceSource.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.CodePages .\System.Text.Encoding.CodePages.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Core .\PaintDotNet.Core.dll, Version=5.0.8361.33457 PaintDotNet.Resources .\PaintDotNet.Resources.dll, Version=5.0.8361.33457 Newtonsoft.Json .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Linq.Expressions .\System.Linq.Expressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter .\System.ComponentModel.TypeConverter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ObjectModel .\System.ObjectModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Numerics .\System.Runtime.Numerics.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Configuration.ConfigurationManager .\System.Configuration.ConfigurationManager.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Specialized .\System.Collections.Specialized.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml .\System.Private.Xml.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Net.WebClient .\System.Net.WebClient.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.ComponentModel.EventBasedAsync .\System.ComponentModel.EventBasedAsync.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xml.ReaderWriter .\System.Xml.ReaderWriter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data .\PaintDotNet.Data.dll, Version=5.0.8361.33457 PaintDotNet.Framework .\PaintDotNet.Framework.dll, Version=5.0.8361.33457 System.Threading.ThreadPool .\System.Threading.ThreadPool.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Windows.Framework .\PaintDotNet.Windows.Framework.dll, Version=5.0.8361.33457 PaintDotNet.UI .\PaintDotNet.UI.dll, Version=5.0.8361.33457 Microsoft.Win32.Registry .\Microsoft.Win32.Registry.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Common .\System.Drawing.Common.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Microsoft.Win32.SystemEvents .\Microsoft.Win32.SystemEvents.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Linq .\System.Linq.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Immutable .\System.Collections.Immutable.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationCore .\PresentationCore.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder .\DirectWriteForwarder.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.Debug .\System.Diagnostics.Debug.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions .\System.Runtime.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC .\System.Runtime.CompilerServices.VisualC.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric .\System.Collections.NonGeneric.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a UIAutomationTypes .\UIAutomationTypes.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35 PaintDotNet.Windows.Core .\PaintDotNet.Windows.Core.dll, Version=5.0.8361.33457 System.Diagnostics.FileVersionInfo .\System.Diagnostics.FileVersionInfo.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects.Core .\PaintDotNet.Effects.Core.dll, Version=5.0.8361.33457 Accessibility .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 CommunityToolkit.HighPerformance .\CommunityToolkit.HighPerformance.dll, Version=8.0.0.0, PublicKeyToken=4aff67a105548ee2 System.Threading.Tasks.Parallel .\System.Threading.Tasks.Parallel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.PropertySystem .\PaintDotNet.PropertySystem.dll, Version=5.0.8361.33457 System.IO.Packaging .\System.IO.Packaging.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Memory .\System.Memory.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Runtime.Loader .\System.Runtime.Loader.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WebPFileType .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.12.0 DdsFileTypePlus .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.12.0 AvifFileType .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.20.0 PaintDotNet.Effects.Gpu .\PaintDotNet.Effects.Gpu.dll, Version=5.0.8361.33457 PaintDotNet.Effects .\PaintDotNet.Effects.dll, Version=5.0.8361.33457 PaintDotNet.Effects.Legacy .\PaintDotNet.Effects.Legacy.dll, Version=5.0.8361.33457 ComputeSharp.D2D1 .\ComputeSharp.D2D1.dll, Version=2.0.0.0 System.Runtime.Intrinsics .\System.Runtime.Intrinsics.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Numerics.Vectors .\System.Numerics.Vectors.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Serialization.Primitives .\System.Runtime.Serialization.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Serialization.Formatters .\System.Runtime.Serialization.Formatters.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.CodeDom .\System.CodeDom.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Security.Claims .\System.Security.Claims.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a mscorlib .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System.Text.RegularExpressions .\System.Text.RegularExpressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a ComputeSharp.Core .\ComputeSharp.Core.dll, Version=2.0.0.0 PhotoSauce.MagicScaler .\PhotoSauce.MagicScaler.dll, Version=0.13.2.0, PublicKeyToken=fc6b9b7b06809481 PointerToolkit.TerraFX.Interop.Windows .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.22621.0 Microsoft.Win32.Primitives .\Microsoft.Win32.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.MetadataLoadContext .\System.Reflection.MetadataLoadContext.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.IO.Compression .\System.IO.Compression.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089 Native modules 187 paintdotnet.exe .\paintdotnet.exe, version=5.0.8361.33457 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.2248 (WinBuild.160101.0800) KERNEL32.DLL C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.2248 (WinBuild.160101.0800) SHELL32.dll C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.2251 (WinBuild.160101.0800) GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.2130 (WinBuild.160101.0800) gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.2130 (WinBuild.160101.0800) ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.2248 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.2248 (WinBuild.160101.0800) OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800) SHLWAPI.dll C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.2248 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) VCRUNTIME140_1.dll .\VCRUNTIME140_1.dll, version=14.34.31931.0 VCRUNTIME140.dll .\VCRUNTIME140.dll, version=14.34.31931.0 IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.2193 (WinBuild.160101.0800) nvinitx.dll C:\WINDOWS\system32\DriverStore\FileRepository\nvami.inf_amd64_1474122a0ce2f241\nvinitx.dll, version=23.21.13.9135 ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.320 (WinBuild.160101.0800) VERSION.dll C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.19041.546 (WinBuild.160101.0800) windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.2248 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.2248 (WinBuild.160101.0800) SHCORE.dll C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.2248 (WinBuild.160101.0800) detoured.dll C:\Program Files\NVIDIA Corporation\CoProcManager\detoured.dll, version= nvd3d9wrapx.dll C:\Program Files\NVIDIA Corporation\CoProcManager\nvd3d9wrapx.dll, version=23.21.13.9135 SETUPAPI.dll C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.19041.2248 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1620 (WinBuild.160101.0800) bcrypt.dll C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.2248 (WinBuild.160101.0800) nvdxgiwrapx.dll C:\Program Files\NVIDIA Corporation\CoProcManager\nvdxgiwrapx.dll, version=23.21.13.9135 hostfxr.dll .\hostfxr.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 hostpolicy.dll .\hostpolicy.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 coreclr.dll .\coreclr.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1415 (WinBuild.160101.0800) System.Private.CoreLib.dll .\System.Private.CoreLib.dll, version=7.0.22.51805 paintdotnet.ni.dll .\paintdotnet.ni.dll, version=5.0.8361.33457 clrjit.dll .\clrjit.dll, version=7,0,22,51805 @Commit: d099f075e45d2aa6007a22b71b45a08758559f80 kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) paintdotnet.dll .\paintdotnet.dll, version=5.0.8361.33457 System.Runtime.dll .\System.Runtime.dll, version=7.0.22.51805 uxtheme.dll C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.2248 (WinBuild.160101.0800) System.Windows.Forms.dll .\System.Windows.Forms.dll, version=7.0.22.51807 PaintDotNet.Fundamentals.dll .\PaintDotNet.Fundamentals.dll, version=5.0.8361.33457 PaintDotNet.ComponentModel.dll .\PaintDotNet.ComponentModel.dll, version=5.0.8361.33457 System.Diagnostics.Tracing.dll .\System.Diagnostics.Tracing.dll, version=7.0.22.51805 icu.dll C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) System.Threading.Thread.dll .\System.Threading.Thread.dll, version=7.0.22.51805 PaintDotNet.Base.dll .\PaintDotNet.Base.dll, version=5.0.8361.33457 System.Collections.Concurrent.dll .\System.Collections.Concurrent.dll, version=7.0.22.51805 PaintDotNet.Collections.dll .\PaintDotNet.Collections.dll, version=5.0.8361.33457 PaintDotNet.Systrace.dll .\PaintDotNet.Systrace.dll, version=5.0.8361.33457 PaintDotNet.Windows.dll .\PaintDotNet.Windows.dll, version=5.0.8361.33457 TerraFX.Interop.Windows.dll .\TerraFX.Interop.Windows.dll, version=10.0.22621.0 PaintDotNet.Primitives.dll .\PaintDotNet.Primitives.dll, version=5.0.8361.33457 PaintDotNet.Runtime.dll .\PaintDotNet.Runtime.dll, version=5.0.8361.33457 PointerToolkit.dll .\PointerToolkit.dll, version=1.0.0.0 System.Threading.dll .\System.Threading.dll, version=7.0.22.51805 System.Diagnostics.Process.dll .\System.Diagnostics.Process.dll, version=7.0.22.51805 PaintDotNet.SystemLayer.dll .\PaintDotNet.SystemLayer.dll, version=5.0.8361.33457 System.Private.Uri.dll .\System.Private.Uri.dll, version=7.0.22.51805 System.ComponentModel.Primitives.dll .\System.ComponentModel.Primitives.dll, version=7.0.22.51805 WindowsBase.dll .\WindowsBase.dll, version=7.0.22.51802 System.Windows.Forms.Primitives.dll .\System.Windows.Forms.Primitives.dll, version=7.0.22.51807 PaintDotNet.ObjectModel.dll .\PaintDotNet.ObjectModel.dll, version=5.0.8361.33457 System.Runtime.InteropServices.dll .\System.Runtime.InteropServices.dll, version=7.0.22.51805 PresentationFramework.dll .\PresentationFramework.dll, version=7.0.22.51802 System.Drawing.Primitives.dll .\System.Drawing.Primitives.dll, version=7.0.22.51805 System.Xaml.dll .\System.Xaml.dll, version=7.0.22.51802 System.ComponentModel.dll .\System.ComponentModel.dll, version=7.0.22.51805 System.Collections.dll .\System.Collections.dll, version=7.0.22.51805 System.Diagnostics.TraceSource.dll .\System.Diagnostics.TraceSource.dll, version=7.0.22.51805 System.Text.Encoding.CodePages.dll .\System.Text.Encoding.CodePages.dll, version=7.0.22.51805 PaintDotNet.Core.dll .\PaintDotNet.Core.dll, version=5.0.8361.33457 PaintDotNet.Resources.dll .\PaintDotNet.Resources.dll, version=5.0.8361.33457 Newtonsoft.Json.dll .\Newtonsoft.Json.dll, version=13.0.1.25517 System.Linq.Expressions.dll .\System.Linq.Expressions.dll, version=7.0.22.51805 System.ComponentModel.TypeConverter.dll .\System.ComponentModel.TypeConverter.dll, version=7.0.22.51805 System.ObjectModel.dll .\System.ObjectModel.dll, version=7.0.22.51805 PresentationNative_cor3.dll .\PresentationNative_cor3.dll, version=7,0,22,50606 @Commit: 00c647d63646ecc287c92f64734f438557f4a813 System.Runtime.Numerics.dll .\System.Runtime.Numerics.dll, version=7.0.22.51805 System.Configuration.ConfigurationManager.dll .\System.Configuration.ConfigurationManager.dll, version=7.0.22.51805 System.Collections.Specialized.dll .\System.Collections.Specialized.dll, version=7.0.22.51805 System.Private.Xml.dll .\System.Private.Xml.dll, version=7.0.22.51805 System.Net.WebClient.dll .\System.Net.WebClient.dll, version=7.0.22.51805 System.ComponentModel.EventBasedAsync.dll .\System.ComponentModel.EventBasedAsync.dll, version=7.0.22.51805 System.Xml.ReaderWriter.dll .\System.Xml.ReaderWriter.dll, version=7.0.22.51805 PaintDotNet.Data.dll .\PaintDotNet.Data.dll, version=5.0.8361.33457 PaintDotNet.Framework.dll .\PaintDotNet.Framework.dll, version=5.0.8361.33457 System.Threading.ThreadPool.dll .\System.Threading.ThreadPool.dll, version=7.0.22.51805 PaintDotNet.Windows.Framework.dll .\PaintDotNet.Windows.Framework.dll, version=5.0.8361.33457 PaintDotNet.UI.dll .\PaintDotNet.UI.dll, version=5.0.8361.33457 Microsoft.Win32.Registry.dll .\Microsoft.Win32.Registry.dll, version=7.0.22.51805 System.Drawing.Common.dll .\System.Drawing.Common.dll, version=7.0.22.51805 Microsoft.Win32.SystemEvents.dll .\Microsoft.Win32.SystemEvents.dll, version=7.0.22.51805 System.Linq.dll .\System.Linq.dll, version=7.0.22.51805 dxgi.DLL C:\WINDOWS\SYSTEM32\dxgi.DLL, version=10.0.19041.2075 (WinBuild.160101.0800) System.Collections.Immutable.dll .\System.Collections.Immutable.dll, version=7.0.22.51805 MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.2248 (WinBuild.160101.0800) DEVOBJ.dll C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.1620 (WinBuild.160101.0800) WINTRUST.dll C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.2193 (WinBuild.160101.0800) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.2248 (WinBuild.160101.0800) MSASN1.dll C:\WINDOWS\SYSTEM32\MSASN1.dll, version=10.0.19041.2251 (WinBuild.160101.0800) PresentationCore.dll .\PresentationCore.dll, version=7.0.22.51802 DirectWriteForwarder.dll .\DirectWriteForwarder.dll, version=7,0,22,51802 @Commit: 636e2b7a00a434a354a126f510a56e16ce3c6bbc System.Diagnostics.Debug.dll .\System.Diagnostics.Debug.dll, version=7.0.22.51805 System.Runtime.Extensions.dll .\System.Runtime.Extensions.dll, version=7.0.22.51805 System.Runtime.CompilerServices.VisualC.dll .\System.Runtime.CompilerServices.VisualC.dll, version=7.0.22.51805 System.Collections.NonGeneric.dll .\System.Collections.NonGeneric.dll, version=7.0.22.51805 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.2248 (WinBuild.160101.0800) UIAutomationTypes.dll .\UIAutomationTypes.dll, version=7.0.22.51802 PaintDotNet.Windows.Core.dll .\PaintDotNet.Windows.Core.dll, version=5.0.8361.33457 System.Diagnostics.FileVersionInfo.dll .\System.Diagnostics.FileVersionInfo.dll, version=7.0.22.51805 PaintDotNet.Effects.Core.dll .\PaintDotNet.Effects.Core.dll, version=5.0.8361.33457 clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800) Accessibility.dll .\Accessibility.dll, version=7.0.22.51807 gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.2251_none_91a40448cc8846c1\gdiplus.dll, version=10.0.19041.2251 (WinBuild.160101.0800) CommunityToolkit.HighPerformance.dll .\CommunityToolkit.HighPerformance.dll, version=8.0.0.1 System.Threading.Tasks.Parallel.dll .\System.Threading.Tasks.Parallel.dll, version=7.0.22.51805 PaintDotNet.PropertySystem.dll .\PaintDotNet.PropertySystem.dll, version=5.0.8361.33457 System.IO.Packaging.dll .\System.IO.Packaging.dll, version=7.0.22.51805 mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.2248 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.320 (WinBuild.160101.0800) windowscodecs.dll C:\WINDOWS\system32\windowscodecs.dll, version=10.0.19041.1706 (WinBuild.160101.0800) CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) System.Memory.dll .\System.Memory.dll, version=7.0.22.51805 Windows.StateRepositoryPS.dll C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.2193 (WinBuild.160101.0800) System.Runtime.Loader.dll .\System.Runtime.Loader.dll, version=7.0.22.51805 WebPFileType.dll .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.12.0 DdsFileTypePlus.dll .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.12.0 AvifFileType.dll .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.20.0 TextShaping.dll C:\WINDOWS\SYSTEM32\TextShaping.dll, version= WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.2248 (WinBuild.160101.0800) PaintDotNet.Effects.Gpu.dll .\PaintDotNet.Effects.Gpu.dll, version=5.0.8361.33457 PaintDotNet.Effects.dll .\PaintDotNet.Effects.dll, version=5.0.8361.33457 d2d1.DLL C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) wtsapi32.dll C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.2075 (WinBuild.160101.0800) d3d11.dll C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.2075 (WinBuild.160101.0800) D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.2075 (WinBuild.160101.0800) dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) PaintDotNet.Effects.Legacy.dll .\PaintDotNet.Effects.Legacy.dll, version=5.0.8361.33457 ComputeSharp.D2D1.dll .\ComputeSharp.D2D1.dll, version=2.0.0.0 System.Runtime.Intrinsics.dll .\System.Runtime.Intrinsics.dll, version=7.0.22.51805 UIAutomationCore.dll C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.2248 (WinBuild.160101.0800) PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.2248 (WinBuild.160101.0800) System.Numerics.Vectors.dll .\System.Numerics.Vectors.dll, version=7.0.22.51805 System.Runtime.Serialization.Primitives.dll .\System.Runtime.Serialization.Primitives.dll, version=7.0.22.51805 profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800) ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.2248 (WinBuild.160101.0800) System.Runtime.Serialization.Formatters.dll .\System.Runtime.Serialization.Formatters.dll, version=7.0.22.51805 System.CodeDom.dll .\System.CodeDom.dll, version=7.0.22.51805 System.Security.Claims.dll .\System.Security.Claims.dll, version=7.0.22.51805 mscorlib.dll .\mscorlib.dll, version=7.0.22.51805 dwmapi.DLL C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1387 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.2075 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.2248 (WinBuild.160101.0800) textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.2075 (WinBuild.160101.0800) CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 CoreMessaging.dll C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.2193 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800) System.Text.RegularExpressions.dll .\System.Text.RegularExpressions.dll, version=7.0.22.51805 powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.2248 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= winmm.DLL C:\WINDOWS\SYSTEM32\winmm.DLL, version=10.0.19041.2248 (WinBuild.160101.0800) PaintDotNet.SystemLayer.Native.x64.dll .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.0.8361.33457 ComputeSharp.Core.dll .\ComputeSharp.Core.dll, version=2.0.0.0 explorerframe.dll C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.2248 (WinBuild.160101.0800) XmlLite.dll C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.546 (WinBuild.160101.0800) d3dcompiler_47.DLL C:\WINDOWS\SYSTEM32\d3dcompiler_47.DLL, version=10.0.19041.868 (WinBuild.160101.0800) CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) Cabinet.dll C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800) PhotoSauce.MagicScaler.dll .\PhotoSauce.MagicScaler.dll, version=0.13.2.0 PointerToolkit.TerraFX.Interop.Windows.dll .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.22621.0 Microsoft.Win32.Primitives.dll .\Microsoft.Win32.Primitives.dll, version=7.0.22.51805 System.Reflection.MetadataLoadContext.dll .\System.Reflection.MetadataLoadContext.dll, version=7.0.22.51805 System.IO.Compression.dll .\System.IO.Compression.dll, version=7.0.22.51805 nvumdshimx.dll C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_1474122a0ce2f241\nvumdshimx.dll, version=23.21.13.9135 igd10umd64.dll C:\WINDOWS\system32\igd10umd64.dll, version=9.17.10.4459 imagehlp.dll C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.1415 (WinBuild.160101.0800) rsaenh.dll C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.320 (WinBuild.160101.0800) CRYPTBASE.dll C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.19041.546 (WinBuild.160101.0800) 1 Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 29, 2022 Author Share Posted November 29, 2022 New build, with fixes for things: The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
