MechaMaria Posted May 28, 2021 Share Posted May 28, 2021 (edited) Hi there So I recently finally figured out the woe to one of my most plaguing issues when I do video editing on my computer. Adobe premiere has an incredibly nasty habit of just deleting the transparency of images it handles as if they never had it to begin with. I've searched for the solution for months and finally found the culprit tonight. As it turns out, premiere eats the transparency of any images saved in index color modes, and as it happens almost everything paint.net touches ends up becoming an indexed png! The catch is too, not all of it gets saved as indexed! Some escape the wrath of the indexed png and I have absolutely zero idea why! So clearly paint.net can save both kinds. Is there any way, any setting any plugin I can get that will allow me to export ONLY in RGB colormodes and not indexed, as now I have to spend the next hour or two mass converting all of my files by hand in photoshop (which yes, I prefer paint.net tools to photoshop, fight me) which is a slow and painful process. Cheers Edited May 28, 2021 by MechaMaria fixed a word Quote Link to comment Share on other sites More sharing options...
MechaMaria Posted May 28, 2021 Author Share Posted May 28, 2021 (edited) If it helps AT ALL The images I am working with are pixel-art sprites that have been sized up 1000x, but all of the edges to the sprites are still crisp and theres no semi-transparent colors on the image. Is that what is causing it maybe? Thinking about it the only images that get index'd are like this, crisp edged without any translucent colors Edited May 28, 2021 by MechaMaria Quote Link to comment Share on other sites More sharing options...
IHaveNoName Posted May 28, 2021 Share Posted May 28, 2021 This is above my knowledge base on saving formats; I had to look up what an indexed PNG was and I'm still not clear. However what I do know about PDN is that whilst the standard Save As: PNG gives you only colour bit options the Save As: Optimised PNG gives you RGB, Palette and other save type options. Is Palette the same as 'Indexed'? I just don't know but in the absence of more knowledgeable advice you might like to try the Optimized PNG plugin: OptiPNG. https://forums.getpaint.net/topic/114190-optipng-filetype-2019-05-07/ Quote Link to comment Share on other sites More sharing options...
null54 Posted May 28, 2021 Share Posted May 28, 2021 3 hours ago, MechaMaria said: Is there any way, any setting any plugin I can get that will allow me to export ONLY in RGB colormodes and not indexed, as now I have to spend the next hour or two mass converting all of my files by hand in photoshop (which yes, I prefer paint.net tools to photoshop, fight me) which is a slow and painful process. In the PNG save configuration dialog change the Bit Depth option from Auto-detect to 32-bit (or 24-bit). The Auto-detect option picks the PNG format that produces the smallest file size, which in your case is one of the indexed formats. 3 hours ago, MechaMaria said: Thinking about it the only images that get index'd are like this, crisp edged without any translucent colors The Indexed PNG formats do not support semi-transparent colors, so any images that have them will be saved as 32-bit RGBA. 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
MechaMaria Posted May 28, 2021 Author Share Posted May 28, 2021 (edited) 7 hours ago, null54 said: In the PNG save configuration dialog change the Bit Depth option from Auto-detect to 32-bit (or 24-bit). The Auto-detect option picks the PNG format that produces the smallest file size, which in your case is one of the indexed formats. Thank you Edited May 28, 2021 by MechaMaria Quote Link to comment Share on other sites More sharing options...
