Bevel Selection won't work on a blank layer
1 hour ago, barbieq25 said:
Any ideas why this is so?
Are you referring to the Bevel Selection plugin in BoltBait's pack?
If so, you should ask that question in the plugin thread:
@barbieq25  It is working for me if you are referring to BoltBait's plugin.
Try this:  Instead of using it on blank layer, duplicate your original layer and un-tick 'Keep original image' box.  Hope this helps.  🙂
You need to use Selection and not Object.
1.  Have object on a layer.
2. Select object.
3.  Invert selection.
4. Make a new layer
5. Selection and then Bevel.
