Raillife3001 Posted April 17, 2022 Share Posted April 17, 2022 Hello, I'm new to paint.net and have come across an issue; whenever I try to use the colorpicker on a shade of gray it simply shows a checker pattern fading to darkness upwards, and it won't let me use the brush for any color regardless of what is selected. Could anyone diagnose the issue? Thank you. Quote Link to comment Share on other sites More sharing options...
Solution AndrewDavid Posted April 18, 2022 Solution Share Posted April 18, 2022 Hi @Raillife3001 Welcome to the forum. If I understand you correctly, it sounds like you are color picking a transparent pixel. If you have that as your primary color, you won't see any difference when you use the brush. Ensure you are not on a transparent layer when you use the color picker. Change your primary color to red, paint a blob, change your primary color to black, then use the color picker on the red to see how it works. I'm sure you'll figure it out. Hope this helps Quote Link to comment Share on other sites More sharing options...
Raillife3001 Posted April 18, 2022 Author Share Posted April 18, 2022 @AndrewDavidit worked, thank you Quote Link to comment Share on other sites More sharing options...
