jlnhlfan Posted December 9, 2021 Share Posted December 9, 2021 In Photoshop, alongside the hue/saturation option, there is a button to click that can make the layer you're dealing with a single colour. No such option exists in paint.net, which sucks if you are dealing with hue and saturation and the sliders don't do that good of a job of getting the hue you want in your image. For example, one of the images I am dealing with has a lot of greens in it. On either end is either blue or purple; brown is the colour I'm looking for in this case. Is there any other way I can get what I want out of this aside from using sepia, which doesn't give me the desired effect? Quote Link to comment Share on other sites More sharing options...
Tony Mcilrath Posted December 9, 2021 Share Posted December 9, 2021 (edited) Hello, I would recommend you edit the post and put an example of the Photoshop tool, with an example of what you want to do, to help you better. Edited December 9, 2021 by Tony Mcilrath 1 Quote Link to comment Share on other sites More sharing options...
IHaveNoName Posted December 10, 2021 Share Posted December 10, 2021 I don't understand the particular problem either as described but there are recolouring plugins like Red Ochre's Recolour Choice and another one called Manual Color which might be what is wanted. Quote Link to comment Share on other sites More sharing options...
AndrewDavid Posted December 10, 2021 Share Posted December 10, 2021 Hello @jlnhlfan Welcome to the forum. Here's my suggestion; Let us know if it works for you. Quote Link to comment Share on other sites More sharing options...
