t.urk Posted October 19, 2021 Share Posted October 19, 2021 recently I updated paint.net and that update caused the paint.net file to be corrupted. I just deleted the file and tried to re-install it, but after I tried to reinstall it I got this error message. (displayed in the picture) I tried searching up the missing file and nothing would pop up, what can I do to fix it? Quote Link to comment Share on other sites More sharing options...
Solution toe_head2001 Posted October 19, 2021 Solution Share Posted October 19, 2021 Please use this utility to properly remove your previous Paint.NET installation: https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed Afterwards, you can install Paint.NET anew. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
