Resizing shortcut keys no longer work
For years I have used CTRL+SHIFT+R to open the resize canvas dialog box. It no longer works. NOTHING. I, now, have to go to the IMAGE area of the menu bar and drop it down to access the canvas dialog. Is there any way to fix this? Thanks.
Try swapping out your keyboard to confirm it is Ok.
Do you have any keyboard macros or third party keyboard apps installed?
9 minutes ago, Djisves said:
Keyboard shortcuts don't work if your keyboard is set to a language that uses non-Latin characters, like Greek, Cyrilic, Arabic, Hebrew etc.
I'm not sure about that. The Russian-language keyboard serves Ctrl+Shift+R and Ctrl+R without problems.
  • 8 months later...
