Clean Transparent 1.0: Removes color variation in transparent pixels (April 22, 2021)
Removes color variation in fully transparent pixels.
Effects > Texture > Clean Transparent...
CleanTransparent.dll
This plugin helps clean up transparent images by removing transparent artifacts often generated by image editors. For example, some image editors don't remove color information when the eraser tool is used to clean up the edges of a shape. The plugin replaces all pixels with an alpha of zero with a user-specified background color. This not only fixes the image in situations where transparency has to be removed but also improves the compression of saved images.
Download the complete plugin pack
Or:
Download 1.0 DLL Download 1.0 Installer
View source code on GitHub
In this example image, transparency has been removed to show the effect (which is usually invisible in the editor).
Edited by mccreery
Add link to pack
  • Thanks 1
  • Upvote 2
  • mccreery changed the title to Clean Transparent 1.0: Removes color variation in transparent pixels (April 22, 2021)
  • Ego Eram Reputo changed the title to Clean Transparent 1.0: Removes color variation in transparent pixels (April 22, 2021)
