OotF#80 - Ice Cube 🧊 - Entries.
Pixey
Object of the Fortnight #80 - An Ice Cube 🧊
"You may have a background other than white for this competition.
It can be a fixed color or a simple gradient."
And, here is a better description of what you may do: https://forums.getpaint.net/topic/117939-object-of-the-fortnight-discussion-thread/?do=findComment&comment=586143
Some samples.
Special thanks to @toe_head2001 and @Ego Eram Reputo for being the theme generators 😊
The deadline for entries is 2.00 PM EST (7:00 PM UK Time) on Saturday 18th September 2021.
 Please see the Countdown Timer for exact time remaining.
This thread is for posting competition entries only. If you're not posting an entry, please don't post here.
Competition Rules:
1. Your entry must not have a background/backdrop/scene; just the object on a transparent canvas. Shadows and reflections are fine.
 2. Your entry must be 100% made using Paint.net. Don't use another image editor. Don't use stock images/photos/textures (in full or parts thereof.)
 3. Max dimensions are 600 x 600.
 4. You may modify or replace your image until the deadline.
 5. Three entries per entrant are allowed. Please make a separate post for each one.
 Many thanks to @toe_head2001 and @DrewDale for launching and hosting the competitions in the past.  Previous comps have included the following topics here.
