kgschlosser Posted August 24, 2022 Share Posted August 24, 2022 I am working on a pretty large project. The PDN file is > 88MB in size and I have come across several bugs while working on this project. Ad the title states this bug is the pixel grid getting all messed up for some reason. It will correct itself if I change the zoom level. Scrolling and drawing does not correct it. I am thinking the only time the grid gets redrawn is durin a zoom event and a window resize or position even I am sure will also trigger a redraw of the grid. Here is an image of the problem. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 24, 2022 Share Posted August 24, 2022 Why do you keep blurring out the title bar? Please make sure you're using the latest version of the app and that you're caught up on all Windows Updates, and are using the latest version of your GPU driver. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
kgschlosser Posted August 25, 2022 Author Share Posted August 25, 2022 I blur the title bar because I do not want to post the file name. I am running the latest version, Video card drivers are all up to date Windows is all up to date I do not experience this kind of an issue using any other application. It is specific to Paint.NET Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 25, 2022 Share Posted August 25, 2022 Does it happen if you disable hardware acceleration in the app Settings? If it does, then this is a GPU-specific/driver thing. If not, then it's a general rendering issue. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
