Andy123 Posted May 17, 2021 Share Posted May 17, 2021 Here's my situation: I'd like to run Paint.NET on a Windows computer where I don't have admin privileges (e.g. college computer). I've tried following the instructions [ https://forums.getpaint.net/topic/113484-paintdotnet-in-a-zip-file-no-installation/ ] to install on another computer and copy across, but I can't do that with my Mac :) There is a solution! (You won't get file associations or a Start Menu icon, but at least you can run it.) First, open cmd (Command Prompt) and run the following: cd %USERPROFILE%\Downloads tar -xf paint.net.4.2.16.install.zip SET __COMPAT_LAYER=RunAsInvoker paint.net.4.2.16.install.exe (Note that "tar" is only available from Windows 10 April 2018 Update onwards; if you don't have it, just unzip the file manually.) When you enter the last command, the installer starts running; and if you click "Show Details", you can see it extracting extracting its files to a temp folder. After all the files are extracted, the installer comes up with a warning: Administrator privilege is required to install paint.net [OK] Don't click OK on that popup just yet! Open up a Windows Explorer window, and browse to %TEMP% (usually C:\Users\<your_name>\AppData\Local\Temp) Find the folder called PdnSetup and copy it to C:\Users\<your_name>\Downloads\PdnSetup Now go back to the warning popup and click OK. The installer will now delete %TEMP%\PdnSetup. Open a new command window, and type in: cd C:\Users\<your_name>\Downloads\PdnSetup msiexec /qb /a PaintDotNet_x64.msi TARGETDIR=C:\Users\<your_name>\Downloads\PaintDotNet The installer will now create a portable version of Paint.NET in the target directory specified. You can now run PaintDotNet.exe in C:\Users\<your_name>\Downloads\PaintDotNet If you plan to use it often, I recommend using "Pin to taskbar" to get quick access. Don't forget to delete the temporary folder PdnSetup, as well as the original paint.net.nnnn.install.zip and paint.net.nnnn.install.exe files. Enjoy! 2 Link to comment Share on other sites More sharing options...
Blurro Posted September 26, 2021 Share Posted September 26, 2021 just here to say thanks a ton, needed this 1 Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 27, 2021 Share Posted September 27, 2021 You can just use the portable version of the app now, since v4.3. It's part of the official release packages. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
