kgschlosser Posted July 20, 2022 Share Posted July 20, 2022 While this problem is not a crash or anything like that and is probably something that has simply been overlooked it still needs to be corrected. To duplicate the problem: select green as the primary color select orange as the secondary color select the line tool set the width to say 5. you want to have the line width at 5 or above for ease of visibility disable the antialiasing set the fill style to diagonal forward or diagonal backwards draw a vertical or horizontal line The colors don't matter , it is just easier to see using those 2 colors. Zoom into the line and look at the green diagonal lines. They are antialiased even tho antialiasing has been disabled. The strange thing is if I have vertical or horizontal fill selected and antialias enabled and draw an angled line the fill is not antialiased. If I have a diagonal fill and draw a line at any angle the fill is antialiased. Just thought I would mention it. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 20, 2022 Share Posted July 20, 2022 The hatch pattern just has antialiasing built-in to it. You can see that if you draw a filled rectangle. Antialiasing doesn't affect the hatch fill itself, which is essentially just a bitmap provided by GDI+ (System.Drawing). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 20, 2022 Share Posted July 20, 2022 Also it looks like you're using an old version of the app (4.3.7). The latest is 4.3.11. Make sure to install those updates! Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
kgschlosser Posted July 20, 2022 Author Share Posted July 20, 2022 Is the issue fixed in the latest version? If antialiasing is turned off this is what should be seen Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 20, 2022 Share Posted July 20, 2022 That’s just how the hatch pattern is, it’s not changing Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
otuncelli Posted July 20, 2022 Share Posted July 20, 2022 You can try "Light Downward Diagonal" pattern instead of "Forward Diagonal". Still not perfect though. If the lines are too frequent for you, Switch to "Forward Diagonal" pattern Set Primary Color: Transparent Draw over the line. Quote Link to comment Share on other sites More sharing options...
kgschlosser Posted July 20, 2022 Author Share Posted July 20, 2022 It's not something I have to have working. It was something I noticed is all. The behavior of the fill is also quite odd as it works like it is filling the entire image and the tool simply acts like it is removing that section of a mask. For example when using the lie tool if i set it to use a diagonal and I draw either a horizontal of a vertical line I get a 45° stripes . But if I draw a 45° line I don't get 90° stripes which is how I would have expected the behavior to be. Quote Link to comment Share on other sites More sharing options...
