Fading a semi transparent fill to the edge of an irregular shape
I want to create a semi transparent background for text that fades towards the edge, so the  obscuring of the background image is minimised but the text stands out clearly. I can't find a gradient tool that doesn't create hard edges on some parts of the border, and I'm not familiar enough with Paint.Net to know another way to do this. Can anyone help?
Hello @mattix and welcome :)
Take a look at this tutorial and use the gradient on the text, which you should have on its own layer:
Not sure exactly what you want to do.
Is it something like this, which is a white block on a layer below the text that has been
Gaussian blurred, then had the Opacity reduced in Layer Properties.
If not then maybe you could explain further what you want.
  1. Open the background image
  2. Add a new layer. (Ctrl + Shift + N). Put yout text on this new layer.
  3. Select the text (usually Magic Wand + Shift key)
  4. Delete the selection from the background layer
  5. With the background layer active, apply the Alpha Blur plugin
