Flingrabu Posted September 3, 2021 Share Posted September 3, 2021 Hi, Oftentimes I'll need to illustrate something by hand. Color of paper cream color. Once done I'll try to scan the pages. Whenever I use the Auto-Level feature on the scanned results the colors come out REALLY intense - to the point of being unrecognizable - so that even the hand-written number 3 with a circle comes out like this: https://ibb.co/k1CM70g The best i could do is to reduce the scanner to 75 DPI - then hand modify the Levels' center column left side. That comes out pretty well. But, for lots of pages, it's a lot of work. Any time I use the Autolevels, the results are seemingly unusable. What do you think is happening? Thanks! Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 3, 2021 Share Posted September 3, 2021 Auto-Levels is generally intended for photographs, so it will probably not work well for other purposes. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Reptillian Posted September 3, 2021 Share Posted September 3, 2021 I have managed to do histogram-based normalization though I can only get back to you on Tuesday for that as I'll be away from my normal PC. For now, you could play with curves tool or levels tool(if it exists in non-auto form). Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
Flingrabu Posted September 4, 2021 Author Share Posted September 4, 2021 Hi Rick, Yep, yep. I follow. Is there any document-focused app you think I could try? Reptillian! Ah, thanks. Looking forward to that. Sincerely, Flin Quote Link to comment Share on other sites More sharing options...
Reptillian Posted September 6, 2021 Share Posted September 6, 2021 On 9/4/2021 at 6:10 AM, Flingrabu said: Reptillian! Ah, thanks. Looking forward to that. Now, I'm back to main computer. I am able to send you what I have. Download my own solution to your problem - Histogram Normalization.zip Lemme know if it works. Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
Flingrabu Posted September 7, 2021 Author Share Posted September 7, 2021 Hi Reptillian! Ah, BLESS you, mate! How do I install? Sincerely, Flin Quote Link to comment Share on other sites More sharing options...
Reptillian Posted September 7, 2021 Share Posted September 7, 2021 (edited) Here's the link to a guide to install pdn plugins - https://boltbait.com/pdn/InstallingEffects.php Edited September 7, 2021 by Reptillian Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
ardneh Posted September 7, 2021 Share Posted September 7, 2021 If you have the Windows Store version of paint.net: In the Windows Store version of paint.net, the directories for plugins and Shapes are different. These locations need to be created manually. First navigate to your Documents folder (this may be translated to your system language). In it, create a new folder called paint.net App Files Then create three subfolders in the new folder. These should be called: Effects, FileTypes and Shapes. The correct spelling of these folder names is essential, however Windows and paint.net will ignore the capitalization (or lack of). Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 7, 2021 Share Posted September 7, 2021 https://www.getpaint.net/doc/latest/InstallPlugins.html Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Flingrabu Posted September 8, 2021 Author Share Posted September 8, 2021 Hi Reptillian, ardneh & Rick!! Ah! Thanks. Will give it a go this evening once things slow down. Sincerely, Flin Quote Link to comment Share on other sites More sharing options...
Reptillian Posted September 8, 2021 Share Posted September 8, 2021 11 hours ago, Flingrabu said: Hi Reptillian, ardneh & Rick!! Ah! Thanks. Will give it a go this evening once things slow down. Sincerely, Flin Have you been able to install it and test it? Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
