Nordy Posted August 25, 2022 Share Posted August 25, 2022 Hello! I am very new to Paint.net and have spend more time on this little project than I care to admit. Would someone please help me with this? I am looking to do this but can not get smooth lines when printing (but can get perfect photo quality print on same canvas in the top white area). The overlaying ribbon is HEX 015836 and the underlaying ribbon is HEX EEE3C6. The bottom right corner has a outline of the state of Minnesota in white. The canvas dimensions are: Will someone please help me out? TIA Nordy Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 26, 2022 Share Posted August 26, 2022 HI Nordy, welcome! 9 hours ago, Nordy said: can not get smooth lines when printing Your source image is very small @212px x 337px. This is probably what's giving you a poor print quality. If you want the stated print size, make the image dimensions match at 300-pixels=per-inch: 2.21 inches x 300ppi = 663pixels wide 3.37 inches x 300ppi = 1011pixels high. ^ Start with a canvas of that size, minimum. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Nordy Posted August 26, 2022 Author Share Posted August 26, 2022 Hi! Thank you, I will test that out. Quote Link to comment Share on other sites More sharing options...
Nordy Posted August 26, 2022 Author Share Posted August 26, 2022 I think that made it worse... 🙁 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 27, 2022 Share Posted August 27, 2022 Did you redraw the image on the larger canvas, or stretch the original to match the new size? Try printing this image out at the required size and see if it works for you. https://i.postimg.cc/D0mFxtmf/Minnesota.png 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
