Thrafic Posted December 7, 2021 Share Posted December 7, 2021 (edited) So sometimes rectangle selection doesn't work I can select but when I release lmb it doesn't select anything have idea how to fix it Edited December 7, 2021 by Thrafic Typo Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 7, 2021 Share Posted December 7, 2021 Please ensure you're using the correct Selection Mode. https://www.getpaint.net/doc/latest/SelectionTools.html#11 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
NinthDesertDude Posted December 7, 2021 Share Posted December 7, 2021 alternatively, your mouse could just be faulty and double click sometimes with left mouse button. I've had two mice do exactly that Quote Link to comment Share on other sites More sharing options...
Thrafic Posted December 8, 2021 Author Share Posted December 8, 2021 im not that dumb is just didnt select dont talk abot mouse to me Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 8, 2021 Share Posted December 8, 2021 Are you using the latest version of the app (4.3.4) ? There was a memory leak that I fixed in the selection rendering code. It could either cause a crash, or cause the selection to not render at all. (If the selection renderer catches an exception, it just drops it on the floor and proceeds w/o drawing anything -- which is preferable to a crash.) Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Michael Ng Posted September 25, 2022 Share Posted September 25, 2022 Nah, I'm also encountering same issue in 4.3.12. If you open many images (min. 5 in my cases), either file size is big or dimension is large, the first image will always be unable to use select rectangle tool. Moreover, if you go to edit the last image you put into paint.net and save, then return to the beginning page, there are high chance that this situation will reoccur. Quote Link to comment Share on other sites More sharing options...
StudioLoading Posted November 4, 2022 Share Posted November 4, 2022 Me too. On v 4.3.12 Selection Tool is quite messy, from this morning actually. I open a new image Select Selection Tool in Normal mode. (**) I move the mouse around inside the image, I see the mouse pointer as a bigger + symbol, with a dashed rectangle. I left click to start a selection and here starts the mess. The mouse pointer changes to a tiny little cross. I move the mouse, with left button still pushed, and nothing happens. I release the left mouse button, and start to move the cursor. A Selected area is drawn. If I left click, nothing happens. If I right click, nothing happens. If I click left and right, selection stops drawning and stands still. I restart the software, restart the entire PC, but this issue won't go away. If I combo Ctrl+D, the situation moves back to normal (**) It's almost impossible to work there. What should I do? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted November 4, 2022 Share Posted November 4, 2022 @StudioLoading, Please post the diagnostic information found within paint.net. Settings -> Diagnostics -> Copy to clipboard. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
StudioLoading Posted November 6, 2022 Share Posted November 6, 2022 @toe_head2001 Application paint.net 4.3.12 (Stable 4.312.8267.29064) Build Date sabato 20 agosto 2022 Install type Classic Rendering accelerato via hardware (GPU) True Remote session False Animazioni True DPI 96 (1,00x scale) Lingua it-IT OS Windows 7 Professional Service Pack 1 x64 (6.1.7601.0) Runtime .NET 6.0.8 x64 Physical Memory 4.788 MB CPU AMD Ryzen 5 5500U with Radeon Graphics Speed ~2096 MHz Cores / Threads 6 / 6 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2 Video Card Software Adapter Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 2.394 MB Vendor ID 0x0000 Device ID 0x0000 Subsystem ID 0x00000000 Revision 0 LUID 0x1200000000 Flags None Graphics Preemption DmaBufferBoundary Compute Preemption DmaBufferBoundary Outputs 1 (0 attached) Feature Level Direct3D_11_0 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Maximum Bitmap Size 16777216 Managed assemblies 143 System.Private.CoreLib .\System.Private.CoreLib.dll, Version=6.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet .\paintdotnet.dll, Version=4.312.8267.29064 System.Runtime .\System.Runtime.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Base .\PaintDotNet.Base.dll, Version=4.312.8267.29064 System.Windows.Forms .\System.Windows.Forms.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 System.Diagnostics.Process .\System.Diagnostics.Process.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer .\PaintDotNet.SystemLayer.dll, Version=4.312.8267.29064 TerraFX.Interop.Windows .\TerraFX.Interop.Windows.dll, Version=10.0.20348.0, PublicKeyToken=35b01b53313a6f7e System.Runtime.InteropServices.RuntimeInformation .\System.Runtime.InteropServices.RuntimeInformation.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.InteropServices .\System.Runtime.InteropServices.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer.Native.x64 .\PaintDotNet.SystemLayer.Native.x64.dll, Version=4.312.8267.29064 System.Threading .\System.Threading.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions .\System.Runtime.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC .\System.Runtime.CompilerServices.VisualC.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric .\System.Collections.NonGeneric.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Intrinsics .\System.Runtime.Intrinsics.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Core .\PaintDotNet.Core.dll, Version=4.312.8267.29064 System.Private.Uri .\System.Private.Uri.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives .\System.ComponentModel.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms.Primitives .\System.Windows.Forms.Primitives.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 System.Drawing.Primitives .\System.Drawing.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WindowsBase .\WindowsBase.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.TraceSource .\System.Diagnostics.TraceSource.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections .\System.Collections.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework .\PresentationFramework.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Text.Encoding.CodePages .\System.Text.Encoding.CodePages.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xaml .\System.Xaml.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.Resources .\PaintDotNet.Resources.dll, Version=4.312.8267.29064 System.ComponentModel .\System.ComponentModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ObjectModel .\System.ObjectModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data .\PaintDotNet.Data.dll, Version=4.312.8267.29064 System.Threading.Thread .\System.Threading.Thread.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Primitives .\Microsoft.Win32.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Framework .\PaintDotNet.Framework.dll, Version=4.312.8267.29064 Microsoft.Win32.SystemEvents .\Microsoft.Win32.SystemEvents.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Threading.ThreadPool .\System.Threading.ThreadPool.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Common .\System.Drawing.Common.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Immutable .\System.Collections.Immutable.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.EventBasedAsync .\System.ComponentModel.EventBasedAsync.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Configuration.ConfigurationManager .\System.Configuration.ConfigurationManager.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Linq .\System.Linq.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Specialized .\System.Collections.Specialized.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Concurrent .\System.Collections.Concurrent.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xml.ReaderWriter .\System.Xml.ReaderWriter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml .\System.Private.Xml.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Microsoft.Win32.Registry .\Microsoft.Win32.Registry.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Principal.Windows .\System.Security.Principal.Windows.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Claims .\System.Security.Claims.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.WebClient .\System.Net.WebClient.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Memory .\System.Memory.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.Encoding.Extensions .\System.Text.Encoding.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter .\System.ComponentModel.TypeConverter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationCore .\PresentationCore.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder .\DirectWriteForwarder.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.Debug .\System.Diagnostics.Debug.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a UIAutomationTypes .\UIAutomationTypes.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.FileVersionInfo .\System.Diagnostics.FileVersionInfo.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects .\PaintDotNet.Effects.dll, Version=4.312.8267.29064 Accessibility .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Threading.Tasks.Parallel .\System.Threading.Tasks.Parallel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Numerics.Vectors .\System.Numerics.Vectors.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Tracing .\System.Diagnostics.Tracing.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.MetadataLoadContext .\System.Reflection.MetadataLoadContext.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.IO.Packaging .\System.IO.Packaging.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.Metadata .\System.Reflection.Metadata.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.MemoryMappedFiles .\System.IO.MemoryMappedFiles.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Loader .\System.Runtime.Loader.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PhotoShop .\FileTypes\PhotoShop.dll, Version=2.5.0.40665 OptiPngFileType .\FileTypes\OptiPngFileType.dll, Version=11.0.0.0 ImZIP.FileType .\FileTypes\ImZIP.FileType.dll, Version=1.0.0.225 IcoCur .\FileTypes\IcoCur.dll, Version=4.0.1.0 mscorlib .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System.Drawing .\System.Drawing.dll, Version=6.0.2.0, PublicKeyToken=b03f5f7f11d50a3a System .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 DdsFileTypePlus .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.12.0 WebPFileType .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.14.0 AvifFileType .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.20.0 Mono.Cecil .\Mono.Cecil.dll, Version=0.11.4.0, PublicKeyToken=50cebf1cceb9d05e netstandard .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Console .\System.Console.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a AA's_Assistant .\Effects\AA's_Assistant.dll, Version=1.1.4329.33034 Alpha_to_0 .\Effects\Alpha_to_0.dll, Version=1.0.4452.22746 Alpha_to_255 .\Effects\Alpha_to_255.dll, Version=1.0.4452.22782 System.Net.Http .\System.Net.Http.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a BlackandAlpha+ .\Effects\BlackandAlpha+.dll, Version=1.2.4329.272 Vandermotten.PaintDotNetEffects.ObjectAlign C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, Version=4.3.2.0 Metallize .\Effects\Metallize.dll, Version=1.2.4415.32969 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 CircleText .\Effects\CircleText.dll, Version=1.4.4415.32488 dpyColorBalance .\Effects\dpyColorBalance.dll, Version=1.1.4330.37850 MultiThreshold .\Effects\MultiThreshold.dll, Version=1.1.4330.38982 System.Net.Primitives .\System.Net.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Pixelate+ .\Effects\Pixelate+.dll, Version=4.0.4642.26940 pxEexpansion .\Effects\pxEexpansion.dll, Version=1.0.4437.36287 Perspective .\Effects\Perspective.dll, Version=2.1.4415.36116 RGB2CMYK .\Effects\RGB2CMYK.dll, Version=0.0.0.0 Recolor Using Palette .\Effects\Recolor Using Palette.dll, Version=1.0.6382.573 RotateText .\Effects\RotateText.dll, Version=1.1.4415.32628 RotateTextSUI .\Effects\RotateTextSUI.dll, Version=1.1.4415.32713 Rotate_Zoom+ .\Effects\Rotate_Zoom+.dll, Version=1.11.5237.17779 SpeechBubble .\Effects\SpeechBubble.dll, Version=2.1.4445.42029 System.Resources.Extensions .\System.Resources.Extensions.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 SpiralText .\Effects\SpiralText.dll, Version=1.4.4415.32775 TextPlus .\Effects\Textplus.dll, Version=1.0.0.0 WaveText .\Effects\WaveText.dll, Version=1.2.4415.32811 WaveTextSUI .\Effects\WaveTextSUI.dll, Version=1.2.4415.33440 System.Runtime.Serialization.Formatters .\System.Runtime.Serialization.Formatters.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Vandermotten.PaintDotNetEffects.Blurs C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects.ColorAccent C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects.Duotones C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects.DropShadow C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects.FadeEdge C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects.Monochromes C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects.Gradient C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects.Grid C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects.MakeTransparent C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, Version=4.3.2.0 Vandermotten.PaintDotNetEffects C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=4.3.2.0 System.CodeDom .\System.CodeDom.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 FloydSteinbergDithering .\Effects\FloydSteinbergDithering.dll, Version=4.6.7358.37110 Crc32.NET .\Crc32.NET.dll, Version=1.0.0.0, PublicKeyToken=dc0b95cf99bf4e99 System.Security.Cryptography.Primitives .\System.Security.Cryptography.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.RegularExpressions .\System.Text.RegularExpressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Newtonsoft.Json .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Linq.Expressions .\System.Linq.Expressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Numerics .\System.Runtime.Numerics.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.Unsafe .\System.Runtime.CompilerServices.Unsafe.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.DiagnosticSource .\System.Diagnostics.DiagnosticSource.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Net.Security .\System.Net.Security.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Cryptography.X509Certificates .\System.Security.Cryptography.X509Certificates.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.Sockets .\System.Net.Sockets.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Overlapped .\System.Threading.Overlapped.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.NameResolution .\System.Net.NameResolution.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Cryptography.Encoding .\System.Security.Cryptography.Encoding.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.Compression .\System.IO.Compression.dll, Version=6.0.0.0, PublicKeyToken=b77a5c561934e089 K4os.Compression.LZ4 .\K4os.Compression.LZ4.dll, Version=1.2.15.0, PublicKeyToken=2186fa9121ef231d Native modules 271 paintdotnet.exe .\paintdotnet.exe, version=4.312.8267.29064 ntdll.dll C:\Windows\SYSTEM32\ntdll.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) kernel32.dll C:\Windows\system32\kernel32.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432) KERNELBASE.dll C:\Windows\system32\KERNELBASE.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432) USER32.dll C:\Windows\system32\USER32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) GDI32.dll C:\Windows\system32\GDI32.dll, version=6.1.7601.24540 (win7sp1_ldr_escrow.191127-1706) LPK.dll C:\Windows\system32\LPK.dll, version=6.1.7601.24537 (win7sp1_ldr_escrow.191114-1547) USP10.dll C:\Windows\system32\USP10.dll, version=1.0626.7601.24535 (win7sp1_ldr_escrow.191105-1059) msvcrt.dll C:\Windows\system32\msvcrt.dll, version=7.0.7601.17744 (win7sp1_gdr.111215-1535) SHELL32.dll C:\Windows\system32\SHELL32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) SHLWAPI.dll C:\Windows\system32\SHLWAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) ADVAPI32.dll C:\Windows\system32\ADVAPI32.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707) sechost.dll C:\Windows\SYSTEM32\sechost.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) RPCRT4.dll C:\Windows\system32\RPCRT4.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) api-ms-win-crt-runtime-l1-1-0.dll .\api-ms-win-crt-runtime-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) ucrtbase.DLL .\ucrtbase.DLL, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-localization-l1-2-0.dll .\api-ms-win-core-localization-l1-2-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-processthreads-l1-1-1.dll .\api-ms-win-core-processthreads-l1-1-1.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-file-l1-2-0.dll .\api-ms-win-core-file-l1-2-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-timezone-l1-1-0.dll .\api-ms-win-core-timezone-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-file-l2-1-0.dll .\api-ms-win-core-file-l2-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-synch-l1-2-0.dll .\api-ms-win-core-synch-l1-2-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-stdio-l1-1-0.dll .\api-ms-win-crt-stdio-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-heap-l1-1-0.dll .\api-ms-win-crt-heap-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-string-l1-1-0.dll .\api-ms-win-crt-string-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-convert-l1-1-0.dll .\api-ms-win-crt-convert-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-locale-l1-1-0.dll .\api-ms-win-crt-locale-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-math-l1-1-0.dll .\api-ms-win-crt-math-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-time-l1-1-0.dll .\api-ms-win-crt-time-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) IMM32.DLL C:\Windows\system32\IMM32.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) MSCTF.dll C:\Windows\system32\MSCTF.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) hostfxr.dll .\hostfxr.dll, version=6,0,822,36306 @Commit: 55fb7ef977e7d120dc12f0960edcff0739d7ee0e api-ms-win-crt-filesystem-l1-1-0.dll .\api-ms-win-crt-filesystem-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) hostpolicy.dll .\hostpolicy.dll, version=6,0,822,36306 @Commit: 55fb7ef977e7d120dc12f0960edcff0739d7ee0e coreclr.dll .\coreclr.dll, version=6,0,822,36306 @Commit: 55fb7ef977e7d120dc12f0960edcff0739d7ee0e ole32.dll C:\Windows\system32\ole32.dll, version=6.1.7601.24537 (win7sp1_ldr_escrow.191114-1547) OLEAUT32.dll C:\Windows\system32\OLEAUT32.dll, version=6.1.7601.24537 api-ms-win-crt-utility-l1-1-0.dll .\api-ms-win-crt-utility-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) CRYPTBASE.dll C:\Windows\system32\CRYPTBASE.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707) System.Private.CoreLib.dll .\System.Private.CoreLib.dll, version=6.0.822.36306 MSCOREE.DLL C:\Windows\SYSTEM32\MSCOREE.DLL, version=4.0.40305.0 (Main.040305-0000) clrjit.dll .\clrjit.dll, version=6,0,822,36306 @Commit: 55fb7ef977e7d120dc12f0960edcff0739d7ee0e paintdotnet.dll .\paintdotnet.dll, version=4.312.8267.29064 System.Runtime.dll .\System.Runtime.dll, version=6.0.822.36306 uxtheme.dll C:\Windows\system32\uxtheme.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) PaintDotNet.Base.dll .\PaintDotNet.Base.dll, version=4.312.8267.29064 System.Windows.Forms.dll .\System.Windows.Forms.dll, version=6.0.822.36804 System.Diagnostics.Process.dll .\System.Diagnostics.Process.dll, version=6.0.822.36306 PaintDotNet.SystemLayer.dll .\PaintDotNet.SystemLayer.dll, version=4.312.8267.29064 TerraFX.Interop.Windows.dll .\TerraFX.Interop.Windows.dll, version=10.0.20348.0 System.Runtime.InteropServices.RuntimeInformation.dll .\System.Runtime.InteropServices.RuntimeInformation.dll, version=6.0.822.36306 System.Runtime.InteropServices.dll .\System.Runtime.InteropServices.dll, version=6.0.822.36306 api-ms-win-core-console-l1-1-0.dll .\api-ms-win-core-console-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-console-l1-2-0.dll .\api-ms-win-core-console-l1-2-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-datetime-l1-1-0.dll .\api-ms-win-core-datetime-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-debug-l1-1-0.dll .\api-ms-win-core-debug-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-errorhandling-l1-1-0.dll .\api-ms-win-core-errorhandling-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-fibers-l1-1-0.dll .\api-ms-win-core-fibers-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-file-l1-1-0.dll .\api-ms-win-core-file-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-handle-l1-1-0.dll .\api-ms-win-core-handle-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-heap-l1-1-0.dll .\api-ms-win-core-heap-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-interlocked-l1-1-0.dll .\api-ms-win-core-interlocked-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-libraryloader-l1-1-0.dll .\api-ms-win-core-libraryloader-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-memory-l1-1-0.dll .\api-ms-win-core-memory-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-namedpipe-l1-1-0.dll .\api-ms-win-core-namedpipe-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-processenvironment-l1-1-0.dll .\api-ms-win-core-processenvironment-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-processthreads-l1-1-0.dll .\api-ms-win-core-processthreads-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-profile-l1-1-0.dll .\api-ms-win-core-profile-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-rtlsupport-l1-1-0.dll .\api-ms-win-core-rtlsupport-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-string-l1-1-0.dll .\api-ms-win-core-string-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-synch-l1-1-0.dll .\api-ms-win-core-synch-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-sysinfo-l1-1-0.dll .\api-ms-win-core-sysinfo-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-core-util-l1-1-0.dll .\api-ms-win-core-util-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-conio-l1-1-0.dll .\api-ms-win-crt-conio-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-environment-l1-1-0.dll .\api-ms-win-crt-environment-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-multibyte-l1-1-0.dll .\api-ms-win-crt-multibyte-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-private-l1-1-0.dll .\api-ms-win-crt-private-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) api-ms-win-crt-process-l1-1-0.dll .\api-ms-win-crt-process-l1-1-0.dll, version=10.0.22000.194 (WinBuild.160101.0800) vcruntime140.dll .\vcruntime140.dll, version=14.32.31332.0 vcruntime140_1.dll .\vcruntime140_1.dll, version=14.32.31332.0 msvcp140.dll .\msvcp140.dll, version=14.32.31332.0 msvcp140_1.dll .\msvcp140_1.dll, version=14.32.31332.0 msvcp140_2.dll .\msvcp140_2.dll, version=14.32.31332.0 msvcp140_codecvt_ids.dll .\msvcp140_codecvt_ids.dll, version=14.32.31332.0 vcomp140.dll .\vcomp140.dll, version=14.32.31332.0 ijwhost.dll .\ijwhost.dll, version=6,0,822,36306 @Commit: 55fb7ef977e7d120dc12f0960edcff0739d7ee0e PaintDotNet.SystemLayer.Native.x64.dll .\PaintDotNet.SystemLayer.Native.x64.dll, version=4.312.8267.29064 PROPSYS.dll C:\Windows\system32\PROPSYS.dll, version=7.00.7600.16385 (win7_rtm.090713-1255) gdiplus.dll C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.24542_none_1459e0f08b91b367\gdiplus.dll, version=6.1.7601.24542 (win7sp1_ldr_escrow.191209-2211) WindowsCodecs.dll C:\Windows\system32\WindowsCodecs.dll, version=6.2.9200.22551 (win8_ldr_escrow.180828-1117) System.Threading.dll .\System.Threading.dll, version=6.0.822.36306 System.Runtime.Extensions.dll .\System.Runtime.Extensions.dll, version=6.0.822.36306 System.Runtime.CompilerServices.VisualC.dll .\System.Runtime.CompilerServices.VisualC.dll, version=6.0.822.36306 System.Collections.NonGeneric.dll .\System.Collections.NonGeneric.dll, version=6.0.822.36306 System.Runtime.Intrinsics.dll .\System.Runtime.Intrinsics.dll, version=6.0.822.36306 PaintDotNet.Core.dll .\PaintDotNet.Core.dll, version=4.312.8267.29064 System.Private.Uri.dll .\System.Private.Uri.dll, version=6.0.822.36306 BCrypt.dll C:\Windows\system32\BCrypt.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707) System.ComponentModel.Primitives.dll .\System.ComponentModel.Primitives.dll, version=6.0.822.36306 bcryptprimitives.dll C:\Windows\system32\bcryptprimitives.dll, version=6.1.7601.23451 (win7sp1_ldr.160511-0600) System.Windows.Forms.Primitives.dll .\System.Windows.Forms.Primitives.dll, version=6.0.822.36804 System.Drawing.Primitives.dll .\System.Drawing.Primitives.dll, version=6.0.822.36306 WindowsBase.dll .\WindowsBase.dll, version=6.0.822.36807 System.Diagnostics.TraceSource.dll .\System.Diagnostics.TraceSource.dll, version=6.0.822.36306 PresentationFramework.dll .\PresentationFramework.dll, version=6.0.822.36807 System.Collections.dll .\System.Collections.dll, version=6.0.822.36306 System.Text.Encoding.CodePages.dll .\System.Text.Encoding.CodePages.dll, version=6.0.822.36306 System.Xaml.dll .\System.Xaml.dll, version=6.0.822.36807 PaintDotNet.Resources.dll .\PaintDotNet.Resources.dll, version=4.312.8267.29064 System.ComponentModel.dll .\System.ComponentModel.dll, version=6.0.822.36306 System.ObjectModel.dll .\System.ObjectModel.dll, version=6.0.822.36306 PaintDotNet.Data.dll .\PaintDotNet.Data.dll, version=4.312.8267.29064 System.Threading.Thread.dll .\System.Threading.Thread.dll, version=6.0.822.36306 CRYPTSP.dll C:\Windows\system32\CRYPTSP.dll, version=6.1.7601.24499 (win7sp1_ldr.190612-0600) rsaenh.dll C:\Windows\system32\rsaenh.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) RpcRtRemote.dll C:\Windows\system32\RpcRtRemote.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) Microsoft.Win32.Primitives.dll .\Microsoft.Win32.Primitives.dll, version=6.0.822.36306 PaintDotNet.Framework.dll .\PaintDotNet.Framework.dll, version=4.312.8267.29064 Microsoft.Win32.SystemEvents.dll .\Microsoft.Win32.SystemEvents.dll, version=6.0.822.36306 System.Drawing.Common.dll .\System.Drawing.Common.dll, version=6.0.822.36306 System.Threading.ThreadPool.dll .\System.Threading.ThreadPool.dll, version=6.0.822.36306 System.Collections.Immutable.dll .\System.Collections.Immutable.dll, version=6.0.822.36306 PresentationNative_cor3.dll .\PresentationNative_cor3.dll, version=6,0,22,31404 @Commit: 02282bc994b3e7cd210e76caca2daa1cbcf934c4 System.ComponentModel.EventBasedAsync.dll .\System.ComponentModel.EventBasedAsync.dll, version=6.0.822.36306 System.Configuration.ConfigurationManager.dll .\System.Configuration.ConfigurationManager.dll, version=6.0.822.36306 dxgi.dll C:\Windows\system32\dxgi.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) VERSION.dll C:\Windows\system32\VERSION.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) dwmapi.dll C:\Windows\system32\dwmapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) System.Linq.dll .\System.Linq.dll, version=6.0.822.36306 WINTRUST.dll C:\Windows\system32\WINTRUST.dll, version=6.1.7601.24542 (win7sp1_ldr_escrow.191209-2211) CRYPT32.dll C:\Windows\system32\CRYPT32.dll, version=6.1.7601.24542 (win7sp1_ldr_escrow.191209-2211) MSASN1.dll C:\Windows\system32\MSASN1.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) System.Collections.Specialized.dll .\System.Collections.Specialized.dll, version=6.0.822.36306 System.Collections.Concurrent.dll .\System.Collections.Concurrent.dll, version=6.0.822.36306 System.Xml.ReaderWriter.dll .\System.Xml.ReaderWriter.dll, version=6.0.822.36306 System.Private.Xml.dll .\System.Private.Xml.dll, version=6.0.822.36306 Microsoft.Win32.Registry.dll .\Microsoft.Win32.Registry.dll, version=6.0.822.36306 System.Security.Principal.Windows.dll .\System.Security.Principal.Windows.dll, version=6.0.822.36306 System.Security.Claims.dll .\System.Security.Claims.dll, version=6.0.822.36306 System.Net.WebClient.dll .\System.Net.WebClient.dll, version=6.0.822.36306 System.Memory.dll .\System.Memory.dll, version=6.0.822.36306 d2d1.dll C:\Windows\system32\d2d1.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) System.Text.Encoding.Extensions.dll .\System.Text.Encoding.Extensions.dll, version=6.0.822.36306 System.ComponentModel.TypeConverter.dll .\System.ComponentModel.TypeConverter.dll, version=6.0.822.36306 PresentationCore.dll .\PresentationCore.dll, version=6.0.822.36807 DirectWriteForwarder.dll .\DirectWriteForwarder.dll, version=6,0,822,36807 @Commit: 7a75fd34f53bc300206bd8cfc636527934dd17af System.Diagnostics.Debug.dll .\System.Diagnostics.Debug.dll, version=6.0.822.36306 dwrite.dll C:\Windows\system32\dwrite.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) UIAutomationTypes.dll .\UIAutomationTypes.dll, version=6.0.822.36807 System.Diagnostics.FileVersionInfo.dll .\System.Diagnostics.FileVersionInfo.dll, version=6.0.822.36306 PaintDotNet.Effects.dll .\PaintDotNet.Effects.dll, version=4.312.8267.29064 Accessibility.dll .\Accessibility.dll, version=6.0.822.36804 System.Threading.Tasks.Parallel.dll .\System.Threading.Tasks.Parallel.dll, version=6.0.822.36306 profapi.dll C:\Windows\system32\profapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) CLBCatQ.DLL C:\Windows\system32\CLBCatQ.DLL, version=2001.12.8530.16385 (win7_rtm.090713-1255) UIAnimation.dll C:\Windows\System32\UIAnimation.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) System.Numerics.Vectors.dll .\System.Numerics.Vectors.dll, version=6.0.822.36306 comctl32.dll C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24483_none_e372d88f30fbb845\comctl32.dll, version=6.10 (win7_rtm.090713-1255) System.Diagnostics.Tracing.dll .\System.Diagnostics.Tracing.dll, version=6.0.822.36306 System.Reflection.MetadataLoadContext.dll .\System.Reflection.MetadataLoadContext.dll, version=6.0.21.52210 System.IO.Packaging.dll .\System.IO.Packaging.dll, version=6.0.822.36306 System.Reflection.Metadata.dll .\System.Reflection.Metadata.dll, version=6.0.822.36306 System.IO.MemoryMappedFiles.dll .\System.IO.MemoryMappedFiles.dll, version=6.0.822.36306 System.Runtime.Loader.dll .\System.Runtime.Loader.dll, version=6.0.822.36306 PhotoShop.dll .\FileTypes\PhotoShop.dll, version=2.5.0.0 OptiPngFileType.dll .\FileTypes\OptiPngFileType.dll, version=11.0.0.0 ImZIP.FileType.dll .\FileTypes\ImZIP.FileType.dll, version=1.0.0.225 IcoCur.dll .\FileTypes\IcoCur.dll, version=4.0.1.0 mscorlib.dll .\mscorlib.dll, version=6.0.822.36306 System.Drawing.dll .\System.Drawing.dll, version=6.0.822.36804 System.dll .\System.dll, version=6.0.822.36306 wtsapi32.dll C:\Windows\system32\wtsapi32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) WINSTA.dll C:\Windows\system32\WINSTA.dll, version=6.1.7601.18540 (win7sp1_gdr.140716-1508) DdsFileTypePlus.dll .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.12.0 WebPFileType.dll .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.14.0 AvifFileType.dll .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.20.0 d3d11.dll C:\Windows\system32\d3d11.dll, version=6.2.9200.16570 (win8_gdr.130327-1526) UIAutomationCore.dll C:\Windows\system32\UIAutomationCore.dll, version=7.0.0.0 (win7_rtm.090713-1255) PSAPI.DLL C:\Windows\system32\PSAPI.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) OLEACC.dll C:\Windows\system32\OLEACC.dll, version=7.0.0.0 (win7sp1_gdr.110826-1504) D3D10Warp.dll C:\Windows\system32\D3D10Warp.dll, version=6.2.9200.22592 (win8_ldr.181005-0600) Mono.Cecil.dll .\Mono.Cecil.dll, version=0.11.4.0 netstandard.dll .\netstandard.dll, version=6.0.822.36306 System.Console.dll .\System.Console.dll, version=6.0.822.36306 AA's_Assistant.dll .\Effects\AA's_Assistant.dll, version=1.1.4329.33034 Alpha_to_0.dll .\Effects\Alpha_to_0.dll, version=1.0.4452.22746 Alpha_to_255.dll .\Effects\Alpha_to_255.dll, version=1.0.4452.22782 AnimationEffect.dll .\Effects\AnimationEffect.dll, version=1.0.0.96 BlackandAlpha+.dll .\Effects\BlackandAlpha+.dll, version=1.2.4329.272 Vandermotten.PaintDotNetEffects.ObjectAlign.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=4.3.2.0 Metallize.dll .\Effects\Metallize.dll, version=1.2.4415.32969 Vandermotten.PaintDotNetEffects.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.dll, version=4.3.2.0 CircleText.dll .\Effects\CircleText.dll, version=1.4.4415.32488 dpyColorBalance.dll .\Effects\dpyColorBalance.dll, version=1.1.4330.37850 MultiThreshold.dll .\Effects\MultiThreshold.dll, version=1.1.4330.38982 Pastel.dll .\Effects\Pastel.dll, version=1.0.0.0 Pixelate+.dll .\Effects\Pixelate+.dll, version=4.0.4642.26940 pxEexpansion.dll .\Effects\pxEexpansion.dll, version=1.0.4437.36287 Perspective.dll .\Effects\Perspective.dll, version=2.1.4415.36116 apphelp.dll C:\Windows\system32\apphelp.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) RGB2CMYK.dll .\Effects\RGB2CMYK.dll, version=0.0.0.0 Recolor Using Palette.dll .\Effects\Recolor Using Palette.dll, version=1.0.6382.573 RotateText.dll .\Effects\RotateText.dll, version=1.1.4415.32628 RotateTextSUI.dll .\Effects\RotateTextSUI.dll, version=1.1.4415.32713 Rotate_Zoom+.dll .\Effects\Rotate_Zoom+.dll, version=1.11.5237.17779 SpeechBubble.dll .\Effects\SpeechBubble.dll, version=2.1.4445.42029 System.Resources.Extensions.dll .\System.Resources.Extensions.dll, version=6.0.822.36306 SpiralText.dll .\Effects\SpiralText.dll, version=1.4.4415.32775 Textplus.dll .\Effects\Textplus.dll, version=1.0.0.0 System.Runtime.Serialization.Formatters.dll .\System.Runtime.Serialization.Formatters.dll, version=6.0.822.36306 WaveText.dll .\Effects\WaveText.dll, version=1.2.4415.32811 WaveTextSUI.dll .\Effects\WaveTextSUI.dll, version=1.2.4415.33440 Vandermotten.PaintDotNetEffects.Blurs.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=4.3.2.0 Vandermotten.PaintDotNetEffects.ColorAccent.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version=4.3.2.0 Vandermotten.PaintDotNetEffects.Duotones.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version=4.3.2.0 Vandermotten.PaintDotNetEffects.DropShadow.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=4.3.2.0 Vandermotten.PaintDotNetEffects.FadeEdge.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version=4.3.2.0 Vandermotten.PaintDotNetEffects.Monochromes.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version=4.3.2.0 Vandermotten.PaintDotNetEffects.Gradient.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=4.3.2.0 Vandermotten.PaintDotNetEffects.Grid.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, version=4.3.2.0 Vandermotten.PaintDotNetEffects.MakeTransparent.dll C:\Users\vir\Documents\paint.net App Files\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, version=4.3.2.0 System.CodeDom.dll .\System.CodeDom.dll, version=6.0.822.36306 Crc32.NET.dll .\Crc32.NET.dll, version=1.2.0.5 System.Security.Cryptography.Primitives.dll .\System.Security.Cryptography.Primitives.dll, version=6.0.822.36306 System.Text.RegularExpressions.dll .\System.Text.RegularExpressions.dll, version=6.0.822.36306 Newtonsoft.Json.dll .\Newtonsoft.Json.dll, version=13.0.1.25517 System.Linq.Expressions.dll .\System.Linq.Expressions.dll, version=6.0.822.36306 System.Runtime.Numerics.dll .\System.Runtime.Numerics.dll, version=6.0.822.36306 winmm.DLL C:\Windows\system32\winmm.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) System.Runtime.CompilerServices.Unsafe.dll .\System.Runtime.CompilerServices.Unsafe.dll, version=6.0.822.36306 explorerframe.dll C:\Windows\system32\explorerframe.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) DUser.dll C:\Windows\system32\DUser.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) DUI70.dll C:\Windows\system32\DUI70.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) System.Net.Http.dll .\System.Net.Http.dll, version=6.0.822.36306 System.Net.Primitives.dll .\System.Net.Primitives.dll, version=6.0.822.36306 System.Diagnostics.DiagnosticSource.dll .\System.Diagnostics.DiagnosticSource.dll, version=6.0.822.36306 System.Net.Security.dll .\System.Net.Security.dll, version=6.0.822.36306 System.Security.Cryptography.X509Certificates.dll .\System.Security.Cryptography.X509Certificates.dll, version=6.0.822.36306 iphlpapi.dll C:\Windows\system32\iphlpapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) NSI.dll C:\Windows\system32\NSI.dll, version=6.1.7601.23889 (win7sp1_ldr.170810-1615) WINNSI.DLL C:\Windows\system32\WINNSI.DLL, version=6.1.7601.23889 (win7sp1_ldr.170810-1615) DNSAPI.dll C:\Windows\system32\DNSAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) WS2_32.dll C:\Windows\system32\WS2_32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) dhcpcsvc6.DLL C:\Windows\system32\dhcpcsvc6.DLL, version=6.1.7601.24498 (win7sp1_ldr_escrow.190712-1655) dhcpcsvc.DLL C:\Windows\system32\dhcpcsvc.DLL, version=6.1.7601.24498 (win7sp1_ldr_escrow.190712-1655) winhttp.dll C:\Windows\system32\winhttp.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) webio.dll C:\Windows\system32\webio.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) SspiCli.dll C:\Windows\system32\SspiCli.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707) credssp.dll C:\Windows\system32\credssp.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707) CFGMGR32.dll C:\Windows\system32\CFGMGR32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) System.Net.Sockets.dll .\System.Net.Sockets.dll, version=6.0.822.36306 mswsock.dll C:\Windows\system32\mswsock.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) wship6.dll C:\Windows\System32\wship6.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) wshtcpip.dll C:\Windows\System32\wshtcpip.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) System.Threading.Overlapped.dll .\System.Threading.Overlapped.dll, version=6.0.822.36306 System.Net.NameResolution.dll .\System.Net.NameResolution.dll, version=6.0.822.36306 rasadhlp.dll C:\Windows\system32\rasadhlp.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) fwpuclnt.dll C:\Windows\System32\fwpuclnt.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) schannel.DLL C:\Windows\system32\schannel.DLL, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707) Normaliz.dll C:\Windows\system32\Normaliz.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) secur32.dll C:\Windows\system32\secur32.dll, version=6.1.7601.24545 (win7sp1_ldr_escrow.200102-1707) ncrypt.dll C:\Windows\system32\ncrypt.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) System.Security.Cryptography.Encoding.dll .\System.Security.Cryptography.Encoding.dll, version=6.0.822.36306 USERENV.dll C:\Windows\system32\USERENV.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) GPAPI.dll C:\Windows\system32\GPAPI.dll, version=6.1.7601.23452 (win7sp1_ldr.160512-0600) System.IO.Compression.dll .\System.IO.Compression.dll, version=6.0.822.36306 K4os.Compression.LZ4.dll .\K4os.Compression.LZ4.dll, version=1.2.15 XmlLite.dll C:\Windows\system32\XmlLite.dll, version=1.3.1001.0 MsftEdit.DLL C:\Windows\system32\MsftEdit.DLL, version=5.41.21.2510 setupapi.DLL C:\Windows\system32\setupapi.DLL, version=6.1.7600.16385 (win7_rtm.090713-1255) DEVOBJ.dll C:\Windows\system32\DEVOBJ.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted November 6, 2022 Share Posted November 6, 2022 11 minutes ago, StudioLoading said: OS Windows 7 Professional Service Pack 1 x64 (6.1.7601.0) CPU AMD Ryzen 5 5500U with Radeon Graphics Video Card Software Adapter This is a very unsupported system. I'm not surprised you're having issues. You're running Windows 7 on hardware that doesn't even have drivers for Windows 7. At the bear minimum, you have no Ryzen chipset drivers and no Radeon GPU drivers. I wonder what other hardware components are not operating correctly. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
StudioLoading Posted November 7, 2022 Share Posted November 7, 2022 I am operating from a local Oracle Virtual Machine. The hardware is actually a Ryzen 5: https://www.amazon.it/gp/product/B08VDJFJ8S more officially: https://www.lenovo.com/ph/en/laptops/ideapad/s-series/IdeaPad-5-14ARE05/p/88IPS501392 Win 7 is not supported then? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 7, 2022 Share Posted November 7, 2022 Do you have the Platform Update installed? It's a requirement for Classic installs under Win 7. See https://www.getpaint.net/doc/latest/SystemRequirements.html Reminder: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
null54 Posted November 8, 2022 Share Posted November 8, 2022 1 hour ago, Ego Eram Reputo said: It's a requirement for Classic installs under Win 7. Paint.NET will install it automatically if it is not present. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 8, 2022 Share Posted November 8, 2022 25 minutes ago, null54 said: Paint.NET will install it automatically if it is not present. Yeah you wouldn’t be able to launch PDN without it — Direct2D v1.1 is utilized right away at startup Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 8, 2022 Share Posted November 8, 2022 16 hours ago, StudioLoading said: I am operating from a local Oracle Virtual Machine. The hardware is actually a Ryzen 5: https://www.amazon.it/gp/product/B08VDJFJ8S more officially: https://www.lenovo.com/ph/en/laptops/ideapad/s-series/IdeaPad-5-14ARE05/p/88IPS501392 Win 7 is not supported then? Ryzens don’t support Windows 7, they don’t have drivers or proper HAL support IIRC. There have been a few problems because of this over the years. PDN v4.2.x would occasionally crash due to a multithreading issue that only existed on this configuration (the code was actually fine). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
StudioLoading Posted November 8, 2022 Share Posted November 8, 2022 Alright, so this is not correct on getpaint website? Otherwise, what's the latest paint.net version fully working on Windows 7 ? Thank you F Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 8, 2022 Share Posted November 8, 2022 This is about the Ryzen series of CPUs -- they don't support Windows 7. Paint.NET does support Windows 7 -- for a little while longer, at least. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
StudioLoading Posted November 9, 2022 Share Posted November 9, 2022 Wait, Win7 is not sopportted by the hardware it's currently running on? I don't get what are you suggesting to do to fix that selection problem. Thank you F Quote Link to comment Share on other sites More sharing options...
mariawe1.9.9.1 Posted December 30, 2022 Share Posted December 30, 2022 Unbelievable, PDN devs avoiding the question by steering the thread off topic..this must be the first time it has happened hahaha.. I had this problem a few times these past three years. Today I had this problem again with one PDN tab (just one, new ones and old ones had working selection tools). I am using latest PDN version on latest version of Windows 10 with updated drivers and everything. It's same as what StudioLoading described—it says I used the selection tool in history but it doesn't actually select anything, nor does a selection box show. It is not on 'negate' or anything. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 30, 2022 Share Posted December 30, 2022 No need for sarcasm. It doesn’t help. Try the 5.0 beta, I did find and fix a bug in the bowels of the canvas UI code. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
