wacher Posted February 15, 2022 Share Posted February 15, 2022 When you use Layers->Rotate/Zoom to rotate you can select Preserve Background, is it possible when using Move Selected Pixels and right mouse button to rotate? Quote Link to comment Share on other sites More sharing options...
MJW Posted February 15, 2022 Share Posted February 15, 2022 No. You'll need copy-and-paste the selected pixels into a new layer to do that. I suppose another method is to first duplicate the layer, do the rotation in the upper layer, then merge the two layers. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 15, 2022 Share Posted February 15, 2022 There's a workaround. After switching to the Move Selected Pixels tool, Ctrl+Click anywhere. You'll see a new history entry for Move Selected Pixels, but nothing will happen. Then you can rotate the copy. edit: Actually you shouldn't need to Ctrl+Click. Should work fine if you just hold down Ctrl while doing that first rotate (or any other type of transform action). 2 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
MJW Posted February 16, 2022 Share Posted February 16, 2022 Shows what I know. Holding down Ctrl works perfectly. Not even really a "workaround" since it's so easy and does exactly what's desired. Quote Link to comment Share on other sites More sharing options...
Solution Ego Eram Reputo Posted February 16, 2022 Solution Share Posted February 16, 2022 From the Docs.... https://www.getpaint.net/doc/latest/MoveTools.html#12 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
