Many problems with 4.3.6
Go to solution Solved by MarvelDream,
Paint.NET used to open pop-up windows in middle position but now it opens on left-top regardless of whether I moved the window's position before before reopening the same window.
Also, "New" pop-up message and possibly some others are broken as seen as the below screenshots.
Note that there's no Plugin Errors to get these.
Screenshots:
^Broken "New" pop-up message
^the additional pop-up message won't appear when saving an image with PNG Sprite Sheet Matrix
Diagnostics:
Spoiler
Application                                                  paint.net 4.3.6 (Stable 4.306.8039.8199)
Build Date                                                   2022년 1월 4일 화요일
Install type                                                 Classic
Hardware accelerated rendering (GPU)                         True
Animations                                                   True
DPI                                                          96 (1.00x scale)
Language                                                     en-US
OS                                                           Windows 11 Home x64 (10.0.22000.0)
Runtime                                                      .NET 6.0.1 x64
Physical Memory                                              15,668 MB
CPU                                                          AMD Ryzen 7 5700G with Radeon Graphics
    Speed                                                    ~3793 MHz
    Cores / Threads                                          8 / 16
    Features                                                 SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2
Pointer                                                      Virtual Multitouch Device
    Type                                                     ExternalPen
    Contacts                                                 1
Video Card                                                   AMD Radeon(TM) Graphics
    Dedicated Video RAM                                      496 MB
    Dedicated System RAM                                     0 MB
    Shared System RAM                                        7,834 MB
    Vendor ID                                                0x1002
    Device ID                                                0x1638
    Subsystem ID                                             0x88091043
    Revision                                                 200
    LUID                                                     0x00009BCE
    Flags                                                    AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                                      DmaBufferBoundary
    Compute Preemption                                       DmaBufferBoundary
    Outputs                                                  1
    Feature Level                                            Direct3D_12_1
    DXGI Formats                                             A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float
    Buffer Precision                                         UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc
Video Card                                                   Microsoft Basic Render Driver
    Dedicated Video RAM                                      0 MB
    Vendor ID                                                0x1414
    Device ID                                                0x008C
    Subsystem ID                                             0x00000000
    Revision                                                 0
    LUID                                                     0x0000A4A8
    Flags                                                    Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                                      InstructionBoundary
    Compute Preemption                                       InstructionBoundary
    Outputs                                                  0
Managed assemblies                                           148
    System.Private.CoreLib                                   .\System.Private.CoreLib.dll, Version=6.0.0.0, PublicKeyToken=7cec85d7bea7798e
    paintdotnet                                              .\paintdotnet.dll, Version=4.306.8039.8199
    System.Runtime                                           .\System.Runtime.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Base                                         .\PaintDotNet.Base.dll, Version=4.306.8039.8199
    System.Windows.Forms                                     .\System.Windows.Forms.dll, Version=6.0.1.0, PublicKeyToken=b77a5c561934e089
    System.Diagnostics.Process                               .\System.Diagnostics.Process.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    TerraFX.Interop.Windows                                  .\TerraFX.Interop.Windows.dll, Version=10.0.20348.0, PublicKeyToken=35b01b53313a6f7e
    PaintDotNet.SystemLayer                                  .\PaintDotNet.SystemLayer.dll, Version=4.306.8039.8199
    System.Runtime.InteropServices.RuntimeInformation        .\System.Runtime.InteropServices.RuntimeInformation.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.InteropServices                           .\System.Runtime.InteropServices.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.SystemLayer.Native.x64                       .\PaintDotNet.SystemLayer.Native.x64.dll, Version=4.306.8039.8199
    System.Threading                                         .\System.Threading.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Extensions                                .\System.Runtime.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.VisualC                  .\System.Runtime.CompilerServices.VisualC.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.NonGeneric                            .\System.Collections.NonGeneric.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Intrinsics                                .\System.Runtime.Intrinsics.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Collections.Concurrent                            .\System.Collections.Concurrent.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Core                                         .\PaintDotNet.Core.dll, Version=4.306.8039.8199
    System.Runtime.CompilerServices.Unsafe                   .\System.Runtime.CompilerServices.Unsafe.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Uri                                       .\System.Private.Uri.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.Primitives                         .\System.ComponentModel.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Windows.Forms.Primitives                          .\System.Windows.Forms.Primitives.dll, Version=6.0.1.0, PublicKeyToken=b77a5c561934e089
    WindowsBase                                              .\WindowsBase.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35
    System.Drawing.Primitives                                .\System.Drawing.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationFramework                                    .\PresentationFramework.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35
    System.Xaml                                              .\System.Xaml.dll, Version=6.0.1.0, PublicKeyToken=b77a5c561934e089
    System.ComponentModel                                    .\System.ComponentModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.TraceSource                           .\System.Diagnostics.TraceSource.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections                                       .\System.Collections.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Thread                                  .\System.Threading.Thread.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.CodePages                           .\System.Text.Encoding.CodePages.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Resources                                    .\PaintDotNet.Resources.dll, Version=4.306.8039.8199
    System.ObjectModel                                       .\System.ObjectModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Primitives                               .\Microsoft.Win32.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Data                                         .\PaintDotNet.Data.dll, Version=4.306.8039.8199
    System.Collections.Immutable                             .\System.Collections.Immutable.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Framework                                    .\PaintDotNet.Framework.dll, Version=4.306.8039.8199
    System.Drawing.Common                                    .\System.Drawing.Common.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Microsoft.Win32.SystemEvents                             .\Microsoft.Win32.SystemEvents.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Configuration.ConfigurationManager                .\System.Configuration.ConfigurationManager.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Collections.Specialized                           .\System.Collections.Specialized.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xml.ReaderWriter                                  .\System.Xml.ReaderWriter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Xml                                       .\System.Private.Xml.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Threading.ThreadPool                              .\System.Threading.ThreadPool.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.WebClient                                     .\System.Net.WebClient.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.ComponentModel.EventBasedAsync                    .\System.ComponentModel.EventBasedAsync.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Linq                                              .\System.Linq.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Memory                                            .\System.Memory.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Text.Encoding.Extensions                          .\System.Text.Encoding.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Registry                                 .\Microsoft.Win32.Registry.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Principal.Windows                        .\System.Security.Principal.Windows.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Claims                                   .\System.Security.Claims.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.TypeConverter                      .\System.ComponentModel.TypeConverter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationCore                                         .\PresentationCore.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35
    DirectWriteForwarder                                     .\DirectWriteForwarder.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35
    System.Diagnostics.Debug                                 .\System.Diagnostics.Debug.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    UIAutomationTypes                                        .\UIAutomationTypes.dll, Version=6.0.1.0, PublicKeyToken=31bf3856ad364e35
    System.Diagnostics.FileVersionInfo                       .\System.Diagnostics.FileVersionInfo.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects                                      .\PaintDotNet.Effects.dll, Version=4.306.8039.8199
    Accessibility                                            .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Numerics.Vectors                                  .\System.Numerics.Vectors.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Tasks.Parallel                          .\System.Threading.Tasks.Parallel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.Tracing                               .\System.Diagnostics.Tracing.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Reflection.MetadataLoadContext                    .\System.Reflection.MetadataLoadContext.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Reflection.Metadata                               .\System.Reflection.Metadata.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.MemoryMappedFiles                              .\System.IO.MemoryMappedFiles.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.Packaging                                      .\System.IO.Packaging.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Loader                                    .\System.Runtime.Loader.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    OptiPngFileType                                          .\FileTypes\OptiPngFileType.dll, Version=11.0.0.0
    AnimGIF                                                  .\FileTypes\AnimGIF.dll, Version=2.4.4119.28305
    PhotoShop                                                .\FileTypes\PhotoShop.dll, Version=2.5.0.40665
    SpriteSheet                                              .\FileTypes\SpriteSheet.dll, Version=1.2.2.0
    LowColor                                                 .\FileTypes\LowColor.dll, Version=1.0.4.0
    PNGSpriteMatrix                                          .\FileTypes\PNGSpriteMatrix.dll, Version=1.0.2.32048
    ImAGIF.FileType                                          .\FileTypes\ImAGIF.FileType.dll, Version=0.13.0.21358
    IcoCur                                                   .\FileTypes\IcoCur.dll, Version=4.0.1.0
    mscorlib                                                 .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Drawing                                           .\System.Drawing.dll, Version=6.0.1.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Cryptography.Primitives                  .\System.Security.Cryptography.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System                                                   .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    DdsFileTypePlus                                          .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.10.0
    WebPFileType                                             .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.7.0
    AvifFileType                                             .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.17.0
    Mono.Cecil                                               .\Mono.Cecil.dll, Version=0.11.4.0, PublicKeyToken=50cebf1cceb9d05e
    netstandard                                              .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    AlphaMask                                                .\Effects\AlphaMask.dll, Version=2.0.3574.41943
    ColorToAlpha                                             .\Effects\ColortoAlpha.dll, Version=2.3.0.0
    System.Console                                           .\System.Console.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    coloraberation                                           .\Effects\coloraberation.dll, Version=1.2.5.15647
    AA's_Assistant                                           .\Effects\AA's_Assistant.dll, Version=1.1.4329.33034
    ColorZoomBlur                                            .\Effects\ColorZoomBlur.dll, Version=1.2.5.17431
    AutoChrome                                               .\Effects\AutoChrome.dll, Version=1.2.5.19669
    AlphaThreshold                                           .\Effects\AlphaThreshold.dll, Version=1.0.1.0
    BlackandAlpha+                                           .\Effects\BlackandAlpha+.dll, Version=1.2.4329.272
    DistortingMirror                                         .\Effects\DistortingMirror.dll, Version=1.2.5.15788
    ExpandColor                                              .\Effects\ExpandColor.dll, Version=1.2.5.15745
    Donut                                                    .\Effects\Donut.dll, Version=1.2.5.15739
    System.Runtime.Serialization.Formatters                  .\System.Runtime.Serialization.Formatters.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Flip                                                     .\Effects\Flip.dll, Version=4.6.7358.36953
    FreeTransform3                                           .\Effects\FreeTransform3.dll, Version=3.0.7933.3577
    DHShapeMaker                                             .\Effects\DHShapeMaker.dll, Version=1.3.0.0
    GradientBlur                                             .\Effects\GradientBlur.dll, Version=1.2.5.28179
    Gradient Bars                                            .\Effects\Gradient Bars.dll, Version=4.0.5152.23084
    Gravity                                                  .\Effects\Gravity.dll, Version=1.2.5.29548
    Jitter                                                   .\Effects\Jitter.dll, Version=4.0.4642.26986
    GridMaker                                                .\Effects\GridMaker.dll, Version=5.2.5.29827
    JuliaPlus                                                .\Effects\JuliaPlus.dll, Version=1.2.5.13821
    Grid Warp                                                .\Effects\Grid Warp.dll, Version=4.0.6544.34496
    Magnifier                                                .\Effects\Magnifier.dll, Version=1.3.5.14308
    Kill Color Keeper                                        .\Effects\Kill Color Keeper.dll, Version=1.0.6641.13453
    Liquify                                                  .\Effects\Liquify.dll, Version=4.0.5873.25113
    Moire                                                    .\Effects\Moire.dll, Version=1.2.5.14350
    Oblique                                                  .\Effects\Oblique.dll, Version=1.2.5.15730
    Overblur                                                 .\Effects\Overblur.dll, Version=1.0.1.0
    Outline Object                                           .\Effects\Outline Object.dll, Version=4.0.4642.26954
    Paneling                                                 .\Effects\Paneling.dll, Version=1.2.5.23448
    System.Core                                              .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    pxEexpansion                                             .\Effects\pxEexpansion.dll, Version=1.0.4437.36287
    Perspective                                              .\Effects\Perspective.dll, Version=2.1.4415.36116
    RecolorGray                                              .\Effects\RecolorGray.dll, Version=1.2.5.27251
    WetFloor                                                 .\Effects\WetFloor.dll, Version=1.2.5.14166
    RadiusFillCorners                                        .\Effects\RadiusFillCorners.dll, Version=1.4.0.0
    RegularNoise                                             .\Effects\RegularNoise.dll, Version=1.2.5.29080
    Sharpen+                                                 .\Effects\Sharpen+.dll, Version=4.0.0.0
    Smudge                                                   .\Effects\Smudge.dll, Version=4.0.5873.25097
    Sparkles                                                 .\Effects\Sparkles.dll, Version=1.2.5.12788
    StarGlow                                                 .\Effects\StarGlow.dll, Version=1.2.5.13055
    Trail                                                    .\Effects\Trail.dll, Version=4.0.4642.26791
    Twist                                                    .\Effects\Twist.dll, Version=4.0.5873.25056
    WaterReflection                                          .\Effects\WaterReflection.dll, Version=1.2.5.15754
    PaintDotNet.Plugins.Compatibility                        .\PaintDotNet.Plugins.Compatibility.dll, Version=4.306.8039.8199
    System.Text.RegularExpressions                           .\System.Text.RegularExpressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.CodeDom                                           .\System.CodeDom.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Crc32.NET                                                .\Crc32.NET.dll, Version=1.0.0.0, PublicKeyToken=dc0b95cf99bf4e99
    Newtonsoft.Json                                          .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed
    System.Linq.Expressions                                  .\System.Linq.Expressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Numerics                                  .\System.Runtime.Numerics.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Vandermotten.PaintDotNetEffects.ObjectAlign              .\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, Version=3.8.0.0
    System.Diagnostics.StackTrace                            .\System.Diagnostics.StackTrace.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    HueSatPlus                                               .\Effects\HueSatPlus.dll, Version=4.6.7359.209
    Vandermotten.PaintDotNetEffects                          .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=3.8.0.0
    System.Xml                                               .\System.Xml.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    Alpha2Gray                                               .\Effects\Alpha2Gray.dll, Version=4.5.6832.21862
    ColorBalance                                             .\Effects\ColorBalance.dll, Version=4.7.7401.17173
    PasteAlpha                                               .\Effects\PasteAlpha.dll, Version=4.6.7358.38804
    Transparency                                             .\Effects\Transparency.dll, Version=4.6.7358.39871
    ObjectTools                                              .\Effects\ObjectTools.dll, Version=5.0.7502.21624
    System.IO.Compression                                    .\System.IO.Compression.dll, Version=6.0.0.0, PublicKeyToken=b77a5c561934e089
Native modules                                               246
    paintdotnet.exe                                          .\paintdotnet.exe, version=4.306.8039.8199
    ntdll.dll                                                C:\Windows\SYSTEM32\ntdll.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    KERNEL32.DLL                                             C:\Windows\System32\KERNEL32.DLL, version=10.0.22000.376 (WinBuild.160101.0800)
    KERNELBASE.dll                                           C:\Windows\System32\KERNELBASE.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    apphelp.dll                                              C:\Windows\SYSTEM32\apphelp.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    AcLayers.DLL                                             C:\Windows\SYSTEM32\AcLayers.DLL, version=10.0.22000.1 (WinBuild.160101.0800)
    msvcrt.dll                                               C:\Windows\System32\msvcrt.dll, version=7.0.22000.1 (WinBuild.160101.0800)
    SHLWAPI.dll                                              C:\Windows\System32\SHLWAPI.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    USER32.dll                                               C:\Windows\System32\USER32.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    win32u.dll                                               C:\Windows\System32\win32u.dll, version=10.0.22000.348 (WinBuild.160101.0800)
    GDI32.dll                                                C:\Windows\System32\GDI32.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    gdi32full.dll                                            C:\Windows\System32\gdi32full.dll, version=10.0.22000.71 (WinBuild.160101.0800)
    msvcp_win.dll                                            C:\Windows\System32\msvcp_win.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    ucrtbase.dll                                             C:\Windows\System32\ucrtbase.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    SHELL32.dll                                              C:\Windows\System32\SHELL32.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    ADVAPI32.dll                                             C:\Windows\System32\ADVAPI32.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    sechost.dll                                              C:\Windows\System32\sechost.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    RPCRT4.dll                                               C:\Windows\System32\RPCRT4.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    IMM32.DLL                                                C:\Windows\System32\IMM32.DLL, version=10.0.22000.1 (WinBuild.160101.0800)
    shcore.dll                                               C:\Windows\System32\shcore.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    hostfxr.dll                                              .\hostfxr.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba
    hostpolicy.dll                                           .\hostpolicy.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba
    coreclr.dll                                              .\coreclr.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba
    ole32.dll                                                C:\Windows\System32\ole32.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    combase.dll                                              C:\Windows\System32\combase.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    OLEAUT32.dll                                             C:\Windows\System32\OLEAUT32.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    bcryptPrimitives.dll                                     C:\Windows\System32\bcryptPrimitives.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    System.Private.CoreLib.dll                               .\System.Private.CoreLib.dll, version=6.0.121.56705
    clrjit.dll                                               .\clrjit.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba
    kernel.appcore.dll                                       C:\Windows\SYSTEM32\kernel.appcore.dll, version=10.0.22000.71 (WinBuild.160101.0800)
    paintdotnet.dll                                          .\paintdotnet.dll, version=4.306.8039.8199
    System.Runtime.dll                                       .\System.Runtime.dll, version=6.0.121.56705
    uxtheme.dll                                              C:\Windows\system32\uxtheme.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    icu.dll                                                  C:\Windows\SYSTEM32\icu.dll, version=68, 2, 0, 6 (WinBuild.160101.0800)
    PaintDotNet.Base.dll                                     .\PaintDotNet.Base.dll, version=4.306.8039.8199
    System.Windows.Forms.dll                                 .\System.Windows.Forms.dll, version=6.0.121.56705
    System.Diagnostics.Process.dll                           .\System.Diagnostics.Process.dll, version=6.0.121.56705
    TerraFX.Interop.Windows.dll                              .\TerraFX.Interop.Windows.dll, version=10.0.20348.0
    PaintDotNet.SystemLayer.dll                              .\PaintDotNet.SystemLayer.dll, version=4.306.8039.8199
    System.Runtime.InteropServices.RuntimeInformation.dll    .\System.Runtime.InteropServices.RuntimeInformation.dll, version=6.0.121.56705
    System.Runtime.InteropServices.dll                       .\System.Runtime.InteropServices.dll, version=6.0.121.56705
    vcruntime140.dll                                         .\vcruntime140.dll, version=14.30.30704.0 built by: vcwrkspc
    vcruntime140_1.dll                                       .\vcruntime140_1.dll, version=14.30.30704.0 built by: vcwrkspc
    msvcp140.dll                                             .\msvcp140.dll, version=14.30.30704.0 built by: vcwrkspc
    msvcp140_1.dll                                           .\msvcp140_1.dll, version=14.30.30704.0 built by: vcwrkspc
    msvcp140_2.dll                                           .\msvcp140_2.dll, version=14.30.30704.0 built by: vcwrkspc
    msvcp140_codecvt_ids.dll                                 .\msvcp140_codecvt_ids.dll, version=14.30.30704.0 built by: vcwrkspc
    vcomp140.dll                                             .\vcomp140.dll, version=14.30.30704.0 built by: vcwrkspc
    ijwhost.dll                                              .\ijwhost.dll, version=6,0,121,56705 @Commit: 3a25a7f1cc446b60678ed25c9d829420d6321eba
    PaintDotNet.SystemLayer.Native.x64.dll                   .\PaintDotNet.SystemLayer.Native.x64.dll, version=4.306.8039.8199
    PROPSYS.dll                                              C:\Windows\SYSTEM32\PROPSYS.dll, version=7.0.22000.376 (WinBuild.160101.0800)
    gdiplus.dll                                              C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.22000.318_none_ce876b9e12f802ea\gdiplus.dll, version=10.0.22000.318 (WinBuild.160101.0800)
    WindowsCodecs.dll                                        C:\Windows\SYSTEM32\WindowsCodecs.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    System.Threading.dll                                     .\System.Threading.dll, version=6.0.121.56705
    System.Runtime.Extensions.dll                            .\System.Runtime.Extensions.dll, version=6.0.121.56705
    System.Runtime.CompilerServices.VisualC.dll              .\System.Runtime.CompilerServices.VisualC.dll, version=6.0.121.56705
    System.Collections.NonGeneric.dll                        .\System.Collections.NonGeneric.dll, version=6.0.121.56705
    System.Runtime.Intrinsics.dll                            .\System.Runtime.Intrinsics.dll, version=6.0.121.56705
    windows.storage.dll                                      C:\Windows\SYSTEM32\windows.storage.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    wintypes.dll                                             C:\Windows\SYSTEM32\wintypes.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    System.Collections.Concurrent.dll                        .\System.Collections.Concurrent.dll, version=6.0.121.56705
    PaintDotNet.Core.dll                                     .\PaintDotNet.Core.dll, version=4.306.8039.8199
    System.Runtime.CompilerServices.Unsafe.dll               .\System.Runtime.CompilerServices.Unsafe.dll, version=6.0.121.56705
    System.Private.Uri.dll                                   .\System.Private.Uri.dll, version=6.0.121.56705
    System.ComponentModel.Primitives.dll                     .\System.ComponentModel.Primitives.dll, version=6.0.121.56705
    BCrypt.dll                                               C:\Windows\SYSTEM32\BCrypt.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    System.Windows.Forms.Primitives.dll                      .\System.Windows.Forms.Primitives.dll, version=6.0.121.56705
    WindowsBase.dll                                          .\WindowsBase.dll, version=6.0.121.56707
    System.Drawing.Primitives.dll                            .\System.Drawing.Primitives.dll, version=6.0.121.56705
    PresentationFramework.dll                                .\PresentationFramework.dll, version=6.0.121.56707
    System.Xaml.dll                                          .\System.Xaml.dll, version=6.0.121.56707
    System.ComponentModel.dll                                .\System.ComponentModel.dll, version=6.0.121.56705
    System.Diagnostics.TraceSource.dll                       .\System.Diagnostics.TraceSource.dll, version=6.0.121.56705
    System.Collections.dll                                   .\System.Collections.dll, version=6.0.121.56705
    System.Threading.Thread.dll                              .\System.Threading.Thread.dll, version=6.0.121.56705
    System.Text.Encoding.CodePages.dll                       .\System.Text.Encoding.CodePages.dll, version=6.0.121.56705
    PaintDotNet.Resources.dll                                .\PaintDotNet.Resources.dll, version=4.306.8039.8199
    System.ObjectModel.dll                                   .\System.ObjectModel.dll, version=6.0.121.56705
    Microsoft.Win32.Primitives.dll                           .\Microsoft.Win32.Primitives.dll, version=6.0.121.56705
    PaintDotNet.Data.dll                                     .\PaintDotNet.Data.dll, version=4.306.8039.8199
    System.Collections.Immutable.dll                         .\System.Collections.Immutable.dll, version=6.0.121.56705
    PaintDotNet.Framework.dll                                .\PaintDotNet.Framework.dll, version=4.306.8039.8199
    System.Drawing.Common.dll                                .\System.Drawing.Common.dll, version=6.0.121.56705
    Microsoft.Win32.SystemEvents.dll                         .\Microsoft.Win32.SystemEvents.dll, version=6.0.121.56705
    PresentationNative_cor3.dll                              .\PresentationNative_cor3.dll, version=6,0,21,48001 @Commit: bf6f24c075ff5315d0ec0e5359138ee796b0491c
    System.Configuration.ConfigurationManager.dll            .\System.Configuration.ConfigurationManager.dll, version=6.0.121.56705
    System.Collections.Specialized.dll                       .\System.Collections.Specialized.dll, version=6.0.121.56705
    System.Xml.ReaderWriter.dll                              .\System.Xml.ReaderWriter.dll, version=6.0.121.56705
    System.Private.Xml.dll                                   .\System.Private.Xml.dll, version=6.0.121.56705
    System.Threading.ThreadPool.dll                          .\System.Threading.ThreadPool.dll, version=6.0.121.56705
    System.Net.WebClient.dll                                 .\System.Net.WebClient.dll, version=6.0.121.56705
    System.ComponentModel.EventBasedAsync.dll                .\System.ComponentModel.EventBasedAsync.dll, version=6.0.121.56705
    System.Linq.dll                                          .\System.Linq.dll, version=6.0.121.56705
    dxgi.dll                                                 C:\Windows\SYSTEM32\dxgi.dll, version=10.0.22000.348 (WinBuild.160101.0800)
    System.Memory.dll                                        .\System.Memory.dll, version=6.0.121.56705
    System.Text.Encoding.Extensions.dll                      .\System.Text.Encoding.Extensions.dll, version=6.0.121.56705
    dxcore.dll                                               C:\Windows\SYSTEM32\dxcore.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    MSCTF.dll                                                C:\Windows\System32\MSCTF.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    directxdatabasehelper.dll                                C:\Windows\SYSTEM32\directxdatabasehelper.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    ntmarta.dll                                              C:\Windows\SYSTEM32\ntmarta.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    Microsoft.Win32.Registry.dll                             .\Microsoft.Win32.Registry.dll, version=6.0.121.56705
    System.Security.Principal.Windows.dll                    .\System.Security.Principal.Windows.dll, version=6.0.121.56705
    System.Security.Claims.dll                               .\System.Security.Claims.dll, version=6.0.121.56705
    System.ComponentModel.TypeConverter.dll                  .\System.ComponentModel.TypeConverter.dll, version=6.0.121.56705
    PresentationCore.dll                                     .\PresentationCore.dll, version=6.0.121.56707
    DirectWriteForwarder.dll                                 .\DirectWriteForwarder.dll, version=6,0,121,56707 @Commit: 0350d04790959e8ebdd3ceab0d34a40f811f019d
    System.Diagnostics.Debug.dll                             .\System.Diagnostics.Debug.dll, version=6.0.121.56705
    dwrite.dll                                               C:\Windows\SYSTEM32\dwrite.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    UIAutomationTypes.dll                                    .\UIAutomationTypes.dll, version=6.0.121.56707
    System.Diagnostics.FileVersionInfo.dll                   .\System.Diagnostics.FileVersionInfo.dll, version=6.0.121.56705
    profapi.dll                                              C:\Windows\SYSTEM32\profapi.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    PaintDotNet.Effects.dll                                  .\PaintDotNet.Effects.dll, version=4.306.8039.8199
    clbcatq.dll                                              C:\Windows\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    UIAnimation.dll                                          C:\Windows\System32\UIAnimation.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    Accessibility.dll                                        .\Accessibility.dll, version=6.0.121.56705
    version.dll                                              C:\Windows\SYSTEM32\version.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    comctl32.dll                                             C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.22000.120_none_9d947278b86cc467\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    System.Numerics.Vectors.dll                              .\System.Numerics.Vectors.dll, version=6.0.121.56705
    System.Threading.Tasks.Parallel.dll                      .\System.Threading.Tasks.Parallel.dll, version=6.0.121.56705
    System.Diagnostics.Tracing.dll                           .\System.Diagnostics.Tracing.dll, version=6.0.121.56705
    ucrtbase.dll                                             .\ucrtbase.dll, version=10.0.19041.685 (WinBuild.160101.0800)
    System.Reflection.MetadataLoadContext.dll                .\System.Reflection.MetadataLoadContext.dll, version=6.0.21.52210
    System.Reflection.Metadata.dll                           .\System.Reflection.Metadata.dll, version=6.0.121.56705
    System.IO.MemoryMappedFiles.dll                          .\System.IO.MemoryMappedFiles.dll, version=6.0.121.56705
    System.IO.Packaging.dll                                  .\System.IO.Packaging.dll, version=6.0.121.56705
    System.Runtime.Loader.dll                                .\System.Runtime.Loader.dll, version=6.0.121.56705
    OptiPngFileType.dll                                      .\FileTypes\OptiPngFileType.dll, version=11.0.0.0
    AnimGIF.dll                                              .\FileTypes\AnimGIF.dll, version=2.4.4119.28305
    PhotoShop.dll                                            .\FileTypes\PhotoShop.dll, version=2.5.0.0
    TextShaping.dll                                          C:\Windows\SYSTEM32\TextShaping.dll, version=
    SpriteSheet.dll                                          .\FileTypes\SpriteSheet.dll, version=1.2.2.0
    LowColor.dll                                             .\FileTypes\LowColor.dll, version=1.0.4.0
    PNGSpriteMatrix.dll                                      .\FileTypes\PNGSpriteMatrix.dll, version=1.0.2.32048
    ImAGIF.FileType.dll                                      .\FileTypes\ImAGIF.FileType.dll, version=0.13.0.21358
    IcoCur.dll                                               .\FileTypes\IcoCur.dll, version=4.0.1.0
    mscorlib.dll                                             .\mscorlib.dll, version=6.0.121.56705
    System.Drawing.dll                                       .\System.Drawing.dll, version=6.0.121.56705
    System.Security.Cryptography.Primitives.dll              .\System.Security.Cryptography.Primitives.dll, version=6.0.121.56705
    System.dll                                               .\System.dll, version=6.0.121.56705
    mfplat.dll                                               C:\Windows\SYSTEM32\mfplat.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    cfgmgr32.dll                                             C:\Windows\SYSTEM32\cfgmgr32.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    RTWorkQ.DLL                                              C:\Windows\SYSTEM32\RTWorkQ.DLL, version=10.0.22000.1 (WinBuild.160101.0800)
    CompPkgSup.DLL                                           C:\Windows\SYSTEM32\CompPkgSup.DLL, version=10.0.22000.1 (WinBuild.160101.0800)
    Windows.StateRepositoryPS.dll                            C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.22000.65 (WinBuild.160101.0800)
    DdsFileTypePlus.dll                                      .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.10.0
    WebPFileType.dll                                         .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.7.0
    AvifFileType.dll                                         .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.17.0
    Mono.Cecil.dll                                           .\Mono.Cecil.dll, version=0.11.4.0
    netstandard.dll                                          .\netstandard.dll, version=6.0.121.56705
    AlphaMask.dll                                            .\Effects\AlphaMask.dll, version=2.0.3574.41943
    ColortoAlpha.dll                                         .\Effects\ColortoAlpha.dll, version=2.3.0.0
    System.Console.dll                                       .\System.Console.dll, version=6.0.121.56705
    coloraberation.dll                                       .\Effects\coloraberation.dll, version=1.2.5.0
    AA's_Assistant.dll                                       .\Effects\AA's_Assistant.dll, version=1.1.4329.33034
    ColorZoomBlur.dll                                        .\Effects\ColorZoomBlur.dll, version=1.2.5.0
    AutoChrome.dll                                           .\Effects\AutoChrome.dll, version=1.2.5.0
    AlphaThreshold.dll                                       .\Effects\AlphaThreshold.dll, version=1.0.0.0
    BlackandAlpha+.dll                                       .\Effects\BlackandAlpha+.dll, version=1.2.4329.272
    DistortingMirror.dll                                     .\Effects\DistortingMirror.dll, version=1.2.5.0
    ExpandColor.dll                                          .\Effects\ExpandColor.dll, version=1.2.5.0
    Donut.dll                                                .\Effects\Donut.dll, version=1.2.5.0
    System.Runtime.Serialization.Formatters.dll              .\System.Runtime.Serialization.Formatters.dll, version=6.0.121.56705
    Flip.dll                                                 .\Effects\Flip.dll, version=4.6.7358.36953
    FreeTransform3.dll                                       .\Effects\FreeTransform3.dll, version=3.0.7933.3577
    DHShapeMaker.dll                                         .\Effects\DHShapeMaker.dll, version=1.3.0.0
    GradientBlur.dll                                         .\Effects\GradientBlur.dll, version=1.2.5.0
    Gradient Bars.dll                                        .\Effects\Gradient Bars.dll, version=4.0.5152.23084
    Gravity.dll                                              .\Effects\Gravity.dll, version=1.2.5.0
    Jitter.dll                                               .\Effects\Jitter.dll, version=4.0.4642.26986
    GridMaker.dll                                            .\Effects\GridMaker.dll, version=5.2.5.0
    JuliaPlus.dll                                            .\Effects\JuliaPlus.dll, version=1.2.5.0
    Grid Warp.dll                                            .\Effects\Grid Warp.dll, version=4.0.6544.34496
    Magnifier.dll                                            .\Effects\Magnifier.dll, version=1.3.5.0
    Kill Color Keeper.dll                                    .\Effects\Kill Color Keeper.dll, version=1.0.6641.13453
    Liquify.dll                                              .\Effects\Liquify.dll, version=4.0.5873.25113
    Moire.dll                                                .\Effects\Moire.dll, version=1.2.5.0
    Oblique.dll                                              .\Effects\Oblique.dll, version=1.2.5.0
    Overblur.dll                                             .\Effects\Overblur.dll, version=1.0.1.0
    Outline Object.dll                                       .\Effects\Outline Object.dll, version=4.0.4642.26954
    Paneling.dll                                             .\Effects\Paneling.dll, version=1.2.5.0
    System.Core.dll                                          .\System.Core.dll, version=6.0.121.56705
    pxEexpansion.dll                                         .\Effects\pxEexpansion.dll, version=1.0.4437.36287
    Perspective.dll                                          .\Effects\Perspective.dll, version=2.1.4415.36116
    RecolorGray.dll                                          .\Effects\RecolorGray.dll, version=1.2.5.0
    WetFloor.dll                                             .\Effects\WetFloor.dll, version=1.2.5.0
    RadiusFillCorners.dll                                    .\Effects\RadiusFillCorners.dll, version=1.4.0.0
    RegularNoise.dll                                         .\Effects\RegularNoise.dll, version=1.2.5.0
    Sharpen+.dll                                             .\Effects\Sharpen+.dll, version=4.0.0.0
    Smudge.dll                                               .\Effects\Smudge.dll, version=4.0.5873.25097
    Sparkles.dll                                             .\Effects\Sparkles.dll, version=1.2.5.0
    StarGlow.dll                                             .\Effects\StarGlow.dll, version=1.2.5.0
    Trail.dll                                                .\Effects\Trail.dll, version=4.0.4642.26791
    Twist.dll                                                .\Effects\Twist.dll, version=4.0.5873.25056
    WaterReflection.dll                                      .\Effects\WaterReflection.dll, version=1.2.5.0
    d2d1.dll                                                 C:\Windows\SYSTEM32\d2d1.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    wtsapi32.dll                                             C:\Windows\SYSTEM32\wtsapi32.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    WINSTA.dll                                               C:\Windows\SYSTEM32\WINSTA.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    d3d11.dll                                                C:\Windows\SYSTEM32\d3d11.dll, version=10.0.22000.120 (WinBuild.160101.0800)
    D3D10Warp.dll                                            C:\Windows\SYSTEM32\D3D10Warp.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    UIAutomationCore.dll                                     C:\Windows\SYSTEM32\UIAutomationCore.dll, version=7.2.22000.376 (WinBuild.160101.0800)
    USERENV.dll                                              C:\Windows\SYSTEM32\USERENV.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    sxs.dll                                                  C:\Windows\SYSTEM32\sxs.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    PaintDotNet.Plugins.Compatibility.dll                    .\PaintDotNet.Plugins.Compatibility.dll, version=4.306.8039.8199
    System.Text.RegularExpressions.dll                       .\System.Text.RegularExpressions.dll, version=6.0.121.56705
    System.CodeDom.dll                                       .\System.CodeDom.dll, version=6.0.121.56705
    dwmapi.DLL                                               C:\Windows\SYSTEM32\dwmapi.DLL, version=10.0.22000.376 (WinBuild.160101.0800)
    dataexchange.dll                                         C:\Windows\system32\dataexchange.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    twinapi.appcore.dll                                      C:\Windows\system32\twinapi.appcore.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    textinputframework.dll                                   C:\Windows\SYSTEM32\textinputframework.dll, version=10.0.22000.282 (WinBuild.160101.0800)
    CoreMessaging.dll                                        C:\Windows\SYSTEM32\CoreMessaging.dll, version=10.0.22000.71 (WinBuild.160101.0800)
    CoreUIComponents.dll                                     C:\Windows\SYSTEM32\CoreUIComponents.dll, version=10.0.22000.132
    CRYPTBASE.DLL                                            C:\Windows\SYSTEM32\CRYPTBASE.DLL, version=10.0.22000.1 (WinBuild.160101.0800)
    imkrtip.dll                                              C:\Windows\System32\IME\IMEKR\imkrtip.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    imetip.dll                                               C:\Windows\System32\IME\shared\imetip.dll, version=10.0.22000.51 (WinBuild.160101.0800)
    DUI70.dll                                                C:\Windows\SYSTEM32\DUI70.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    OLEACC.dll                                               C:\Windows\SYSTEM32\OLEACC.dll, version=7.2.22000.1 (WinBuild.160101.0800)
    imkrapi.dll                                              C:\Windows\System32\IME\IMEKR\imkrapi.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    policymanager.dll                                        C:\Windows\SYSTEM32\policymanager.dll, version=10.0.22000.348 (WinBuild.160101.0800)
    msvcp110_win.dll                                         C:\Windows\SYSTEM32\msvcp110_win.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    imjkapi.dll                                              C:\Windows\System32\IME\shared\imjkapi.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    Crc32.NET.dll                                            .\Crc32.NET.dll, version=1.2.0.5
    powrprof.dll                                             C:\Windows\SYSTEM32\powrprof.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    UMPDC.dll                                                C:\Windows\SYSTEM32\UMPDC.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    Newtonsoft.Json.dll                                      .\Newtonsoft.Json.dll, version=13.0.1.25517
    System.Linq.Expressions.dll                              .\System.Linq.Expressions.dll, version=6.0.121.56705
    System.Runtime.Numerics.dll                              .\System.Runtime.Numerics.dll, version=6.0.121.56705
    winmm.DLL                                                C:\Windows\SYSTEM32\winmm.DLL, version=10.0.22000.376 (WinBuild.160101.0800)
    amsi.dll                                                 C:\Windows\SYSTEM32\amsi.dll, version=10.0.22000.120 (WinBuild.160101.0800)
    antimalware_provider.dll                                 C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Cloud 21.3\x64\antimalware_provider.dll, version=30.587.0.880
    product_info.dll                                         C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Cloud 21.3\x64\product_info.dll, version=21.3.10.350
    WS2_32.dll                                               C:\Windows\System32\WS2_32.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    Vandermotten.PaintDotNetEffects.ObjectAlign.dll          .\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=3.8.0.0
    System.Diagnostics.StackTrace.dll                        .\System.Diagnostics.StackTrace.dll, version=6.0.121.56705
    Microsoft.DiaSymReader.Native.amd64.dll                  .\Microsoft.DiaSymReader.Native.amd64.dll, version=14.28.29715.1 built by: vcwrkspc
    System.Xml.dll                                           .\System.Xml.dll, version=6.0.121.56705
    aticfx64.dll                                             C:\Windows\System32\DriverStore\FileRepository\u0373733.inf_amd64_a70fcd9f085a1b58\B373745\aticfx64.dll, version=8.17.10.1697
    atiuxp64.dll                                             C:\Windows\System32\DriverStore\FileRepository\u0373733.inf_amd64_a70fcd9f085a1b58\B373745\atiuxp64.dll, version=8.14.01.6564
    atidxx64.dll                                             C:\Windows\System32\DriverStore\FileRepository\u0373733.inf_amd64_a70fcd9f085a1b58\B373745\atidxx64.dll, version=8.17.10.01043
    SETUPAPI.dll                                             C:\Windows\System32\SETUPAPI.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    amdihk64.dll                                             C:\Windows\SYSTEM32\amdihk64.dll, version=2,00,00,1788
    dcomp.dll                                                C:\Windows\SYSTEM32\dcomp.dll, version=10.0.22000.348 (WinBuild.160101.0800)
    System.IO.Compression.dll                                .\System.IO.Compression.dll, version=6.0.121.56705
    DEVOBJ.dll                                               C:\Windows\SYSTEM32\DEVOBJ.dll, version=10.0.22000.1 (WinBuild.160101.0800)
    WINTRUST.dll                                             C:\Windows\System32\WINTRUST.dll, version=10.0.22000.194 (WinBuild.160101.0800)
    CRYPT32.dll                                              C:\Windows\System32\CRYPT32.dll, version=10.0.22000.376 (WinBuild.160101.0800)
    MSASN1.dll                                               C:\Windows\SYSTEM32\MSASN1.dll, version=10.0.22000.1 (WinBuild.160101.0800)
No possibility to save PNG files anymore with version 4.3.6 (same for JPG, didn't tried other formats).
Following message is displayed after entering the filename, and never disappears.
No possibility to close it, neither to quit the application properly (needed to kill the process manually).
Edited by Entropiness
I have no problem saving as PNG, but I when opened a 692kb 24-bit JPG in Paint.Net (4.3.6), and then saved as a 24-bit PNG, the file size jumped to 4.49 mb!
Is this right?
Brian
14 minutes ago, Metorical said:
I'm having exactly the same problem.
When trying to save as "t1.png" it instead creates "t1.png.1.pdnSave" and hangs at the Initialization dialog.
Downgraded back to 4.2.16 and all is working again.
Exactly ! (it also creates a temporary file for me)
Downgrading just to version 4.3.4 also works fine (for me).
After installing NOTHING works anymore. All the plugins appears in a very small box/window in the upper left corner without most of their options. On more simple effect like "local contrast" a new window "Initializing" appears and nothing happens after waiting for many minutes. I have to end the program in task-manager.
Please help!
Edited by IRON67
Is this right?
Brian
PNG is lossless, file sizes are expected to go up when saving from a JPEG, which lossily saves things in a way that makes it harder for PNG's compression to work.
  • Rick Brewster changed the title to Many problems with 4.3.6
Can everyone do the following / answer these questions ...
1) When looking at Task Manager, is Paint.NET sitting "idle" or is it using up a ton of CPU time? If it's using a lot of CPU time, then creating a "performance trace" and sending it to me may be very helpful.
2) Please post the diagnostics information from Settings (gear icon at top right of main window) -> Diagnostics -> Copy to Clipboard
3) If you haven't already, make sure to restart and try running the app again.
4) In Settings, disable "Hardware accelerated rendering" and "Animations" and report back if that helps. Try to see which combination of those settings works, or doesn't.
33 minutes ago, Merowinger86 said:
Is there a way to download the older version?
I need to figure out the problem so I can solve it. If you just go back to the older version, I won't be able to do that.
1 minute ago, Merowinger86 said:
What should I do? There is no error message or something.
See this reply:
  • Thanks 1
What I really need is at least 1 person who's having this issue who can be very responsive in replying to questions or trying out updated builds with prospective fixes
