NinthDesertDude Posted December 16, 2021 Share Posted December 16, 2021 Most controls (where it makes sense) nudge with the arrowkeys (e.g. Move tool, Shapes tool). The text tool can't because the arrowkeys are used to navigate the text field. However, while you're holding the control nub, you can move the text with arrowkeys. I think this is worth mentioning in the help documentation because exactly-positioning text with the mouse can be a lot harder. Don't know where else to put this, so I raised it here. Cheers! Quote Link to comment Share on other sites More sharing options...
Tactilis Posted December 16, 2021 Share Posted December 16, 2021 And in pictures.... 1. Type your text 2. Move the cursor over the control nub. 3. Hold down the left mouse button and use the arrow keys to move the nub (and hence the text) Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 16, 2021 Share Posted December 16, 2021 I do have this info on the Keyboard and Mouse page https://www.getpaint.net/doc/latest/KeyboardMouseCommands.html#29 FYI - You can actually use either mouse button. Here's how the change will look on the Text Tool page. 2 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
NinthDesertDude Posted December 16, 2021 Author Share Posted December 16, 2021 That's great! Thanks for including that tip under the text control as well. Quote Link to comment Share on other sites More sharing options...
