OotF#97 - A Spider Web 🕸- Entries.
Pixey
Object of the Fortnight #97 - A Spider Web 🕸 - Entries.
The Spider Web can be on a colored background of your choice - and have a spider, if you wish.
There is a Plugin by @Red ochre for this found here.
Some Examples
The deadline for entries is 2.00 PM EST (7:00 PM UK Time) on Saturday 10th September, 2022.
Theme-Generator-s-size-16.png Please see the Countdown Timer for exact time remaining.
This thread is for posting competition entries only. If you're not posting an entry, please don't post here.
Competition Rules:
*   Your entry must not have a background/backdrop/scene; just the object on a transparent canvas. Shadows and reflections are fine.
*   Your entry must be 100% made using Paint.net. Don't use another image editor. Don't use stock images/photos/textures (in full or parts thereof.)
*    Max dimensions are 600 x 600.
*    You may modify or replace your image until the deadline.
*    Three entries per entrant are allowed. Please make a separate post for each one.
Many thanks to @toe_head2001and @DrewDale for hosting this competition in the past.  Previous subjects can be found here.
