BReditor Posted August 2, 2022 Share Posted August 2, 2022 So i am pretty new at this and all i want to do is copy the image you are seeing below and paste into another without the transparent (Yes i have tried the magic wand tool, it leaves many important areas of the image blank such as the face, so yeah no.) (Sorry for the pixelated image, needed to decrease it's quality because of the file size limit) Quote Link to comment Share on other sites More sharing options...
Solution BoltBait Posted August 2, 2022 Solution Share Posted August 2, 2022 Ctrl-A to select all. Ctrl-C to copy the guy. Switch to your desired image. Ctrl-Shift-V to paste into the new image with layer. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
BReditor Posted August 3, 2022 Author Share Posted August 3, 2022 (edited) 44 minutes ago, BoltBait said: Ctrl-A to select all. Ctrl-C to copy the guy. Switch to your desired image. Ctrl-Shift-V to paste into the new image with layer. Thx so much dude, idk how i didnt think of this before xd, i abandoned a lot of projects because i didnt know how to do this xd Edited August 3, 2022 by BReditor Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 3, 2022 Share Posted August 3, 2022 Yup, once you learn even a little bit about layers, a whole new world opens up Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
MJW Posted August 3, 2022 Share Posted August 3, 2022 As much as I recommend knowing about and using layers, you can also use the Paste From Clipboard plugin to directly blend the image on the clipboard into a layer. Just enable the Blend with Canvas Image option. Quote Link to comment Share on other sites More sharing options...
