paint.net 4.3 alpha build 7881
Rick Brewster
1 hour ago, AndrewDavid said:
Brush Factory is crashing the beta build
The Brush Factory plugin will need to be updated to not use the ancient ContextMenu type that was made obsolete way back in .NET Framework 2.0.
  • Thanks 1
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
Please make sure to tell me all of the plugins you've found that no longer work. I will add them to the list of blocked plugins, along with the notes for "incompatible" and "update available" (hopefully).
On 7/31/2021 at 6:39 AM, Pixey said:
I just updated to 4.3 (a 4.300.7881.30820) and am experiencing trouble with the Gradient Tool set to transparency.
This:   Untitled.png
With Gradient set to transparency:  transparent-gradient-mode.png
@Pixey can you show me your full toolbar and Colors window settings? I'm not necessarily sure what you mean by "with Gradient set to transparency"  (alpha mode, I'm guessing?) -- this doesn't reproduce for me 🤔
Also can you post the text from Diagnostics? Or at least the CPU section, like so:
49 minutes ago, AndrewDavid said:
@Rick Brewster
Are you trying @Pixey ' bug on a new layer?
Open New
Add Layer
Draw a couple of lines.
On same layer, select transparent gradient and see the lines break apart.
Okay perfect, that repros for me. Thanks! And thanks @ardneh for the second confirmation
Okay I figured out the cause and I've fixed it
As it turns out my code was just completely wrong :) It was accidentally working fine when the alpha values were homogenous, e.g. all 0 or all 255 (or all anything else). In the screenshots it looks like the color values are getting shifted around, but that's not actually the case -- all those pixels have RGB values of 0, it's just the alpha values that delineate what you see as "the line".
Another filetype to add to your list
Spoiler
Exception:
System.TypeLoadException: Could not load type 'System.Windows.Forms.ContextMenu' from assembly 'System.Windows.Forms, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.
   at OptionBasedFileTypes.OpenFileType.OnLoad(Stream input)
   at PaintDotNet.FileType.Load(Stream input) in D:\src\pdn\src\Data\FileType.cs:line 501
   at PaintDotNet.Functional.Func.Eval[T1,TRet](Func`2 f, T1 arg1) in D:\src\pdn\src\Base\Functional\Func.cs:line 158
Diagnostics:
Application                                                  paint.net 4.3 (α 4.300.7881.3082)
Build Date                                                   Friday, July 30, 2021
Expiration Date                                              Friday, October 22, 2021
Install type                                                 Classic
Hardware accelerated rendering (GPU)                         True
Animations                                                   True
DPI                                                          96 (1.00x scale)
Language                                                     en-US
OS                                                           Windows 10 Home x64 (10.0.19044.0)
Runtime                                                      .NET 5.0.8 x64
Physical Memory                                              8,143 MB
CPU                                                          Intel(R) Core(TM) i5-4460  CPU @ 3.20GHz
    Speed                                                    ~3193 MHz
    Cores / Threads                                          4 / 4
    Features                                                 SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2
Video Card                                                   NVIDIA GeForce GT 720
    Dedicated Video RAM                                      984 MB
    Dedicated System RAM                                     0 MB
    Shared System RAM                                        4,071 MB
    Vendor ID                                                0x10DE
    Device ID                                                0x1286
    Subsystem ID                                             0x108710DE
    Revision                                                 161
    LUID                                                     0x0000D7D3
    Flags                                                    AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                                      DmaBufferBoundary
    Compute Preemption                                       DmaBufferBoundary
    Outputs                                                  1
    Feature Level                                            Direct3D_11_0
    DXGI Formats                                             A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float
    Buffer Precision                                         UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc
Video Card                                                   Microsoft Basic Render Driver
    Dedicated Video RAM                                      0 MB
    Vendor ID                                                0x1414
    Device ID                                                0x008C
    Subsystem ID                                             0x00000000
    Revision                                                 0
    LUID                                                     0x0000E1ED
    Flags                                                    Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                                      InstructionBoundary
    Compute Preemption                                       InstructionBoundary
    Outputs                                                  0
    Feature Level                                            Direct3D_12_1
Managed assemblies                                           723
    System.Private.CoreLib                                   System.Private.CoreLib, Version=5.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e
    paintdotnet                                              paintdotnet, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    System.Runtime                                           System.Runtime, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Windows.Forms                                     System.Windows.Forms, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    PaintDotNet.Base                                         PaintDotNet.Base, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    System.Collections                                       System.Collections, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.SystemLayer                                  PaintDotNet.SystemLayer, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    PaintDotNet.Core                                         PaintDotNet.Core, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    PaintDotNet.Resources                                    PaintDotNet.Resources, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    System.Runtime.InteropServices.RuntimeInformation        System.Runtime.InteropServices.RuntimeInformation, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.FileSystem                                     System.IO.FileSystem, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Thread                                  System.Threading.Thread, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.Concurrent                            System.Collections.Concurrent, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.SystemLayer.Native.x64                       PaintDotNet.SystemLayer.Native.x64, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    System.Threading                                         System.Threading, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Extensions                                System.Runtime.Extensions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.InteropServices                           System.Runtime.InteropServices, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.VisualC                  System.Runtime.CompilerServices.VisualC, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.NonGeneric                            System.Collections.NonGeneric, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Memory                                            System.Memory, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.Private.Uri                                       System.Private.Uri, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.Primitives                         System.ComponentModel.Primitives, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    WindowsBase                                              WindowsBase, Version=5.0.8.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    System.Windows.Forms.Primitives                          System.Windows.Forms.Primitives, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Microsoft.Win32.Primitives                               Microsoft.Win32.Primitives, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Drawing.Primitives                                System.Drawing.Primitives, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Configuration.ConfigurationManager                System.Configuration.ConfigurationManager, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.Diagnostics.TraceSource                           System.Diagnostics.TraceSource, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.CodePages                           System.Text.Encoding.CodePages, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.Specialized                           System.Collections.Specialized, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.ObjectModel                                       System.ObjectModel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Data                                         PaintDotNet.Data, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    System.Private.Xml                                       System.Private.Xml, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.Net.WebClient                                     System.Net.WebClient, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.Framework                                    PaintDotNet.Framework, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    netstandard                                              netstandard, Version=2.1.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.Security.Cryptography.Algorithms                  System.Security.Cryptography.Algorithms, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.SystemEvents                             Microsoft.Win32.SystemEvents, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.Drawing.Common                                    System.Drawing.Common, Version=5.0.0.2, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.ComponentModel.EventBasedAsync                    System.ComponentModel.EventBasedAsync, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Registry                                 Microsoft.Win32.Registry, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Linq                                              System.Linq, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    PresentationFramework                                    PresentationFramework, Version=5.0.8.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    System.Xml.ReaderWriter                                  System.Xml.ReaderWriter, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.Extensions                          System.Text.Encoding.Extensions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.TypeConverter                      System.ComponentModel.TypeConverter, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Principal.Windows                        System.Security.Principal.Windows, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel                                    System.ComponentModel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Claims                                   System.Security.Claims, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Xaml                                              System.Xaml, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    PresentationCore                                         PresentationCore, Version=5.0.8.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    System.Threading.ThreadPool                              System.Threading.ThreadPool, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    DirectWriteForwarder                                     DirectWriteForwarder, Version=5.0.8.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    System.Diagnostics.FileVersionInfo                       System.Diagnostics.FileVersionInfo, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects                                      PaintDotNet.Effects, Version=4.300.7881.3082, Culture=neutral, PublicKeyToken=null
    Accessibility                                            Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
    System.Collections.Immutable                             System.Collections.Immutable, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.Unsafe                   System.Runtime.CompilerServices.Unsafe, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.Packaging                                      System.IO.Packaging, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Serialization.Formatters                  System.Runtime.Serialization.Formatters, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    mscorlib                                                 mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System.Runtime.Intrinsics                                System.Runtime.Intrinsics, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.Diagnostics.Debug                                 System.Diagnostics.Debug, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    ABRFileType                                              ABRFileType, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    ArgusPDN.AppIconSet                                      ArgusPDN.AppIconSet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    AsciiArtFileType                                         AsciiArtFileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    CSVFiletype                                              CSVFiletype, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    IcoCur                                                   IcoCur, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null
    ImAGIF.FileType                                          ImAGIF.FileType, Version=0.13.0.23943, Culture=neutral, PublicKeyToken=null
    ImPDF.Open.FileType                                      ImPDF.Open.FileType, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    ImPDF.Save.FileType                                      ImPDF.Save.FileType, Version=1.4.5187.23557, Culture=neutral, PublicKeyToken=null
    ImPS,EPS,AI.Open.FileType                                ImPS\,EPS\,AI.Open.FileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ImXcf.FileType                                           ImXcf.FileType, Version=1.4.0.95, Culture=neutral, PublicKeyToken=null
    ImZIP.FileType                                           ImZIP.FileType, Version=1.0.0.225, Culture=neutral, PublicKeyToken=null
    LowColor                                                 LowColor, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null
    OptionBasedLibrary v0.6                                  OptionBasedLibrary v0.6, Version=0.5.0.0, Culture=neutral, PublicKeyToken=null
    OptiPngFileType                                          OptiPngFileType, Version=11.0.0.0, Culture=neutral, PublicKeyToken=null
    PatternFileType                                          PatternFileType, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null
    PhotoShop                                                PhotoShop, Version=2.5.0.40665, Culture=neutral, PublicKeyToken=null
    PNGSpriteMatrix                                          PNGSpriteMatrix, Version=1.0.2.32048, Culture=neutral, PublicKeyToken=null
    RAWFile                                                  RAWFile, Version=1.0.5.1, Culture=neutral, PublicKeyToken=null
    SpriteSheet                                              SpriteSheet, Version=1.2.2.0, Culture=neutral, PublicKeyToken=null
    SvgFileType                                              SvgFileType, Version=1.0.3.1, Culture=neutral, PublicKeyToken=null
    TileImageFileType                                        TileImageFileType, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    System.Drawing                                           System.Drawing, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System                                                   System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System.Buffers                                           System.Buffers, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    AvifFileType                                             AvifFileType, Version=1.1.14.0, Culture=neutral, PublicKeyToken=null
    DdsFileTypePlus                                          DdsFileTypePlus, Version=1.10.10.0, Culture=neutral, PublicKeyToken=null
    System.Core                                              System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    WebPFileType                                             WebPFileType, Version=1.3.6.0, Culture=neutral, PublicKeyToken=null
    System.Xml                                               System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System.Resources.ResourceManager                         System.Resources.ResourceManager, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.CodeDom                                           System.CodeDom, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    System.Text.RegularExpressions                           System.Text.RegularExpressions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Numerics.Vectors                                  System.Numerics.Vectors, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Tasks.Parallel                          System.Threading.Tasks.Parallel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.Tracing                               System.Diagnostics.Tracing, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    2dImageFilter                                            2dImageFilter, Version=1.1.3.3, Culture=neutral, PublicKeyToken=null
    AA's_Assistant                                           "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null
    Aardvark                                                 Aardvark, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null
    Advanced Julia Fractal                                   Advanced Julia Fractal, Version=1.0.7702.38303, Culture=neutral, PublicKeyToken=null
    AdvancedRotate                                           AdvancedRotate, Version=1.0.3663.28009, Culture=neutral, PublicKeyToken=null
    a_kaleido                                                a_kaleido, Version=1.0.7194.37638, Culture=neutral, PublicKeyToken=null
    advcolorrep                                              advcolorrep, Version=1.3.3303.27314, Culture=neutral, PublicKeyToken=null
    AdvDith-en.dll                                           AdvDith-en.dll, Version=1.0.7500.29117, Culture=neutral, PublicKeyToken=null
    AdvGrey                                                  AdvGrey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    AForge.Imaging                                           AForge.Imaging, Version=2.2.5.0, Culture=neutral, PublicKeyToken=ba8ddea9676ca48b
    Align Object                                             Align Object, Version=1.0.1.9, Culture=neutral, PublicKeyToken=null
    AForge                                                   AForge, Version=2.2.5.0, Culture=neutral, PublicKeyToken=c1db6ff4eaa06aeb
    Align+                                                   Align+, Version=0.7.0.0, Culture=neutral, PublicKeyToken=null
    OptionBasedLibrary v0.7.9                                OptionBasedLibrary v0.7.9, Version=0.7.9.1561, Culture=neutral, PublicKeyToken=null
    Alias                                                    Alias, Version=2.0.3167.14578, Culture=neutral, PublicKeyToken=null
    AlignPlugin                                              AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null
    Alpha2Gray                                               Alpha2Gray, Version=4.5.6832.21862, Culture=neutral, PublicKeyToken=null
    Alpha-Displacement Mask                                  Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null
    AlphaBlur                                                AlphaBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null
    AlphaContrast                                            AlphaContrast, Version=1.0.3813.18307, Culture=neutral, PublicKeyToken=null
    AlphaMask                                                AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null
    AlphaSpace                                               AlphaSpace, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    AlphaThreshold                                           AlphaThreshold, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    Alpha_to_0                                               Alpha_to_0, Version=1.0.4452.22746, Culture=neutral, PublicKeyToken=null
    Alpha_to_255                                             Alpha_to_255, Version=1.0.4452.22782, Culture=neutral, PublicKeyToken=null
    alphalevels                                              alphalevels, Version=1.0.6826.15479, Culture=neutral, PublicKeyToken=null
    Angled Gradient                                          Angled Gradient, Version=1.0.6166.41233, Culture=neutral, PublicKeyToken=null
    animal                                                   animal, Version=2.1.6443.30021, Culture=neutral, PublicKeyToken=null
    AnimationEffect                                          AnimationEffect, Version=1.0.0.10, Culture=neutral, PublicKeyToken=null
    AnimGIF                                                  AnimGIF, Version=2.4.4119.28305, Culture=neutral, PublicKeyToken=null
    System.Security.Cryptography.Primitives                  System.Security.Cryptography.Primitives, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Anti-Alias by jsonchiu                                   Anti-Alias by jsonchiu, Version=1.0.4348.36767, Culture=neutral, PublicKeyToken=null
    Archimedean Spiral                                       Archimedean Spiral, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Apply Color                                              Apply Color, Version=1.0.4406.25220, Culture=neutral, PublicKeyToken=null
    Apply Texture                                            Apply Texture, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null
    System.Diagnostics.Process                               System.Diagnostics.Process, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    ArgusPDN.Barcode                                         ArgusPDN.Barcode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ArgusPDN.EdgeDetect                                      ArgusPDN.EdgeDetect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ArgusPDN.FFTEffects                                      ArgusPDN.FFTEffects, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ArgusPDN.Unblend                                         ArgusPDN.Unblend, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ArtyThing                                                ArtyThing, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null
    Asphalt.Controls                                         Asphalt.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Asphalt.Fonts                                            Asphalt.Fonts, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Asphalt.PDN                                              Asphalt.PDN, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    AlignNSD                                                 AlignNSD, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    AutoChrome                                               AutoChrome, Version=1.2.1.22603, Culture=neutral, PublicKeyToken=null
    AutoChromeNoise                                          AutoChromeNoise, Version=1.0.3847.37353, Culture=neutral, PublicKeyToken=null
    AveragedColorBlur                                        AveragedColorBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    AverageEdgeBlur                                          AverageEdgeBlur, Version=1.0.3991.32409, Culture=neutral, PublicKeyToken=null
    AverageSelectionColor                                    AverageSelectionColor, Version=1.1.3256.33886, Culture=neutral, PublicKeyToken=null
    AxInterop.WMPLib                                         AxInterop.WMPLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Interop.WMPLib                                           Interop.WMPLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    BaseUtility                                              BaseUtility, Version=1.0.3704.34812, Culture=neutral, PublicKeyToken=null
    BBOutlinedGradientText                                   BBOutlinedGradientText, Version=4.6.7358.38713, Culture=neutral, PublicKeyToken=null
    Basic Edge Detector                                      Basic Edge Detector, Version=1.0.5347.22706, Culture=neutral, PublicKeyToken=null
    Bevel                                                    Bevel, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    BasicAntialias11                                         BasicAntialias11, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    AxisStreakGmicPDN                                        AxisStreakGmicPDN, Version=0.2.0.0, Culture=neutral, PublicKeyToken=null
    BasicPhotoAdjustments                                    BasicPhotoAdjustments, Version=2.1.4020.485, Culture=neutral, PublicKeyToken=null
    BandWPlus                                                BandWPlus, Version=1.3.7359.317, Culture=neutral, PublicKeyToken=null
    Bars                                                     Bars, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Bezncurve                                                Bezncurve, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null
    Bidirectional Blur                                       Bidirectional Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    BlackAndWhiteConverter                                   BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null
    BlackandAlpha+                                           BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null
    BlackAndWhite+                                           BlackAndWhite+, Version=1.1.6744.2631, Culture=neutral, PublicKeyToken=null
    BlackWhiteOnly                                           BlackWhiteOnly, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    BlendModesPlus                                           BlendModesPlus, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null
    BlendSeams                                               BlendSeams, Version=1.1.6021.34867, Culture=neutral, PublicKeyToken=null
    BlurBlend                                                BlurBlend, Version=1.1.6601.26020, Culture=neutral, PublicKeyToken=null
    BlurFill                                                 BlurFill, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null
    Borders N' Shapes                                        "Borders N' Shapes", Version=4.0.4642.26476, Culture=neutral, PublicKeyToken=null
    Boutons                                                  Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    boxfitting                                               boxfitting, Version=1.1.6164.32856, Culture=neutral, PublicKeyToken=null
    BrushFactory                                             BrushFactory, Version=2.0.2.34059, Culture=neutral, PublicKeyToken=null
    BumpChecker                                              BumpChecker, Version=1.4.4399.25606, Culture=neutral, PublicKeyToken=null
    Burninate                                                Burninate, Version=4.6.7358.31797, Culture=neutral, PublicKeyToken=null
    Calendar                                                 Calendar, Version=4.6.7358.32649, Culture=neutral, PublicKeyToken=null
    CalliColour                                              CalliColour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    Cartoonize                                               Cartoonize, Version=1.0.4629.37393, Culture=neutral, PublicKeyToken=null
    CellMaker                                                CellMaker, Version=1.1.6139.29120, Culture=neutral, PublicKeyToken=null
    BrushFilter                                              BrushFilter, Version=1.3.0.13866, Culture=neutral, PublicKeyToken=null
    Bullet                                                   Bullet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    BulletinBoardTrim                                        BulletinBoardTrim, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    CellMakerRev                                             CellMakerRev, Version=1.0.7006.21865, Culture=neutral, PublicKeyToken=null
    CellTexture                                              CellTexture, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Centerlines 2                                            Centerlines 2, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    CenterLines                                              CenterLines, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ChangeExtremeColors                                      ChangeExtremeColors, Version=1.2.5.29023, Culture=neutral, PublicKeyToken=null
    Channel Editing.dll                                      Channel Editing.dll, Version=1.0.7702.39387, Culture=neutral, PublicKeyToken=null
    Channel Extraction.dll                                   Channel Extraction.dll, Version=1.0.7703.23621, Culture=neutral, PublicKeyToken=null
    ChannelOperation                                         ChannelOperation, Version=1.0.6350.2522, Culture=neutral, PublicKeyToken=null
    ChessFEN                                                 ChessFEN, Version=1.1.6139.31083, Culture=neutral, PublicKeyToken=null
    circleFractal2                                           circleFractal2, Version=1.1.5613.38521, Culture=neutral, PublicKeyToken=null
    CircleGen                                                CircleGen, Version=1.3.7505.20607, Culture=neutral, PublicKeyToken=null
    CircleText                                               CircleText, Version=1.4.4415.32488, Culture=neutral, PublicKeyToken=null
    circle_draw                                              circle_draw, Version=1.0.7180.25304, Culture=neutral, PublicKeyToken=null
    CircularText                                             CircularText, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null
    CK_Plugin                                                CK_Plugin, Version=1.5.5345.24808, Culture=neutral, PublicKeyToken=null
    ClampedGaussianBlur                                      ClampedGaussianBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null
    Clarifaction+                                            Clarifaction+, Version=1.0.4406.25898, Culture=neutral, PublicKeyToken=null
    Clarify                                                  Clarify, Version=1.0.4349.19613, Culture=neutral, PublicKeyToken=null
    CleanTransparent                                         CleanTransparent, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ClipDisplaceAA                                           ClipDisplaceAA, Version=1.2.4.0, Culture=neutral, PublicKeyToken=null
    ClipWarp                                                 ClipWarp, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null
    ClipWarpNew                                              ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    Clock                                                    Clock, Version=1.1.6245.30896, Culture=neutral, PublicKeyToken=null
    CloudEffect                                              CloudEffect, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    ClusterClearEffect                                       ClusterClearEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    CMY Ghost                                                CMY Ghost, Version=1.0.4909.35063, Culture=neutral, PublicKeyToken=null
    Cobweb                                                   Cobweb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    Color Match                                              Color Match, Version=4.0.4642.26532, Culture=neutral, PublicKeyToken=null
    coloraberation                                           coloraberation, Version=1.0.3859.18981, Culture=neutral, PublicKeyToken=null
    CodeArtEng.DspToolbox                                    CodeArtEng.DspToolbox, Version=2.0.3.0, Culture=neutral, PublicKeyToken=null
    CodeLab                                                  CodeLab, Version=6.1.7846.37265, Culture=neutral, PublicKeyToken=null
    ColorBalance                                             ColorBalance, Version=4.7.7401.17173, Culture=neutral, PublicKeyToken=null
    ColorBalanceLesson                                       ColorBalanceLesson, Version=1.0.6621.10132, Culture=neutral, PublicKeyToken=null
    Colorblindness4                                          Colorblindness4, Version=4.0.7585.35502, Culture=neutral, PublicKeyToken=null
    ColorClearer                                             ColorClearer, Version=1.1.6009.41762, Culture=neutral, PublicKeyToken=null
    ColorHarmonies.Effect                                    ColorHarmonies.Effect, Version=0.7.0.155, Culture=neutral, PublicKeyToken=null
    ColorRamp                                                ColorRamp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    OptionBasedLibrary v0.7.3                                OptionBasedLibrary v0.7.3, Version=0.7.0.229, Culture=neutral, PublicKeyToken=null
    ColorRange                                               ColorRange, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Copy Selection Bounding Box.dll                          Copy Selection Bounding Box.dll, Version=1.0.7837.1417, Culture=neutral, PublicKeyToken=null
    ColorSketch                                              ColorSketch, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    CopyAlpha                                                CopyAlpha, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    CreativeTextPro                                          CreativeTextPro, Version=1.1.7358.34307, Culture=neutral, PublicKeyToken=null
    ColorSketch_en                                           ColorSketch_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ColorToAlpha                                             ColorToAlpha, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null
    a_rectangle_transform3                                   a_rectangle_transform3, Version=2.0.7235.39373, Culture=neutral, PublicKeyToken=null
    ColorTrimming                                            ColorTrimming, Version=1.0.3167.14623, Culture=neutral, PublicKeyToken=null
    ColorZoomBlur                                            ColorZoomBlur, Version=1.1.3873.36417, Culture=neutral, PublicKeyToken=null
    a_color_swap                                             a_color_swap, Version=1.0.7186.9639, Culture=neutral, PublicKeyToken=null
    CombinedAdjustments                                      CombinedAdjustments, Version=1.1.7358.40688, Culture=neutral, PublicKeyToken=null
    complement                                               complement, Version=0.1.7021.39134, Culture=neutral, PublicKeyToken=null
    CompoGrids                                               CompoGrids, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null
    Compotool                                                Compotool, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    ComputeShaderEffects                                     ComputeShaderEffects, Version=3.1.0.0, Culture=neutral, PublicKeyToken=null
    SharpDX.Direct3D11                                       SharpDX.Direct3D11, Version=4.0.1.0, Culture=neutral, PublicKeyToken=b4dcf0f35e5521f1
    Cuboids                                                  Cuboids, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null
    SharpDX                                                  SharpDX, Version=4.0.1.0, Culture=neutral, PublicKeyToken=b4dcf0f35e5521f1
    ColorMatrix.Effect                                       ColorMatrix.Effect, Version=1.1.0.22, Culture=neutral, PublicKeyToken=null
    LightningCurve                                           LightningCurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    SharpDX.D3DCompiler                                      SharpDX.D3DCompiler, Version=4.0.1.0, Culture=neutral, PublicKeyToken=b4dcf0f35e5521f1
    Curves+                                                  Curves+, Version=4.0.6119.31044, Culture=neutral, PublicKeyToken=null
    CustomControls                                           CustomControls, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    ContentAwareFill                                         ContentAwareFill, Version=1.4.4.0, Culture=neutral, PublicKeyToken=null
    CustomCornerFrame                                        CustomCornerFrame, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null
    Contour                                                  Contour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    CustomBrushesMini                                        CustomBrushesMini, Version=2.2.5286.39584, Culture=neutral, PublicKeyToken=null
    CoordinatePlanePoints                                    CoordinatePlanePoints, Version=1.0.6034.29864, Culture=neutral, PublicKeyToken=null
    ColorMixer                                               ColorMixer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    ColorModulo                                              ColorModulo, Version=1.1.2.40250, Culture=neutral, PublicKeyToken=null
    CustomFrame                                              CustomFrame, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null
    CycleHSV                                                 CycleHSV, Version=1.0.4909.35068, Culture=neutral, PublicKeyToken=null
    deviation-to-alpha.dll                                   deviation-to-alpha.dll, Version=1.1.7681.23746, Culture=neutral, PublicKeyToken=null
    DHShapeMaker                                             DHShapeMaker, Version=1.7.0.1, Culture=neutral, PublicKeyToken=null
    Diagonal Lines                                           Diagonal Lines, Version=1.0.4800.36619, Culture=neutral, PublicKeyToken=null
    Diffuse                                                  Diffuse, Version=1.0.3254.27766, Culture=neutral, PublicKeyToken=null
    Dimensions                                               Dimensions, Version=1.3.6826.38472, Culture=neutral, PublicKeyToken=null
    Displacement                                             Displacement, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    dpyColorBalance                                          dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null
    DispMap                                                  DispMap, Version=2.1.7197.13119, Culture=neutral, PublicKeyToken=null
    DraganEffect_en                                          DraganEffect_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    DistortingMirror                                         DistortingMirror, Version=1.0.4281.30602, Culture=neutral, PublicKeyToken=null
    DragFrom                                                 DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    DistortThis                                              DistortThis, Version=2.9.0.0, Culture=neutral, PublicKeyToken=null
    DrawCenterCell                                           DrawCenterCell, Version=0.1.6965.21445, Culture=neutral, PublicKeyToken=null
    Donut                                                    Donut, Version=1.1.6406.36312, Culture=neutral, PublicKeyToken=null
    Dot                                                      Dot, Version=1.0.4673.202, Culture=neutral, PublicKeyToken=null
    DotMatrix                                                DotMatrix, Version=1.0.6178.27733, Culture=neutral, PublicKeyToken=null
    DPLNightVision                                           DPLNightVision, Version=1.0.4004.18455, Culture=neutral, PublicKeyToken=null
    dpyColorBalance+                                         dpyColorBalance+, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null
    DrawGrid                                                 DrawGrid, Version=0.1.6965.21086, Culture=neutral, PublicKeyToken=null
    DrawingTool                                              DrawingTool, Version=1.0.0.2, Culture=neutral, PublicKeyToken=null
    EarthsAndGreys                                           EarthsAndGreys, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    System.Xml.Linq                                          System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System.Xml.XDocument                                     System.Xml.XDocument, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Dream                                                    Dream, Version=4.6.7358.35004, Culture=neutral, PublicKeyToken=null
    System.Private.Xml.Linq                                  System.Private.Xml.Linq, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    Droste                                                   Droste, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    DrPrepper                                                DrPrepper, Version=1.4.4399.25637, Culture=neutral, PublicKeyToken=null
    Dryad                                                    Dryad, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null
    DuotoneGradientMap                                       DuotoneGradientMap, Version=1.0.7487.40422, Culture=neutral, PublicKeyToken=null
    DynamicContrast                                          DynamicContrast, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    System.Numerics                                          System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    System.Runtime.Numerics                                  System.Runtime.Numerics, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Edge Shader                                              Edge Shader, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    EdgeBlur                                                 EdgeBlur, Version=1.1.6579.1729, Culture=neutral, PublicKeyToken=null
    EdgeExpander                                             EdgeExpander, Version=1.0.5863.38192, Culture=neutral, PublicKeyToken=null
    EdgeFader                                                EdgeFader, Version=5.3.5.0, Culture=neutral, PublicKeyToken=null
    EdgeShaderMJW                                            EdgeShaderMJW, Version=1.0.5717.35999, Culture=neutral, PublicKeyToken=null
    EdHarvey.Effects.Archive.PolarInversionPlus              EdHarvey.Effects.Archive.PolarInversionPlus, Version=3.22.3024.37811, Culture=neutral, PublicKeyToken=null
    EdHarvey.Effects.Archives.DentsClassic                   EdHarvey.Effects.Archives.DentsClassic, Version=3.5.3777.3380, Culture=neutral, PublicKeyToken=null
    Mono.Cecil                                               Mono.Cecil, Version=0.11.4.0, Culture=neutral, PublicKeyToken=50cebf1cceb9d05e
    System.IO.Compression                                    System.IO.Compression, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    EditableText                                             EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    SBCommon                                                 SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null
    EigenBlur                                                EigenBlur, Version=1.3.3555.24648, Culture=neutral, PublicKeyToken=null
    Emboss+                                                  Emboss+, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null
    EngraveEmboss                                            EngraveEmboss, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null
    IniFile                                                  IniFile, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null
    FillFromFile                                             FillFromFile, Version=4.7.7358.36581, Culture=neutral, PublicKeyToken=null
    FillPalette                                              FillPalette, Version=0.4.0.27894, Culture=neutral, PublicKeyToken=null
    EOEffects                                                EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null
    Color Dimmer                                             Color Dimmer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    FindEdges                                                FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null
    Fisheye                                                  Fisheye, Version=2.2.5533.12794, Culture=neutral, PublicKeyToken=null
    Flip                                                     Flip, Version=4.6.7358.36953, Culture=neutral, PublicKeyToken=null
    Flourish                                                 Flourish, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null
    Frames                                                   Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    FloydSteinbergDithering                                  FloydSteinbergDithering, Version=4.6.7358.37110, Culture=neutral, PublicKeyToken=null
    FSPost                                                   FSPost, Version=1.0.4913.8979, Culture=neutral, PublicKeyToken=null
    Fractal Attractor                                        Fractal Attractor, Version=1.0.6388.26241, Culture=neutral, PublicKeyToken=null
    FractalFern                                              FractalFern, Version=1.2.0.28378, Culture=neutral, PublicKeyToken=null
    FractalTree                                              FractalTree, Version=1.2.0.38806, Culture=neutral, PublicKeyToken=null
    Equirectangular Diffuse Transform                        Equirectangular Diffuse Transform, Version=1.0.7159.445, Culture=neutral, PublicKeyToken=null
    Equirectangular Viewer                                   Equirectangular Viewer, Version=1.0.0.42271, Culture=neutral, PublicKeyToken=null
    Erode                                                    Erode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ErodeDilate                                              ErodeDilate, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ErrorDiffusionDithering                                  ErrorDiffusionDithering, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ExpandColor                                              ExpandColor, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null
    ExtendBorder                                             ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    Eyeshine                                                 Eyeshine, Version=1.0.3700.25905, Culture=neutral, PublicKeyToken=null
    Facet                                                    Facet, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null
    FibonacciFill                                            FibonacciFill, Version=1.1.6139.28851, Culture=neutral, PublicKeyToken=null
    FillFromClipboard                                        FillFromClipboard, Version=4.7.7358.36519, Culture=neutral, PublicKeyToken=null
    FurBlur                                                  FurBlur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    Gingham                                                  Gingham, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    __blur                                                   __blur, Version=1.1.7212.26179, Culture=neutral, PublicKeyToken=null
    Edge Detect And Affect3                                  Edge Detect And Affect3, Version=1.0.5885.13123, Culture=neutral, PublicKeyToken=null
    __bulgespiral                                            __bulgespiral, Version=1.0.7267.41850, Culture=neutral, PublicKeyToken=null
    GaussianBlurPlus                                         GaussianBlurPlus, Version=4.2.5691.27401, Culture=neutral, PublicKeyToken=null
    Gears                                                    Gears, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null
    Gen96Colors                                              Gen96Colors, Version=1.0.0.32381, Culture=neutral, PublicKeyToken=null
    GenesisVFX                                               GenesisVFX, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    GenTree                                                  GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null
    Gmic                                                     Gmic, Version=2.9.8.0, Culture=neutral, PublicKeyToken=null
    Gossamer                                                 Gossamer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null
    GpcDotNet.AMD64                                          GpcDotNet.AMD64, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    GpcDotNet.Interface                                      GpcDotNet.Interface, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    GreenTintReduction                                       GreenTintReduction, Version=1.0.6484.29238, Culture=neutral, PublicKeyToken=null
    Grid Warp                                                Grid Warp, Version=4.0.6544.34496, Culture=neutral, PublicKeyToken=null
    GridCheckerboard                                         GridCheckerboard, Version=4.5.6828.36789, Culture=neutral, PublicKeyToken=null
    GridGrad                                                 GridGrad, Version=1.0.4172.25342, Culture=neutral, PublicKeyToken=null
    GridMaker                                                GridMaker, Version=5.1.0.0, Culture=neutral, PublicKeyToken=null
    GrimColorReaper                                          GrimColorReaper, Version=1.2.4299.5808, Culture=neutral, PublicKeyToken=null
    Grow                                                     Grow, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null
    GS_Plugin                                                GS_Plugin, Version=1.3.5345.24516, Culture=neutral, PublicKeyToken=null
    GuideLines                                               GuideLines, Version=1.0.6239.35558, Culture=neutral, PublicKeyToken=null
    Heightmap plugin v1                                      Heightmap plugin v1, Version=1.3.4261.22267, Culture=neutral, PublicKeyToken=null
    HeightToNormal                                           HeightToNormal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Helix                                                    Helix, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    System.Diagnostics.StackTrace                            System.Diagnostics.StackTrace, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    HexaGrid                                                 HexaGrid, Version=4.1.0.25984, Culture=neutral, PublicKeyToken=null
    InvertAlpha                                              InvertAlpha, Version=1.0.3040.33378, Culture=neutral, PublicKeyToken=null
    Highlight                                                Highlight, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    __invert_anything                                        __invert_anything, Version=1.0.7213.37760, Culture=neutral, PublicKeyToken=null
    isolate                                                  isolate, Version=1.0.3303.3202, Culture=neutral, PublicKeyToken=null
    HighPass_rec                                             HighPass_rec, Version=1.3.6135.23156, Culture=neutral, PublicKeyToken=null
    HilbertCurve                                             HilbertCurve, Version=1.2.0.40828, Culture=neutral, PublicKeyToken=null
    Histogram                                                Histogram, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    HotMetalGlow                                             HotMetalGlow, Version=1.2.5985.32923, Culture=neutral, PublicKeyToken=null
    EdHarvey.Effects                                         EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null
    HsvEraser                                                HsvEraser, Version=1.1.5625.39352, Culture=neutral, PublicKeyToken=null
    HSVGradients                                             HSVGradients, Version=4.5.6832.41864, Culture=neutral, PublicKeyToken=null
    HsvScrambler                                             HsvScrambler, Version=1.1.5675.38718, Culture=neutral, PublicKeyToken=null
    HueSatPlus                                               HueSatPlus, Version=4.6.7359.209, Culture=neutral, PublicKeyToken=null
    System.Design                                            System.Design, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    System.Reflection.Metadata                               System.Reflection.Metadata, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Image Modulo Toolkit.dll                                 Image Modulo Toolkit.dll, Version=1.0.7587.35621, Culture=neutral, PublicKeyToken=null
    Gradient Bars                                            Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null
    ImageDifference                                          ImageDifference, Version=1.0.0.21216, Culture=neutral, PublicKeyToken=null
    Gradient Blocks                                          Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null
    GradientBlur                                             GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ImageDistortion                                          ImageDistortion, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Gradient Grid                                            Gradient Grid, Version=4.0.6436.36068, Culture=neutral, PublicKeyToken=null
    Gradient Mapping                                         Gradient Mapping, Version=4.0.6547.33963, Culture=neutral, PublicKeyToken=null
    GradientMap                                              GradientMap, Version=1.1.7440.15108, Culture=neutral, PublicKeyToken=null
    GradientsGalore                                          GradientsGalore, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null
    Gradual_Stripes_a                                        Gradual_Stripes_a, Version=1.0.6595.41826, Culture=neutral, PublicKeyToken=null
    GraphPaper                                               GraphPaper, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null
    System.Windows.Forms.Design                              System.Windows.Forms.Design, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    ImageInText                                              ImageInText, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    ImgurUploader                                            ImgurUploader, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    InkSketch+                                               InkSketch+, Version=1.0.4629.39900, Culture=neutral, PublicKeyToken=null
    InsetBoxShadow                                           InsetBoxShadow, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    Gravity                                                  Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    IntensityRGB                                             IntensityRGB, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    InterlockingTiles                                        InterlockingTiles, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Gray2Alpha                                               Gray2Alpha, Version=4.5.6826.36897, Culture=neutral, PublicKeyToken=null
    IsolateChannel                                           IsolateChannel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    IsometricCuboid                                          IsometricCuboid, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null
    IsometricTiled                                           IsometricTiled, Version=1.0.6827.41632, Culture=neutral, PublicKeyToken=null
    PDNPI_IndirectUI                                         PDNPI_IndirectUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Microsoft.VisualBasic                                    Microsoft.VisualBasic, Version=10.1.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.VisualBasic.Forms                              Microsoft.VisualBasic.Forms, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Jitter                                                   Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null
    NoiseReduction                                           NoiseReduction, Version=1.0.3747.24002, Culture=neutral, PublicKeyToken=null
    JuliaPlus                                                JuliaPlus, Version=1.0.5.18510, Culture=neutral, PublicKeyToken=null
    JustifyText                                              JustifyText, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Lens                                                     Lens, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    PresentationFramework-SystemXmlLinq                      PresentationFramework-SystemXmlLinq, Version=5.0.8.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    LensFlare                                                LensFlare, Version=2.2.12.32979, Culture=neutral, PublicKeyToken=null
    LevelHorizon                                             LevelHorizon, Version=4.6.7358.37589, Culture=neutral, PublicKeyToken=null
    Lightning                                                Lightning, Version=1.1.3896.32593, Culture=neutral, PublicKeyToken=null
    Kaleidoscope                                             Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    Kill Color Keeper                                        Kill Color Keeper, Version=1.0.6641.13453, Culture=neutral, PublicKeyToken=null
    Kuwahara                                                 Kuwahara, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Landscape                                                Landscape, Version=4.6.7358.37463, Culture=neutral, PublicKeyToken=null
    LaplacianPyramidFilter                                   LaplacianPyramidFilter, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null
    __lattice                                                __lattice, Version=1.0.7215.30711, Culture=neutral, PublicKeyToken=null
    LavEnt.Effects.RoundedRectangle                          LavEnt.Effects.RoundedRectangle, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null
    Layer Cake                                               Layer Cake, Version=1.0.4911.8147, Culture=neutral, PublicKeyToken=null
    LightRays                                                LightRays, Version=2.1.0.29680, Culture=neutral, PublicKeyToken=null
    LinesGrid                                                LinesGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null
    Linocut_en                                               Linocut_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Liquify                                                  Liquify, Version=4.0.5873.25113, Culture=neutral, PublicKeyToken=null
    ListOfPalettes                                           ListOfPalettes, Version=1.0.0.30736, Culture=neutral, PublicKeyToken=null
    LocalContrast                                            LocalContrast, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null
    LocalNoise                                               LocalNoise, Version=1.0.4674.29909, Culture=neutral, PublicKeyToken=null
    LookAtIt.Effect                                          LookAtIt.Effect, Version=0.6.0.779, Culture=neutral, PublicKeyToken=null
    Magnifier                                                Magnifier, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    Majority                                                 Majority, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    MakePalette.dll                                          MakePalette.dll, Version=1.0.7740.39799, Culture=neutral, PublicKeyToken=null
    mandala                                                  mandala, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    MandalaCreator                                           MandalaCreator, Version=1.2.6946.21792, Culture=neutral, PublicKeyToken=null
    Manual Color Correction                                  Manual Color Correction, Version=1.0.4314.41440, Culture=neutral, PublicKeyToken=null
    MarkupRenderer                                           MarkupRenderer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    MathNet.Iridium                                          MathNet.Iridium, Version=2007.3.8.35795, Culture=neutral, PublicKeyToken=null
    Matrice                                                  Matrice, Version=1.0.3810.11744, Culture=neutral, PublicKeyToken=null
    MeasureObject                                            MeasureObject, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null
    Nebulous                                                 Nebulous, Version=1.2.4.16193, Culture=neutral, PublicKeyToken=null
    NeonEdges                                                NeonEdges, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    NeutralWire                                              NeutralWire, Version=1.0.6333.34789, Culture=neutral, PublicKeyToken=null
    NewtonFractal                                            NewtonFractal, Version=2.2.1.40537, Culture=neutral, PublicKeyToken=null
    MeasureSelection                                         MeasureSelection, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null
    NoiseBleach                                              NoiseBleach, Version=1.0.4909.35542, Culture=neutral, PublicKeyToken=null
    NoiseChoice                                              NoiseChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    Normalizer                                               Normalizer, Version=1.8.4399.25698, Culture=neutral, PublicKeyToken=null
    NormalMapPlus                                            NormalMapPlus, Version=1.4.6422.43071, Culture=neutral, PublicKeyToken=null
    Norm_Render                                              Norm_Render, Version=7.3.4484.27012, Culture=neutral, PublicKeyToken=null
    Object Pruner                                            Object Pruner, Version=1.0.7020.41772, Culture=neutral, PublicKeyToken=null
    Melting                                                  Melting, Version=1.0.6547.32118, Culture=neutral, PublicKeyToken=null
    MemeMaker                                                MemeMaker, Version=4.5.6828.38061, Culture=neutral, PublicKeyToken=null
    Object2Colour                                            Object2Colour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    Metallize                                                Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null
    ObjectBevel                                              ObjectBevel, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null
    Microsoft.ML.OnnxRuntime                                 Microsoft.ML.OnnxRuntime, Version=1.0.0.0, Culture=neutral, PublicKeyToken=f27f157f0a5b7bb6
    ObjectEdge                                               ObjectEdge, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    ObjectShadowPro                                          ObjectShadowPro, Version=1.0.7421.614, Culture=neutral, PublicKeyToken=null
    ObjectTools                                              ObjectTools, Version=5.0.7502.21624, Culture=neutral, PublicKeyToken=null
    MirrorRotate                                             MirrorRotate, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null
    Oblique                                                  Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    MirrorRotateMenu                                         MirrorRotateMenu, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null
    Mise En Abyme                                            Mise En Abyme, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ModifyChannels                                           ModifyChannels, Version=1.0.1.3233, Culture=neutral, PublicKeyToken=null
    MotionSharpen                                            MotionSharpen, Version=1.2.1.0, Culture=neutral, PublicKeyToken=null
    MoveSeams                                                MoveSeams, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    MultiColorGradient                                       MultiColorGradient, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Offset Shadow                                            Offset Shadow, Version=1.0.4247.30184, Culture=neutral, PublicKeyToken=null
    Offset                                                   Offset, Version=1.0.4914.19410, Culture=neutral, PublicKeyToken=null
    OffsetAlternatingStripes                                 OffsetAlternatingStripes, Version=1.0.6025.41452, Culture=neutral, PublicKeyToken=null
    OilPaintingPlus                                          OilPaintingPlus, Version=4.6.7358.38406, Culture=neutral, PublicKeyToken=null
    MultiSpline                                              MultiSpline, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null
    Feather                                                  Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null
    MySignature                                              MySignature, Version=1.5.6617.41275, Culture=neutral, PublicKeyToken=null
    OptionBasedLibrary v0.7.8                                OptionBasedLibrary v0.7.8, Version=0.7.0.1343, Culture=neutral, PublicKeyToken=null
    OrderedDither                                            OrderedDither, Version=1.1.7438.17572, Culture=neutral, PublicKeyToken=null
    Organigram                                               Organigram, Version=1.3.6565.29874, Culture=neutral, PublicKeyToken=null
    Outline Object                                           Outline Object, Version=4.0.4642.26954, Culture=neutral, PublicKeyToken=null
    Outline                                                  Outline, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    OutlineGradientText                                      OutlineGradientText, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Overblur                                                 Overblur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    Overliner                                                Overliner, Version=1.2.3888.29226, Culture=neutral, PublicKeyToken=null
    PageCurl                                                 PageCurl, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null
    PaletteFromImage                                         PaletteFromImage, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Panelling                                                Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    ParallelLines.Effect                                     ParallelLines.Effect, Version=1.6.0.575, Culture=neutral, PublicKeyToken=null
    Paste Warp Plus                                          Paste Warp Plus, Version=1.0.6244.33283, Culture=neutral, PublicKeyToken=null
    PasteAlpha                                               PasteAlpha, Version=4.6.7358.38804, Culture=neutral, PublicKeyToken=null
    PasteFill                                                PasteFill, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null
    PasteFromClipboard                                       PasteFromClipboard, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null
    Pastel                                                   Pastel, Version=4.6.7358.38877, Culture=neutral, PublicKeyToken=null
    PdnColorInpaintingFilter                                 PdnColorInpaintingFilter, Version=1.0.3704.35070, Culture=neutral, PublicKeyToken=null
    PdnManualColorFilter                                     PdnManualColorFilter, Version=1.0.3704.35071, Culture=neutral, PublicKeyToken=null
    PDNPalette                                               PDNPalette, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    PdnPropertiesAndControlTypes                             PdnPropertiesAndControlTypes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    PDNSpriteSheetAnim                                       PDNSpriteSheetAnim, Version=1.0.0.3, Culture=neutral, PublicKeyToken=null
    PerlinTexture                                            PerlinTexture, Version=2.0.6411.25796, Culture=neutral, PublicKeyToken=null
    perlin_noise                                             perlin_noise, Version=1.1.7172.28890, Culture=neutral, PublicKeyToken=null
    Perspective                                              Perspective, Version=2.1.4415.36116, Culture=neutral, PublicKeyToken=null
    PerspectiveLines1_2                                      PerspectiveLines1_2, Version=1.2.3679.1005, Culture=neutral, PublicKeyToken=null
    PerspectiveTransformation                                PerspectiveTransformation, Version=1.2.5795.41799, Culture=neutral, PublicKeyToken=null
    phips_fill_gaps                                          phips_fill_gaps, Version=1.0.3307.18956, Culture=neutral, PublicKeyToken=null
    phips_kill_color                                         phips_kill_color, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    phips_selective_enhancer                                 phips_selective_enhancer, Version=1.1.3302.33189, Culture=neutral, PublicKeyToken=null
    phips_selective_toning                                   phips_selective_toning, Version=1.0.3304.32827, Culture=neutral, PublicKeyToken=null
    PhotoAdjustments                                         PhotoAdjustments, Version=4.6.7358.38979, Culture=neutral, PublicKeyToken=null
    Pixel Art Palette Switcher.dll                           Pixel Art Palette Switcher.dll, Version=0.1.7583.18176, Culture=neutral, PublicKeyToken=null
    Pixelate+                                                Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null
    PixSetRepl                                               PixSetRepl, Version=1.0.0.20200, Culture=neutral, PublicKeyToken=null
    Planetoid                                                Planetoid, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null
    PlugInData                                               PlugInData, Version=1.3.9.2, Culture=neutral, PublicKeyToken=null
    System.Resources.Extensions                              System.Resources.Extensions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
    PointBlur                                                PointBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    pointwarp                                                pointwarp, Version=1.2.5709.42172, Culture=neutral, PublicKeyToken=null
    Polar                                                    Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null
    PolaroidFrame                                            PolaroidFrame, Version=1.2.6565.30489, Culture=neutral, PublicKeyToken=null
    a_polar_test                                             a_polar_test, Version=1.0.7188.40229, Culture=neutral, PublicKeyToken=null
    __clamp                                                  __clamp, Version=1.0.7198.21126, Culture=neutral, PublicKeyToken=null
    __polar_tunnel                                           __polar_tunnel, Version=1.0.7216.34965, Culture=neutral, PublicKeyToken=null
    PolyGlitch.Effects                                       PolyGlitch.Effects, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null
    Polygon Tool                                             Polygon Tool, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Polygon                                                  Polygon, Version=4.5.6828.38648, Culture=neutral, PublicKeyToken=null
    Polygones                                                Polygones, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Poster                                                   Poster, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null
    posterize+                                               posterize+, Version=1.0.4629.2600, Culture=neutral, PublicKeyToken=null
    PowerStretch20Beta                                       PowerStretch20Beta, Version=1.9.3045.14671, Culture=neutral, PublicKeyToken=null
    PremultiplyAlpha                                         PremultiplyAlpha, Version=1.0.6868.37601, Culture=neutral, PublicKeyToken=null
    PSFilterPdn                                              PSFilterPdn, Version=1.0.8.2, Culture=neutral, PublicKeyToken=null
    Psychocolour                                             Psychocolour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    pxEexpansion                                             pxEexpansion, Version=1.0.4437.36287, Culture=neutral, PublicKeyToken=null
    QuadrilateralCorrection                                  QuadrilateralCorrection, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    Quick Gravity                                            Quick Gravity, Version=1.0.4408.25818, Culture=neutral, PublicKeyToken=null
    Radialcolors                                             Radialcolors, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null
    RadiusFillCorners                                        RadiusFillCorners, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null
    rainball                                                 rainball, Version=1.0.4907.41850, Culture=neutral, PublicKeyToken=null
    Rainbowify.dll                                           Rainbowify.dll, Version=1.0.7876.29048, Culture=neutral, PublicKeyToken=null
    RainbowTwist                                             RainbowTwist, Version=1.1.6410.28789, Culture=neutral, PublicKeyToken=null
    Random Effect                                            Random Effect, Version=4.0.4642.26928, Culture=neutral, PublicKeyToken=null
    Random Gradient Bars.dll                                 Random Gradient Bars.dll, Version=0.75.7835.24729, Culture=neutral, PublicKeyToken=null
    RandLines                                                RandLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    RandMaze1                                                RandMaze1, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    RandMaze2                                                RandMaze2, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Random Shape Fill                                        Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null
    Recolor Using Palette                                    Recolor Using Palette, Version=1.0.6382.573, Culture=neutral, PublicKeyToken=null
    RecolorGray                                              RecolorGray, Version=1.0.6438.38281, Culture=neutral, PublicKeyToken=null
    RecolourChoice                                           RecolourChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    RectangleToArchimedeanSpiral.dll                         RectangleToArchimedeanSpiral.dll, Version=1.0.7623.289, Culture=neutral, PublicKeyToken=null
    an_eversion2                                             an_eversion2, Version=2.0.7222.27910, Culture=neutral, PublicKeyToken=null
    RegularNoise                                             RegularNoise, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    RemoveBrightDark                                         RemoveBrightDark, Version=1.1.3063.36415, Culture=neutral, PublicKeyToken=null
    RemoveDust                                               RemoveDust, Version=4.5.6826.37862, Culture=neutral, PublicKeyToken=null
    RemoveTransparency                                       RemoveTransparency, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    __killblack                                              __killblack, Version=1.0.7212.28737, Culture=neutral, PublicKeyToken=null
    RenderSphereHeightMap                                    RenderSphereHeightMap, Version=1.0.6145.37460, Culture=neutral, PublicKeyToken=null
    Replace Colors                                           Replace Colors, Version=1.1.5767.26297, Culture=neutral, PublicKeyToken=null
    file                                                     file, Version=1.0.7180.10774, Culture=neutral, PublicKeyToken=null
    ReverseColors                                            ReverseColors, Version=1.0.4121.15722, Culture=neutral, PublicKeyToken=null
    ReverseFisheye                                           ReverseFisheye, Version=1.0.5146.26176, Culture=neutral, PublicKeyToken=null
    ReversePalette                                           ReversePalette, Version=0.1.6969.15756, Culture=neutral, PublicKeyToken=null
    RGBCompositor                                            RGBCompositor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    RGB to Linear Interpolation                              RGB to Linear Interpolation, Version=1.0.7378.19728, Culture=neutral, PublicKeyToken=null
    Rosaces                                                  Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    RotateColor                                              RotateColor, Version=0.5.0.32475, Culture=neutral, PublicKeyToken=null
    RotateTextSUI                                            RotateTextSUI, Version=1.1.4415.32713, Culture=neutral, PublicKeyToken=null
    Rotate_Zoom+                                             Rotate_Zoom+, Version=1.11.5237.17779, Culture=neutral, PublicKeyToken=null
    RotationBilinear                                         RotationBilinear, Version=1.1.3594.29946, Culture=neutral, PublicKeyToken=null
    RoundedRectangle                                         RoundedRectangle, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Ruler                                                    Ruler, Version=1.0.6034.31429, Culture=neutral, PublicKeyToken=null
    SaturationRGB                                            SaturationRGB, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Scintillate                                              Scintillate, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    ScratchArt_en                                            ScratchArt_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    ScreenPixel                                              ScreenPixel, Version=1.1.5534.1997, Culture=neutral, PublicKeyToken=null
    Scribble                                                 Scribble, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    ScriptLab                                                ScriptLab, Version=4.2.7616.26525, Culture=neutral, PublicKeyToken=null
    SeamCarving                                              SeamCarving, Version=4.6.7358.39596, Culture=neutral, PublicKeyToken=null
    SeamlessTextureMaker                                     SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    SegmentImage                                             SegmentImage, Version=1.1.3674.15788, Culture=neutral, PublicKeyToken=null
    Selection2Clear                                          Selection2Clear, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    SelectionInnerContour                                    SelectionInnerContour, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    SelectionObscure                                         SelectionObscure, Version=1.1.4602.34476, Culture=neutral, PublicKeyToken=null
    SelectionTools                                           SelectionTools, Version=5.0.7502.22140, Culture=neutral, PublicKeyToken=null
    __self_spiral                                            __self_spiral, Version=1.0.7263.1666, Culture=neutral, PublicKeyToken=null
    ShadowEffect                                             ShadowEffect, Version=1.3.0.23429, Culture=neutral, PublicKeyToken=null
    ShadowHighlight                                          ShadowHighlight, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null
    Shape3D                                                  Shape3D, Version=1.2.6.2, Culture=neutral, PublicKeyToken=null
    shapegradient                                            shapegradient, Version=1.5.3886.6574, Culture=neutral, PublicKeyToken=null
    Shapes                                                   Shapes, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null
    Shape_umabob                                             Shape_umabob, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null
    SharpDX.DXGI                                             SharpDX.DXGI, Version=4.0.1.0, Culture=neutral, PublicKeyToken=b4dcf0f35e5521f1
    Sharpen+                                                 Sharpen+, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null
    EffectsPluginTemplate2                                   EffectsPluginTemplate2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Sierpinski                                               Sierpinski, Version=2.1.6389.29730, Culture=neutral, PublicKeyToken=null
    silhouetteplus                                           silhouetteplus, Version=1.1.3131.17586, Culture=neutral, PublicKeyToken=null
    SinWaves                                                 SinWaves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Skew                                                     Skew, Version=1.0.7638.38725, Culture=neutral, PublicKeyToken=null
    SkewedRotatedText                                        SkewedRotatedText, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    SlightEdgeBoost                                          SlightEdgeBoost, Version=1.3.7446.26435, Culture=neutral, PublicKeyToken=null
    Slinky                                                   Slinky, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    SmartSharpen                                             SmartSharpen, Version=1.5.0.1, Culture=neutral, PublicKeyToken=null
    Smooth                                                   Smooth, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null
    SmoothNoise                                              SmoothNoise, Version=1.0.0.28227, Culture=neutral, PublicKeyToken=null
    Smudge                                                   Smudge, Version=4.0.5873.25097, Culture=neutral, PublicKeyToken=null
    SoundWave                                                SoundWave, Version=1.0.7433.14854, Culture=neutral, PublicKeyToken=null
    SpacedTextPlugin                                         SpacedTextPlugin, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null
    Sparkles                                                 Sparkles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Specular                                                 Specular, Version=1.0.3254.27778, Culture=neutral, PublicKeyToken=null
    SpeechBubble                                             SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null
    __bulge2                                                 __bulge2, Version=1.0.7224.336, Culture=neutral, PublicKeyToken=null
    Spiral                                                   Spiral, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    SpiralText                                               SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null
    SpiritLevel.Effect                                       SpiritLevel.Effect, Version=1.0.0.40, Culture=neutral, PublicKeyToken=null
    __trace                                                  __trace, Version=1.0.7198.41170, Culture=neutral, PublicKeyToken=null
    Trail                                                    Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null
    trail3d                                                  trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null
    Trail Blur                                               Trail Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Transitional Brush                                       Transitional Brush, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Transparency                                             Transparency, Version=4.6.7358.39871, Culture=neutral, PublicKeyToken=null
    TransparencyRGB                                          TransparencyRGB, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    TransparentToTransparentBlack                            TransparentToTransparentBlack, Version=1.0.6479.25661, Culture=neutral, PublicKeyToken=null
    SpiroGraph                                               SpiroGraph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    SpiroShapes                                              SpiroShapes, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null
    Splashes                                                 Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null
    Splatter                                                 Splatter, Version=4.0.5873.25083, Culture=neutral, PublicKeyToken=null
    SplitColorAndBrightness.dll                              SplitColorAndBrightness.dll, Version=1.0.7845.681, Culture=neutral, PublicKeyToken=null
    SplitHueAndBrightness                                    SplitHueAndBrightness, Version=1.0.5800.37276, Culture=neutral, PublicKeyToken=null
    SpokedWheel                                              SpokedWheel, Version=1.1.5908.19821, Culture=neutral, PublicKeyToken=null
    SpotCenter                                               SpotCenter, Version=1.2.0.17265, Culture=neutral, PublicKeyToken=null
    SpriteSheetGridModifier                                  SpriteSheetGridModifier, Version=0.1.6968.18281, Culture=neutral, PublicKeyToken=null
    Squirkle                                                 Squirkle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    SquirkleWarp                                             SquirkleWarp, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    StarGlow                                                 StarGlow, Version=1.3.5.17930, Culture=neutral, PublicKeyToken=null
    Starry                                                   Starry, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    Stars                                                    Stars, Version=1.3.5.21601, Culture=neutral, PublicKeyToken=null
    Stickman                                                 Stickman, Version=1.2.2.30005, Culture=neutral, PublicKeyToken=null
    Stipple                                                  Stipple, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Stitch                                                   Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null
    StrayPixelRemover                                        StrayPixelRemover, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    StringAndPin                                             StringAndPin, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    StyleTransferEffect                                      StyleTransferEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    TransparentToTransparentWhite                            TransparentToTransparentWhite, Version=1.0.6963.30396, Culture=neutral, PublicKeyToken=null
    TrippyRainbow                                            TrippyRainbow, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    TRs Scatter                                              TRs Scatter, Version=1.3.4949.23250, Culture=neutral, PublicKeyToken=null
    TRsAlphaCutter                                           TRsAlphaCutter, Version=3.0.4.0, Culture=neutral, PublicKeyToken=null
    TRsColorReducer                                          TRsColorReducer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null
    TRsContourFiller                                         TRsContourFiller, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null
    TRsCustomRandomFill                                      TRsCustomRandomFill, Version=1.5.1.31287, Culture=neutral, PublicKeyToken=null
    Line Tracer                                              Line Tracer, Version=1.0.4911.29141, Culture=neutral, PublicKeyToken=null
    TRsMonolithic                                            TRsMonolithic, Version=1.0.6.24412, Culture=neutral, PublicKeyToken=null
    TRsMorpher                                               TRsMorpher, Version=1.1.10.8959, Culture=neutral, PublicKeyToken=null
    TRsPasteFrame                                            TRsPasteFrame, Version=1.3.20.9613, Culture=neutral, PublicKeyToken=null
    TRsPixelPuller                                           TRsPixelPuller, Version=1.1.4994.29625, Culture=neutral, PublicKeyToken=null
    TRsPSnap                                                 TRsPSnap, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null
    TRsSplineMaster                                          TRsSplineMaster, Version=1.4.2.18310, Culture=neutral, PublicKeyToken=null
    TRsStrangeAttractor                                      TRsStrangeAttractor, Version=1.1.4.0, Culture=neutral, PublicKeyToken=null
    TRsThirdDimension                                        TRsThirdDimension, Version=1.7.13.38717, Culture=neutral, PublicKeyToken=null
    SubtractColor                                            SubtractColor, Version=1.0.4679.26877, Culture=neutral, PublicKeyToken=null
    TubeOblique                                              TubeOblique, Version=1.2.5.15697, Culture=neutral, PublicKeyToken=null
    TurbulentCircles                                         TurbulentCircles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    TurbulentLines                                           TurbulentLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Tweaktrans2                                              Tweaktrans2, Version=2.0.4252.27152, Culture=neutral, PublicKeyToken=null
    Twist                                                    Twist, Version=4.0.5873.25056, Culture=neutral, PublicKeyToken=null
    Table                                                    Table, Version=1.1.5847.38905, Culture=neutral, PublicKeyToken=null
    Tartan                                                   Tartan, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null
    TwistZ                                                   TwistZ, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null
    Tattersall                                               Tattersall, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Temperature                                              Temperature, Version=4.6.7358.39746, Culture=neutral, PublicKeyToken=null
    TwoPointPerspective                                      TwoPointPerspective, Version=1.6.0.0, Culture=neutral, PublicKeyToken=null
    Tesserae                                                 Tesserae, Version=1.0.6200.27517, Culture=neutral, PublicKeyToken=null
    TwoToneThreshold                                         TwoToneThreshold, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    EnvelopeDistorsion                                       EnvelopeDistorsion, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.Blurs                    Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects                          Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.ColorAccent              Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.DropShadow               Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.Duotones                 Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.FadeEdge                 Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.Gradient                 Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.Grid                     Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.Monochromes              Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vandermotten.PaintDotNetEffects.ObjectAlign              Vandermotten.PaintDotNetEffects.ObjectAlign, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null
    Vanishing Trails                                         Vanishing Trails, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null
    VanishPoint                                              VanishPoint, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null
    Varicose2                                                Varicose2, Version=2.1.1.42085, Culture=neutral, PublicKeyToken=null
    Vibration                                                Vibration, Version=1.0.4407.34043, Culture=neutral, PublicKeyToken=null
    Vibrato                                                  Vibrato, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null
    ViewFramer                                               ViewFramer, Version=1.0.6074.42436, Culture=neutral, PublicKeyToken=null
    Vignette1                                                Vignette1, Version=1.0.3538.14367, Culture=neutral, PublicKeyToken=null
    VignettePlus                                             VignettePlus, Version=4.6.7358.40027, Culture=neutral, PublicKeyToken=null
    Volutes                                                  Volutes, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    WarpTextOnPath                                           WarpTextOnPath, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    TextDistortion                                           TextDistortion, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    TextMask                                                 TextMask, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    WaterReflection                                          WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    Waves                                                    Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    WaveTextSUI                                              WaveTextSUI, Version=1.2.4415.33440, Culture=neutral, PublicKeyToken=null
    WaveToolBox                                              WaveToolBox, Version=1.3.7456.16099, Culture=neutral, PublicKeyToken=null
    TextPlus                                                 TextPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Texture Object Rounder                                   Texture Object Rounder, Version=1.0.6464.41586, Culture=neutral, PublicKeyToken=null
    Texture Scaler                                           Texture Scaler, Version=1.2.6430.41316, Culture=neutral, PublicKeyToken=null
    TextureMerger                                            TextureMerger, Version=1.1.6159.40169, Culture=neutral, PublicKeyToken=null
    TextureShader                                            TextureShader, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null
    TextureSmoother                                          TextureSmoother, Version=1.0.6096.31689, Culture=neutral, PublicKeyToken=null
    TextureViewSkewer                                        TextureViewSkewer, Version=1.0.5713.42082, Culture=neutral, PublicKeyToken=null
    Texturize                                                Texturize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    TextWindow                                               TextWindow, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null
    Text_on_Path                                             Text_on_Path, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    TGAngle                                                  TGAngle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    TGMagnitude                                              TGMagnitude, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null
    ThermalHeatMapEffect                                     ThermalHeatMapEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Thorn Fractal.dll                                        Thorn Fractal.dll, Version=1.0.7611.40689, Culture=neutral, PublicKeyToken=null
    ThreeColorDithering.dll                                  ThreeColorDithering.dll, Version=1.0.7652.19490, Culture=neutral, PublicKeyToken=null
    TileCount.dll                                            TileCount.dll, Version=1.0.7676.6172, Culture=neutral, PublicKeyToken=null
    Tiles                                                    Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null
    TileWorld                                                TileWorld, Version=1.0.2.30273, Culture=neutral, PublicKeyToken=null
    Tint-Splitter                                            Tint-Splitter, Version=1.0.4636.5475, Culture=neutral, PublicKeyToken=null
    TJacksonEffects                                          TJacksonEffects, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    Toon Shader                                              Toon Shader, Version=1.0.3470.28696, Culture=neutral, PublicKeyToken=null
    TOON                                                     TOON, Version=1.0.7446.7819, Culture=neutral, PublicKeyToken=null
    Tournesol                                                Tournesol, Version=1.0.0.29873, Culture=neutral, PublicKeyToken=null
    TR's Pixel Push                                          "TR's Pixel Push", Version=1.0.4954.37564, Culture=neutral, PublicKeyToken=null
    WetFloor                                                 WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null
    WhichSymbolRedux                                         WhichSymbolRedux, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    WoodsyVP1                                                WoodsyVP1, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null
    WoodsyVP2                                                WoodsyVP2, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null
    WoodsyVP3                                                WoodsyVP3, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null
    WovenPhoto94                                             WovenPhoto94, Version=1.94.6505.33087, Culture=neutral, PublicKeyToken=null
    WovenPhoto95                                             WovenPhoto95, Version=1.94.6529.30892, Culture=neutral, PublicKeyToken=null
    XYCoords                                                 XYCoords, Version=1.2.1.40230, Culture=neutral, PublicKeyToken=null
    zkaleidoscope                                            zkaleidoscope, Version=1.3.7168.35177, Culture=neutral, PublicKeyToken=null
    Zoom Selection.dll                                       Zoom Selection.dll, Version=1.0.7734.39804, Culture=neutral, PublicKeyToken=null
    ZoomBlurDeluxe                                           ZoomBlurDeluxe, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
    K4os.Compression.LZ4                                     K4os.Compression.LZ4, Version=1.2.6.0, Culture=neutral, PublicKeyToken=2186fa9121ef231d
Native modules                                               878
    PaintDotNet.exe                                          C:\Program Files\paint.net\PaintDotNet.exe, version=4.300.7881.3082
    ntdll.dll                                                C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.1023 (WinBuild.160101.0800)
    KERNEL32.DLL                                             C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.1151 (WinBuild.160101.0800)
    KERNELBASE.dll                                           C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    USER32.dll                                               C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    win32u.dll                                               C:\WINDOWS\System32\win32u.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    GDI32.dll                                                C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    gdi32full.dll                                            C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.1110 (WinBuild.160101.0800)
    msvcp_win.dll                                            C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800)
    ucrtbase.dll                                             C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800)
    SHELL32.dll                                              C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    ADVAPI32.dll                                             C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    msvcrt.dll                                               C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800)
    sechost.dll                                              C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    RPCRT4.dll                                               C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    IMM32.DLL                                                C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800)
    hostfxr.dll                                              C:\Program Files\dotnet\host\fxr\5.0.8\hostfxr.dll, version=5,0,821,31504 @Commit: 35964c9215613d66a687ebcb2d7fcd9496390ee7
    hostpolicy.dll                                           C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\hostpolicy.dll, version=5,0,821,31504 @Commit: 35964c9215613d66a687ebcb2d7fcd9496390ee7
    coreclr.dll                                              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\coreclr.dll, version=5,0,821,31504 @Commit: 35964c9215613d66a687ebcb2d7fcd9496390ee7
    ole32.dll                                                C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    combase.dll                                              C:\WINDOWS\System32\combase.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    OLEAUT32.dll                                             C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800)
    bcryptPrimitives.dll                                     C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1023 (WinBuild.160101.0800)
    System.Private.CoreLib.dll                               C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Private.CoreLib.dll, version=5.0.821.31504
    clrjit.dll                                               C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\clrjit.dll, version=5,0,821,31504 @Commit: 35964c9215613d66a687ebcb2d7fcd9496390ee7
    kernel.appcore.dll                                       C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    paintdotnet.dll                                          C:\Program Files\paint.net\paintdotnet.dll, version=4.300.7881.3082
    System.Runtime.dll                                       C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.dll, version=5.0.821.31504
    uxtheme.dll                                              C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    System.Windows.Forms.dll                                 C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Windows.Forms.dll, version=5.0.821.31504
    icu.dll                                                  C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800)
    PaintDotNet.Base.dll                                     C:\Program Files\paint.net\PaintDotNet.Base.dll, version=4.300.7881.3082
    System.Collections.dll                                   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Collections.dll, version=5.0.821.31504
    PaintDotNet.SystemLayer.dll                              C:\Program Files\paint.net\PaintDotNet.SystemLayer.dll, version=4.300.7881.3082
    PaintDotNet.Core.dll                                     C:\Program Files\paint.net\PaintDotNet.Core.dll, version=4.300.7881.3082
    PaintDotNet.Resources.dll                                C:\Program Files\paint.net\PaintDotNet.Resources.dll, version=4.300.7881.3082
    System.Runtime.InteropServices.RuntimeInformation.dll    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.InteropServices.RuntimeInformation.dll, version=5.0.821.31504
    System.IO.FileSystem.dll                                 C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.IO.FileSystem.dll, version=5.0.821.31504
    System.Threading.Thread.dll                              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Threading.Thread.dll, version=5.0.821.31504
    System.Collections.Concurrent.dll                        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Collections.Concurrent.dll, version=5.0.821.31504
    vcruntime140.dll                                         C:\Program Files\paint.net\vcruntime140.dll, version=14.29.30040.0 built by: vcwrkspc
    vcruntime140_1.dll                                       C:\Program Files\paint.net\vcruntime140_1.dll, version=14.29.30040.0 built by: vcwrkspc
    msvcp140.dll                                             C:\Program Files\paint.net\msvcp140.dll, version=14.29.30040.0 built by: vcwrkspc
    msvcp140_1.dll                                           C:\Program Files\paint.net\msvcp140_1.dll, version=14.29.30040.0 built by: vcwrkspc
    msvcp140_2.dll                                           C:\Program Files\paint.net\msvcp140_2.dll, version=14.29.30040.0 built by: vcwrkspc
    msvcp140_codecvt_ids.dll                                 C:\Program Files\paint.net\msvcp140_codecvt_ids.dll, version=14.29.30040.0 built by: vcwrkspc
    vcomp140.dll                                             C:\Program Files\paint.net\vcomp140.dll, version=14.29.30040.0 built by: vcwrkspc
    ijwhost.dll                                              C:\Program Files\paint.net\ijwhost.dll, version=5,0,821,31504 @Commit: 35964c9215613d66a687ebcb2d7fcd9496390ee7
    PaintDotNet.SystemLayer.Native.x64.dll                   C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.300.7881.3082
    PROPSYS.dll                                              C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.1100 (WinBuild.160101.0800)
    gdiplus.dll                                              C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.1151_none_91a40286cc884949\gdiplus.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    WindowsCodecs.dll                                        C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    bcrypt.dll                                               C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    System.Threading.dll                                     C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Threading.dll, version=5.0.821.31504
    System.Runtime.Extensions.dll                            C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.Extensions.dll, version=5.0.821.31504
    System.Runtime.InteropServices.dll                       C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.InteropServices.dll, version=5.0.821.31504
    System.Runtime.CompilerServices.VisualC.dll              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.CompilerServices.VisualC.dll, version=5.0.821.31504
    System.Collections.NonGeneric.dll                        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Collections.NonGeneric.dll, version=5.0.821.31504
    windows.storage.dll                                      C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    Wldp.dll                                                 C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    SHCORE.dll                                               C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    shlwapi.dll                                              C:\WINDOWS\System32\shlwapi.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    System.Memory.dll                                        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Memory.dll, version=5.0.821.31504
    System.Private.Uri.dll                                   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Private.Uri.dll, version=5.0.821.31504
    System.ComponentModel.Primitives.dll                     C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.ComponentModel.Primitives.dll, version=5.0.821.31504
    WindowsBase.dll                                          C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\WindowsBase.dll, version=5.0.821.31506
    System.Windows.Forms.Primitives.dll                      C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Windows.Forms.Primitives.dll, version=5.0.821.31504
    Microsoft.Win32.Primitives.dll                           C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\Microsoft.Win32.Primitives.dll, version=5.0.821.31504
    System.Drawing.Primitives.dll                            C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Drawing.Primitives.dll, version=5.0.821.31504
    System.Configuration.ConfigurationManager.dll            C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Configuration.ConfigurationManager.dll, version=5.0.20.51904
    System.Diagnostics.TraceSource.dll                       C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Diagnostics.TraceSource.dll, version=5.0.821.31504
    System.Text.Encoding.CodePages.dll                       C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Text.Encoding.CodePages.dll, version=5.0.821.31504
    System.Collections.Specialized.dll                       C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Collections.Specialized.dll, version=5.0.821.31504
    System.ObjectModel.dll                                   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.ObjectModel.dll, version=5.0.821.31504
    PaintDotNet.Data.dll                                     C:\Program Files\paint.net\PaintDotNet.Data.dll, version=4.300.7881.3082
    System.Private.Xml.dll                                   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Private.Xml.dll, version=5.0.821.31504
    System.Net.WebClient.dll                                 C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Net.WebClient.dll, version=5.0.821.31504
    PresentationNative_cor3.dll                              C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\PresentationNative_cor3.dll, version=5,0,821,31102 @Commit: 6e0788b3a9c83d8461ccf4c9d8a14794a231b1b4
    PaintDotNet.Framework.dll                                C:\Program Files\paint.net\PaintDotNet.Framework.dll, version=4.300.7881.3082
    netstandard.dll                                          C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\netstandard.dll, version=5.0.821.31504
    System.Security.Cryptography.Algorithms.dll              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Security.Cryptography.Algorithms.dll, version=5.0.821.31504
    Microsoft.Win32.SystemEvents.dll                         C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\Microsoft.Win32.SystemEvents.dll, version=5.0.20.51904
    System.Drawing.Common.dll                                C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Drawing.Common.dll, version=5.0.421.11614
    System.ComponentModel.EventBasedAsync.dll                C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.ComponentModel.EventBasedAsync.dll, version=5.0.821.31504
    Microsoft.Win32.Registry.dll                             C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\Microsoft.Win32.Registry.dll, version=5.0.821.31504
    System.Linq.dll                                          C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Linq.dll, version=5.0.821.31504
    PresentationFramework.dll                                C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\PresentationFramework.dll, version=5.0.821.31506
    System.Xml.ReaderWriter.dll                              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Xml.ReaderWriter.dll, version=5.0.821.31504
    System.Text.Encoding.Extensions.dll                      C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Text.Encoding.Extensions.dll, version=5.0.821.31504
    System.ComponentModel.TypeConverter.dll                  C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.ComponentModel.TypeConverter.dll, version=5.0.821.31504
    System.Security.Principal.Windows.dll                    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Security.Principal.Windows.dll, version=5.0.821.31504
    System.ComponentModel.dll                                C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.ComponentModel.dll, version=5.0.821.31504
    System.Security.Claims.dll                               C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Security.Claims.dll, version=5.0.821.31504
    System.Xaml.dll                                          C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Xaml.dll, version=5.0.821.31506
    MSCTF.dll                                                C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    btmmhook.dll                                             C:\Program Files\WIDCOMM\Bluetooth Software\btmmhook.dll, version=12.0.1.587
    PSAPI.DLL                                                C:\WINDOWS\System32\PSAPI.DLL, version=10.0.19041.546 (WinBuild.160101.0800)
    PresentationCore.dll                                     C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\PresentationCore.dll, version=5.0.821.31506
    System.Threading.ThreadPool.dll                          C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Threading.ThreadPool.dll, version=5.0.821.31504
    DirectWriteForwarder.dll                                 C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\DirectWriteForwarder.dll, version=5,0,821,31506 @Commit: c3afd220b9380b3b329e7eddc63224d74e6f25fe
    System.Diagnostics.FileVersionInfo.dll                   C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Diagnostics.FileVersionInfo.dll, version=5.0.821.31504
    PaintDotNet.Effects.dll                                  C:\Program Files\paint.net\PaintDotNet.Effects.dll, version=4.300.7881.3082
    Accessibility.dll                                        C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\Accessibility.dll, version=5.0.821.31504
    System.Collections.Immutable.dll                         C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Collections.Immutable.dll, version=5.0.821.31504
    dxgi.dll                                                 C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.964 (WinBuild.160101.0800)
    System.Runtime.CompilerServices.Unsafe.dll               C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.CompilerServices.Unsafe.dll, version=5.0.821.31504
    System.IO.Packaging.dll                                  C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.IO.Packaging.dll, version=5.0.20.51904
    System.Runtime.Serialization.Formatters.dll              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.Serialization.Formatters.dll, version=5.0.821.31504
    mscorlib.dll                                             C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\mscorlib.dll, version=5.0.821.31504
    System.Runtime.Intrinsics.dll                            C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.Intrinsics.dll, version=5.0.821.31504
    System.Diagnostics.Debug.dll                             C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Diagnostics.Debug.dll, version=5.0.821.31504
    dwrite.dll                                               C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    profapi.dll                                              C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800)
    clbcatq.dll                                              C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    UIAnimation.dll                                          C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    version.dll                                              C:\WINDOWS\SYSTEM32\version.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    comctl32.dll                                             C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    ABRFileType.dll                                          C:\Program Files\paint.net\FileTypes\ABRFileType.dll, version=1.3.0.0
    ArgusPDN.AppIconSet.dll                                  C:\Program Files\paint.net\FileTypes\ArgusPDN.AppIconSet.dll, version=1.0.0.0
    AsciiArtFileType.dll                                     C:\Program Files\paint.net\FileTypes\AsciiArtFileType.dll, version=1.0.0.0
    CSVFiletype.dll                                          C:\Program Files\paint.net\FileTypes\CSVFiletype.dll, version=1.0.0.0
    IcoCur.dll                                               C:\Program Files\paint.net\FileTypes\IcoCur.dll, version=4.0.1.0
    ImAGIF.FileType.dll                                      C:\Program Files\paint.net\FileTypes\ImAGIF.FileType.dll, version=0.13.0.23943
    ImPDF.Open.FileType.dll                                  C:\Program Files\paint.net\FileTypes\ImPDF.Open.FileType.dll, version=1.1.0.0
    ImPDF.Save.FileType.dll                                  C:\Program Files\paint.net\FileTypes\ImPDF.Save.FileType.dll, version=1.4.5187.23557
    ImPS,EPS,AI.Open.FileType.dll                            C:\Program Files\paint.net\FileTypes\ImPS,EPS,AI.Open.FileType.dll, version=1.0.0.0
    ImXCF.FileType.dll                                       C:\Program Files\paint.net\FileTypes\ImXCF.FileType.dll, version=1.4.0.95
    ImZIP.FileType.dll                                       C:\Program Files\paint.net\FileTypes\ImZIP.FileType.dll, version=1.0.0.225
    LowColor.dll                                             C:\Program Files\paint.net\FileTypes\LowColor.dll, version=1.0.4.0
    OptionBasedLibrary v0.6.dll                              C:\Program Files\paint.net\FileTypes\OptionBasedLibrary v0.6.dll, version=0.5.0.0
    OptiPngFileType.dll                                      C:\Program Files\paint.net\FileTypes\OptiPngFileType.dll, version=11.0.0.0
    PatternFileType.dll                                      C:\Program Files\paint.net\FileTypes\PatternFileType.dll, version=1.0.5.0
    PhotoShop.dll                                            C:\Program Files\paint.net\FileTypes\PhotoShop.dll, version=2.5.0.0
    PNGSpriteMatrix.dll                                      C:\Program Files\paint.net\FileTypes\PNGSpriteMatrix.dll, version=1.0.2.32048
    RAWFile.dll                                              C:\Program Files\paint.net\FileTypes\RAWFile.dll, version=1.0.5.1
    SpriteSheet.dll                                          C:\Program Files\paint.net\FileTypes\SpriteSheet.dll, version=1.2.2.0
    SvgFileType.dll                                          C:\Program Files\paint.net\FileTypes\SvgFileType.dll, version=1.0.3.1
    TileImageFileType.dll                                    C:\Program Files\paint.net\FileTypes\TileImageFileType.dll, version=1.1.0.0
    System.Drawing.dll                                       C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Drawing.dll, version=5.0.821.31504
    System.dll                                               C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.dll, version=5.0.821.31504
    mfplat.dll                                               C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    cfgmgr32.dll                                             C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    RTWorkQ.DLL                                              C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    TextShaping.dll                                          C:\WINDOWS\SYSTEM32\TextShaping.dll, version=
    CompPkgSup.DLL                                           C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800)
    System.Buffers.dll                                       C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Buffers.dll, version=5.0.821.31504
    AvifFileType.dll                                         C:\Program Files\paint.net\Bundled\AvifFileType\AvifFileType.dll, version=1.1.14.0
    DdsFileTypePlus.dll                                      C:\Program Files\paint.net\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.10.0
    System.Core.dll                                          C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Core.dll, version=5.0.821.31504
    WebPFileType.dll                                         C:\Program Files\paint.net\Bundled\WebPFileType\WebPFileType.dll, version=1.3.6.0
    WinTypes.dll                                             C:\Windows\System32\WinTypes.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    System.Xml.dll                                           C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Xml.dll, version=5.0.821.31504
    UIAutomationCore.dll                                     C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.1100 (WinBuild.160101.0800)
    sxs.dll                                                  C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    oleacc.dll                                               C:\WINDOWS\SYSTEM32\oleacc.dll, version=7.2.19041.746 (WinBuild.160101.0800)
    d2d1.dll                                                 C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    wtsapi32.dll                                             C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    WINSTA.dll                                               C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    System.Resources.ResourceManager.dll                     C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Resources.ResourceManager.dll, version=5.0.821.31504
    d3d11.dll                                                C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    D3D10Warp.dll                                            C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    dxcore.dll                                               C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    System.CodeDom.dll                                       C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.CodeDom.dll, version=5.0.20.51904
    dwmapi.dll                                               C:\WINDOWS\SYSTEM32\dwmapi.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    dataexchange.dll                                         C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    dcomp.dll                                                C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.1023 (WinBuild.160101.0800)
    twinapi.appcore.dll                                      C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    textinputframework.dll                                   C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    CoreUIComponents.dll                                     C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546
    CoreMessaging.dll                                        C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746
    WS2_32.dll                                               C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800)
    ntmarta.dll                                              C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    powrprof.dll                                             C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    UMPDC.dll                                                C:\WINDOWS\SYSTEM32\UMPDC.dll, version=
    System.Text.RegularExpressions.dll                       C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Text.RegularExpressions.dll, version=5.0.821.31504
    System.Numerics.Vectors.dll                              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Numerics.Vectors.dll, version=5.0.821.31504
    winmm.dll                                                C:\WINDOWS\SYSTEM32\winmm.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    System.Threading.Tasks.Parallel.dll                      C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Threading.Tasks.Parallel.dll, version=5.0.821.31504
    explorerframe.dll                                        C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    nvldumdx.dll                                             C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5d5c294bb8d17217\nvldumdx.dll, version=30.0.14.7141
    msasn1.dll                                               C:\WINDOWS\SYSTEM32\msasn1.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    cryptnet.dll                                             C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.19041.906 (WinBuild.160101.0800)
    CRYPT32.dll                                              C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    drvstore.dll                                             C:\WINDOWS\SYSTEM32\drvstore.dll, version=10.0.19041.1081 (WinBuild.160101.0800)
    devobj.dll                                               C:\WINDOWS\SYSTEM32\devobj.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    cryptbase.dll                                            C:\WINDOWS\SYSTEM32\cryptbase.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    WINTRUST.DLL                                             C:\WINDOWS\System32\WINTRUST.DLL, version=10.0.19041.1151 (WinBuild.160101.0800)
    imagehlp.dll                                             C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    CRYPTSP.dll                                              C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    rsaenh.dll                                               C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    nvwgf2umx_cfg.dll                                        C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5d5c294bb8d17217\nvwgf2umx_cfg.dll, version=30.0.14.7141
    nvspcap64.dll                                            C:\WINDOWS\system32\nvspcap64.dll, version=3.23.0.74
    System.Diagnostics.Tracing.dll                           C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Diagnostics.Tracing.dll, version=5.0.821.31504
    2dImageFilter-r133.dll                                   C:\Program Files\paint.net\Effects\2dImageFilter-r133.dll, version=1.1.3.3
    AA's_Assistant.dll                                       C:\Program Files\paint.net\Effects\AA's_Assistant.dll, version=1.1.4329.33034
    Aardvark.dll                                             C:\Program Files\paint.net\Effects\Aardvark.dll, version=1.0.6.0
    Advanced Julia Fractal.dll                               C:\Program Files\paint.net\Effects\Advanced Julia Fractal.dll, version=1.0.7702.38303
    AdvancedRotate.dll                                       C:\Program Files\paint.net\Effects\AdvancedRotate.dll, version=1.0.3663.28009
    Advanced_Kaleidoscope.dll                                C:\Program Files\paint.net\Effects\Advanced_Kaleidoscope.dll, version=1.0.7194.37638
    advcolorrep.dll                                          C:\Program Files\paint.net\Effects\advcolorrep.dll, version=1.3.3303.27314
    AdvDith-en.dll                                           C:\Program Files\paint.net\Effects\AdvDith-en.dll, version=1.0.7500.29117
    AdvGrey.dll                                              C:\Program Files\paint.net\Effects\AdvGrey.dll, version=0.0.0.0
    AForge.Imaging.dll                                       C:\Program Files\paint.net\Effects\AForge.Imaging.dll, version=2.2.5.0
    Align Object.dll                                         C:\Program Files\paint.net\Effects\Align Object.dll, version=1.0.1.9
    AForge.dll                                               C:\Program Files\paint.net\Effects\AForge.dll, version=2.2.5.0
    Align+.dll                                               C:\Program Files\paint.net\Effects\Align+.dll, version=0.7.0.0
    OptionBasedLibrary v0.7.9.dll                            C:\Program Files\paint.net\Effects\OptionBasedLibrary v0.7.9.dll, version=0.7.9.1561
    Alias.dll                                                C:\Program Files\paint.net\Effects\Alias.dll, version=2.0.3167.14578
    AlignPlugin.dll                                          C:\Program Files\paint.net\Effects\AlignPlugin.dll, version=1.5.1.0
    Alpha2Gray.dll                                           C:\Program Files\paint.net\Effects\Alpha2Gray.dll, version=4.5.6832.21862
    Alpha-Displacement Mask.dll                              C:\Program Files\paint.net\Effects\Alpha-Displacement Mask.dll, version=1.4.1.1
    AlphaBlur.dll                                            C:\Program Files\paint.net\Effects\AlphaBlur.dll, version=2.0.0.0
    AlphaContrast.dll                                        C:\Program Files\paint.net\Effects\AlphaContrast.dll, version=1.0.3813.18307
    AlphaMask.dll                                            C:\Program Files\paint.net\Effects\AlphaMask.dll, version=2.0.3574.41943
    AlphaSpace.dll                                           C:\Program Files\paint.net\Effects\AlphaSpace.dll, version=1.0.0.0
    AlphaThreshold.dll                                       C:\Program Files\paint.net\Effects\AlphaThreshold.dll, version=1.0.0.0
    Alpha_to_0.dll                                           C:\Program Files\paint.net\Effects\Alpha_to_0.dll, version=1.0.4452.22746
    Alpha_to_255.dll                                         C:\Program Files\paint.net\Effects\Alpha_to_255.dll, version=1.0.4452.22782
    alphalevels.dll                                          C:\Program Files\paint.net\Effects\alphalevels.dll, version=1.0.6826.15479
    Angled Gradient.dll                                      C:\Program Files\paint.net\Effects\Angled Gradient.dll, version=1.0.6166.41233
    animal.dll                                               C:\Program Files\paint.net\Effects\animal.dll, version=2.1.6443.30021
    AnimationEffect.dll                                      C:\Program Files\paint.net\Effects\AnimationEffect.dll, version=1.0.0.10
    AnimGIF.dll                                              C:\Program Files\paint.net\Effects\AnimGIF.dll, version=2.4.4119.28305
    System.Security.Cryptography.Primitives.dll              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Security.Cryptography.Primitives.dll, version=5.0.821.31504
    Anti-Alias by jsonchiu.dll                               C:\Program Files\paint.net\Effects\Anti-Alias by jsonchiu.dll, version=1.0.4348.36767
    Archimedean Spiral.dll                                   C:\Program Files\paint.net\Effects\Archimedean Spiral.dll, version=1.0.0.0
    Apply Color.dll                                          C:\Program Files\paint.net\Effects\Apply Color.dll, version=1.0.4406.25220
    Apply Texture.dll                                        C:\Program Files\paint.net\Effects\Apply Texture.dll, version=1.0.0.0
    System.Diagnostics.Process.dll                           C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Diagnostics.Process.dll, version=5.0.821.31504
    ArgusPDN.Barcode.dll                                     C:\Program Files\paint.net\Effects\ArgusPDN.Barcode.dll, version=1.0.0.0
    ArgusPDN.EdgeDetect.dll                                  C:\Program Files\paint.net\Effects\ArgusPDN.EdgeDetect.dll, version=1.0.0.0
    ArgusPDN.FFTEffects.dll                                  C:\Program Files\paint.net\Effects\ArgusPDN.FFTEffects.dll, version=1.0.0.0
    ArgusPDN.Unblend.dll                                     C:\Program Files\paint.net\Effects\ArgusPDN.Unblend.dll, version=1.0.0.0
    ArtyThing.dll                                            C:\Program Files\paint.net\Effects\ArtyThing.dll, version=1.0.5.0
    Asphalt.Controls.dll                                     C:\Program Files\paint.net\Effects\Asphalt.Controls.dll, version=1.0.0.0
    Asphalt.Fonts.dll                                        C:\Program Files\paint.net\Effects\Asphalt.Fonts.dll, version=1.0.0.0
    Asphalt.PDN.dll                                          C:\Program Files\paint.net\Effects\Asphalt.PDN.dll, version=1.0.0.0
    AlignNSD.dll                                             C:\Program Files\paint.net\Effects\AlignNSD.dll, version=1.0.1.0
    AutoChrome.dll                                           C:\Program Files\paint.net\Effects\AutoChrome.dll, version=1.2.1.0
    AutoChromeNoise.dll                                      C:\Program Files\paint.net\Effects\AutoChromeNoise.dll, version=1.0.3847.37353
    AveragedColorBlur.dll                                    C:\Program Files\paint.net\Effects\AveragedColorBlur.dll, version=1.0.0.0
    AverageEdgeBlur.dll                                      C:\Program Files\paint.net\Effects\AverageEdgeBlur.dll, version=1.0.3991.32409
    AverageSelectionColor.dll                                C:\Program Files\paint.net\Effects\AverageSelectionColor.dll, version=1.1.3256.33886
    AxInterop.WMPLib.dll                                     C:\Program Files\paint.net\Effects\AxInterop.WMPLib.dll, version=1.0.0.0
    Interop.WMPLib.dll                                       C:\Program Files\paint.net\Effects\Interop.WMPLib.dll, version=1.0.0.0
    BaseUtility.dll                                          C:\Program Files\paint.net\Effects\BaseUtility.dll, version=1.0.0.0
    BBOutlinedGradientText.dll                               C:\Program Files\paint.net\Effects\BBOutlinedGradientText.dll, version=4.6.7358.38713
    Basic Edge Detector.dll                                  C:\Program Files\paint.net\Effects\Basic Edge Detector.dll, version=1.0.5347.22706
    Bevel_v1.4.0.0.dll                                       C:\Program Files\paint.net\Effects\Bevel_v1.4.0.0.dll, version=0.0.0.0
    BasicAntialias11.dll                                     C:\Program Files\paint.net\Effects\BasicAntialias11.dll, version=0.0.0.0
    AxisStreakGmicPDN.dll                                    C:\Program Files\paint.net\Effects\AxisStreakGmicPDN.dll, version=0.2.0.0
    BasicPhotoAdjustments.dll                                C:\Program Files\paint.net\Effects\BasicPhotoAdjustments.dll, version=2.1.4020.485
    BandWPlus.dll                                            C:\Program Files\paint.net\Effects\BandWPlus.dll, version=1.3.7359.317
    Bars.dll                                                 C:\Program Files\paint.net\Effects\Bars.dll, version=1.1.0.0
    Bezncurve.dll                                            C:\Program Files\paint.net\Effects\Bezncurve.dll, version=4.0.1.0
    Bidirectional Blur.dll                                   C:\Program Files\paint.net\Effects\Bidirectional Blur.dll, version=1.0.0.0
    Black and White Converter.dll                            C:\Program Files\paint.net\Effects\Black and White Converter.dll, version=1.1.0.0
    BlackandAlpha+.dll                                       C:\Program Files\paint.net\Effects\BlackandAlpha+.dll, version=1.2.4329.272
    BlackAndWhite+.dll                                       C:\Program Files\paint.net\Effects\BlackAndWhite+.dll, version=1.1.6744.2631
    BlackWhiteOnly.dll                                       C:\Program Files\paint.net\Effects\BlackWhiteOnly.dll, version=1.0.0.0
    BlendModesPlus.dll                                       C:\Program Files\paint.net\Effects\BlendModesPlus.dll, version=3.1.0.0
    BlendSeams.dll                                           C:\Program Files\paint.net\Effects\BlendSeams.dll, version=1.1.6021.34867
    BlurBlend.dll                                            C:\Program Files\paint.net\Effects\BlurBlend.dll, version=1.1.6601.26020
    BlurFill.dll                                             C:\Program Files\paint.net\Effects\BlurFill.dll, version=1.5.1.0
    Borders N' Shapes.dll                                    C:\Program Files\paint.net\Effects\Borders N' Shapes.dll, version=4.0.4642.26476
    Boutons.dll                                              C:\Program Files\paint.net\Effects\Boutons.dll, version=1.1.0.0
    boxfitting.dll                                           C:\Program Files\paint.net\Effects\boxfitting.dll, version=1.1.6164.32856
    BrushFactory.dll                                         C:\Program Files\paint.net\Effects\BrushFactory.dll, version=2.0.2
    BumpChecker.dll                                          C:\Program Files\paint.net\Effects\BumpChecker.dll, version=1.4.4399.25606
    Burninate.dll                                            C:\Program Files\paint.net\Effects\Burninate.dll, version=4.6.7358.31797
    Calendar.dll                                             C:\Program Files\paint.net\Effects\Calendar.dll, version=4.6.7358.32649
    CalliColour.dll                                          C:\Program Files\paint.net\Effects\CalliColour.dll, version=1.0.1.0
    Cartoonize.dll                                           C:\Program Files\paint.net\Effects\Cartoonize.dll, version=1.0.4629.37393
    CellMaker.dll                                            C:\Program Files\paint.net\Effects\CellMaker.dll, version=1.1.6139.29120
    BrushFilter.dll                                          C:\Program Files\paint.net\Effects\BrushFilter.dll, version=1.3.0.13866
    Bullet.dll                                               C:\Program Files\paint.net\Effects\Bullet.dll, version=1.0.0.0
    BulletinBoardTrim.dll                                    C:\Program Files\paint.net\Effects\BulletinBoardTrim.dll, version=1.0.0.0
    CellMakerRev.dll                                         C:\Program Files\paint.net\Effects\CellMakerRev.dll, version=1.0.7006.21865
    CellTexture.dll                                          C:\Program Files\paint.net\Effects\CellTexture.dll, version=1.0.0.0
    Centerlines 2.dll                                        C:\Program Files\paint.net\Effects\Centerlines 2.dll, version=0.0.0.0
    CenterLines.dll                                          C:\Program Files\paint.net\Effects\CenterLines.dll, version=1.0.0.0
    ChangeExtremeColors.dll                                  C:\Program Files\paint.net\Effects\ChangeExtremeColors.dll, version=1.2.5.0
    Channel Editing.dll                                      C:\Program Files\paint.net\Effects\Channel Editing.dll, version=1.0.7702.39387
    Channel Extraction.dll                                   C:\Program Files\paint.net\Effects\Channel Extraction.dll, version=1.0.7703.23621
    ChannelOperation.dll                                     C:\Program Files\paint.net\Effects\ChannelOperation.dll, version=1.0.6350.2522
    ChessFEN.dll                                             C:\Program Files\paint.net\Effects\ChessFEN.dll, version=1.1.6139.31083
    circleFractal2.dll                                       C:\Program Files\paint.net\Effects\circleFractal2.dll, version=1.1.5613.38521
    CircleGen.dll                                            C:\Program Files\paint.net\Effects\CircleGen.dll, version=1.3.7505.20607
    CircleText.dll                                           C:\Program Files\paint.net\Effects\CircleText.dll, version=1.4.4415.32488
    circle_draw.dll                                          C:\Program Files\paint.net\Effects\circle_draw.dll, version=1.0.7180.25304
    CircularText.dll                                         C:\Program Files\paint.net\Effects\CircularText.dll, version=2.0.1.0
    CK_Plugin.dll                                            C:\Program Files\paint.net\Effects\CK_Plugin.dll, version=1.5.5345.24808
    ClampedGaussianBlur.dll                                  C:\Program Files\paint.net\Effects\ClampedGaussianBlur.dll, version=2.0.0.0
    Clarifaction+.dll                                        C:\Program Files\paint.net\Effects\Clarifaction+.dll, version=1.0.4406.25898
    Clarify.dll                                              C:\Program Files\paint.net\Effects\Clarify.dll, version=1.0.4349.19613
    CleanTransparent.dll                                     C:\Program Files\paint.net\Effects\CleanTransparent.dll, version=1.0.0.0
    ClipDisplaceAA.dll                                       C:\Program Files\paint.net\Effects\ClipDisplaceAA.dll, version=1.2.4.0
    ClipWarp.dll                                             C:\Program Files\paint.net\Effects\ClipWarp.dll, version=1.0.9.0
    ClipWarpNew.dll                                          C:\Program Files\paint.net\Effects\ClipWarpNew.dll, version=1.0.1.0
    Clock.dll                                                C:\Program Files\paint.net\Effects\Clock.dll, version=1.1.6245.30896
    CloudEffect.dll                                          C:\Program Files\paint.net\Effects\CloudEffect.dll, version=1.1.0.0
    ClusterClearEffect.dll                                   C:\Program Files\paint.net\Effects\ClusterClearEffect.dll, version=1.0.0.0
    CMY Ghost.dll                                            C:\Program Files\paint.net\Effects\CMY Ghost.dll, version=1.0.4909.35063
    Cobweb.dll                                               C:\Program Files\paint.net\Effects\Cobweb.dll, version=1.0.1.0
    Color Match.dll                                          C:\Program Files\paint.net\Effects\Color Match.dll, version=4.0.4642.26532
    coloraberation.dll                                       C:\Program Files\paint.net\Effects\coloraberation.dll, version=1.0.3859.18981
    CodeArtEng.DspToolbox.dll                                C:\Program Files\paint.net\Effects\CodeArtEng.DspToolbox.dll, version=2.0.3.0
    CodeLab.dll                                              C:\Program Files\paint.net\Effects\CodeLab.dll, version=6.1.7846.37265
    ColorBalance.dll                                         C:\Program Files\paint.net\Effects\ColorBalance.dll, version=4.7.7401.17173
    ColorBalanceLesson.dll                                   C:\Program Files\paint.net\Effects\ColorBalanceLesson.dll, version=1.0.6621.10132
    Colorblindness.dll                                       C:\Program Files\paint.net\Effects\Colorblindness.dll, version=4.0.7585.35502
    ColorClearer.dll                                         C:\Program Files\paint.net\Effects\ColorClearer.dll, version=1.1.6009.41762
    ColorHarmonies.Effect.dll                                C:\Program Files\paint.net\Effects\ColorHarmonies.Effect.dll, version=0.7.0.155
    ColorRamp.dll                                            C:\Program Files\paint.net\Effects\ColorRamp.dll, version=1.0.0.0
    OptionBasedLibrary v0.7.3.dll                            C:\Program Files\paint.net\Effects\OptionBasedLibrary v0.7.3.dll, version=0.7.0.229
    ColorRange.dll                                           C:\Program Files\paint.net\Effects\ColorRange.dll, version=1.1.0.0
    Copy Selection Bounding Box.dll                          C:\Program Files\paint.net\Effects\Copy Selection Bounding Box.dll, version=1.0.7837.1417
    ColorSketch.dll                                          C:\Program Files\paint.net\Effects\ColorSketch.dll, version=1.1.0.0
    CopyAlpha.dll                                            C:\Program Files\paint.net\Effects\CopyAlpha.dll, version=1.0.0.0
    CreativeTextPro.dll                                      C:\Program Files\paint.net\Effects\CreativeTextPro.dll, version=1.1.7358.34307
    ColorSketch_en.dll                                       C:\Program Files\paint.net\Effects\ColorSketch_en.dll, version=1.0.0.0
    ColorToAlpha.dll                                         C:\Program Files\paint.net\Effects\ColorToAlpha.dll, version=2.3.0.0
    Cubic_Transformation.dll                                 C:\Program Files\paint.net\Effects\Cubic_Transformation.dll, version=2.0.7235.39373
    ColorTrimming.dll                                        C:\Program Files\paint.net\Effects\ColorTrimming.dll, version=1.0.3167.14623
    ColorZoomBlur.dll                                        C:\Program Files\paint.net\Effects\ColorZoomBlur.dll, version=1.1.3873.36417
    Color_Magic.dll                                          C:\Program Files\paint.net\Effects\Color_Magic.dll, version=1.0.7186.9639
    CombinedAdjustments.dll                                  C:\Program Files\paint.net\Effects\CombinedAdjustments.dll, version=1.1.7358.40688
    complement.dll                                           C:\Program Files\paint.net\Effects\complement.dll, version=0.1.7021.39134
    CompoGrids.dll                                           C:\Program Files\paint.net\Effects\CompoGrids.dll, version=1.0.2.0
    Compotool.dll                                            C:\Program Files\paint.net\Effects\Compotool.dll, version=1.0.1.0
    ComputeShaderEffects.dll                                 C:\Program Files\paint.net\Effects\ComputeShaderEffects.dll, version=3.1.0.0
    SharpDX.Direct3D11.dll                                   C:\Program Files\paint.net\Effects\SharpDX.Direct3D11.dll, version=4.0.1
    Cuboids.dll                                              C:\Program Files\paint.net\Effects\Cuboids.dll, version=1.1.1.0
    SharpDX.dll                                              C:\Program Files\paint.net\Effects\SharpDX.dll, version=4.0.1
    ColorMatrix.Effect.dll                                   C:\Program Files\paint.net\Effects\ColorMatrix.Effect.dll, version=1.1.0.22
    CurlyLines.dll                                           C:\Program Files\paint.net\Effects\CurlyLines.dll, version=1.0.0.0
    SharpDX.D3DCompiler.dll                                  C:\Program Files\paint.net\Effects\SharpDX.D3DCompiler.dll, version=4.0.1
    Curves+.dll                                              C:\Program Files\paint.net\Effects\Curves+.dll, version=4.0.6119.31044
    CustomControls.dll                                       C:\Program Files\paint.net\Effects\CustomControls.dll, version=0.0.0.0
    ContentAwareFill.dll                                     C:\Program Files\paint.net\Effects\ContentAwareFill.dll, version=1.4.4.0
    CustomCornerFrame.dll                                    C:\Program Files\paint.net\Effects\CustomCornerFrame.dll, version=1.0.4.0
    Contour.dll                                              C:\Program Files\paint.net\Effects\Contour.dll, version=1.0.1.0
    CustomBrushesMini.dll                                    C:\Program Files\paint.net\Effects\CustomBrushesMini.dll, version=2.2.5286.39584
    CoordinatePlanePoints.dll                                C:\Program Files\paint.net\Effects\CoordinatePlanePoints.dll, version=1.0.6034.29864
    ColorMixer.dll                                           C:\Program Files\paint.net\Effects\ColorMixer.dll, version=1.3.0.0
    ColorModulo.dll                                          C:\Program Files\paint.net\Effects\ColorModulo.dll, version=1.1.2.0
    CustomFrame.dll                                          C:\Program Files\paint.net\Effects\CustomFrame.dll, version=1.5.0.0
    CycleHSV.dll                                             C:\Program Files\paint.net\Effects\CycleHSV.dll, version=1.0.4909.35068
    deviation-to-alpha.dll                                   C:\Program Files\paint.net\Effects\deviation-to-alpha.dll, version=1.1.7681.23746
    DHShapeMaker.dll                                         C:\Program Files\paint.net\Effects\DHShapeMaker.dll, version=1.7.0.1
    Diagonal Lines.dll                                       C:\Program Files\paint.net\Effects\Diagonal Lines.dll, version=1.0.4800.36619
    Diffuse.dll                                              C:\Program Files\paint.net\Effects\Diffuse.dll, version=1.0.3254.27766
    Dimensions.dll                                           C:\Program Files\paint.net\Effects\Dimensions.dll, version=1.3.6826.38472
    Displacement.dll                                         C:\Program Files\paint.net\Effects\Displacement.dll, version=1.1.0.0
    dpyColorBalance.dll                                      C:\Program Files\paint.net\Effects\dpyColorBalance.dll, version=1.1.4330.37850
    DispMap.dll                                              C:\Program Files\paint.net\Effects\DispMap.dll, version=2.1.7197.13119
    DraganEffect_en.dll                                      C:\Program Files\paint.net\Effects\DraganEffect_en.dll, version=1.0.0.0
    DistortingMirror.dll                                     C:\Program Files\paint.net\Effects\DistortingMirror.dll, version=1.0.4281.30602
    DragFrom.dll                                             C:\Program Files\paint.net\Effects\DragFrom.dll, version=1.1.0.0
    DistortThis.dll                                          C:\Program Files\paint.net\Effects\DistortThis.dll, version=2.9.0.0
    DrawCenterCell.dll                                       C:\Program Files\paint.net\Effects\DrawCenterCell.dll, version=0.1.6965.21445
    Donut.dll                                                C:\Program Files\paint.net\Effects\Donut.dll, version=1.1.6406.36312
    Dot.dll                                                  C:\Program Files\paint.net\Effects\Dot.dll, version=1.0.4673.202
    DotMatrix.dll                                            C:\Program Files\paint.net\Effects\DotMatrix.dll, version=1.0.6178.27733
    DPLNightVision.dll                                       C:\Program Files\paint.net\Effects\DPLNightVision.dll, version=1.0.4004.18455
    dpyColorBalance+.dll                                     C:\Program Files\paint.net\Effects\dpyColorBalance+.dll, version=1.1.1.0
    DrawGrid.dll                                             C:\Program Files\paint.net\Effects\DrawGrid.dll, version=0.1.6965.21086
    DrawingTool.dll                                          C:\Program Files\paint.net\Effects\DrawingTool.dll, version=1.0.0.2
    EarthsAndGreys.dll                                       C:\Program Files\paint.net\Effects\EarthsAndGreys.dll, version=1.0.1.0
    System.Xml.Linq.dll                                      C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Xml.Linq.dll, version=5.0.821.31504
    Dream.dll                                                C:\Program Files\paint.net\Effects\Dream.dll, version=4.6.7358.35004
    System.Xml.XDocument.dll                                 C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Xml.XDocument.dll, version=5.0.821.31504
    System.Private.Xml.Linq.dll                              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Private.Xml.Linq.dll, version=5.0.821.31504
    Droste.dll                                               C:\Program Files\paint.net\Effects\Droste.dll, version=1.0.0.0
    DrPrepper.dll                                            C:\Program Files\paint.net\Effects\DrPrepper.dll, version=1.4.4399.25637
    Dryad.dll                                                C:\Program Files\paint.net\Effects\Dryad.dll, version=1.0.2.0
    DuotoneGradientMap.dll                                   C:\Program Files\paint.net\Effects\DuotoneGradientMap.dll, version=1.0.7487.40422
    DynamicContrast.dll                                      C:\Program Files\paint.net\Effects\DynamicContrast.dll, version=1.1.0.0
    System.Numerics.dll                                      C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Numerics.dll, version=5.0.821.31504
    System.Runtime.Numerics.dll                              C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Runtime.Numerics.dll, version=5.0.821.31504
    Edge Shader.dll                                          C:\Program Files\paint.net\Effects\Edge Shader.dll, version=1.0.1.0
    EdgeBlur.dll                                             C:\Program Files\paint.net\Effects\EdgeBlur.dll, version=1.1.6579.1729
    EdgeExpander.dll                                         C:\Program Files\paint.net\Effects\EdgeExpander.dll, version=1.0.5863.38192
    EdgeFader.dll                                            C:\Program Files\paint.net\Effects\EdgeFader.dll, version=5.3.5.0
    EdgeShaderMJW.dll                                        C:\Program Files\paint.net\Effects\EdgeShaderMJW.dll, version=1.0.5717.35999
    EdHarvey.Effects.Archive.PolarInversionPlus.dll          C:\Program Files\paint.net\Effects\EdHarvey.Effects.Archive.PolarInversionPlus.dll, version=3.22.3024.37811
    EdHarvey.Effects.Archives.DentsClassic.dll               C:\Program Files\paint.net\Effects\EdHarvey.Effects.Archives.DentsClassic.dll, version=3.5.3777.3380
    Mono.Cecil.dll                                           C:\Program Files\paint.net\Mono.Cecil.dll, version=0.11.4.0
    System.IO.Compression.dll                                C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.IO.Compression.dll, version=5.0.821.31504
    EditableText.dll                                         C:\Program Files\paint.net\Effects\EditableText.dll, version=1.0.1.0
    SBCommon.dll                                             C:\Program Files\paint.net\Effects\SBCommon.dll, version=3.0.0.0
    EigenBlur.dll                                            C:\Program Files\paint.net\Effects\EigenBlur.dll, version=1.3.3555.24648
    Emboss+.dll                                              C:\Program Files\paint.net\Effects\Emboss+.dll, version=1.2.0.0
    EngraveEmboss.dll                                        C:\Program Files\paint.net\Effects\EngraveEmboss.dll, version=2.0.2
    IniFile.dll                                              C:\Program Files\paint.net\Effects\IniFile.dll, version=2.0.2
    FillFromFile.dll                                         C:\Program Files\paint.net\Effects\FillFromFile.dll, version=4.7.7358.36581
    FillPalette.dll                                          C:\Program Files\paint.net\Effects\FillPalette.dll, version=0.4.0.0
    EOEffects.dll                                            C:\Program Files\paint.net\Effects\EOEffects.dll, version=1.10.16.12
    Color Dimmer.dll                                         C:\Program Files\paint.net\Effects\Color Dimmer.dll, version=1.3.0.0
    FindEdges.dll                                            C:\Program Files\paint.net\Effects\FindEdges.dll, version=1.2.0.0
    Fisheye.dll                                              C:\Program Files\paint.net\Effects\Fisheye.dll, version=2.2.5533.12794
    Flip.dll                                                 C:\Program Files\paint.net\Effects\Flip.dll, version=4.6.7358.36953
    Flourish.dll                                             C:\Program Files\paint.net\Effects\Flourish.dll, version=1.0.2.0
    Frame.dll                                                C:\Program Files\paint.net\Effects\Frame.dll, version=1.1.0.0
    FloydSteinbergDithering.dll                              C:\Program Files\paint.net\Effects\FloydSteinbergDithering.dll, version=4.6.7358.37110
    FSPost.dll                                               C:\Program Files\paint.net\Effects\FSPost.dll, version=1.0.4913.8979
    Fractal Attractor.dll                                    C:\Program Files\paint.net\Effects\Fractal Attractor.dll, version=1.0.6388.26241
    FractalFern.dll                                          C:\Program Files\paint.net\Effects\FractalFern.dll, version=1.2.0.0
    FractalTree.dll                                          C:\Program Files\paint.net\Effects\FractalTree.dll, version=1.2.0.0
    Equirectangular Diffuse Transform.dll                    C:\Program Files\paint.net\Effects\Equirectangular Diffuse Transform.dll, version=1.0.7159.445
    Equirectangular Viewer.dll                               C:\Program Files\paint.net\Effects\Equirectangular Viewer.dll, version=1.0.0.42271
    Erode.dll                                                C:\Program Files\paint.net\Effects\Erode.dll, version=1.0.0.0
    ErodeDilate_v0.2.dll                                     C:\Program Files\paint.net\Effects\ErodeDilate_v0.2.dll, version=1.0.0.0
    ErrorDiffusionDithering.dll                              C:\Program Files\paint.net\Effects\ErrorDiffusionDithering.dll, version=1.0.0.0
    ExpandColor.dll                                          C:\Program Files\paint.net\Effects\ExpandColor.dll, version=1.2.0.0
    ExtendBorder.dll                                         C:\Program Files\paint.net\Effects\ExtendBorder.dll, version=1.3.0.0
    Eyeshine.dll                                             C:\Program Files\paint.net\Effects\Eyeshine.dll, version=1.0.3700.25905
    Facet.dll                                                C:\Program Files\paint.net\Effects\Facet.dll, version=1.0.3.0
    FibonacciFill.dll                                        C:\Program Files\paint.net\Effects\FibonacciFill.dll, version=1.1.6139.28851
    FillFromClipboard.dll                                    C:\Program Files\paint.net\Effects\FillFromClipboard.dll, version=4.7.7358.36519
    FurBlur.dll                                              C:\Program Files\paint.net\Effects\FurBlur.dll, version=1.0.1.0
    Gingham.dll                                              C:\Program Files\paint.net\Effects\Gingham.dll, version=1.1.0.0
    Glass_Blur.dll                                           C:\Program Files\paint.net\Effects\Glass_Blur.dll, version=1.1.7212.26179
    FuzzyEdgeDetect.dll                                      C:\Program Files\paint.net\Effects\FuzzyEdgeDetect.dll, version=1.0.5885.13123
    Galaxy Transformation (1).dll                            C:\Program Files\paint.net\Effects\Galaxy Transformation (1).dll, version=1.0.7267.41850
    GaussianBlurPlus.dll                                     C:\Program Files\paint.net\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401
    Gears.dll                                                C:\Program Files\paint.net\Effects\Gears.dll, version=1.0.2.0
    Gen96Colors.dll                                          C:\Program Files\paint.net\Effects\Gen96Colors.dll, version=1.0.0.0
    GenesisVFX.dll                                           C:\Program Files\paint.net\Effects\GenesisVFX.dll, version=1.0.0.0
    GenTree.dll                                              C:\Program Files\paint.net\Effects\GenTree.dll, version=0.1.0.0
    Gmic.dll                                                 C:\Program Files\paint.net\Effects\Gmic.dll, version=2.9.8.0
    Gossamer.dll                                             C:\Program Files\paint.net\Effects\Gossamer.dll, version=1.0.2.0
    GpcDotNet.AMD64.dll                                      C:\Program Files\paint.net\Effects\GpcDotNet.AMD64.dll, version=
    mscoree.dll                                              C:\WINDOWS\SYSTEM32\mscoree.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    MSVCR90.dll                                              C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9625_none_08e1c10da83fbc83\MSVCR90.dll, version=9.00.30729.9625
    msvcm90.dll                                              C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9625_none_08e1c10da83fbc83\msvcm90.dll, version=9.00.30729.9625
    mscoreei.dll                                             C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.8.4180.0 built by: NET48REL1LAST_B
    GpcDotNet.Interface.dll                                  C:\Program Files\paint.net\Effects\GpcDotNet.Interface.dll, version=0.0.0.0
    Microsoft.DiaSymReader.Native.amd64.dll                  C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\Microsoft.DiaSymReader.Native.amd64.dll, version=14.12.25830.2 built by: VCTOOLSD15ULDR
    amsi.dll                                                 C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    USERENV.dll                                              C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    MpOav.dll                                                C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.2106.6-0\MpOav.dll, version=4.18.2106.6 (WinBuild.160101.0800)
    MPCLIENT.DLL                                             C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.2106.6-0\MPCLIENT.DLL, version=4.18.2106.6 (WinBuild.160101.0800)
    gpapi.dll                                                C:\WINDOWS\SYSTEM32\gpapi.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    GreenTintReduction.dll                                   C:\Program Files\paint.net\Effects\GreenTintReduction.dll, version=1.0.6484.29238
    Grid Warp.dll                                            C:\Program Files\paint.net\Effects\Grid Warp.dll, version=4.0.6544.34496
    GridCheckerboard.dll                                     C:\Program Files\paint.net\Effects\GridCheckerboard.dll, version=4.5.6828.36789
    GridGrad.dll                                             C:\Program Files\paint.net\Effects\GridGrad.dll, version=1.0.4172.25342
    GridMaker.dll                                            C:\Program Files\paint.net\Effects\GridMaker.dll, version=5.1.0.0
    GrimColorReaper.dll                                      C:\Program Files\paint.net\Effects\GrimColorReaper.dll, version=1.2.4299.5808
    Grow.dll                                                 C:\Program Files\paint.net\Effects\Grow.dll, version=1.0.7.0
    GS_Plugin.dll                                            C:\Program Files\paint.net\Effects\GS_Plugin.dll, version=1.3.5345.24516
    GuideLines.dll                                           C:\Program Files\paint.net\Effects\GuideLines.dll, version=1.0.6239.35558
    Heightmap v1.3.dll                                       C:\Program Files\paint.net\Effects\Heightmap v1.3.dll, version=1.3.4261.22267
    HeightToNormal.dll                                       C:\Program Files\paint.net\Effects\HeightToNormal.dll, version=1.0.0.0
    Helix.dll                                                C:\Program Files\paint.net\Effects\Helix.dll, version=1.0.1.0
    System.Diagnostics.StackTrace.dll                        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Diagnostics.StackTrace.dll, version=5.0.821.31504
    HexaGrid.dll                                             C:\Program Files\paint.net\Effects\HexaGrid.dll, version=4.1.0.0
    InvertAlpha.dll                                          C:\Program Files\paint.net\Effects\InvertAlpha.dll, version=1.0.3040.33378
    Highlight.dll                                            C:\Program Files\paint.net\Effects\Highlight.dll, version=1.0.1.0
    Invert_Anything.dll                                      C:\Program Files\paint.net\Effects\Invert_Anything.dll, version=1.0.7213.37760
    isolate.dll                                              C:\Program Files\paint.net\Effects\isolate.dll, version=1.0.3303.3202
    HighPass_rec.dll                                         C:\Program Files\paint.net\Effects\HighPass_rec.dll, version=1.3.6135.23156
    HilbertCurve.dll                                         C:\Program Files\paint.net\Effects\HilbertCurve.dll, version=1.2.0.0
    Histogram.dll                                            C:\Program Files\paint.net\Effects\Histogram.dll, version=1.0.0.0
    HotMetalGlow.dll                                         C:\Program Files\paint.net\Effects\HotMetalGlow.dll, version=1.2.5985.32923
    HsvEraser.dll                                            C:\Program Files\paint.net\Effects\HsvEraser.dll, version=1.1.5625.39352
    HSVGradients.dll                                         C:\Program Files\paint.net\Effects\HSVGradients.dll, version=4.5.6832.41864
    HsvScrambler.dll                                         C:\Program Files\paint.net\Effects\HsvScrambler.dll, version=1.1.5675.38718
    HueSatPlus.dll                                           C:\Program Files\paint.net\Effects\HueSatPlus.dll, version=4.6.7359.209
    System.Design.dll                                        C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Design.dll, version=5.0.821.31504
    Image Modulo Toolkit.dll                                 C:\Program Files\paint.net\Effects\Image Modulo Toolkit.dll, version=1.0.7587.35621
    System.Reflection.Metadata.dll                           C:\Program Files\dotnet\shared\Microsoft.NETCore.App\5.0.8\System.Reflection.Metadata.dll, version=5.0.821.31504
    System.Windows.Forms.Design.dll                          C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Windows.Forms.Design.dll, version=5.0.821.31504
    Gradient Bars.dll                                        C:\Program Files\paint.net\Effects\Gradient Bars.dll, version=4.0.5152.23084
    ImageDifference.dll                                      C:\Program Files\paint.net\Effects\ImageDifference.dll, version=1.0.0.21216
    Gradient Blocks.dll                                      C:\Program Files\paint.net\Effects\Gradient Blocks.dll, version=4.0.4642.26658
    Gradient Blur.dll                                        C:\Program Files\paint.net\Effects\Gradient Blur.dll, version=1.0.0.0
    ImageDistortion.dll                                      C:\Program Files\paint.net\Effects\ImageDistortion.dll, version=1.1.0.0
    Gradient Grid.dll                                        C:\Program Files\paint.net\Effects\Gradient Grid.dll, version=4.0.6436.36068
    Gradient Mapping.dll                                     C:\Program Files\paint.net\Effects\Gradient Mapping.dll, version=4.0.6547.33963
    GradientMap.dll                                          C:\Program Files\paint.net\Effects\GradientMap.dll, version=1.1.7440.15108
    GradientsGalore.dll                                      C:\Program Files\paint.net\Effects\GradientsGalore.dll, version=1.0.5.0
    Gradual_Stripes.dll                                      C:\Program Files\paint.net\Effects\Gradual_Stripes.dll, version=1.0.6595.41826
    GraphPaper.dll                                           C:\Program Files\paint.net\Effects\GraphPaper.dll, version=2.1.0.0
    ImageInText.dll                                          C:\Program Files\paint.net\Effects\ImageInText.dll, version=0.0.0.0
    ImgurUploader.dll                                        C:\Program Files\paint.net\Effects\ImgurUploader.dll, version=1.3.0.0
    InkSketch+.dll                                           C:\Program Files\paint.net\Effects\InkSketch+.dll, version=1.0.4629.39900
    InsetBoxShadow.dll                                       C:\Program Files\paint.net\Effects\InsetBoxShadow.dll, version=1.3.0.0
    Gravity.dll                                              C:\Program Files\paint.net\Effects\Gravity.dll, version=1.1.0.0
    IntensityRGB.dll                                         C:\Program Files\paint.net\Effects\IntensityRGB.dll, version=1.0.0.0
    InterlockingTiles.dll                                    C:\Program Files\paint.net\Effects\InterlockingTiles.dll, version=1.0.0.0
    Gray2Alpha.dll                                           C:\Program Files\paint.net\Effects\Gray2Alpha.dll, version=4.5.6826.36897
    IsolateChannel.dll                                       C:\Program Files\paint.net\Effects\IsolateChannel.dll, version=1.0.0.0
    IsometricCuboid.dll                                      C:\Program Files\paint.net\Effects\IsometricCuboid.dll, version=1.6.0.0
    IsometricTiled.dll                                       C:\Program Files\paint.net\Effects\IsometricTiled.dll, version=1.0.6827.41632
    jchunn.dll                                               C:\Program Files\paint.net\Effects\jchunn.dll, version=1.0.0.0
    Microsoft.VisualBasic.dll                                C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\Microsoft.VisualBasic.dll, version=5.0.821.31504
    Microsoft.VisualBasic.Forms.dll                          C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\Microsoft.VisualBasic.Forms.dll, version=5.0.821.31504
    Jitter.dll                                               C:\Program Files\paint.net\Effects\Jitter.dll, version=4.0.4642.26986
    JPGNoiseReduction.dll                                    C:\Program Files\paint.net\Effects\JPGNoiseReduction.dll, version=1.0.3747.24002
    JuliaPlus.dll                                            C:\Program Files\paint.net\Effects\JuliaPlus.dll, version=1.0.5.0
    JustifyText.dll                                          C:\Program Files\paint.net\Effects\JustifyText.dll, version=1.0.0.0
    Lens.dll                                                 C:\Program Files\paint.net\Effects\Lens.dll, version=1.3.0.0
    PresentationFramework-SystemXmlLinq.dll                  C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\PresentationFramework-SystemXmlLinq.dll, version=5.0.821.31506
    LensFlare.dll                                            C:\Program Files\paint.net\Effects\LensFlare.dll, version=2.2.12.0
    LevelHorizon.dll                                         C:\Program Files\paint.net\Effects\LevelHorizon.dll, version=4.6.7358.37589
    Lightning.dll                                            C:\Program Files\paint.net\Effects\Lightning.dll, version=1.1.3896.32593
    Kaleidoscope.dll                                         C:\Program Files\paint.net\Effects\Kaleidoscope.dll, version=1.3.0.0
    Kill Color Keeper.dll                                    C:\Program Files\paint.net\Effects\Kill Color Keeper.dll, version=1.0.6641.13453
    Kuwahara.dll                                             C:\Program Files\paint.net\Effects\Kuwahara.dll, version=1.0.0.0
    Landscape.dll                                            C:\Program Files\paint.net\Effects\Landscape.dll, version=4.6.7358.37463
    LaplacianPyramidFilter.dll                               C:\Program Files\paint.net\Effects\LaplacianPyramidFilter.dll, version=1.1.1
    Lattice_Transform.dll                                    C:\Program Files\paint.net\Effects\Lattice_Transform.dll, version=1.0.7215.30711
    LavEnt.Effects.RoundedRectangle.dll                      C:\Program Files\paint.net\Effects\LavEnt.Effects.RoundedRectangle.dll, version=1.5.0.0
    Layer Cake.dll                                           C:\Program Files\paint.net\Effects\Layer Cake.dll, version=1.0.4911.8147
    LightRays.dll                                            C:\Program Files\paint.net\Effects\LightRays.dll, version=2.1.0.0
    LinesGrid.dll                                            C:\Program Files\paint.net\Effects\LinesGrid.dll, version=1.2.0.0
    Linocut_en.dll                                           C:\Program Files\paint.net\Effects\Linocut_en.dll, version=1.0.0.0
    Liquify.dll                                              C:\Program Files\paint.net\Effects\Liquify.dll, version=4.0.5873.25113
    ListOfPalettes.dll                                       C:\Program Files\paint.net\Effects\ListOfPalettes.dll, version=1.0.0.0
    LocalContrast.dll                                        C:\Program Files\paint.net\Effects\LocalContrast.dll, version=3.0.0.0
    LocalNoise.dll                                           C:\Program Files\paint.net\Effects\LocalNoise.dll, version=1.0.4674.29909
    LookAtIt.Effect.dll                                      C:\Program Files\paint.net\Effects\LookAtIt.Effect.dll, version=0.6.0.779
    Magnifier.dll                                            C:\Program Files\paint.net\Effects\Magnifier.dll, version=1.3.0.0
    Majority.dll                                             C:\Program Files\paint.net\Effects\Majority.dll, version=1.1.0.0
    MakePalette.dll                                          C:\Program Files\paint.net\Effects\MakePalette.dll, version=1.0.7740.39799
    mandala.dll                                              C:\Program Files\paint.net\Effects\mandala.dll, version=1.0.0.0
    MandalaCreator.dll                                       C:\Program Files\paint.net\Effects\MandalaCreator.dll, version=1.2.6946.21792
    ManualColorCorrection.dll                                C:\Program Files\paint.net\Effects\ManualColorCorrection.dll, version=1.0.4314.41440
    MarkupRenderer.dll                                       C:\Program Files\paint.net\Effects\MarkupRenderer.dll, version=1.0.0.0
    MathNet.Iridium.dll                                      C:\Program Files\paint.net\Effects\MathNet.Iridium.dll, version=2007.3.8.0
    Matrice.dll                                              C:\Program Files\paint.net\Effects\Matrice.dll, version=1.0.3810.11744
    MeasureObject.dll                                        C:\Program Files\paint.net\Effects\MeasureObject.dll, version=1.5.0.0
    Nebulous.dll                                             C:\Program Files\paint.net\Effects\Nebulous.dll, version=1.2.4.0
    NeonEdges.dll                                            C:\Program Files\paint.net\Effects\NeonEdges.dll, version=1.1.0.0
    NeutralWire.dll                                          C:\Program Files\paint.net\Effects\NeutralWire.dll, version=1.0.6333.34789
    NewtonFractal.dll                                        C:\Program Files\paint.net\Effects\NewtonFractal.dll, version=2.2.1.0
    MeasureSelection.dll                                     C:\Program Files\paint.net\Effects\MeasureSelection.dll, version=1.5.0.0
    NoiseBleach.dll                                          C:\Program Files\paint.net\Effects\NoiseBleach.dll, version=1.0.4909.35542
    NoiseChoice.dll                                          C:\Program Files\paint.net\Effects\NoiseChoice.dll, version=1.0.1.0
    Normalizer.dll                                           C:\Program Files\paint.net\Effects\Normalizer.dll, version=1.8.4399.25698
    NormalMapPlus.dll                                        C:\Program Files\paint.net\Effects\NormalMapPlus.dll, version=1.4.6422.43071
    Norm_Render.dll                                          C:\Program Files\paint.net\Effects\Norm_Render.dll, version=7.3.4484.27012
    Object Pruner.dll                                        C:\Program Files\paint.net\Effects\Object Pruner.dll, version=1.0.7020.41772
    Melting.dll                                              C:\Program Files\paint.net\Effects\Melting.dll, version=1.0.0.0
    MemeMaker.dll                                            C:\Program Files\paint.net\Effects\MemeMaker.dll, version=4.5.6828.38061
    Object2Colour.dll                                        C:\Program Files\paint.net\Effects\Object2Colour.dll, version=1.0.1.0
    Metallize.dll                                            C:\Program Files\paint.net\Effects\Metallize.dll, version=1.2.4415.32969
    ObjectBevel.dll                                          C:\Program Files\paint.net\Effects\ObjectBevel.dll, version=1.0.6.0
    Microsoft.ML.OnnxRuntime.dll                             C:\Program Files\paint.net\Effects\Microsoft.ML.OnnxRuntime.dll, version=1.0.0.0
    Objectedge.dll                                           C:\Program Files\paint.net\Effects\Objectedge.dll, version=1.0.1.0
    ObjectShadowPro.dll                                      C:\Program Files\paint.net\Effects\ObjectShadowPro.dll, version=1.0.7421.614
    ObjectTools.dll                                          C:\Program Files\paint.net\Effects\ObjectTools.dll, version=5.0.7502.21624
    MirrorRotate.dll                                         C:\Program Files\paint.net\Effects\MirrorRotate.dll, version=2.0.2
    Oblique.dll                                              C:\Program Files\paint.net\Effects\Oblique.dll, version=1.0.0.0
    MirrorRotateMenu.dll                                     C:\Program Files\paint.net\Effects\MirrorRotateMenu.dll, version=2.0.2
    Mise En Abyme.dll                                        C:\Program Files\paint.net\Effects\Mise En Abyme.dll, version=1.0.0.0
    ModifyChannels.dll                                       C:\Program Files\paint.net\Effects\ModifyChannels.dll, version=1.0.1.0
    MotionSharpen.dll                                        C:\Program Files\paint.net\Effects\MotionSharpen.dll, version=1.2.1.0
    MoveSeams.dll                                            C:\Program Files\paint.net\Effects\MoveSeams.dll, version=1.0.0.0
    MultiColorGradient.dll                                   C:\Program Files\paint.net\Effects\MultiColorGradient.dll, version=1.0.0.0
    Offset Shadow.dll                                        C:\Program Files\paint.net\Effects\Offset Shadow.dll, version=1.0.4247.30184
    Offset.dll                                               C:\Program Files\paint.net\Effects\Offset.dll, version=1.0.4914.19410
    OffsetAlternatingStripes.dll                             C:\Program Files\paint.net\Effects\OffsetAlternatingStripes.dll, version=1.0.6025.41452
    OilPaintingPlus.dll                                      C:\Program Files\paint.net\Effects\OilPaintingPlus.dll, version=4.6.7358.38406
    MultiSpline.dll                                          C:\Program Files\paint.net\Effects\MultiSpline.dll, version=1.0.4.0
    OldFeather.dll                                           C:\Program Files\paint.net\Effects\OldFeather.dll, version=2.3.4315.37038
    MySignature.dll                                          C:\Program Files\paint.net\Effects\MySignature.dll, version=1.5.6617.41275
    OptionBasedLibrary v0.7.8.dll                            C:\Program Files\paint.net\Effects\OptionBasedLibrary v0.7.8.dll, version=0.7.0.1343
    OrderedDither.dll                                        C:\Program Files\paint.net\Effects\OrderedDither.dll, version=1.1.7438.17572
    Organigram.dll                                           C:\Program Files\paint.net\Effects\Organigram.dll, version=1.3.6565.29874
    Outline Object.dll                                       C:\Program Files\paint.net\Effects\Outline Object.dll, version=4.0.4642.26954
    Outline.dll                                              C:\Program Files\paint.net\Effects\Outline.dll, version=1.0.0.0
    OutlineGradientText.dll                                  C:\Program Files\paint.net\Effects\OutlineGradientText.dll, version=1.0.0.0
    Overblur.dll                                             C:\Program Files\paint.net\Effects\Overblur.dll, version=1.0.1.0
    Overliner.dll                                            C:\Program Files\paint.net\Effects\Overliner.dll, version=1.2.3888.29226
    PageCurl.dll                                             C:\Program Files\paint.net\Effects\PageCurl.dll, version=1.4.0.0
    PaletteFromImage.dll                                     C:\Program Files\paint.net\Effects\PaletteFromImage.dll, version=1.0.0.0
    Panelling.dll                                            C:\Program Files\paint.net\Effects\Panelling.dll, version=1.1.0.0
    ParallelLines.Effect.dll                                 C:\Program Files\paint.net\Effects\ParallelLines.Effect.dll, version=1.6.0.575
    Paste Warp Plus.dll                                      C:\Program Files\paint.net\Effects\Paste Warp Plus.dll, version=1.0.6244.33283
    PasteAlpha.dll                                           C:\Program Files\paint.net\Effects\PasteAlpha.dll, version=4.6.7358.38804
    PasteFill.dll                                            C:\Program Files\paint.net\Effects\PasteFill.dll, version=2.0.0.0
    PasteFromClipboard.dll                                   C:\Program Files\paint.net\Effects\PasteFromClipboard.dll, version=2.0.1.0
    Pastel.dll                                               C:\Program Files\paint.net\Effects\Pastel.dll, version=4.6.7358.38877
    PdnColorInpaintingFilter.dll                             C:\Program Files\paint.net\Effects\PdnColorInpaintingFilter.dll, version=1.0.0.0
    PdnManualColorFilter.dll                                 C:\Program Files\paint.net\Effects\PdnManualColorFilter.dll, version=1.0.0.0
    PDNPalette.dll                                           C:\Program Files\paint.net\Effects\PDNPalette.dll, version=1.0.0.0
    PdnPropertiesAndControlTypes.dll                         C:\Program Files\paint.net\Effects\PdnPropertiesAndControlTypes.dll, version=1.0.0.0
    PDNSpriteSheetAnim.dll                                   C:\Program Files\paint.net\Effects\PDNSpriteSheetAnim.dll, version=1.0.0.3
    PerlinTexture.dll                                        C:\Program Files\paint.net\Effects\PerlinTexture.dll, version=2.0.6411.25796
    perlin_noise.dll                                         C:\Program Files\paint.net\Effects\perlin_noise.dll, version=1.1.7172.28890
    Perspective.dll                                          C:\Program Files\paint.net\Effects\Perspective.dll, version=2.1.4415.36116
    PerspectiveLines1_2.dll                                  C:\Program Files\paint.net\Effects\PerspectiveLines1_2.dll, version=1.2.3679.1005
    PerspectiveTransformation.dll                            C:\Program Files\paint.net\Effects\PerspectiveTransformation.dll, version=1.2.5795.41799
    phips_fill_gaps.dll                                      C:\Program Files\paint.net\Effects\phips_fill_gaps.dll, version=1.0.3307.18956
    phips_kill_color.dll                                     C:\Program Files\paint.net\Effects\phips_kill_color.dll, version=1.1.0.0
    phips_selective_enhancer.dll                             C:\Program Files\paint.net\Effects\phips_selective_enhancer.dll, version=1.1.3302.33189
    phips_selective_toning.dll                               C:\Program Files\paint.net\Effects\phips_selective_toning.dll, version=1.0.3304.32827
    PhotoAdjustments.dll                                     C:\Program Files\paint.net\Effects\PhotoAdjustments.dll, version=4.6.7358.38979
    Pixel Art Palette Switcher.dll                           C:\Program Files\paint.net\Effects\Pixel Art Palette Switcher.dll, version=0.1.7583.18176
    Pixelate+.dll                                            C:\Program Files\paint.net\Effects\Pixelate+.dll, version=4.0.4642.26940
    PixSetRepl.dll                                           C:\Program Files\paint.net\Effects\PixSetRepl.dll, version=1.0.0.20200
    Planetoid.dll                                            C:\Program Files\paint.net\Effects\Planetoid.dll, version=1.0.4.0
    PlugInData.dll                                           C:\Program Files\paint.net\Effects\PlugInData.dll, version=1.3.9.2
    System.Resources.Extensions.dll                          C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\5.0.8\System.Resources.Extensions.dll, version=5.0.20.51904
    PointBlur.dll                                            C:\Program Files\paint.net\Effects\PointBlur.dll, version=1.0.0.0
    PointWarpEffect.dll                                      C:\Program Files\paint.net\Effects\PointWarpEffect.dll, version=1.2.5709.42172
    Polar.dll                                                C:\Program Files\paint.net\Effects\Polar.dll, version=1.1.1.0
    PolaroidFrame.dll                                        C:\Program Files\paint.net\Effects\PolaroidFrame.dll, version=1.2.6565.30489
    Polar_Kaleidoscope.dll                                   C:\Program Files\paint.net\Effects\Polar_Kaleidoscope.dll, version=1.0.7188.40229
    Polar_Reflection.dll                                     C:\Program Files\paint.net\Effects\Polar_Reflection.dll, version=1.0.7198.21126
    Polar_Singularity.dll                                    C:\Program Files\paint.net\Effects\Polar_Singularity.dll, version=1.0.7216.34965
    PolyGlitch.Effects.dll                                   C:\Program Files\paint.net\Effects\PolyGlitch.Effects.dll, version=1.4.0.0
    Polygon Tool.dll                                         C:\Program Files\paint.net\Effects\Polygon Tool.dll, version=1.0.0.0
    Polygon.dll                                              C:\Program Files\paint.net\Effects\Polygon.dll, version=4.5.6828.38648
    Polygones.dll                                            C:\Program Files\paint.net\Effects\Polygones.dll, version=1.1.0.0
    Poster.dll                                               C:\Program Files\paint.net\Effects\Poster.dll, version=1.0.2.0
    posterize+.dll                                           C:\Program Files\paint.net\Effects\posterize+.dll, version=1.0.4629.2600
    PowerStretch.dll                                         C:\Program Files\paint.net\Effects\PowerStretch.dll, version=1.9.3045.14671
    PremultiplyAlpha.dll                                     C:\Program Files\paint.net\Effects\PremultiplyAlpha.dll, version=1.0.6868.37601
    PSFilterPdn.dll                                          C:\Program Files\paint.net\Effects\PSFilterPdn.dll, version=1.0.8.2
    Psychocolour.dll                                         C:\Program Files\paint.net\Effects\Psychocolour.dll, version=1.0.1.0
    pxEexpansion.dll                                         C:\Program Files\paint.net\Effects\pxEexpansion.dll, version=1.0.4437.36287
    QuadrilateralCorrection.dll                              C:\Program Files\paint.net\Effects\QuadrilateralCorrection.dll, version=1.3.0.0
    Quick Gravity.dll                                        C:\Program Files\paint.net\Effects\Quick Gravity.dll, version=1.0.4408.25818
    Radialcolors.dll                                         C:\Program Files\paint.net\Effects\Radialcolors.dll, version=1.2.0.0
    RadiusFillCorners.dll                                    C:\Program Files\paint.net\Effects\RadiusFillCorners.dll, version=1.4.0.0
    rainball.dll                                             C:\Program Files\paint.net\Effects\rainball.dll, version=1.0.4907.41850
    Rainbowify.dll                                           C:\Program Files\paint.net\Effects\Rainbowify.dll, version=1.0.7876.29048
    RainbowTwist.dll                                         C:\Program Files\paint.net\Effects\RainbowTwist.dll, version=1.1.6410.28789
    Random Effect.dll                                        C:\Program Files\paint.net\Effects\Random Effect.dll, version=4.0.4642.26928
    Random Gradient Bars.dll                                 C:\Program Files\paint.net\Effects\Random Gradient Bars.dll, version=0.75.7835.24729
    Random lines.dll                                         C:\Program Files\paint.net\Effects\Random lines.dll, version=1.1.0.0
    Random Maze1.dll                                         C:\Program Files\paint.net\Effects\Random Maze1.dll, version=1.1.0.0
    Random Maze2.dll                                         C:\Program Files\paint.net\Effects\Random Maze2.dll, version=1.1.0.0
    Random Shape Fill.dll                                    C:\Program Files\paint.net\Effects\Random Shape Fill.dll, version=4.0.4642.26910
    Recolor Using Palette.dll                                C:\Program Files\paint.net\Effects\Recolor Using Palette.dll, version=1.0.6382.573
    RecolorGray.dll                                          C:\Program Files\paint.net\Effects\RecolorGray.dll, version=1.0.6438.38281
    RecolourChoice.dll                                       C:\Program Files\paint.net\Effects\RecolourChoice.dll, version=1.0.1.0
    RectangleToArchimedeanSpiral.dll                         C:\Program Files\paint.net\Effects\RectangleToArchimedeanSpiral.dll, version=1.0.7623.289
    Rectangular_Inversion.dll                                C:\Program Files\paint.net\Effects\Rectangular_Inversion.dll, version=2.0.7222.27910
    RegularNoise.dll                                         C:\Program Files\paint.net\Effects\RegularNoise.dll, version=1.1.0.0
    RemoveBrightDark.dll                                     C:\Program Files\paint.net\Effects\RemoveBrightDark.dll, version=1.1.3063.36415
    RemoveDust.dll                                           C:\Program Files\paint.net\Effects\RemoveDust.dll, version=4.5.6826.37862
    RemoveTransparency.dll                                   C:\Program Files\paint.net\Effects\RemoveTransparency.dll, version=1.0.0.0
    Remove_Black.dll                                         C:\Program Files\paint.net\Effects\Remove_Black.dll, version=1.0.7212.28737
    RenderSphereHeightMap.dll                                C:\Program Files\paint.net\Effects\RenderSphereHeightMap.dll, version=1.0.6145.37460
    Replace Colors.dll                                       C:\Program Files\paint.net\Effects\Replace Colors.dll, version=1.1.5767.26297
    ReplaceColorsPalette.dll                                 C:\Program Files\paint.net\Effects\ReplaceColorsPalette.dll, version=1.0.7180.10774
    ReverseColors.dll                                        C:\Program Files\paint.net\Effects\ReverseColors.dll, version=1.0.4121.15722
    ReverseFisheye.dll                                       C:\Program Files\paint.net\Effects\ReverseFisheye.dll, version=1.0.5146.26176
    ReversePalette.dll                                       C:\Program Files\paint.net\Effects\ReversePalette.dll, version=0.1.6969.15756
    RGBCompositor.dll                                        C:\Program Files\paint.net\Effects\RGBCompositor.dll, version=1.0.0.0
    RGBtoLinearInterpolation.dll                             C:\Program Files\paint.net\Effects\RGBtoLinearInterpolation.dll, version=1.0.7378.19728
    Rosaces.dll                                              C:\Program Files\paint.net\Effects\Rosaces.dll, version=1.1.0.0
    RotateColor.dll                                          C:\Program Files\paint.net\Effects\RotateColor.dll, version=0.5.0.0
    RotateTextSUI.dll                                        C:\Program Files\paint.net\Effects\RotateTextSUI.dll, version=1.1.4415.32713
    Rotate_Zoom+.dll                                         C:\Program Files\paint.net\Effects\Rotate_Zoom+.dll, version=1.11.5237.17779
    RotationBilinear.dll                                     C:\Program Files\paint.net\Effects\RotationBilinear.dll, version=1.1.3594.29946
    RoundedRectangle.dll                                     C:\Program Files\paint.net\Effects\RoundedRectangle.dll, version=1.1.0.0
    Ruler.dll                                                C:\Program Files\paint.net\Effects\Ruler.dll, version=1.0.6034.31429
    SaturationRGB.dll                                        C:\Program Files\paint.net\Effects\SaturationRGB.dll, version=1.1.0.0
    Scintillate.dll                                          C:\Program Files\paint.net\Effects\Scintillate.dll, version=1.0.1.0
    ScratchArt_en.dll                                        C:\Program Files\paint.net\Effects\ScratchArt_en.dll, version=1.0.0.0
    ScreenPixel.dll                                          C:\Program Files\paint.net\Effects\ScreenPixel.dll, version=1.1.5534.1997
    Scribble.dll                                             C:\Program Files\paint.net\Effects\Scribble.dll, version=1.0.1.0
    ScriptLab.dll                                            C:\Program Files\paint.net\Effects\ScriptLab.dll, version=4.2.7616.26525
    SeamCarving.dll                                          C:\Program Files\paint.net\Effects\SeamCarving.dll, version=4.6.7358.39596
    SeamlessTextureMaker.dll                                 C:\Program Files\paint.net\Effects\SeamlessTextureMaker.dll, version=1.0.0.0
    SegmentImage.dll                                         C:\Program Files\paint.net\Effects\SegmentImage.dll, version=1.1.3674.15788
    Selection2Clear.dll                                      C:\Program Files\paint.net\Effects\Selection2Clear.dll, version=1.0.1.0
    SelectionInnerContour.dll                                C:\Program Files\paint.net\Effects\SelectionInnerContour.dll, version=0.0.0.0
    SelectionObscure.dll                                     C:\Program Files\paint.net\Effects\SelectionObscure.dll, version=1.1.4602.34476
    SelectionTools.dll                                       C:\Program Files\paint.net\Effects\SelectionTools.dll, version=5.0.7502.22140
    Self Spiral.dll                                          C:\Program Files\paint.net\Effects\Self Spiral.dll, version=1.0.7263.1666
    ShadowEffect.dll                                         C:\Program Files\paint.net\Effects\ShadowEffect.dll, version=1.3.0.23429
    ShadowHighlight.dll                                      C:\Program Files\paint.net\Effects\ShadowHighlight.dll, version=3.0.0.0
    Shape3D.dll                                              C:\Program Files\paint.net\Effects\Shape3D.dll, version=1.2.6.2
    shapegradient.dll                                        C:\Program Files\paint.net\Effects\shapegradient.dll, version=1.5.3886.6574
    Shapes.dll                                               C:\Program Files\paint.net\Effects\Shapes.dll, version=1.4.0.0
    Shape_umabob.dll                                         C:\Program Files\paint.net\Effects\Shape_umabob.dll, version=3.4.0.0
    SharpDX.DXGI.dll                                         C:\Program Files\paint.net\Effects\SharpDX.DXGI.dll, version=4.0.1
    Sharpen+.dll                                             C:\Program Files\paint.net\Effects\Sharpen+.dll, version=4.0.0.0
    Shatters_0.55beta.dll                                    C:\Program Files\paint.net\Effects\Shatters_0.55beta.dll, version=1.0.0.0
    Sierpinski.dll                                           C:\Program Files\paint.net\Effects\Sierpinski.dll, version=2.1.6389.29730
    silhouetteplus.dll                                       C:\Program Files\paint.net\Effects\silhouetteplus.dll, version=1.1.3131.17586
    SinWaves.dll                                             C:\Program Files\paint.net\Effects\SinWaves.dll, version=1.1.0.0
    Skew.dll                                                 C:\Program Files\paint.net\Effects\Skew.dll, version=1.0.7638.38725
    SkewedRotatedText.dll                                    C:\Program Files\paint.net\Effects\SkewedRotatedText.dll, version=1.0.0.0
    SlightEdgeBoost.dll                                      C:\Program Files\paint.net\Effects\SlightEdgeBoost.dll, version=1.3.7446.26435
    Slinky.dll                                               C:\Program Files\paint.net\Effects\Slinky.dll, version=1.0.1.0
    SmartSharpen.dll                                         C:\Program Files\paint.net\Effects\SmartSharpen.dll, version=1.5.0.1
    Smooth.dll                                               C:\Program Files\paint.net\Effects\Smooth.dll, version=2.0.2
    SmoothNoise.dll                                          C:\Program Files\paint.net\Effects\SmoothNoise.dll, version=1.0.0.0
    Smudge.dll                                               C:\Program Files\paint.net\Effects\Smudge.dll, version=4.0.5873.25097
    SoundWave.dll                                            C:\Program Files\paint.net\Effects\SoundWave.dll, version=1.0.7433.14854
    SpacedTextPlugin.dll                                     C:\Program Files\paint.net\Effects\SpacedTextPlugin.dll, version=2.0
    Sparkles.dll                                             C:\Program Files\paint.net\Effects\Sparkles.dll, version=1.1.0.0
    Specular.dll                                             C:\Program Files\paint.net\Effects\Specular.dll, version=1.0.3254.27778
    SpeechBubble.dll                                         C:\Program Files\paint.net\Effects\SpeechBubble.dll, version=2.1.4445.42029
    Spherical_Bulge.dll                                      C:\Program Files\paint.net\Effects\Spherical_Bulge.dll, version=1.0.7224.336
    Spiral.dll                                               C:\Program Files\paint.net\Effects\Spiral.dll, version=1.1.0.0
    SpiralText.dll                                           C:\Program Files\paint.net\Effects\SpiralText.dll, version=1.4.4415.32775
    SpiritLevel.Effect.dll                                   C:\Program Files\paint.net\Effects\SpiritLevel.Effect.dll, version=1.0.0.40
    Trace.dll                                                C:\Program Files\paint.net\Effects\Trace.dll, version=1.0.7198.41170
    Trail.dll                                                C:\Program Files\paint.net\Effects\Trail.dll, version=4.0.4642.26791
    trail3d.dll                                              C:\Program Files\paint.net\Effects\trail3d.dll, version=1.0.3902.32071
    TrailBlur.dll                                            C:\Program Files\paint.net\Effects\TrailBlur.dll, version=1.0.0.0
    Transitional Brush.dll                                   C:\Program Files\paint.net\Effects\Transitional Brush.dll, version=1.0.0.0
    Transparency.dll                                         C:\Program Files\paint.net\Effects\Transparency.dll, version=4.6.7358.39871
    TransparencyRGB.dll                                      C:\Program Files\paint.net\Effects\TransparencyRGB.dll, version=1.0.0.0
    TransparentToTransparentBlack.dll                        C:\Program Files\paint.net\Effects\TransparentToTransparentBlack.dll, version=1.0.6479.25661
    SpiroGraph.dll                                           C:\Program Files\paint.net\Effects\SpiroGraph.dll, version=1.1.0.0
    SpiroShapes.dll                                          C:\Program Files\paint.net\Effects\SpiroShapes.dll, version=2.0.0.0
    Splashes.dll                                             C:\Program Files\paint.net\Effects\Splashes.dll, version=1.1.1.0
    Splatter.dll                                             C:\Program Files\paint.net\Effects\Splatter.dll, version=4.0.5873.25083
    SplitColorAndBrightness.dll                              C:\Program Files\paint.net\Effects\SplitColorAndBrightness.dll, version=1.0.7845.681
    SplitHueAndBrightness.dll                                C:\Program Files\paint.net\Effects\SplitHueAndBrightness.dll, version=1.0.5800.37276
    SpokedWheel.dll                                          C:\Program Files\paint.net\Effects\SpokedWheel.dll, version=1.1.5908.19821
    SpotCenter.dll                                           C:\Program Files\paint.net\Effects\SpotCenter.dll, version=1.2.0.0
    SpriteSheetGridModifier.dll                              C:\Program Files\paint.net\Effects\SpriteSheetGridModifier.dll, version=0.1.6968.18281
    Squirkle.dll                                             C:\Program Files\paint.net\Effects\Squirkle.dll, version=1.0.1.0
    SquirkleWarp.dll                                         C:\Program Files\paint.net\Effects\SquirkleWarp.dll, version=1.0.1.0
    StarGlow.dll                                             C:\Program Files\paint.net\Effects\StarGlow.dll, version=1.3.5.0
    Starry.dll                                               C:\Program Files\paint.net\Effects\Starry.dll, version=0.0.0.0
    Stars.dll                                                C:\Program Files\paint.net\Effects\Stars.dll, version=1.3.5.0
    Stickman.dll                                             C:\Program Files\paint.net\Effects\Stickman.dll, version=1.0.0.0
    Stipple.dll                                              C:\Program Files\paint.net\Effects\Stipple.dll, version=1.0.0.0
    Stitch.dll                                               C:\Program Files\paint.net\Effects\Stitch.dll, version=4.0.4642.26808
    StrayPixelRemover.dll                                    C:\Program Files\paint.net\Effects\StrayPixelRemover.dll, version=1.0.0.0
    StringAndPin.dll                                         C:\Program Files\paint.net\Effects\StringAndPin.dll, version=1.0.1.0
    StyleTransferEffect.dll                                  C:\Program Files\paint.net\Effects\StyleTransferEffect.dll, version=1.0.0.0
    TransparentToTransparentWhite.dll                        C:\Program Files\paint.net\Effects\TransparentToTransparentWhite.dll, version=1.0.6963.30396
    TrippyRainbow.dll                                        C:\Program Files\paint.net\Effects\TrippyRainbow.dll, version=1.0.0.0
    TRs Scatter.dll                                          C:\Program Files\paint.net\Effects\TRs Scatter.dll, version=1.3.4949.23250
    TRsAlphaCutter.dll                                       C:\Program Files\paint.net\Effects\TRsAlphaCutter.dll, version=3.0.4.0
    TRsColorReducer.dll                                      C:\Program Files\paint.net\Effects\TRsColorReducer.dll, version=1.0.2.0
    TRsContourFiller.dll                                     C:\Program Files\paint.net\Effects\TRsContourFiller.dll, version=1.5.2.0
    TRsCustomRandomFill.dll                                  C:\Program Files\paint.net\Effects\TRsCustomRandomFill.dll, version=1.5.1.31287
    TRsLineTracer.dll                                        C:\Program Files\paint.net\Effects\TRsLineTracer.dll, version=1.0.4911.29141
    TRsMonolithic.dll                                        C:\Program Files\paint.net\Effects\TRsMonolithic.dll, version=1.0.6.24412
    TRsMorpher.dll                                           C:\Program Files\paint.net\Effects\TRsMorpher.dll, version=1.1.10.8959
    TRsPasteFrame.dll                                        C:\Program Files\paint.net\Effects\TRsPasteFrame.dll, version=1.3.20.9613
    TRsPixelPuller.dll                                       C:\Program Files\paint.net\Effects\TRsPixelPuller.dll, version=1.1.4994.29625
    TRsPSnap.dll                                             C:\Program Files\paint.net\Effects\TRsPSnap.dll, version=1.2.0.0
    TRsSplineMaster.dll                                      C:\Program Files\paint.net\Effects\TRsSplineMaster.dll, version=1.4.2.18310
    TRsStrangeAttractor.dll                                  C:\Program Files\paint.net\Effects\TRsStrangeAttractor.dll, version=1.1.4.0
    TRsThirdDimension.dll                                    C:\Program Files\paint.net\Effects\TRsThirdDimension.dll, version=1.7.13.38717
    onnxruntime.DLL                                          C:\Program Files\paint.net\Effects\onnxruntime.DLL, version=
    SubtractColor.dll                                        C:\Program Files\paint.net\Effects\SubtractColor.dll, version=1.0.4679.26877
    TubeOblique.dll                                          C:\Program Files\paint.net\Effects\TubeOblique.dll, version=1.2.5.0
    TurbulentCircles.dll                                     C:\Program Files\paint.net\Effects\TurbulentCircles.dll, version=1.1.0.0
    TurbulentLines.dll                                       C:\Program Files\paint.net\Effects\TurbulentLines.dll, version=1.1.0.0
    Tweaktrans2.dll                                          C:\Program Files\paint.net\Effects\Tweaktrans2.dll, version=2.0.4252.27152
    Twist.dll                                                C:\Program Files\paint.net\Effects\Twist.dll, version=4.0.5873.25056
    Table.dll                                                C:\Program Files\paint.net\Effects\Table.dll, version=1.1.5847.38905
    Tartan.dll                                               C:\Program Files\paint.net\Effects\Tartan.dll, version=1.5.2.0
    TwistZ.dll                                               C:\Program Files\paint.net\Effects\TwistZ.dll, version=1.1.2.0
    Tattersall.dll                                           C:\Program Files\paint.net\Effects\Tattersall.dll, version=1.1.0.0
    Temperature.dll                                          C:\Program Files\paint.net\Effects\Temperature.dll, version=4.6.7358.39746
    TwoPointPerspective.dll                                  C:\Program Files\paint.net\Effects\TwoPointPerspective.dll, version=1.6.0.0
    Tesserae.dll                                             C:\Program Files\paint.net\Effects\Tesserae.dll, version=1.0.6200.27517
    TwoToneThreshold.dll                                     C:\Program Files\paint.net\Effects\TwoToneThreshold.dll, version=1.0.0.0
    TextDistorsion.dll                                       C:\Program Files\paint.net\Effects\TextDistorsion.dll, version=1.0.0.0
    Vandermotten.PaintDotNetEffects.Blurs.dll                C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.dll                      C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.ColorAccent.dll          C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.DropShadow.dll           C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.Duotones.dll             C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.FadeEdge.dll             C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.Gradient.dll             C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.Grid.dll                 C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.Monochromes.dll          C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version=3.8.0.0
    Vandermotten.PaintDotNetEffects.ObjectAlign.dll          C:\Program Files\paint.net\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=3.8.0.0
    Vanishing Trails.dll                                     C:\Program Files\paint.net\Effects\Vanishing Trails.dll, version=2.0.0.0
    VanishPoint.dll                                          C:\Program Files\paint.net\Effects\VanishPoint.dll, version=1.0.3.0
    Varicose2.dll                                            C:\Program Files\paint.net\Effects\Varicose2.dll, version=2.1.1.0
    Vibration.dll                                            C:\Program Files\paint.net\Effects\Vibration.dll, version=1.0.4407.34043
    Vibrato.dll                                              C:\Program Files\paint.net\Effects\Vibrato.dll, version=2.0.0.0
    ViewFramer.dll                                           C:\Program Files\paint.net\Effects\ViewFramer.dll, version=1.0.6074.42436
    Vignette1.dll                                            C:\Program Files\paint.net\Effects\Vignette1.dll, version=1.0.3538.14367
    VignettePlus.dll                                         C:\Program Files\paint.net\Effects\VignettePlus.dll, version=4.6.7358.40027
    Volutes.dll                                              C:\Program Files\paint.net\Effects\Volutes.dll, version=1.1.0.0
    WarpTextOnPath.dll                                       C:\Program Files\paint.net\Effects\WarpTextOnPath.dll, version=1.0.0.0
    TextDistortion.dll                                       C:\Program Files\paint.net\Effects\TextDistortion.dll, version=1.3.0.0
    TextMask.dll                                             C:\Program Files\paint.net\Effects\TextMask.dll, version=1.0.0.0
    WaterReflection.dll                                      C:\Program Files\paint.net\Effects\WaterReflection.dll, version=1.1.0.0
    Waves.dll                                                C:\Program Files\paint.net\Effects\Waves.dll, version=1.1.0.0
    WaveTextSUI.dll                                          C:\Program Files\paint.net\Effects\WaveTextSUI.dll, version=1.2.4415.33440
    WaveToolBox.dll                                          C:\Program Files\paint.net\Effects\WaveToolBox.dll, version=1.3.7456.16099
    Textplus.dll                                             C:\Program Files\paint.net\Effects\Textplus.dll, version=1.0.0.0
    Texture Object Rounder.dll                               C:\Program Files\paint.net\Effects\Texture Object Rounder.dll, version=1.0.6464.41586
    Texture Scaler.dll                                       C:\Program Files\paint.net\Effects\Texture Scaler.dll, version=1.2.6430.41316
    TextureMerger.dll                                        C:\Program Files\paint.net\Effects\TextureMerger.dll, version=1.1.6159.40169
    TextureShader.dll                                        C:\Program Files\paint.net\Effects\TextureShader.dll, version=2.3.0.0
    TextureSmoother.dll                                      C:\Program Files\paint.net\Effects\TextureSmoother.dll, version=1.0.6096.31689
    TextureViewSkewer.dll                                    C:\Program Files\paint.net\Effects\TextureViewSkewer.dll, version=1.0.5713.42082
    Texturize.dll                                            C:\Program Files\paint.net\Effects\Texturize.dll, version=1.1.0.1
    TextWindow.dll                                           C:\Program Files\paint.net\Effects\TextWindow.dll, version=1.3.0.0
    Text_on_Path.dll                                         C:\Program Files\paint.net\Effects\Text_on_Path.dll, version=1.0.0.0
    TGAngle.dll                                              C:\Program Files\paint.net\Effects\TGAngle.dll, version=1.0.1.0
    TGMagnitude.dll                                          C:\Program Files\paint.net\Effects\TGMagnitude.dll, version=1.0.1.0
    ThermalHeatMapEffect.dll                                 C:\Program Files\paint.net\Effects\ThermalHeatMapEffect.dll, version=1.0.0.0
    Thorn Fractal.dll                                        C:\Program Files\paint.net\Effects\Thorn Fractal.dll, version=1.0.7611.40689
    ThreeColorDithering.dll                                  C:\Program Files\paint.net\Effects\ThreeColorDithering.dll, version=1.0.7652.19490
    TileCount.dll                                            C:\Program Files\paint.net\Effects\TileCount.dll, version=1.0.7676.6172
    Tiles.dll                                                C:\Program Files\paint.net\Effects\Tiles.dll, version=1.1.1.0
    TileWorld.dll                                            C:\Program Files\paint.net\Effects\TileWorld.dll, version=1.0.2.0
    Tint-Splitter.dll                                        C:\Program Files\paint.net\Effects\Tint-Splitter.dll, version=1.0.4636.5475
    TJacksonEffects.dll                                      C:\Program Files\paint.net\Effects\TJacksonEffects.dll, version=1.0.0.0
    Toon Shader.dll                                          C:\Program Files\paint.net\Effects\Toon Shader.dll, version=1.0.3470.28696
    TOON.dll                                                 C:\Program Files\paint.net\Effects\TOON.dll, version=1.0.7446.7819
    Tournesol.dll                                            C:\Program Files\paint.net\Effects\Tournesol.dll, version=1.0.0.0
    TR's Pixel Push.dll                                      C:\Program Files\paint.net\Effects\TR's Pixel Push.dll, version=1.0.4954.37564
    WetFloor.dll                                             C:\Program Files\paint.net\Effects\WetFloor.dll, version=1.1.0.0
    WhichSymbolRedux.dll                                     C:\Program Files\paint.net\Effects\WhichSymbolRedux.dll, version=1.0.0.0
    WoodsyVP1.dll                                            C:\Program Files\paint.net\Effects\WoodsyVP1.dll, version=1.0.6.0
    WoodsyVP2.dll                                            C:\Program Files\paint.net\Effects\WoodsyVP2.dll, version=1.0.6.0
    WoodsyVP3.dll                                            C:\Program Files\paint.net\Effects\WoodsyVP3.dll, version=1.0.6.0
    WovenPhoto94.dll                                         C:\Program Files\paint.net\Effects\WovenPhoto94.dll, version=1.94.6505.33087
    WovenPhoto95.dll                                         C:\Program Files\paint.net\Effects\WovenPhoto95.dll, version=1.94.6529.30892
    XYCoords.dll                                             C:\Program Files\paint.net\Effects\XYCoords.dll, version=1.2.1.0
    zkaleidoscope.dll                                        C:\Program Files\paint.net\Effects\zkaleidoscope.dll, version=1.3.7168.35177
    Zoom Selection.dll                                       C:\Program Files\paint.net\Effects\Zoom Selection.dll, version=1.0.7734.39804
    ZoomBlurDeluxe.dll                                       C:\Program Files\paint.net\Effects\ZoomBlurDeluxe.dll, version=1.0.0.0
    K4os.Compression.LZ4.dll                                 C:\Program Files\paint.net\K4os.Compression.LZ4.dll, version=1.2.6
    comdlg32.dll                                             C:\WINDOWS\System32\comdlg32.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    DUI70.dll                                                C:\WINDOWS\System32\DUI70.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    DUser.dll                                                C:\WINDOWS\System32\DUser.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    thumbcache.dll                                           C:\Windows\System32\thumbcache.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    Windows.UI.FileExplorer.dll                              C:\Windows\System32\Windows.UI.FileExplorer.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    edputil.dll                                              C:\WINDOWS\SYSTEM32\edputil.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    atlthunk.dll                                             C:\WINDOWS\SYSTEM32\atlthunk.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    StructuredQuery.dll                                      C:\WINDOWS\System32\StructuredQuery.dll, version=7.0.19041.867 (WinBuild.160101.0800)
    Windows.FileExplorer.Common.dll                          C:\Windows\System32\Windows.FileExplorer.Common.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    iertutil.dll                                             C:\Windows\System32\iertutil.dll, version=11.00.19041.1100 (WinBuild.160101.0800)
    SspiCli.dll                                              C:\WINDOWS\SYSTEM32\SspiCli.dll, version=10.0.19041.906 (WinBuild.160101.0800)
    tiptsf.dll                                               C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    MPR.dll                                                  C:\WINDOWS\SYSTEM32\MPR.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    drprov.dll                                               C:\WINDOWS\System32\drprov.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    ntlanman.dll                                             C:\WINDOWS\System32\ntlanman.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    davclnt.dll                                              C:\WINDOWS\System32\davclnt.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    DAVHLPR.dll                                              C:\WINDOWS\System32\DAVHLPR.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    wkscli.dll                                               C:\WINDOWS\System32\wkscli.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    cscapi.dll                                               C:\WINDOWS\SYSTEM32\cscapi.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    netutils.dll                                             C:\WINDOWS\System32\netutils.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    twinapi.dll                                              C:\Windows\System32\twinapi.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    apphelp.dll                                              C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    dlnashext.dll                                            C:\Windows\System32\dlnashext.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    DevDispItemProvider.dll                                  C:\Windows\System32\DevDispItemProvider.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    ntshrui.dll                                              C:\WINDOWS\SYSTEM32\ntshrui.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    srvcli.dll                                               C:\WINDOWS\SYSTEM32\srvcli.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    wpdshext.dll                                             C:\WINDOWS\system32\wpdshext.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    SETUPAPI.dll                                             C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    PortableDeviceTypes.dll                                  C:\Windows\System32\PortableDeviceTypes.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    MrmCoreR.dll                                             C:\Windows\System32\MrmCoreR.dll, version=10.0.19041.1023 (WinBuild.160101.0800)
    windows.staterepositorycore.dll                          C:\WINDOWS\SYSTEM32\windows.staterepositorycore.dll, version=10.0.19041.844 (WinBuild.160101.0800)
    EhStorShell.dll                                          C:\Windows\System32\EhStorShell.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    policymanager.dll                                        C:\WINDOWS\SYSTEM32\policymanager.dll, version=10.0.19041.1151 (WinBuild.160101.0800)
    msvcp110_win.dll                                         C:\WINDOWS\SYSTEM32\msvcp110_win.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    urlmon.dll                                               C:\WINDOWS\System32\urlmon.dll, version=11.00.19041.1100 (WinBuild.160101.0800)
    FileSyncShell64.dll                                      C:\Users\Andrew\AppData\Local\Microsoft\OneDrive\21.145.0718.0001\FileSyncShell64.dll, version=21.145.0718.0001
    Secur32.dll                                              C:\WINDOWS\SYSTEM32\Secur32.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    WININET.dll                                              C:\WINDOWS\SYSTEM32\WININET.dll, version=11.00.19041.1100 (WinBuild.160101.0800)
    NetworkExplorer.dll                                      C:\WINDOWS\system32\NetworkExplorer.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    DdsFileTypePlusIO_x64.dll                                C:\Program Files\paint.net\Bundled\DDSFileTypePlus\DdsFileTypePlusIO_x64.dll, version=1.10.10.0
    ActXPrxy.dll                                             C:\Windows\System32\ActXPrxy.dll, version=10.0.19041.844 (WinBuild.160101.0800)
    Windows.Storage.Search.dll                               C:\WINDOWS\system32\Windows.Storage.Search.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    PlayToDevice.dll                                         C:\Windows\System32\PlayToDevice.dll, version=10.0.19041.1100 (WinBuild.160101.0800)
    MMDevApi.dll                                             C:\WINDOWS\System32\MMDevApi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    PortableDeviceApi.dll                                    C:\Windows\System32\PortableDeviceApi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    EhStorAPI.dll                                            C:\Windows\System32\EhStorAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    Windows.StateRepositoryPS.dll                            C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.844 (WinBuild.160101.0800)
    provsvc.dll                                              C:\WINDOWS\System32\provsvc.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    Windows.Devices.Enumeration.dll                          C:\Windows\System32\Windows.Devices.Enumeration.dll, version=10.0.19041.867 (WinBuild.160101.0800)
    MsftEdit.DLL                                             C:\WINDOWS\SYSTEM32\MsftEdit.DLL, version=10.0.19041.1100 (WinBuild.160101.0800)
15 hours ago, AndrewDavid said:
Another plugin that should go on the list.
I just ran Genesis and it is working fine with the Beta of PDN.
I know I had trouble with it a few months ago, and @lynxster4 helped me to get it working again.  It is a bit finicky.
9 hours ago, ReMake said:
A strange list. In my case, none of my effects are displayed in Plugin Errors.
@Panchdara, update the effects from my Plugin Pack.
About PSFilterPdn, see here.
Many thanks RM... sad to say.... I'll revert to 4.2.16 and let ya know.
Best
Edit: revert cleared all messages. I was just notifying the v4.3 alpha has some effects messages. Thanks guys. Best regards
Edited by Panchdara
5 minutes ago, fixator10 said:
AMD Phenom(tm) II X4 B40 Processor
Oh, it's because SSSE3 (yes, 3 S's) is actually required. The translation was not yet updated.
I've actually removed the SSSE3 requirement for the next update. Just regular SSE2 is needed. Performance will be lower on systems without SSSE3, however. For code paths that benefit from SSSE3, but which also had an SSE2 path, the SSE2 path has been removed. This reduces the time/resources I need to implement and validate new optimizations, and CPUs without SSSE3 are quite rare now.
