Wunderly Posted April 28, 2022 Share Posted April 28, 2022 I have noticed that the rulers on the Paint program are not accurate to a actual ruler. Is there any way to fix this little problem. Thanks Quote Link to comment Share on other sites More sharing options...
BoltBait Posted April 28, 2022 Share Posted April 28, 2022 What are you seeing that makes you think the ruler on the screen is not accurate? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
kreemoweet Posted April 30, 2022 Share Posted April 30, 2022 Paint.net has to get its information on how many screen pixels make a unit of length from the operating system (i.e. Windows). Windows is not able to use accurate pixels-per-inch numbers without causing large display problems. Windows can only handle some very approximate DPI settings, such as 96, 120, etc. If you find out what your monitor's pixel size actually is, and then set Window's DPI value to that actual value, then you should theoretically get accurate rulers in Paint.net. But at a price. Quote Link to comment Share on other sites More sharing options...
