i had a "zoom in" processing problem
i was asked buy a avast guy
ZOOMIN.EXE is associated with Microsoft's Visual Studio 6.x
Do you use this program? --answer no
my new lap couldn't close a zoom in program that may have been causing a processor loop answer in later post here
wonder if a recomeneded download called ms .net framework 2. uses this .exe too----answer -no it doesn't
after first boot of this new acer laptop with amd sempron 512ddr i installed adaware and avast
then i returned to majorgeeks to download pnt.net and ms frame
as i started editing a pdn file & when i tried rotate/zoom a pdn layer.all windows processing slowed to a crawl. i was rocking on 1 of 25 layers but it didn't seem like a ram problem,
windows reported that it couldn't shut down ZOOM IN (a running process)
task mgr. showed 100% usage of processor, though i had a defective amd
bug related to a, zoom in.exe, causing a calucalition loop, on my amd processor
as for the most part, a virus writter wouldn't want to draw attention to the virus
I want to use my adobe paint 3.0, and I liked quite a few functions better[/
I for some reason thought, you, RickB were affiliated with MS.netfarame2.0 as it seemed to be nessary to run your program,
Thanks again for your responses,
i'll post some glass/bubble/cat eyes, pdn png, soon as i visit the forum about how to do it, the blurs did help with smudging
hi guys
i found the problem/ /processor issue for Acers using .net
when a Acer machine, probally laptops, is using a
QtZgAcer Launch Mgr., probally version 1.6.812,
if the end user installs Paint.net with, MS.net framework 2., one, or the other, of the programs may conflict and
the processor runs at 100% and windows won't automatically shut down a process called ZOOM IN created by QtZgAcer Launch Mgr., not caused by or from PDNet, MS.net or MS VB6 as they researched.
after explaining it, their temp., solution from Acer Cust. Serv., is to
turn off QtZgAcer in, start/run/MSConfig/open >tab to, Start up>deselect-QtZgAcer Launch Mgr > Apply
then you have to tell windows to stop opening Config after rebooting and some acer buttons won't work.
acer will probally post a fix or repair.
Thanks for Your Help, Avast guys, am sorry to bother the pdn and ms.net guys but though tired of helping me they were a big help.
changed last post on processor worm thred to have them read this thread
thanks - rickb and illnab1024
RJ
