Sednaiur Posted September 3, 2022 Share Posted September 3, 2022 (edited) Hello there, I'd like to ask a question about saving settings inbetween sessions working with Paint.net and I hope this topic is okay for that. About three versions ago, Paint.net stopped to save any tool settings like anti-aliasing, tolerance etc. Why is that? An oversight maybe? Or is there a setting I might have missed somewhere? The way it is now, it makes it more tedious to work on any files as I need to set all the parameters for all the tools everytime I start up Paint.net. Thanks in advance. Edited September 3, 2022 by Sednaiur Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 3, 2022 Share Posted September 3, 2022 (I split this out into its own post) Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 5, 2022 Share Posted September 5, 2022 Set up your configuration, then open Settings > Tools and hit Load from Toolbar. This will make your current settings the default ones. https://www.getpaint.net/doc/latest/SettingsDialog.html#3 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Sednaiur Posted October 8, 2022 Author Share Posted October 8, 2022 On 9/5/2022 at 2:13 AM, Ego Eram Reputo said: Set up your configuration, then open Settings > Tools and hit Load from Toolbar. This will make your current settings the default ones. https://www.getpaint.net/doc/latest/SettingsDialog.html#3 I apologize for my late reply. I was searching my post but since it was moved, I couldn't find it. An automated email helped me find it though. Thank you very much for the suggestion. I just did what you said and finally that problem about Paint.net "forgetting" the settings is fixed. Helped me quite a lot. Have a nice day Quote Link to comment Share on other sites More sharing options...
NinthDesertDude Posted October 8, 2022 Share Posted October 8, 2022 I documented an issue with settings not persisting (when changed from the Settings menu itself) a few months ago. I think there is a bug somewhere. (Though on a re-read I'm not convinced the OP was talking about that) Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 9, 2022 Share Posted October 9, 2022 23 hours ago, NinthDesertDude said: I documented an issue with settings not persisting (when changed from the Settings menu itself) a few months ago. I think there is a bug somewhere. (Though on a re-read I'm not convinced the OP was talking about that) Link? Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
NinthDesertDude Posted October 9, 2022 Share Posted October 9, 2022 54 minutes ago, Rick Brewster said: Link? (I'm currently on a different computer which is working fine right now.) 1 Quote Link to comment Share on other sites More sharing options...
