Gapple Posted January 6, 2022 Share Posted January 6, 2022 System.AggregateException: One or more errors occurred. ---> System.TypelnitializationException: The type initializer for 'PaintDotNet.Tools.Tool' threw an exception.--> System.BadimageFormatException: Could not load file or assembly 'Windows Base, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 or one of its dependencies. The module was expected to contain an assembly manifest. at PaintDotNet.Tools.Tool..cctor --- End of inner exception stack trace --- at PaintDotNet.Settings.App.AppSettings.Tools Section..ctor(String pathPrefix) in D:\src\pdn\src\PaintDotNet\Settings\App\AppSettings.Tools.cs:line 327 at PaintDotNet.Settings.App.AppSettings.<>c_DisplayClass29_0.<.ctor>b_00 in D:\src\pdn\src\PaintDotNet\Settings\App\AppSettings.cs:line 112 at System.Threading.Tasks.Task 1.Innerinvoke( at System.Threading.Tasks.Task.Execute() -End of inner exception stack trace --- at System.Threading.Tasks.Task 1.GetResult Core(Boolean wait CompletionNotification) at PaintDotNet.Settings.App.AppSettings..ctor(SettingsStorageHandler storageHandler) in D:\src\pdn\src\PaintDotNet\Settings\App\AppSettings.cs:line 124 at PaintDotNet.Settings.App.AppSettings.Initialize(Settings StorageHandler storageHandler) in D:\src\pdn\src\PaintDotNet\Settings\App\AppSettings.cs:line 75 at PaintDotNet.Setup.SetupWizard.Mainimpl(String args) in D:\src\pdn\src\SetupFrontEnd SetupWizard.cs:line 917 at PaintDotNet.Setup.SetupWizard.Main(String args) in D:\src\pdn\src\SetupFrontEnd SetupWizard.cs:line 872 ---> (Inner Exception #0) System.TypelnitializationException: The type initializer for PaintDotNet.Tools.Tool threw an exception. ---> System.BadimageFormatException: Could not load file or assembly WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 or one of its dependencies. The module was expected to contain an assembly manifest. at PaintDotNet.Tools.Tool..cctor --- End of inner exception stack trace --- at PaintDotNet.Settings App.AppSettings.Tools Section..ctor(String pathPrefix) in DAsrc\pdn\src\PaintDotNet Settings\App\AppSettings.Tools.cs:line 327 at PaintDotNet Settings App AppSettings.<>c__DisplayClass29_0.<.ctor>b__00 in D:\src\pdn\src\PaintDotNet Settings\App\AppSettings.cs:line 112 at System.Threading.Tasks Task 1.innerinvoke() at System.Threading.Tasks.Task.Execute() <--- Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 6, 2022 Share Posted January 6, 2022 It looks like you're trying to install paint.net, but the .NET Framework is not working correctly on your computer. Please run Microsoft's .NET Framework Repair Tool. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 6, 2022 Share Posted January 6, 2022 .NET Framework is no longer part of the equation. You're either using an old version of the app, in which case you need to install 4.3.7, or your installation has somehow gotten mismatched or corrupted files. You can run the PdnRepair.exe program in the installation directory, which you can also invoke by running paintdotnet:/repair at the Run dialog (right click on Start button, then click on Run) You may also need to run chkdsk. See instructions over here Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 6, 2022 Share Posted January 6, 2022 37 minutes ago, Rick Brewster said: .NET Framework is no longer part of the equation. oops, I had thought the installer was still using .NET Framework. My mistake. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Pixey Posted January 6, 2022 Share Posted January 6, 2022 35 minutes ago, toe_head2001 said: oops, I had thought the installer was still using .NET Framework. My mistake Me too - now I learned something too Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 6, 2022 Share Posted January 6, 2022 1 hour ago, toe_head2001 said: oops, I had thought the installer was still using .NET Framework. My mistake. Yeah but the crash is from the app Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
otuncelli Posted January 6, 2022 Share Posted January 6, 2022 2 hours ago, Rick Brewster said: .NET Framework is no longer part of the equation. But there is an executable (SetupDownloader.exe) inside the installer which seems to be targeted against .NET Framework 2.0. Are you somehow running this executable on embedded .NET 6 runtime? I'm just curious to know. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 6, 2022 Share Posted January 6, 2022 Like I said, the stack trace is from the app. Has nothing to do w/ .NET Framework for this one. Actually, I take that back -- it's from the setup UI ("wizard"). Still, it's not using .NET Framework. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 6, 2022 Share Posted January 6, 2022 To clarify, SetupShim.exe is just a bootstrapper/chainer written in basic C. SetupDownloader.exe uses .NET Framework. It just checks prereqs and downloads things (including Paint.NET itself, when using the web installer). SetupFrontEnd.exe, which is the setup UI w/ the Paint.NET logo that actually installs Paint.NET, uses .NET 6 PaintDotNet.exe uses .NET 6 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
otuncelli Posted January 6, 2022 Share Posted January 6, 2022 Just now, Rick Brewster said: To clarify, SetupShim.exe is just a bootstrapper/chainer written in basic C. SetupDownloader.exe uses .NET Framework. It just checks prereqs and downloads things (including Paint.NET itself, when using the web installer). SetupFrontEnd.exe, which is the setup UI w/ the Paint.NET logo that actually installs Paint.NET, uses .NET 6 PaintDotNet.exe uses .NET 6 Thank you for clarification. Quote Link to comment Share on other sites More sharing options...
