MJW Posted February 18, 2022 Share Posted February 18, 2022 To create the problem on my system: Create a new canvas Select Paintbrush tool Set Fill to 50% Increase brush size to fill entire canvas Fill canvas with 50% pattern (a one-pixel checkerboard). (Long way of saying fill the canvas with a 50% fill pattern.) When I turn hardware acceleration off, the canvas gets considerably lighter. When I turn it back on, the canvas gets darker again. The effect is visible up to about 400% magnification. The white pixels seem to be dimmer when HA is enabled. Also, when hardware acceleration in enabled, if I make a rectangular selection on the 50%-filled canvas and adjust the Brightness/Contrast the region outside the selection flashes as I change the brightness and contrast. I have no idea if this is a new problem, since as far as I know I haven't tried the particular combination things that show the problem. EDIT: I see now I misunderstood what was going on. What happens is that, with HA is enabled), when I make a selection, the 50%-filled region outside the selection gets darker. When I deselect, the pixels that had been selected remain the original brightness. When I click the mouse somewhere outside, the darkened area returns to its original state. However, the original brightness is still considerably darker than the same 50%-filled region when HA is disabled. The approximate matching RGB values are: HA off: 183, 183, 183 No selection with HA on: 154, 154, 154 Outside selection with HA on: 126, 126, 126 Very strange -- and strange none else has previously reported it. Could it be a hardware problem with my computer? I don't know. EDIT 2: I suppose it's not so strange it hasn't been reported, since it seems to happen only with the checkerboard pattern, not wih solid colors. Spoiler Application paint.net 4.3.8 (Stable 4.308.8083.2561) Build Date Thursday, February 17, 2022 Install type Classic Hardware accelerated rendering (GPU) False Remote session False Animations True DPI 96 (1.00x scale) Language en-US OS Windows 10 Pro x64 (10.0.19043.0) Runtime .NET 6.0.2 x64 Physical Memory 8,108 MB CPU Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz Speed ~3193 MHz Cores / Threads 4 / 4 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2 Video Card Intel(R) HD Graphics 4600 Dedicated Video RAM 112 MB Dedicated System RAM 0 MB Shared System RAM 2,048 MB Vendor ID 0x8086 Device ID 0x0412 Subsystem ID 0x06221028 Revision 6 LUID 0x0000BA1C Flags SupportMonitoredFences, KeyedMutexConformance Graphics Preemption PrimitiveBoundary Compute Preemption ThreadGroupBoundary Outputs 1 Feature Level Direct3D_11_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 4,054 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000BCB3 Flags Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Managed assemblies 392 System.Private.CoreLib .\System.Private.CoreLib.dll, Version=6.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet .\paintdotnet.dll, Version=4.308.8083.2561 System.Runtime .\System.Runtime.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms .\System.Windows.Forms.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.Base .\PaintDotNet.Base.dll, Version=4.308.8083.2561 System.Diagnostics.Process .\System.Diagnostics.Process.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a TerraFX.Interop.Windows .\TerraFX.Interop.Windows.dll, Version=10.0.20348.0, PublicKeyToken=35b01b53313a6f7e PaintDotNet.SystemLayer .\PaintDotNet.SystemLayer.dll, Version=4.308.8083.2561 System.Runtime.InteropServices.RuntimeInformation .\System.Runtime.InteropServices.RuntimeInformation.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.InteropServices .\System.Runtime.InteropServices.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer.Native.x64 .\PaintDotNet.SystemLayer.Native.x64.dll, Version=4.308.8083.2561 System.Threading .\System.Threading.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions .\System.Runtime.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC .\System.Runtime.CompilerServices.VisualC.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric .\System.Collections.NonGeneric.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Intrinsics .\System.Runtime.Intrinsics.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Core .\PaintDotNet.Core.dll, Version=4.308.8083.2561 System.Private.Uri .\System.Private.Uri.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives .\System.ComponentModel.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WindowsBase .\WindowsBase.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Windows.Forms.Primitives .\System.Windows.Forms.Primitives.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 System.Drawing.Primitives .\System.Drawing.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework .\PresentationFramework.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.TraceSource .\System.Diagnostics.TraceSource.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections .\System.Collections.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xaml .\System.Xaml.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 System.ComponentModel .\System.ComponentModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.CodePages .\System.Text.Encoding.CodePages.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread .\System.Threading.Thread.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Primitives .\Microsoft.Win32.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Resources .\PaintDotNet.Resources.dll, Version=4.308.8083.2561 System.ObjectModel .\System.ObjectModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data .\PaintDotNet.Data.dll, Version=4.308.8083.2561 System.Configuration.ConfigurationManager .\System.Configuration.ConfigurationManager.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Framework .\PaintDotNet.Framework.dll, Version=4.308.8083.2561 System.Collections.Specialized .\System.Collections.Specialized.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Common .\System.Drawing.Common.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Xml.ReaderWriter .\System.Xml.ReaderWriter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.SystemEvents .\Microsoft.Win32.SystemEvents.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Private.Xml .\System.Private.Xml.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.ComponentModel.EventBasedAsync .\System.ComponentModel.EventBasedAsync.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Immutable .\System.Collections.Immutable.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Linq .\System.Linq.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.ThreadPool .\System.Threading.ThreadPool.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.WebClient .\System.Net.WebClient.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Microsoft.Win32.Registry .\Microsoft.Win32.Registry.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Concurrent .\System.Collections.Concurrent.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Memory .\System.Memory.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Security.Principal.Windows .\System.Security.Principal.Windows.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.Extensions .\System.Text.Encoding.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Claims .\System.Security.Claims.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter .\System.ComponentModel.TypeConverter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationCore .\PresentationCore.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder .\DirectWriteForwarder.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.Debug .\System.Diagnostics.Debug.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a UIAutomationTypes .\UIAutomationTypes.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.FileVersionInfo .\System.Diagnostics.FileVersionInfo.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects .\PaintDotNet.Effects.dll, Version=4.308.8083.2561 Accessibility .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Numerics.Vectors .\System.Numerics.Vectors.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Crc32.NET .\Crc32.NET.dll, Version=1.0.0.0, PublicKeyToken=dc0b95cf99bf4e99 System.Security.Cryptography.Primitives .\System.Security.Cryptography.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.Packaging .\System.IO.Packaging.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Loader .\System.Runtime.Loader.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Tasks.Parallel .\System.Threading.Tasks.Parallel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Tracing .\System.Diagnostics.Tracing.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.MetadataLoadContext .\System.Reflection.MetadataLoadContext.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Reflection.Metadata .\System.Reflection.Metadata.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.MemoryMappedFiles .\System.IO.MemoryMappedFiles.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a CSVFiletype .\FileTypes\CSVFiletype.dll, Version=1.0.0.0 ABRFileType .\FileTypes\ABRFileType.dll, Version=1.0.0.1 ImSVG.Open.FileType .\FileTypes\ImSVG.Open.FileType.dll, Version=0.18.0.0 IcoCur .\FileTypes\IcoCur.dll, Version=4.0.1.0 mscorlib .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System.Drawing .\System.Drawing.dll, Version=6.0.2.0, PublicKeyToken=b03f5f7f11d50a3a System .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 DdsFileTypePlus .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.11.0 AvifFileType .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.18.0 WebPFileType .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.11.0 System.Runtime.Serialization.Formatters .\System.Runtime.Serialization.Formatters.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.StackTrace .\System.Diagnostics.StackTrace.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.CodeDom .\System.CodeDom.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Mono.Cecil .\Mono.Cecil.dll, Version=0.11.4.0, PublicKeyToken=50cebf1cceb9d05e netstandard .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.RegularExpressions .\System.Text.RegularExpressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Newtonsoft.Json .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Linq.Expressions .\System.Linq.Expressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Numerics .\System.Runtime.Numerics.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.Unsafe .\System.Runtime.CompilerServices.Unsafe.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Plugins.Compatibility .\PaintDotNet.Plugins.Compatibility.dll, Version=4.308.8083.2561 System.Console .\System.Console.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Vandermotten.PaintDotNetEffects.ObjectAlign C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 System.Resources.Extensions .\System.Resources.Extensions.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Vandermotten.PaintDotNetEffects.Monochromes C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects.MakeTransparent C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects.Grid C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects.Gradient C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects.FadeEdge C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects.Duotones C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects.DropShadow C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects.ColorAccent C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects.Blurs C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, Version=4.3.0.0 Vandermotten.PaintDotNetEffects C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.0.0 ZoomBlurDeluxeCL .\Effects\ZoomBlurDeluxeCL.dll, Version=1.0.5709.38898 ZoomBlurDeluxe .\Effects\ZoomBlurDeluxe.dll, Version=1.0.0.0 WindowSizeTest .\Effects\WindowSizeTest.dll, Version=1.0.7013.27531 WaveTextSUI .\Effects\WaveTextSUI.dll, Version=1.2.4415.33440 WaveText .\Effects\WaveText.dll, Version=1.2.4415.32811 ViewFramer .\Effects\ViewFramer.dll, Version=1.0.6074.42436 Vanishing Trails .\Effects\Vanishing Trails.dll, Version=2.0.0.0 UnselectedRectangleKeeper .\Effects\UnselectedRectangleKeeper.dll, Version=1.0.5669.36271 UIExamples .\Effects\UIExamples.dll, Version=1.0.6584.1918 TwoToneThreshold .\Effects\TwoToneThreshold.dll, Version=1.0.0.0 TwoColorMixer .\Effects\TwoColorMixer.dll, Version=1.1.5616.26437 Twist .\Effects\Twist.dll, Version=4.0.4642.26767 System.Core .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 TRsTreeMaker .\Effects\TRsTreeMaker.dll, Version=1.0.3.0 TRsThirdDimension .\Effects\TRsThirdDimension.dll, Version=1.7.9.3072 TRsSplineMaster .\Effects\TRsSplineMaster.dll, Version=1.4.2.18310 TRsSnowFlakeMaker .\Effects\trssnowflakemaker.dll, Version=1.0.3.10409 TRsRadialExtruder .\Effects\TRsRadialExtruder.dll, Version=1.2.5609.8244 TRsPasteWarp .\Effects\TRsPasteWarp.dll, Version=1.0.0.0 TRsMonolithic .\Effects\TRsMonolithic.dll, Version=1.0.4.12960 TRsFireWorks .\Effects\TRsFireWorks.dll, Version=1.2.0.0 TRsDrumSkin .\Effects\TRsDrumSkin.dll, Version=1.4.5199.15427 TRsDodgeBurn .\Effects\TRsDodgeBurn.dll, Version=1.4.0.33503 TRsDodgeBurn.resources .\Effects\TRsDodgeBurn.resources.dll, Version=1.3.26.12436, Culture=zh-CN TRsCustomRandomFill .\Effects\TRsCustomRandomFill.dll, Version=1.5.1.38287 TRsCustomPaletteMatch .\Effects\TRsCustomPaletteMatch.dll, Version=1.0.5.0 TRsAlphaCutter .\Effects\TRsAlphaCutter.dll, Version=3.0.4.0 TRDistortMap3D .\Effects\TRDistortMap3D.dll, Version=1.0.5550.23545 TransparentToTransparentWhite .\Effects\TransparentToTransparentWhite.dll, Version=1.0.6963.30396 TransparentToTransparentBlack .\Effects\TransparentToTransparentBlack.dll, Version=1.0.6479.25661 Trail .\Effects\Trail.dll, Version=4.0.4642.26791 Trail Blur .\Effects\Trail Blur.dll, Version=1.0.0.0 TJacksonEffects .\Effects\TJacksonEffects.dll, Version=1.0.0.0 TileWorld .\Effects\TileWorld.dll, Version=1.0.0.30524 ThatOtherApp .\Effects\ThatOtherApp.dll, Version=2.2.0.0 System.Windows.Forms.Legacy .\System.Windows.Forms.Legacy.dll, Version=0.1.1.0 AA's_Assistant .\Effects\AA's_Assistant.dll, Version=1.1.4329.33034 Aardvark .\Effects\Aardvark.dll, Version=1.0.5.0 a_kaleido .\Effects\Advanced_Kaleidoscope.dll, Version=1.0.7194.37638 Alpha-Displacement Mask .\Effects\Alpha-Displacement Mask.dll, Version=1.4.1.1 AlphaThreshold .\Effects\AlphaThreshold.dll, Version=1.0.1.0 Alpha_to_0 .\Effects\Alpha_to_0.dll, Version=1.0.4452.22746 Alpha_to_255 .\Effects\Alpha_to_255.dll, Version=1.0.4452.22782 Angled Gradient .\Effects\Angled Gradient.dll, Version=1.0.6166.41233 Align .\Effects\Align.dll, Version=1.0.0.1 AntialiasTest .\Effects\AntialiasTest.dll, Version=1.0.5719.38547 ArtyThing .\Effects\ArtyThing.dll, Version=1.0.5.0 Archimedean Spiral .\Effects\Archimedean Spiral.dll, Version=1.0.0.0 AverageObjectColor .\Effects\AverageObjectColor.dll, Version=1.1.6241.40360 AverageSelectionColor .\Effects\AverageSelectionColor.dll, Version=1.0.5641.22197 Basic Clipboard Transformations .\Effects\Basic Clipboard Transformations.dll, Version=1.0.6242.42182 BasicAntialias .\Effects\BasicAntialias.dll, Version=1.0.6164.34111 BBOutlinedGradientText .\Effects\BBOutlinedGradientText.dll, Version=4.6.7358.38713 BevelObject .\Effects\BevelObject.dll, Version=1.0.1.0 Bezncurve .\Effects\Bezncurve.dll, Version=1.0.0.0 Average Object Color .\Effects\Average Object Color.dll, Version=1.0.6242.23734 BilinearTest .\Effects\BilinearTest.dll, Version=1.0.5719.29019 BlackandAlpha+ .\Effects\BlackandAlpha+.dll, Version=1.2.4329.272 Borders N' Shapes .\Effects\Borders N' Shapes.dll, Version=4.0.4642.26476 Calendar .\Effects\Calendar.dll, Version=4.6.7358.32649 BBChart .\Effects\BBChart.dll, Version=1.0.7358.33924 CalliColour .\Effects\CalliColour.dll, Version=1.0.1.0 BlackAndWhite+ .\Effects\BlackAndWhite+.dll, Version=1.1.6744.2631 CellMaker .\Effects\CellMaker.dll, Version=1.1.6139.29120 CellTexture .\Effects\CellTexture.dll, Version=1.1.0.0 CircleText .\Effects\CircleText.dll, Version=1.4.4415.32488 ClampedGaussianBlur .\Effects\ClampedGaussianBlur.dll, Version=2.0.0.0 ClipWarpNew .\Effects\ClipWarpNew.dll, Version=1.0.1.0 ClipDisplaceAA .\Effects\ClipDisplaceAA.dll, Version=1.2.4.0 Clipboard Selection Test .\Effects\Clipboard Selection Test.dll, Version=1.0.7863.822 CloudDisplacement .\Effects\CloudDisplacement.dll, Version=1.0.5493.27534 CloudEffect .\Effects\CloudEffect.dll, Version=1.1.0.0 Color Match .\Effects\Color Match.dll, Version=4.0.4642.26532 ColorClearer .\Effects\ColorClearer.dll, Version=1.1.6009.41762 Cobweb .\Effects\Cobweb.dll, Version=1.0.1.0 Compotool .\Effects\Compotool.dll, Version=1.0.1.0 ContentAwareFill .\Effects\ContentAwareFill.dll, Version=1.1.0.0 CountNonWhitePixels .\Effects\CountNonWhitePixels.dll, Version=1.0.5677.2063 Contour .\Effects\Contour.dll, Version=1.0.1.0 CountSelectedPixels .\Effects\CountSelectedPixels.dll, Version=1.0.5677.2584 LightningCurve .\Effects\CurlyLines.dll, Version=1.0.0.0 DeFisheye .\Effects\DeFisheye.dll, Version=1.0.6483.24639 Dimensions .\Effects\Dimensions.dll, Version=1.3.6826.38472 Displacement .\Effects\Displacement.dll, Version=1.1.0.0 DisplayColorChangeDirection .\Effects\DisplayColorChangeDirection.dll, Version=2.0.5621.37825 DisplayColorDifferenceChange .\Effects\DisplayColorDifferenceChange.dll, Version=1.0.5800.33546 DistortThis .\Effects\DistortThis.dll, Version=2.7.0.0 dpyColorBalance .\Effects\dpyColorBalance.dll, Version=1.1.4330.37850 DragFrom .\Effects\DragFrom.dll, Version=1.1.0.0 Droste .\Effects\Droste.dll, Version=1.1.0.0 Dryad .\Effects\Dryad.dll, Version=1.0.1.0 CreativeTextPro .\Effects\CreativeTextPro.dll, Version=1.1.7358.34307 EarthsAndGreys .\Effects\EarthsAndGreys.dll, Version=1.0.1.0 Edge Antialias Test .\Effects\Edge Antialias Test.dll, Version=1.0.7455.535 Edge Shader Test .\Effects\Edge Shader Test.dll, Version=1.0.1.0 EdgeDetector .\Effects\EdgeDetector.dll, Version=1.0.5626.32775 EdgeExpander .\Effects\EdgeExpander.dll, Version=1.0.5863.38192 Edge Shader .\Effects\Edge Shader.dll, Version=1.0.1.0 CodeLab .\Effects\CodeLab.dll, Version=6.4.7995.19949 Equirectangular Diffuse Transform Exact .\Effects\Equirectangular Diffuse Transform Exact.dll, Version=1.0.7114.4176 Equirectangular Diffuse Transform .\Effects\Equirectangular Diffuse Transform.dll, Version=1.0.7159.445 Curves+ .\Effects\Curves+.dll, Version=4.0.4642.26561 Film .\Effects\Film.dll, Version=4.0.4642.26607 FindEdges .\Effects\FindEdges.dll, Version=1.2.0.0 FishEyeAntialias .\Effects\FishEyeAntialias.dll, Version=1.0.5540.25286 Equirectangular Viewer .\Effects\Equirectangular Viewer.dll, Version=1.1.0.32613 FisheyeTest .\Effects\FisheyeTest.dll, Version=1.0.6484.351 Flourish .\Effects\Flourish.dll, Version=1.0.2.0 FloodFill Test .\Effects\FloodFill Test.dll, Version=1.0.6170.2244 FurBlur .\Effects\FurBlur.dll, Version=1.0.1.0 Flip .\Effects\Flip.dll, Version=4.6.7358.36953 GaussianBlurPlus .\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401 GaussianBlurPP .\Effects\GaussianBlurPP.dll, Version=4.1.5687.39957 GaussianBrightnessContrast .\Effects\GaussianBrightnessContrast.dll, Version=1.0.5797.40273 Gears .\Effects\Gears.dll, Version=1.0.2.0 Gmic .\Effects\Gmic.dll, Version=1.2.1.0 Gradient Bars .\Effects\Gradient Bars.dll, Version=4.0.5152.23084 Gradient Blocks .\Effects\Gradient Blocks.dll, Version=4.0.4642.26658 GradientsGalore .\Effects\GradientsGalore.dll, Version=1.0.2.0 GraphParabolas .\Effects\GraphParabolas.dll, Version=1.0.5843.29999 GraphQuadAndCubicAdj .\Effects\GraphQuadAndCubicAdj.dll, Version=1.0.6246.24680 Gradient Mapping .\Effects\Gradient Mapping.dll, Version=4.0.4642.26687 GraphSine .\Effects\GraphSine.dll, Version=1.0.5813.34527 Gravity .\Effects\Gravity.dll, Version=1.1.0.0 GridCheckerboard .\Effects\GridCheckerboard.dll, Version=4.5.6828.36789 Heightmap plugin v1 .\Effects\Heightmap v1.3.dll, Version=1.3.4261.22267 Helix .\Effects\Helix.dll, Version=1.0.1.0 Grid Warp .\Effects\Grid Warp.dll, Version=4.0.6544.34496 HexaGrid .\Effects\HexaGrid.dll, Version=1.2.0.0 Highlight .\Effects\Highlight.dll, Version=1.0.1.0 HotMetalGlow .\Effects\HotMetalGlow.dll, Version=1.2.5985.32923 HSVEraser .\Effects\HSVEraser.dll, Version=1.0.5800.36672 HsvRecolorer .\Effects\HsvRecolorer.dll, Version=1.0.5810.40990 HsvScrambler .\Effects\HsvScrambler.dll, Version=1.0.5675.38066 InsetBoxShadow .\Effects\InsetBoxShadow.dll, Version=1.0.0.0 Jitter .\Effects\Jitter.dll, Version=4.0.4642.26986 LabelPixelColors .\Effects\LabelPixelColors.dll, Version=1.0.0.0 LaplacianPyramidFilter .\Effects\LaplacianPyramidFilter.dll, Version=1.0.3.0 LightRays .\Effects\LightRays.dll, Version=2.1.5.14276 PDNPI_IndirectUI .\Effects\jchunn.dll, Version=1.0.0.0 Microsoft.VisualBasic .\Microsoft.VisualBasic.dll, Version=10.1.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.VisualBasic.Forms .\Microsoft.VisualBasic.Forms.dll, Version=6.0.2.0, PublicKeyToken=b03f5f7f11d50a3a Linearly Tile From Clipboard .\Effects\Linearly Tile From Clipboard.dll, Version=1.0.6789.43109 MakeTransparent .\Effects\MakeTransparent.dll, Version=1.0.0.0 MemeMaker .\Effects\MemeMaker.dll, Version=4.5.6828.38061 Metallize .\Effects\Metallize.dll, Version=1.2.4415.32969 MidpointDisplacementTest .\Effects\MidpointDisplacementTest.dll, Version=1.0.5986.26909 Mise En Abyme .\Effects\Mise En Abyme.dll, Version=1.1.0.0 MismatchEraser .\Effects\MismatchEraser.dll, Version=1.0.6920.41978 Monet .\Effects\Monet.dll, Version=1.0.5499.36110 Mandelbrot Plus .\Effects\Mandelbrot Plus.dll, Version=1.0.6245.41754 Liquify .\Effects\Liquify.dll, Version=4.0.4642.26973 MoveRectangle .\Effects\MoveRectangle.dll, Version=1.0.6477.2565 MultiThreshold .\Effects\MultiThreshold.dll, Version=1.1.4330.38982 NoiseChoice .\Effects\NoiseChoice.dll, Version=1.0.1.0 NonBlackToAlpha .\Effects\NonBlackToAlpha.dll, Version=1.0.5557.34844 Object2Colour .\Effects\Object2Colour.dll, Version=1.0.1.0 Object Pruner .\Effects\Object Pruner.dll, Version=1.0.1.0 Neighbor Blur .\Effects\Neighbor Blur.dll, Version=1.0.6738.24032 ObjectEdge .\Effects\Objectedge.dll, Version=1.0.1.0 OffsetAlternatingStripes .\Effects\OffsetAlternatingStripes.dll, Version=1.0.6025.41452 OilPaintingPlus .\Effects\OilPaintingPlus.dll, Version=4.6.7358.38406 ObjectShadowPro .\Effects\ObjectShadowPro.dll, Version=1.0.7421.614 Olden .\Effects\Olden.dll, Version=1.5.0.0 Feather .\Effects\OldFeather.dll, Version=2.3.4315.37038 Otsu .\Effects\Otsu.dll, Version=1.2.6051.11025 Outline Object .\Effects\Outline Object.dll, Version=4.0.4642.26954 Overblur .\Effects\Overblur.dll, Version=1.0.1.0 PasteAlphaPlus .\Effects\PasteAlphaPlus.dll, Version=1.0.6451.40672 Perspective .\Effects\Perspective.dll, Version=2.1.4415.36116 PerspectiveTransformation .\Effects\PerspectiveTransformation.dll, Version=1.2.5795.41799 PasteFromClipboard .\Effects\PasteFromClipboard.dll, Version=2.0.1.0 Pixelate+ .\Effects\Pixelate+.dll, Version=4.0.4642.26940 Planetoid .\Effects\Planetoid.dll, Version=1.0.2.0 PNG Preprocessor .\Effects\PNG_Preprocessor.dll, Version=1.0.3876.32360 PointBlur .\Effects\PointBlur.dll, Version=1.0.0.0 Polar .\Effects\Polar.dll, Version=1.1.1.0 Paste Warp Plus .\Effects\Paste Warp Plus.dll, Version=1.1.0.0 PrinterPlus .\Effects\PrinterPlus.dll, Version=1.5.0.0 Psychocolour .\Effects\Psychocolour.dll, Version=1.0.1.0 pxEexpansion .\Effects\pxEexpansion.dll, Version=1.0.4437.36287 RadialSlicer .\Effects\RadialSlicer.dll, Version=1.0.6059.41294 Random Shape Fill .\Effects\Random Shape Fill.dll, Version=4.0.4642.26910 Randomize Object Color .\Effects\Randomize Object Color.dll, Version=1.0.6298.4733 QuadrilateralCorrection .\Effects\QuadrilateralCorrection.dll, Version=1.0.0.0 RecolourChoice .\Effects\RecolourChoice.dll, Version=1.0.1.0 RectangleEraser .\Effects\RectangleEraser.dll, Version=1.0.5630.22007 RectangleToArchimedeanSpiral.dll .\Effects\RectangleToArchimedeanSpiral.dll, Version=1.0.7623.289 RemoveStamp2 .\Effects\RemoveStamp2.dll, Version=1.0.5490.41603 Recolor Using Palette .\Effects\Recolor Using Palette.dll, Version=1.0.6382.573 Render Gray Scale .\Effects\Render Gray Scale.dll, Version=1.0.0.0 RenderSphereHeightMap .\Effects\RenderSphereHeightMap.dll, Version=1.0.6145.37460 ReplaceBackgroundColor .\Effects\ReplaceBackgroundColor.dll, Version=1.0.5622.40133 Replace Colors .\Effects\Replace Colors.dll, Version=1.1.5767.26297 RotateText .\Effects\RotateText.dll, Version=1.1.4415.32628 RotateTextSUI .\Effects\RotateTextSUI.dll, Version=1.1.4415.32713 Rotate_Zoom+ .\Effects\Rotate_Zoom+.dll, Version=1.11.5237.17779 Scintillate .\Effects\Scintillate.dll, Version=1.0.1.0 RotateZoomPlus .\Effects\RotateZoomPlus.dll, Version=1.0.5979.31043 RotateZoomDeluxe .\Effects\RotateZoomDeluxe.dll, Version=1.0.7594.3020 Scribble .\Effects\Scribble.dll, Version=1.0.1.0 ScribbleIntermediate .\Effects\ScribbleIntermediate.dll, Version=1.0.1.0 SBCommon .\Effects\SBCommon.dll, Version=3.0.0.0 Selection2Clear .\Effects\Selection2Clear.dll, Version=1.0.1.0 ShadowEffect .\Effects\ShadowEffect.dll, Version=1.2.0.0 Shapes .\Effects\Shapes.dll, Version=1.6.5.30197 Shape3D .\Effects\Shape3D.dll, Version=1.2.6.3 Slinky .\Effects\Slinky.dll, Version=1.0.1.0 ShapeMaker .\Effects\shapemaker.dll, Version=1.3.9.1 SpeechBubble .\Effects\SpeechBubble.dll, Version=2.1.4445.42029 Sparkles .\Effects\Sparkles.dll, Version=1.1.0.0 SpiralText .\Effects\SpiralText.dll, Version=1.4.4415.32775 SpotRemover .\Effects\SpotRemover.dll, Version=1.0.5716.23929 Squirkle .\Effects\Squirkle.dll, Version=1.0.1.0 SquirkleWarp .\Effects\SquirkleWarp.dll, Version=1.0.1.0 Smudge .\Effects\Smudge.dll, Version=4.0.4642.26844 Stitch .\Effects\Stitch.dll, Version=4.0.4642.26808 Splatter .\Effects\Splatter.dll, Version=4.0.4642.26829 StrayPixelRemover .\Effects\StrayPixelRemover.dll, Version=1.0.0.0 StringAndPin .\Effects\StringAndPin.dll, Version=1.0.1.0 Tartan .\Effects\Tartan.dll, Version=1.1.0.0 TextPlus .\Effects\Textplus.dll, Version=1.0.0.0 Texture Object Rounder .\Effects\Texture Object Rounder.dll, Version=1.0.7012.43139 TextureAdder .\Effects\TextureAdder.dll, Version=1.0.5832.39552 Texture Scaler .\Effects\Texture Scaler.dll, Version=1.2.6431.28257 Texture Edge Shader .\Effects\Texture Edge Shader.dll, Version=1.0.7776.42842 TextureMerger .\Effects\TextureMerger.dll, Version=1.1.6167.3701 TextureShader .\Effects\TextureShader.dll, Version=2.3.0.0 TextureShaderCompatible .\Effects\TextureShaderCompatible.dll, Version=1.0.5657.33215 TextureViewSkewer .\Effects\TextureViewSkewer.dll, Version=1.0.5714.24733 TextureSmoother .\Effects\TextureSmoother.dll, Version=1.0.6096.31689 TGMagnitude .\Effects\TGMagnitude.dll, Version=1.0.2.0 SBCommon .\Effects\SBCommon.dll, Version=3.0.0.0 CombinedAdjustments .\Effects\CombinedAdjustments.dll, Version=1.1.7358.40688 MarkupRenderer .\Effects\MarkupRenderer.dll, Version=1.0.0.0 HueSatPlus .\Effects\HueSatPlus.dll, Version=4.6.7359.209 Burninate .\Effects\Burninate.dll, Version=4.6.7358.31797 SelectionTools .\Effects\SelectionTools.dll, Version=4.6.7359.373 EdHarvey.Effects .\Effects\EdHarvey.Effects.dll, Version=4.0.5120.42730 PhotoAdjustments .\Effects\PhotoAdjustments.dll, Version=4.6.7358.38979 System.Design .\System.Design.dll, Version=6.0.2.0, PublicKeyToken=b03f5f7f11d50a3a Pastel .\Effects\Pastel.dll, Version=4.6.7358.38877 ColorBalance .\Effects\ColorBalance.dll, Version=4.6.7358.34213 System.Windows.Forms.Design .\System.Windows.Forms.Design.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 System.IO.FileSystem .\System.IO.FileSystem.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Tasks .\System.Threading.Tasks.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xml.XDocument .\System.Xml.XDocument.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml.Linq .\System.Private.Xml.Linq.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.IO.Compression .\System.IO.Compression.dll, Version=6.0.0.0, PublicKeyToken=b77a5c561934e089 System.Security.Cryptography.Algorithms .\System.Security.Cryptography.Algorithms.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a NormalMapPlus .\Effects\NormalMapPlus.dll, Version=1.4.6422.43071 FillFromClipboard .\Effects\FillFromClipboard.dll, Version=4.7.7358.36519 Transparency .\Effects\Transparency.dll, Version=4.6.7358.39871 WhichSymbolRedux .\Effects\WhichSymbolRedux.dll, Version=1.0.0.0 SplitColorAndBrightness.dll .\Effects\SplitColorAndBrightness.dll, Version=1.0.7845.681 Copy Selection Bounding Box.dll .\Effects\Copy Selection Bounding Box.dll, Version=1.0.7837.463 Clock .\Effects\Clock.dll, Version=1.1.6245.30896 VignettePlus .\Effects\VignettePlus.dll, Version=4.6.7358.40027 RemoveDust .\Effects\RemoveDust.dll, Version=4.5.6826.37862 Stickman .\Effects\Stickman.dll, Version=1.2.2.30005 FloydSteinbergDithering .\Effects\FloydSteinbergDithering.dll, Version=4.6.7358.37110 BrushFactory .\Effects\BrushFactory.dll, Version=1.5.0.21980 FillFromFile .\Effects\FillFromFile.dll, Version=4.7.7358.36581 Polygon .\Effects\Polygon.dll, Version=4.5.6828.38648 CustomBrushesMini .\Effects\CustomBrushesMini.dll, Version=2.2.5286.39584 BandWPlus .\Effects\BandWPlus.dll, Version=1.3.7359.317 PasteAlpha .\Effects\PasteAlpha.dll, Version=4.6.7358.38804 EditableText .\Effects\EditableText.dll, Version=1.0.1.0 Dream .\Effects\Dream.dll, Version=4.6.7358.35004 Alpha2Gray .\Effects\Alpha2Gray.dll, Version=4.5.6832.21862 HSVGradients .\Effects\HSVGradients.dll, Version=4.5.6832.41864 Temperature .\Effects\Temperature.dll, Version=4.6.7358.39746 Landscape .\Effects\Landscape.dll, Version=4.6.7358.37463 ObjectTools .\Effects\ObjectTools.dll, Version=4.6.7358.41753 SeamCarving .\Effects\SeamCarving.dll, Version=4.6.7358.39596 LevelHorizon .\Effects\LevelHorizon.dll, Version=4.6.7358.37589 Gray2Alpha .\Effects\Gray2Alpha.dll, Version=4.5.6826.36897 K4os.Compression.LZ4 .\K4os.Compression.LZ4.dll, Version=1.2.15.0, PublicKeyToken=2186fa9121ef231d PresentationFramework-SystemXmlLinq .\PresentationFramework-SystemXmlLinq.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 System.Xml.Linq .\System.Xml.Linq.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 Native modules 452 PaintDotNet.exe .\PaintDotNet.exe, version=4.308.8083.2561 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.1466 (WinBuild.160101.0800) KERNEL32.DLL C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.1503 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.1503 (WinBuild.160101.0800) USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.1526 (WinBuild.160101.0800) GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.1202 (WinBuild.160101.0800) gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.1466 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) SHELL32.dll C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.964 (WinBuild.160101.0800) ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800) IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800) hostfxr.dll .\hostfxr.dll, version=6,0,222,6406 @Commit: 839cdfb0ecca5e0be3dbccd926e7651ef50fdf10 hostpolicy.dll .\hostpolicy.dll, version=6,0,222,6406 @Commit: 839cdfb0ecca5e0be3dbccd926e7651ef50fdf10 coreclr.dll .\coreclr.dll, version=6,0,222,6406 @Commit: 839cdfb0ecca5e0be3dbccd926e7651ef50fdf10 ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1320 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.1320 (WinBuild.160101.0800) OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800) bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1415 (WinBuild.160101.0800) System.Private.CoreLib.dll .\System.Private.CoreLib.dll, version=6.0.222.6406 clrjit.dll .\clrjit.dll, version=6,0,222,6406 @Commit: 839cdfb0ecca5e0be3dbccd926e7651ef50fdf10 kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) paintdotnet.dll .\paintdotnet.dll, version=4.308.8083.2561 System.Runtime.dll .\System.Runtime.dll, version=6.0.222.6406 uxtheme.dll C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Windows.Forms.dll .\System.Windows.Forms.dll, version=6.0.222.6407 PaintDotNet.Base.dll .\PaintDotNet.Base.dll, version=4.308.8083.2561 System.Diagnostics.Process.dll .\System.Diagnostics.Process.dll, version=6.0.222.6406 TerraFX.Interop.Windows.dll .\TerraFX.Interop.Windows.dll, version=10.0.20348.0 PaintDotNet.SystemLayer.dll .\PaintDotNet.SystemLayer.dll, version=4.308.8083.2561 System.Runtime.InteropServices.RuntimeInformation.dll .\System.Runtime.InteropServices.RuntimeInformation.dll, version=6.0.222.6406 System.Runtime.InteropServices.dll .\System.Runtime.InteropServices.dll, version=6.0.222.6406 vcruntime140.dll .\vcruntime140.dll, version=14.31.31103.0 vcruntime140_1.dll .\vcruntime140_1.dll, version=14.31.31103.0 msvcp140.dll .\msvcp140.dll, version=14.31.31103.0 msvcp140_1.dll .\msvcp140_1.dll, version=14.31.31103.0 msvcp140_2.dll .\msvcp140_2.dll, version=14.31.31103.0 msvcp140_codecvt_ids.dll .\msvcp140_codecvt_ids.dll, version=14.31.31103.0 vcomp140.dll .\vcomp140.dll, version=14.31.31103.0 ijwhost.dll .\ijwhost.dll, version=6,0,222,6406 @Commit: 839cdfb0ecca5e0be3dbccd926e7651ef50fdf10 PaintDotNet.SystemLayer.Native.x64.dll .\PaintDotNet.SystemLayer.Native.x64.dll, version=4.308.8083.2561 PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.1 (WinBuild.160101.0800) gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.1466_none_91a4907ccc87e3b8\gdiplus.dll, version=10.0.19041.1466 (WinBuild.160101.0800) WindowsCodecs.dll C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1151 (WinBuild.160101.0800) bcrypt.dll C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Threading.dll .\System.Threading.dll, version=6.0.222.6406 System.Runtime.Extensions.dll .\System.Runtime.Extensions.dll, version=6.0.222.6406 System.Runtime.CompilerServices.VisualC.dll .\System.Runtime.CompilerServices.VisualC.dll, version=6.0.222.6406 System.Collections.NonGeneric.dll .\System.Collections.NonGeneric.dll, version=6.0.222.6406 System.Runtime.Intrinsics.dll .\System.Runtime.Intrinsics.dll, version=6.0.222.6406 windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) SHCORE.dll C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.1 (WinBuild.160101.0800) shlwapi.dll C:\WINDOWS\System32\shlwapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) PaintDotNet.Core.dll .\PaintDotNet.Core.dll, version=4.308.8083.2561 System.Private.Uri.dll .\System.Private.Uri.dll, version=6.0.222.6406 System.ComponentModel.Primitives.dll .\System.ComponentModel.Primitives.dll, version=6.0.222.6406 WindowsBase.dll .\WindowsBase.dll, version=6.0.222.6408 System.Windows.Forms.Primitives.dll .\System.Windows.Forms.Primitives.dll, version=6.0.222.6407 System.Drawing.Primitives.dll .\System.Drawing.Primitives.dll, version=6.0.222.6406 PresentationFramework.dll .\PresentationFramework.dll, version=6.0.222.6408 System.Diagnostics.TraceSource.dll .\System.Diagnostics.TraceSource.dll, version=6.0.222.6406 System.Collections.dll .\System.Collections.dll, version=6.0.222.6406 System.Xaml.dll .\System.Xaml.dll, version=6.0.222.6408 System.ComponentModel.dll .\System.ComponentModel.dll, version=6.0.222.6406 System.Text.Encoding.CodePages.dll .\System.Text.Encoding.CodePages.dll, version=6.0.222.6406 System.Threading.Thread.dll .\System.Threading.Thread.dll, version=6.0.222.6406 Microsoft.Win32.Primitives.dll .\Microsoft.Win32.Primitives.dll, version=6.0.222.6406 PaintDotNet.Resources.dll .\PaintDotNet.Resources.dll, version=4.308.8083.2561 System.ObjectModel.dll .\System.ObjectModel.dll, version=6.0.222.6406 PaintDotNet.Data.dll .\PaintDotNet.Data.dll, version=4.308.8083.2561 PresentationNative_cor3.dll .\PresentationNative_cor3.dll, version=6,0,21,48001 @Commit: bf6f24c075ff5315d0ec0e5359138ee796b0491c System.Configuration.ConfigurationManager.dll .\System.Configuration.ConfigurationManager.dll, version=6.0.222.6406 icu.dll C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) PaintDotNet.Framework.dll .\PaintDotNet.Framework.dll, version=4.308.8083.2561 System.Collections.Specialized.dll .\System.Collections.Specialized.dll, version=6.0.222.6406 System.Drawing.Common.dll .\System.Drawing.Common.dll, version=6.0.222.6406 System.Xml.ReaderWriter.dll .\System.Xml.ReaderWriter.dll, version=6.0.222.6406 System.Private.Xml.dll .\System.Private.Xml.dll, version=6.0.222.6406 Microsoft.Win32.SystemEvents.dll .\Microsoft.Win32.SystemEvents.dll, version=6.0.222.6406 MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.ComponentModel.EventBasedAsync.dll .\System.ComponentModel.EventBasedAsync.dll, version=6.0.222.6406 System.Collections.Immutable.dll .\System.Collections.Immutable.dll, version=6.0.222.6406 System.Linq.dll .\System.Linq.dll, version=6.0.222.6406 System.Threading.ThreadPool.dll .\System.Threading.ThreadPool.dll, version=6.0.222.6406 System.Net.WebClient.dll .\System.Net.WebClient.dll, version=6.0.222.6406 dxgi.dll C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.1266 (WinBuild.160101.0800) Microsoft.Win32.Registry.dll .\Microsoft.Win32.Registry.dll, version=6.0.222.6406 System.Collections.Concurrent.dll .\System.Collections.Concurrent.dll, version=6.0.222.6406 System.Memory.dll .\System.Memory.dll, version=6.0.222.6406 System.Security.Principal.Windows.dll .\System.Security.Principal.Windows.dll, version=6.0.222.6406 System.Text.Encoding.Extensions.dll .\System.Text.Encoding.Extensions.dll, version=6.0.222.6406 System.Security.Claims.dll .\System.Security.Claims.dll, version=6.0.222.6406 System.ComponentModel.TypeConverter.dll .\System.ComponentModel.TypeConverter.dll, version=6.0.222.6406 PresentationCore.dll .\PresentationCore.dll, version=6.0.222.6408 DirectWriteForwarder.dll .\DirectWriteForwarder.dll, version=6,0,222,6408 @Commit: fb76229895cae74c1adc62c2411a0730a2f3759b System.Diagnostics.Debug.dll .\System.Diagnostics.Debug.dll, version=6.0.222.6406 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) UIAutomationTypes.dll .\UIAutomationTypes.dll, version=6.0.222.6408 System.Diagnostics.FileVersionInfo.dll .\System.Diagnostics.FileVersionInfo.dll, version=6.0.222.6406 PaintDotNet.Effects.dll .\PaintDotNet.Effects.dll, version=4.308.8083.2561 profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800) clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) version.dll C:\WINDOWS\SYSTEM32\version.dll, version=10.0.19041.546 (WinBuild.160101.0800) Accessibility.dll .\Accessibility.dll, version=6.0.222.6407 System.Numerics.Vectors.dll .\System.Numerics.Vectors.dll, version=6.0.222.6406 comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800) Crc32.NET.dll .\Crc32.NET.dll, version=1.2.0.5 System.Security.Cryptography.Primitives.dll .\System.Security.Cryptography.Primitives.dll, version=6.0.222.6406 d2d1.dll C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.IO.Packaging.dll .\System.IO.Packaging.dll, version=6.0.222.6406 TextShaping.dll C:\WINDOWS\SYSTEM32\TextShaping.dll, version= System.Runtime.Loader.dll .\System.Runtime.Loader.dll, version=6.0.222.6406 System.Threading.Tasks.Parallel.dll .\System.Threading.Tasks.Parallel.dll, version=6.0.222.6406 System.Diagnostics.Tracing.dll .\System.Diagnostics.Tracing.dll, version=6.0.222.6406 ucrtbase.dll .\ucrtbase.dll, version=10.0.19041.685 (WinBuild.160101.0800) wtsapi32.dll C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.Reflection.MetadataLoadContext.dll .\System.Reflection.MetadataLoadContext.dll, version=6.0.21.52210 System.Reflection.Metadata.dll .\System.Reflection.Metadata.dll, version=6.0.222.6406 UIAutomationCore.dll C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.1 (WinBuild.160101.0800) d3d11.dll C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.1202 (WinBuild.160101.0800) System.IO.MemoryMappedFiles.dll .\System.IO.MemoryMappedFiles.dll, version=6.0.222.6406 D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800) sxs.dll C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800) CSVFiletype.dll .\FileTypes\CSVFiletype.dll, version=1.0.0.0 dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1151 (WinBuild.160101.0800) ABRFileType.dll .\FileTypes\ABRFileType.dll, version=1.0.0.1 ImSVG.Open.FileType.dll .\FileTypes\ImSVG.Open.FileType.dll, version=0.18.0.0 IcoCur.dll .\FileTypes\IcoCur.dll, version=4.0.1.0 mscorlib.dll .\mscorlib.dll, version=6.0.222.6406 System.Drawing.dll .\System.Drawing.dll, version=6.0.222.6407 System.dll .\System.dll, version=6.0.222.6406 mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800) AvifFileType.dll .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.18.0 DdsFileTypePlus.dll .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.11.0 CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) WebPFileType.dll .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.11.0 WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.1320 (WinBuild.160101.0800) Microsoft.DiaSymReader.Native.amd64.dll .\Microsoft.DiaSymReader.Native.amd64.dll, version=14.28.29715.1 built by: vcwrkspc System.Runtime.Serialization.Formatters.dll .\System.Runtime.Serialization.Formatters.dll, version=6.0.222.6406 System.Diagnostics.StackTrace.dll .\System.Diagnostics.StackTrace.dll, version=6.0.222.6406 System.CodeDom.dll .\System.CodeDom.dll, version=6.0.222.6406 dwmapi.DLL C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) Mono.Cecil.dll .\Mono.Cecil.dll, version=0.11.4.0 dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1387 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.1387 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) netstandard.dll .\netstandard.dll, version=6.0.222.6406 textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.1503 (WinBuild.160101.0800) CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 CoreMessaging.dll C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800) ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= System.Text.RegularExpressions.dll .\System.Text.RegularExpressions.dll, version=6.0.222.6406 Newtonsoft.Json.dll .\Newtonsoft.Json.dll, version=13.0.1.25517 System.Linq.Expressions.dll .\System.Linq.Expressions.dll, version=6.0.222.6406 System.Runtime.Numerics.dll .\System.Runtime.Numerics.dll, version=6.0.222.6406 winmm.DLL C:\WINDOWS\SYSTEM32\winmm.DLL, version=10.0.19041.1 (WinBuild.160101.0800) System.Runtime.CompilerServices.Unsafe.dll .\System.Runtime.CompilerServices.Unsafe.dll, version=6.0.222.6406 oleacc.dll C:\WINDOWS\SYSTEM32\oleacc.dll, version=7.2.19041.746 (WinBuild.160101.0800) explorerframe.dll C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.1 (WinBuild.160101.0800) igd10iumd64.dll C:\WINDOWS\SYSTEM32\igd10iumd64.dll, version=20.19.15.4531 ncrypt.dll C:\WINDOWS\SYSTEM32\ncrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) NTASN1.dll C:\WINDOWS\SYSTEM32\NTASN1.dll, version=10.0.19041.1 (WinBuild.160101.0800) igdusc64.dll C:\WINDOWS\SYSTEM32\igdusc64.dll, version=20.19.15.4531 PaintDotNet.Plugins.Compatibility.dll .\PaintDotNet.Plugins.Compatibility.dll, version=4.308.8083.2561 System.Console.dll .\System.Console.dll, version=6.0.222.6406 Vandermotten.PaintDotNetEffects.ObjectAlign.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=4.3.0.0 Vandermotten.PaintDotNetEffects.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, version=4.3.0.0 System.Resources.Extensions.dll .\System.Resources.Extensions.dll, version=6.0.222.6406 Vandermotten.PaintDotNetEffects.Monochromes.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version=4.3.0.0 Vandermotten.PaintDotNetEffects.MakeTransparent.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, version=4.3.0.0 Vandermotten.PaintDotNetEffects.Grid.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, version=4.3.0.0 Vandermotten.PaintDotNetEffects.Gradient.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=4.3.0.0 Vandermotten.PaintDotNetEffects.FadeEdge.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version=4.3.0.0 Vandermotten.PaintDotNetEffects.Duotones.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version=4.3.0.0 Vandermotten.PaintDotNetEffects.DropShadow.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=4.3.0.0 amsi.dll C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.19041.746 (WinBuild.160101.0800) Vandermotten.PaintDotNetEffects.ColorAccent.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version=4.3.0.0 USERENV.dll C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800) symamsi.dll C:\Program Files (x86)\Norton AntiVirus\Engine\22.20.5.39\symamsi.dll, version=15.7.10.10 WINTRUST.dll C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.1503 (WinBuild.160101.0800) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800) MSASN1.dll C:\WINDOWS\SYSTEM32\MSASN1.dll, version=10.0.19041.546 (WinBuild.160101.0800) AMSIExt.dll C:\Program Files\McAfee\MfeAV\AMSIExt.dll, version=24.5.111 55f19358 slippery pie PSAPI.DLL C:\WINDOWS\System32\PSAPI.DLL, version=10.0.19041.546 (WinBuild.160101.0800) Vandermotten.PaintDotNetEffects.Blurs.dll C:\Users\Michael\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=4.3.0.0 ZoomBlurDeluxeCL.dll .\Effects\ZoomBlurDeluxeCL.dll, version=1.0.5709.38898 ZoomBlurDeluxe.dll .\Effects\ZoomBlurDeluxe.dll, version=1.0.0.0 WindowSizeTest.dll .\Effects\WindowSizeTest.dll, version=1.0.7013.27531 WaveTextSUI.dll .\Effects\WaveTextSUI.dll, version=1.2.4415.33440 WaveText.dll .\Effects\WaveText.dll, version=1.2.4415.32811 ViewFramer.dll .\Effects\ViewFramer.dll, version=1.0.6074.42436 Vanishing Trails.dll .\Effects\Vanishing Trails.dll, version=2.0.0.0 UnselectedRectangleKeeper.dll .\Effects\UnselectedRectangleKeeper.dll, version=1.0.5669.36271 UIExamples.dll .\Effects\UIExamples.dll, version=1.0.6584.1918 TwoToneThreshold.dll .\Effects\TwoToneThreshold.dll, version=1.0.0.0 TwoColorMixer.dll .\Effects\TwoColorMixer.dll, version=1.1.5616.26437 Twist.dll .\Effects\Twist.dll, version=4.0.4642.26767 System.Core.dll .\System.Core.dll, version=6.0.222.6406 TRsTreeMaker.dll .\Effects\TRsTreeMaker.dll, version=1.0.3.0 TRsThirdDimension.dll .\Effects\TRsThirdDimension.dll, version=1.7.9.3072 TRsSplineMaster.dll .\Effects\TRsSplineMaster.dll, version=1.4.2.18310 trssnowflakemaker.dll .\Effects\trssnowflakemaker.dll, version=1.0.3.10409 TRsRadialExtruder.dll .\Effects\TRsRadialExtruder.dll, version=1.2.5609.8244 TRsPasteWarp.dll .\Effects\TRsPasteWarp.dll, version=1.0.0.0 CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) rsaenh.dll C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) CRYPTBASE.dll C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.19041.546 (WinBuild.160101.0800) imagehlp.dll C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.1415 (WinBuild.160101.0800) TRsMonolithic.dll .\Effects\TRsMonolithic.dll, version=1.0.4.12960 TRsFireWorks.dll .\Effects\TRsFireWorks.dll, version=1.2.0.0 TRsDrumSkin.dll .\Effects\TRsDrumSkin.dll, version=1.4.5199.15427 TRsDodgeBurn.dll .\Effects\TRsDodgeBurn.dll, version=1.4.0.33503 TRsDodgeBurn.resources.dll .\Effects\TRsDodgeBurn.resources.dll, version=1.3.26.12436 TRsCustomRandomFill.dll .\Effects\TRsCustomRandomFill.dll, version=1.5.1.38287 TRsCustomPaletteMatch.dll .\Effects\TRsCustomPaletteMatch.dll, version=1.0.5.0 TRsAlphaCutter.dll .\Effects\TRsAlphaCutter.dll, version=3.0.4.0 gpapi.dll C:\WINDOWS\SYSTEM32\gpapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) TRDistortMap3D.dll .\Effects\TRDistortMap3D.dll, version=1.0.5550.23545 TransparentToTransparentWhite.dll .\Effects\TransparentToTransparentWhite.dll, version=1.0.6963.30396 TransparentToTransparentBlack.dll .\Effects\TransparentToTransparentBlack.dll, version=1.0.6479.25661 Trail.dll .\Effects\Trail.dll, version=4.0.4642.26791 Trail Blur.dll .\Effects\Trail Blur.dll, version=1.0.0.0 TJacksonEffects.dll .\Effects\TJacksonEffects.dll, version=1.0.0.0 TileWorld.dll .\Effects\TileWorld.dll, version=1.0.0.0 ThatOtherApp.dll .\Effects\ThatOtherApp.dll, version=2.2.0.0 System.Windows.Forms.Legacy.dll .\System.Windows.Forms.Legacy.dll, version=0.1.1.0 vtploader.dll C:\Program Files\Common Files\McAfee\Platform\core\vtploader.dll, version=13,4,108,0 cryptnet.dll C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.19041.906 (WinBuild.160101.0800) mfevtpa.dll C:\Program Files\Common Files\McAfee\SystemCore\mfevtpa.dll, version=SYSCORE.21.4.0.163 mfehida.dll C:\Program Files\Common Files\McAfee\SystemCore\mfehida.dll, version=SYSCORE.21.4.0.163 mfemmsa.dll C:\Program Files\Common Files\McAfee\SystemCore\mfemmsa.dll, version=SYSCORE.21.4.0.163 AA's_Assistant.dll .\Effects\AA's_Assistant.dll, version=1.1.4329.33034 Aardvark.dll .\Effects\Aardvark.dll, version=1.0.5.0 Advanced_Kaleidoscope.dll .\Effects\Advanced_Kaleidoscope.dll, version=1.0.7194.37638 Alpha-Displacement Mask.dll .\Effects\Alpha-Displacement Mask.dll, version=1.4.1.1 AlphaThreshold.dll .\Effects\AlphaThreshold.dll, version=1.0.0.0 Alpha_to_0.dll .\Effects\Alpha_to_0.dll, version=1.0.4452.22746 Alpha_to_255.dll .\Effects\Alpha_to_255.dll, version=1.0.4452.22782 Align.dll .\Effects\Align.dll, version=1.0.0.1 Angled Gradient.dll .\Effects\Angled Gradient.dll, version=1.0.6166.41233 AntialiasTest.dll .\Effects\AntialiasTest.dll, version=1.0.5719.38547 Archimedean Spiral.dll .\Effects\Archimedean Spiral.dll, version=1.0.0.0 ArtyThing.dll .\Effects\ArtyThing.dll, version=1.0.5.0 Average Object Color.dll .\Effects\Average Object Color.dll, version=1.0.6242.23734 AverageObjectColor.dll .\Effects\AverageObjectColor.dll, version=1.1.6241.40360 AverageSelectionColor.dll .\Effects\AverageSelectionColor.dll, version=1.0.5641.22197 Basic Clipboard Transformations.dll .\Effects\Basic Clipboard Transformations.dll, version=1.0.6242.42182 BasicAntialias.dll .\Effects\BasicAntialias.dll, version=1.0.6164.34111 BBOutlinedGradientText.dll .\Effects\BBOutlinedGradientText.dll, version=4.6.7358.38713 BevelObject.dll .\Effects\BevelObject.dll, version=1.0.1.0 Bezncurve.dll .\Effects\Bezncurve.dll, version=1.0.0.0 BilinearTest.dll .\Effects\BilinearTest.dll, version=1.0.5719.29019 BlackandAlpha+.dll .\Effects\BlackandAlpha+.dll, version=1.2.4329.272 Borders N' Shapes.dll .\Effects\Borders N' Shapes.dll, version=4.0.4642.26476 Calendar.dll .\Effects\Calendar.dll, version=4.6.7358.32649 BBChart.dll .\Effects\BBChart.dll, version=1.0.7358.33924 CalliColour.dll .\Effects\CalliColour.dll, version=1.0.1.0 BlackAndWhite+.dll .\Effects\BlackAndWhite+.dll, version=1.1.6744.2631 CellMaker.dll .\Effects\CellMaker.dll, version=1.1.6139.29120 CellTexture.dll .\Effects\CellTexture.dll, version=1.0.0.0 CircleText.dll .\Effects\CircleText.dll, version=1.4.4415.32488 ClampedGaussianBlur.dll .\Effects\ClampedGaussianBlur.dll, version=2.0.0.0 Clipboard Selection Test.dll .\Effects\Clipboard Selection Test.dll, version=1.0.7863.822 ClipWarpNew.dll .\Effects\ClipWarpNew.dll, version=1.0.1.0 ClipDisplaceAA.dll .\Effects\ClipDisplaceAA.dll, version=1.2.4.0 CloudDisplacement.dll .\Effects\CloudDisplacement.dll, version=1.0.5493.27534 Cobweb.dll .\Effects\Cobweb.dll, version=1.0.1.0 CloudEffect.dll .\Effects\CloudEffect.dll, version=1.1.0.0 Color Match.dll .\Effects\Color Match.dll, version=4.0.4642.26532 ColorClearer.dll .\Effects\ColorClearer.dll, version=1.1.6009.41762 Compotool.dll .\Effects\Compotool.dll, version=1.0.1.0 CodeLab.dll .\Effects\CodeLab.dll, version=6.4.7995.19949 Contour.dll .\Effects\Contour.dll, version=1.0.1.0 ContentAwareFill.dll .\Effects\ContentAwareFill.dll, version=1.1.0.0 CountNonWhitePixels.dll .\Effects\CountNonWhitePixels.dll, version=1.0.5677.2063 CountSelectedPixels.dll .\Effects\CountSelectedPixels.dll, version=1.0.5677.2584 CurlyLines.dll .\Effects\CurlyLines.dll, version=1.0.0.0 DeFisheye.dll .\Effects\DeFisheye.dll, version=1.0.6483.24639 Dimensions.dll .\Effects\Dimensions.dll, version=1.3.6826.38472 Displacement.dll .\Effects\Displacement.dll, version=1.1.0.0 DisplayColorChangeDirection.dll .\Effects\DisplayColorChangeDirection.dll, version=2.0.5621.37825 DisplayColorDifferenceChange.dll .\Effects\DisplayColorDifferenceChange.dll, version=1.0.5800.33546 DistortThis.dll .\Effects\DistortThis.dll, version=2.7.0.0 dpyColorBalance.dll .\Effects\dpyColorBalance.dll, version=1.1.4330.37850 DragFrom.dll .\Effects\DragFrom.dll, version=1.1.0.0 Droste.dll .\Effects\Droste.dll, version=1.1.0.0 Dryad.dll .\Effects\Dryad.dll, version=1.0.1.0 CreativeTextPro.dll .\Effects\CreativeTextPro.dll, version=1.1.7358.34307 EarthsAndGreys.dll .\Effects\EarthsAndGreys.dll, version=1.0.1.0 Edge Antialias Test.dll .\Effects\Edge Antialias Test.dll, version=1.0.7455.535 Edge Shader Test.dll .\Effects\Edge Shader Test.dll, version=1.0.1.0 EdgeDetector.dll .\Effects\EdgeDetector.dll, version=1.0.5626.32775 EdgeExpander.dll .\Effects\EdgeExpander.dll, version=1.0.5863.38192 Edge Shader.dll .\Effects\Edge Shader.dll, version=1.0.1.0 Equirectangular Diffuse Transform Exact.dll .\Effects\Equirectangular Diffuse Transform Exact.dll, version=1.0.7114.4176 Equirectangular Diffuse Transform.dll .\Effects\Equirectangular Diffuse Transform.dll, version=1.0.7159.445 Curves+.dll .\Effects\Curves+.dll, version=4.0.4642.26561 Equirectangular Viewer.dll .\Effects\Equirectangular Viewer.dll, version=1.1.0.32613 Film.dll .\Effects\Film.dll, version=4.0.4642.26607 FindEdges.dll .\Effects\FindEdges.dll, version=1.2.0.0 FishEyeAntialias.dll .\Effects\FishEyeAntialias.dll, version=1.0.5540.25286 FisheyeTest.dll .\Effects\FisheyeTest.dll, version=1.0.6484.351 Flourish.dll .\Effects\Flourish.dll, version=1.0.2.0 FloodFill Test.dll .\Effects\FloodFill Test.dll, version=1.0.6170.2244 FurBlur.dll .\Effects\FurBlur.dll, version=1.0.1.0 Flip.dll .\Effects\Flip.dll, version=4.6.7358.36953 GaussianBlurPlus.dll .\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401 GaussianBlurPP.dll .\Effects\GaussianBlurPP.dll, version=4.1.5687.39957 GaussianBrightnessContrast.dll .\Effects\GaussianBrightnessContrast.dll, version=1.0.5797.40273 Gears.dll .\Effects\Gears.dll, version=1.0.2.0 Gmic.dll .\Effects\Gmic.dll, version=1.2.1.0 Gradient Bars.dll .\Effects\Gradient Bars.dll, version=4.0.5152.23084 Gradient Blocks.dll .\Effects\Gradient Blocks.dll, version=4.0.4642.26658 GradientsGalore.dll .\Effects\GradientsGalore.dll, version=1.0.2.0 GraphParabolas.dll .\Effects\GraphParabolas.dll, version=1.0.5843.29999 GraphQuadAndCubicAdj.dll .\Effects\GraphQuadAndCubicAdj.dll, version=1.0.6246.24680 Gradient Mapping.dll .\Effects\Gradient Mapping.dll, version=4.0.4642.26687 GraphSine.dll .\Effects\GraphSine.dll, version=1.0.5813.34527 Gravity.dll .\Effects\Gravity.dll, version=1.1.0.0 GridCheckerboard.dll .\Effects\GridCheckerboard.dll, version=4.5.6828.36789 Heightmap v1.3.dll .\Effects\Heightmap v1.3.dll, version=1.3.4261.22267 Helix.dll .\Effects\Helix.dll, version=1.0.1.0 Grid Warp.dll .\Effects\Grid Warp.dll, version=4.0.6544.34496 HexaGrid.dll .\Effects\HexaGrid.dll, version=1.2.0.0 Highlight.dll .\Effects\Highlight.dll, version=1.0.1.0 HotMetalGlow.dll .\Effects\HotMetalGlow.dll, version=1.2.5985.32923 HSVEraser.dll .\Effects\HSVEraser.dll, version=1.0.5800.36672 HsvRecolorer.dll .\Effects\HsvRecolorer.dll, version=1.0.5810.40990 HsvScrambler.dll .\Effects\HsvScrambler.dll, version=1.0.5675.38066 InsetBoxShadow.dll .\Effects\InsetBoxShadow.dll, version=1.0.0.0 Jitter.dll .\Effects\Jitter.dll, version=4.0.4642.26986 LaplacianPyramidFilter.dll .\Effects\LaplacianPyramidFilter.dll, version=1.0.3.0 LabelPixelColors.dll .\Effects\LabelPixelColors.dll, version=1.0.0.0 LightRays.dll .\Effects\LightRays.dll, version=2.1.5.0 jchunn.dll .\Effects\jchunn.dll, version=1.0.0.0 Microsoft.VisualBasic.dll .\Microsoft.VisualBasic.dll, version=6.0.222.6407 Microsoft.VisualBasic.Forms.dll .\Microsoft.VisualBasic.Forms.dll, version=6.0.222.6407 Linearly Tile From Clipboard.dll .\Effects\Linearly Tile From Clipboard.dll, version=1.0.6789.43109 MakeTransparent.dll .\Effects\MakeTransparent.dll, version=1.0.0.0 Mandelbrot Plus.dll .\Effects\Mandelbrot Plus.dll, version=1.0.6245.41754 MemeMaker.dll .\Effects\MemeMaker.dll, version=4.5.6828.38061 Metallize.dll .\Effects\Metallize.dll, version=1.2.4415.32969 MidpointDisplacementTest.dll .\Effects\MidpointDisplacementTest.dll, version=1.0.5986.26909 Mise En Abyme.dll .\Effects\Mise En Abyme.dll, version=1.1.0.0 MismatchEraser.dll .\Effects\MismatchEraser.dll, version=1.0.6920.41978 Monet.dll .\Effects\Monet.dll, version=1.0.5499.36110 Liquify.dll .\Effects\Liquify.dll, version=4.0.4642.26973 MoveRectangle.dll .\Effects\MoveRectangle.dll, version=1.0.6477.2565 MultiThreshold.dll .\Effects\MultiThreshold.dll, version=1.1.4330.38982 Neighbor Blur.dll .\Effects\Neighbor Blur.dll, version=1.0.6738.24032 NoiseChoice.dll .\Effects\NoiseChoice.dll, version=1.0.1.0 NonBlackToAlpha.dll .\Effects\NonBlackToAlpha.dll, version=1.0.5557.34844 Object Pruner.dll .\Effects\Object Pruner.dll, version=1.0.1.0 Object2Colour.dll .\Effects\Object2Colour.dll, version=1.0.1.0 Objectedge.dll .\Effects\Objectedge.dll, version=1.0.1.0 ObjectShadowPro.dll .\Effects\ObjectShadowPro.dll, version=1.0.7421.614 OffsetAlternatingStripes.dll .\Effects\OffsetAlternatingStripes.dll, version=1.0.6025.41452 OilPaintingPlus.dll .\Effects\OilPaintingPlus.dll, version=4.6.7358.38406 Olden.dll .\Effects\Olden.dll, version=1.5.0.0 OldFeather.dll .\Effects\OldFeather.dll, version=2.3.4315.37038 Otsu.dll .\Effects\Otsu.dll, version=1.2.6051.11025 Outline Object.dll .\Effects\Outline Object.dll, version=4.0.4642.26954 Overblur.dll .\Effects\Overblur.dll, version=1.0.1.0 PasteAlphaPlus.dll .\Effects\PasteAlphaPlus.dll, version=1.0.6451.40672 Perspective.dll .\Effects\Perspective.dll, version=2.1.4415.36116 PerspectiveTransformation.dll .\Effects\PerspectiveTransformation.dll, version=1.2.5795.41799 PasteFromClipboard.dll .\Effects\PasteFromClipboard.dll, version=2.0.1.0 Pixelate+.dll .\Effects\Pixelate+.dll, version=4.0.4642.26940 Planetoid.dll .\Effects\Planetoid.dll, version=1.0.2.0 PNG_Preprocessor.dll .\Effects\PNG_Preprocessor.dll, version=1.0.3876.32360 PointBlur.dll .\Effects\PointBlur.dll, version=1.0.0.0 Polar.dll .\Effects\Polar.dll, version=1.1.1.0 Paste Warp Plus.dll .\Effects\Paste Warp Plus.dll, version=1.1.0.0 PrinterPlus.dll .\Effects\PrinterPlus.dll, version=1.5.0.0 Psychocolour.dll .\Effects\Psychocolour.dll, version=1.0.1.0 pxEexpansion.dll .\Effects\pxEexpansion.dll, version=1.0.4437.36287 RadialSlicer.dll .\Effects\RadialSlicer.dll, version=1.0.6059.41294 Random Shape Fill.dll .\Effects\Random Shape Fill.dll, version=4.0.4642.26910 Randomize Object Color.dll .\Effects\Randomize Object Color.dll, version=1.0.6298.4733 Recolor Using Palette.dll .\Effects\Recolor Using Palette.dll, version=1.0.6382.573 QuadrilateralCorrection.dll .\Effects\QuadrilateralCorrection.dll, version=1.0.0.0 RecolourChoice.dll .\Effects\RecolourChoice.dll, version=1.0.1.0 RectangleEraser.dll .\Effects\RectangleEraser.dll, version=1.0.5630.22007 RectangleToArchimedeanSpiral.dll .\Effects\RectangleToArchimedeanSpiral.dll, version=1.0.7623.289 RemoveStamp2.dll .\Effects\RemoveStamp2.dll, version=1.0.5490.41603 Render Gray Scale.dll .\Effects\Render Gray Scale.dll, version=1.0.0.0 RenderSphereHeightMap.dll .\Effects\RenderSphereHeightMap.dll, version=1.0.6145.37460 ReplaceBackgroundColor.dll .\Effects\ReplaceBackgroundColor.dll, version=1.0.5622.40133 Replace Colors.dll .\Effects\Replace Colors.dll, version=1.1.5767.26297 RotateText.dll .\Effects\RotateText.dll, version=1.1.4415.32628 RotateTextSUI.dll .\Effects\RotateTextSUI.dll, version=1.1.4415.32713 Rotate_Zoom+.dll .\Effects\Rotate_Zoom+.dll, version=1.11.5237.17779 Scintillate.dll .\Effects\Scintillate.dll, version=1.0.1.0 RotateZoomPlus.dll .\Effects\RotateZoomPlus.dll, version=1.0.5979.31043 RotateZoomDeluxe.dll .\Effects\RotateZoomDeluxe.dll, version=1.0.7594.3020 Scribble.dll .\Effects\Scribble.dll, version=1.0.1.0 ScribbleIntermediate.dll .\Effects\ScribbleIntermediate.dll, version=1.0.1.0 Selection2Clear.dll .\Effects\Selection2Clear.dll, version=1.0.1.0 ShadowEffect.dll .\Effects\ShadowEffect.dll, version=1.2.0.0 Shape3D.dll .\Effects\Shape3D.dll, version=1.2.6.2 Shapes.dll .\Effects\Shapes.dll, version=1.6.5.0 Slinky.dll .\Effects\Slinky.dll, version=1.0.1.0 shapemaker.dll .\Effects\shapemaker.dll, version=1.3.9.1 SpeechBubble.dll .\Effects\SpeechBubble.dll, version=2.1.4445.42029 Sparkles.dll .\Effects\Sparkles.dll, version=1.1.0.0 SpiralText.dll .\Effects\SpiralText.dll, version=1.4.4415.32775 SpotRemover.dll .\Effects\SpotRemover.dll, version=1.0.5716.23929 Squirkle.dll .\Effects\Squirkle.dll, version=1.0.1.0 SquirkleWarp.dll .\Effects\SquirkleWarp.dll, version=1.0.1.0 Smudge.dll .\Effects\Smudge.dll, version=4.0.4642.26844 Stitch.dll .\Effects\Stitch.dll, version=4.0.4642.26808 Splatter.dll .\Effects\Splatter.dll, version=4.0.4642.26829 StrayPixelRemover.dll .\Effects\StrayPixelRemover.dll, version=1.0.0.0 StringAndPin.dll .\Effects\StringAndPin.dll, version=1.0.1.0 Tartan.dll .\Effects\Tartan.dll, version=1.1.0.0 Textplus.dll .\Effects\Textplus.dll, version=1.0.0.0 Texture Object Rounder.dll .\Effects\Texture Object Rounder.dll, version=1.0.7012.43139 Texture Scaler.dll .\Effects\Texture Scaler.dll, version=1.2.6431.28257 TextureAdder.dll .\Effects\TextureAdder.dll, version=1.0.5832.39552 Texture Edge Shader.dll .\Effects\Texture Edge Shader.dll, version=1.0.7776.42842 TextureMerger.dll .\Effects\TextureMerger.dll, version=1.1.6167.3701 TextureShader.dll .\Effects\TextureShader.dll, version=2.3.0.0 TextureShaderCompatible.dll .\Effects\TextureShaderCompatible.dll, version=1.0.5657.33215 TextureSmoother.dll .\Effects\TextureSmoother.dll, version=1.0.6096.31689 TextureViewSkewer.dll .\Effects\TextureViewSkewer.dll, version=1.0.5714.24733 TGMagnitude.dll .\Effects\TGMagnitude.dll, version=1.0.2.0 System.Design.dll .\System.Design.dll, version=6.0.222.6407 System.Windows.Forms.Design.dll .\System.Windows.Forms.Design.dll, version=6.0.222.6407 System.IO.FileSystem.dll .\System.IO.FileSystem.dll, version=6.0.222.6406 System.Threading.Tasks.dll .\System.Threading.Tasks.dll, version=6.0.222.6406 System.Xml.XDocument.dll .\System.Xml.XDocument.dll, version=6.0.222.6406 System.Private.Xml.Linq.dll .\System.Private.Xml.Linq.dll, version=6.0.222.6406 System.IO.Compression.dll .\System.IO.Compression.dll, version=6.0.222.6406 System.Security.Cryptography.Algorithms.dll .\System.Security.Cryptography.Algorithms.dll, version=6.0.222.6406 K4os.Compression.LZ4.dll .\K4os.Compression.LZ4.dll, version=1.2.15 PresentationFramework-SystemXmlLinq.dll .\PresentationFramework-SystemXmlLinq.dll, version=6.0.222.6408 System.Xml.Linq.dll .\System.Xml.Linq.dll, version=6.0.222.6406 XmlLite.dll C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.546 (WinBuild.160101.0800) setupapi.DLL C:\WINDOWS\System32\setupapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) DEVOBJ.dll C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.1151 (WinBuild.160101.0800) Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 19, 2022 Share Posted February 19, 2022 I'm not reproducing this over on my side -- can you post screenshots? A video might be helpful too. I would also try making sure your GPU driver is updated. Intel HD 4600 is pretty old, although Windows Update will sometimes update the GPU driver automatically, so this may or may not matter. There are often rendering differences between GPU and CPU rendering for the canvas, it just depends on what the driver does with the high-level drawing instructions from Direct2D. The 50% fill pattern is also a strange one when it comes to zooming out; the aliasing gets mangled in weird ways with the mip mapping For instance, when the canvas is filled with the 50% pattern, and you get just the right zoom level (not exactly 50%, but close to it, via Zoom to Window enabled), it looks like this: Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 19, 2022 Share Posted February 19, 2022 Also, the GPU driver is a prime suspect here because 1) things look different w/ GPU acceleration disabled, and 2) at certain zoom levels, the canvas is actually rendered using two mip map layers but they're blended together using a custom pixel shader. If your GPU or GPU driver doesn't handle shaders, or at least that shader, properly (not uncommon FYI), it might visually break things. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Kamikaze Posted February 19, 2022 Share Posted February 19, 2022 Rick if everyone was on the ball like you this world would be a more efficient place.. Thank you.. Quote Link to comment Share on other sites More sharing options...
MJW Posted February 19, 2022 Author Share Posted February 19, 2022 The first image with hardware acceleration. The bottom three rectangles are the solid colors that approximately match the non-accelerated 50%-fill color, the normal accelerated 50%-fill color, and the accelerated 50%-fill color outside a selection, and after the selection has been cleared. The small rectangle in the upper region is the region that was selected. The remainder of the upper region is the area that was outside the selection. In the darker region, the color of "black" is 120,120,120, while "white" is 134,134,134. In the lighter region, the color of "black" is 37,37,37, while "white" is 217,217,217. In both cases, "white" plus "black" is 254,254,254. For the non-accelerated version, "black" is black, and "white" is white. The second image without hardware acceleration. Quote Link to comment Share on other sites More sharing options...
MJW Posted February 19, 2022 Author Share Posted February 19, 2022 This is a 1400% magnified screenshot of a four-by-four checkerboard with HW acceleration. Quote Link to comment Share on other sites More sharing options...
