DryToad Posted May 26, 2021 Share Posted May 26, 2021 Let's say I have an image made with white (0), gray-ish white (64) and gray (128). What inbuilt tools / plug-ins could I use to "rescale" (I have no idea what's the word for this) these values so that I use the full range, ending up with something like 0, 128 and 255? (I suppose levels does that but I have no idea how to use it, and if there is a plugin that does something like that I would like to know) Many thanks! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 26, 2021 Share Posted May 26, 2021 I think what you're looking for is: Adjustments > Brightness / Contrast 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
ardneh Posted May 26, 2021 Share Posted May 26, 2021 (edited) Move the Input bottom slider up to 64. Edited May 26, 2021 by ardneh 1 Quote Link to comment Share on other sites More sharing options...
MJW Posted May 26, 2021 Share Posted May 26, 2021 Though it wasn't designed specifically to do this, the Texture Scaler plugin will stretch a grayscale image to span the entire range. Just uncheck Produce 24-Bit Height Map and leave the other controls at their defaults. EDIT: If the image contains transparent pixels, you should check Don't Scale Transparent Pixels. 1 Quote Link to comment Share on other sites More sharing options...
DryToad Posted June 8, 2021 Author Share Posted June 8, 2021 Thanks for the replies, everyone! @BoltBait thanks for reminding me that tool existed, I guess I was thinking so much about curves and levels that I forgot about the basics. @MJW, do you have a magical box from where you take out a plugin for every need I have? Sadly, the scanned documents I wanted to enhance seemed to have some very dark pixels scattered around, so the changes it made were near to none. I ended up going with @ardneh's tip. Using the levels tool wasn't so difficult after someone told me what slider to use (thanks dude), and once I realized I could use the histogram to figure out where to stop. Definetively using your plugin for other projects tought, having a task automated is always great! Quote Link to comment Share on other sites More sharing options...
