Pog cat king Posted January 10, 2022 Share Posted January 10, 2022 Hello, my friend has problem with installing Paint.net and this is what it showed what does it mean and how to fix that? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 10, 2022 Share Posted January 10, 2022 51 minutes ago, Pog cat king said: what does it mean Paint.NET tried to download the latest version and for some reason that download failed. 51 minutes ago, Pog cat king said: how to fix that? There are lots of things that could be wrong. Your internet is not connected (Check your connection--are you able to visit other sites) Your virus scanner is blocking internet access for Paint.NET (add Paint.NET to your virus software white list) And... less likely... Your Windows is broken (run "SFC /scannow") Also, you could download the latest version manually (link in upper right corner of this page): https://www.dotpdn.com/downloads/pdn.html Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Pog cat king Posted January 13, 2022 Author Share Posted January 13, 2022 Thx Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 13, 2022 Share Posted January 13, 2022 Looks like it was trying to download some prerequisites that you normally would already have gotten through Windows Update. Maybe it's a fresh install of Windows 7? Make sure you're up-to-date with Windows Update. Also, and I highly recommend this, don't use Windows 7 or 8.1. Upgrade to Windows 10/11. Paint.NET will not be supporting Win7 or 8.1 in the near future ("support" as in "it won't work at all"). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
