Mr Darlin Posted October 6, 2008 Share Posted October 6, 2008 Okay. When I tried to add a plugin this came up... Does anyone know how to fix this? Link to comment Share on other sites More sharing options...
Simon Brown Posted October 6, 2008 Share Posted October 6, 2008 Are you the administrator? Link to comment Share on other sites More sharing options...
Mr Darlin Posted October 6, 2008 Author Share Posted October 6, 2008 Are you the administrator? No is that all I need to change? Get on an admin user name? Link to comment Share on other sites More sharing options...
Simon Brown Posted October 6, 2008 Share Posted October 6, 2008 No is that all I need to change? Get on an admin user name? It is worth a try. Link to comment Share on other sites More sharing options...
Myrddin Posted October 7, 2008 Share Posted October 7, 2008 It's also worth visiting the plugin troubleshooting thread for further help: viewtopic.php?f=16&t=2023. I believe this has happened before with someone else, they solved it the same way Simon suggested. Or, you may need to unblock the DLL (steps #4 and #5). It's worth even more brushing up on the Rules (particularly #6): viewtopic.php?f=20&t=3446. I hope you can understand why I'm locking this now. Topic locked How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
