n SSIW I Posted June 6, 2006 Share Posted June 6, 2006 I'm pretty new at this. I just created a custom glassy orb and would like to upload it to my myspace. I've saved it as all file types that myspace allows, but when the image uploads nothing is there. Its a blank picture. :? any help would be greatly appreciated! thx Quote Link to comment Share on other sites More sharing options...
Crazy Man Dan Posted June 6, 2006 Share Posted June 6, 2006 How do the images appear on your home computer? (Like if you open the image in Windows Picture and Fax Viewer.) I've not had any problem uploading images (I use PhotoBucket for hosting), I just sometimes accidentally try uploading the .pdn from time to time... (That's the problem with giving the .pdn and the final image the same name.) Just make sure you're saving the image in a web-compatible format, such as .jpg, .png, or .gif. It sounds like you've tried a bunch of formats, so also check and make sure you're giving myspace the correct URL to your image. What hosting site are you using? Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to comment Share on other sites More sharing options...
n SSIW I Posted June 6, 2006 Author Share Posted June 6, 2006 I was using filelodge.bolt.com but i successfully uploaded them to photobucket. thanks. by the way your tutorial is very helpful. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 6, 2006 Share Posted June 6, 2006 Moved to General Discussion Please keep posts in the right area of the forum. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
