Miszkurka2000 Posted September 9, 2022 Share Posted September 9, 2022 (edited) In AVIF save window. Image analysis - It realistically reflects what is happening with the image quality and the time it takes to process it. Compression speed - Everyone wants the compression speed to be as high as possible (fastest) and the Very Slow option may be incomprehensible. Edited September 9, 2022 by Miszkurka2000 Quote Link to comment Share on other sites More sharing options...
null54 Posted September 9, 2022 Share Posted September 9, 2022 1 hour ago, Miszkurka2000 said: Compression speed - Everyone wants the compression speed to be as high as possible (fastest) and the Very Slow option may be incomprehensible. The Fast, Medium, Slow, Very Slow naming scheme is based on what the x265 encoder uses. Compression speed is referring to how much effort AOM puts into compressing the image data, slower speeds can produce a smaller/higher quality file but will take longer to process the image. Image analysis is not an accurate name because AOM is compressing the data after it analyzes it. I would support changing Compression speed to Compression preset. This matches the terminology used by x265 and may better reflect that it changes multiple settings that may affect the compression quality/speed tradeoff. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
