CometChaser Posted June 11, 2022 Share Posted June 11, 2022 So, in essence, I wish to overlay a map on top of another to make a new map. However I can't find any way to distort the image in reference to the basemap: I can only see 1 layer. Is there any way to fix this? (Google Drive Link because image is too large) https://drive.google.com/file/d/1Q9znTJNMjX7q-Ts3Nh7MIc3CAcCMfPmL/view?usp=sharing I want the coasts to line up, is there any way to do this? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 11, 2022 Share Posted June 11, 2022 Hello and welcome to the forum @CometChaser Paste your second image into a new layer with Ctrl + Shift + V. Then you'll want to lower the opacity of this new layer (press F4 and adjust the Opacity slider) so the first image shows through a little. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Tactilis Posted June 11, 2022 Share Posted June 11, 2022 2 hours ago, Ego Eram Reputo said: Paste your second image into a new layer with Ctrl + Shift + V. Then you'll want to lower the opacity of this new layer (press F4 and adjust the Opacity slider) so the first image shows through a little. That is essentially what @CometChaser has done. If you look carefully, you can see the base map through the upper map. The maps look as though they are drawn with different projections, so they will not line up unless you distort them. You could use the Grid Warp plugin to do this: Quote Link to comment Share on other sites More sharing options...
Solution CometChaser Posted June 11, 2022 Author Solution Share Posted June 11, 2022 (edited) 16 hours ago, Tactilis said: That is essentially what @CometChaser has done. If you look carefully, you can see the base map through the upper map. The maps look as though they are drawn with different projections, so they will not line up unless you distort them. You could use the Grid Warp plugin to do this: Through testing, there are three ways: -Using Grid warp and making the longitude/latitude lines perfectly straight. Only works if projection has perfectly straight meridians too. Reason is that Grid Warp only shows 1 layer instead of the whole image, so I can't use the coasts to reference. Example: https://drive.google.com/file/d/1bbrstNSZBG4TTmSt2Nt32lV8TfwsU4QP/view?usp=sharing You can't see the background, which does have perfectly straight meridians. -Using Distort This! plugin. Probably the most effective. Only shortfall is that there is a limit to how far you can pull the nubs. -Making small sectors of the map and using the cropping tools to make the coasts line up, which is easier since area is smaller. Edit: An example of Method 2 here. Edited June 11, 2022 by CometChaser 1 Quote Link to comment Share on other sites More sharing options...
