McCreery's Plugins: Texture Tools, Color Ramp, Outline and Erode (April 23, 2021)
mccreery
Download DLLs and Installer
Install: Run install.bat as administrator, or copy the DLLs directly to
  • C:\Program Files\paint.net\Effects (for the regular version) or
  • Documents\paint.net App Files\Effects (for the Windows store version).
View source code on GitHub
Effects > Texture > Clean Transparent...
Removes color variation in fully transparent pixels.
CleanTransparent.dll
Adjustments > Color Ramp...
Maps brightness to a color gradient with up to three stops.
ColorRamp.dll
Effects > Object > Erode...
Removes edges from objects using an erosion technique.
Erode.dll
Effects > Texture > Isolate Channel...
Extracts a single color channel from a texture to grayscale or another channel.
IsolateChannel.dll
Effects > Texture > Move Seams...
Draws a tiled version of the canvas at an offset, allowing seamless texture creation and positioning.
MoveSeams.dll
Effects > Object > Outline...
Adds precise outlines to objects using a dilation technique.
Outline.dll
Effects > Texture > Remove Transparency
Makes the canvas opaque by setting alpha to 255 for all pixels.
RemoveTransparency.dll
Edited by mccreery
Add install info
  • Upvote 2
