Hatori360 Posted January 21, 2021 Share Posted January 21, 2021 I have been experiencing intermittent bugs in two areas of the user interface in the main window. Specifically, the tabbed list of thumbnail images and the layers window. There are no crash logs when I check for issues. I copied the diagnostic log. There are no error messages. The issues do not occur every time. It does not matter how many images I am working with or how many other MS Windows apps or browsers are open, the problem is unpredictable. I cannot purposely replicate the problem. There are two specific problems, and they both occur at the same time - if one problem occurs, the other problem occurs. They do not occur independently. Image List (Tabs): If I have more than one thumbnail image in the tabs row of the image list, only one of those images is visibly displayed. It may be the fifth image tab, the first one, or the twentieth image in the row. The areas where the tabs exist are blank, but I can click on a blank area where the tabs are usually visible, and an image I created will appear on the canvas. But, the order of images is not accurate. If I click on the active tab (blue highlighted tab) with an image, it will not be the correct image that displays on the canvas - it will be the one next to it on the tab list. The drop down list of tabbed images are visible and can be accurately used to load the images on the canvas. Layers Window: If an image has layers, only one of the images in the layer list appears and the checkbox is not checked. If I click in the checkbox, the red check mark appears, but the image on the canvas is toggled off. I can click in the blank areas of the layer list, and the image in that area displays (if it is the top image in the layer list, of course.) I can copy and paste it on a new canvas. If more than one image on the tab list has layers and I switch to a different tabbed image, the Layers Window gets stuck displaying the previous list. If I toggle it on and off, it doesn't switch to the active image. Today, I was able to close the problematic tab by guessing, and I was able to use the interface without problems. I have been using Paint.net for several years now on different Windows computers starting with Windows 7. I have been using it without too much trouble until this past year. I installed a Beta version a year or two ago, and started having problems with the app freezing and then shutting down. That problem still occurs, but not as often, and there is no error message. About a year ago, I uninstalled the Beta build and then reinstalled the regular build from the Microsoft Store. Quote Link to comment Share on other sites More sharing options...
Hatori360 Posted January 22, 2021 Author Share Posted January 22, 2021 I uninstalled/reinstalled Paint.net tonight. After reading several posts about various troubleshooting topics, I navigated to the Program Files and opened the paint.net folder. There are no files there and my Explorer view settings allow me to see hidden files. Is a previous installation with my current installation of paint.net? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 22, 2021 Share Posted January 22, 2021 To me this sounds like a problem of bad graphics card drivers. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Hatori360 Posted January 22, 2021 Author Share Posted January 22, 2021 42 minutes ago, BoltBait said: To me this sounds like a problem of bad graphics card drivers. Or the settings? Quote Link to comment Share on other sites More sharing options...
Djisves Posted January 22, 2021 Share Posted January 22, 2021 7 hours ago, Hatori360 said: Image List (Tabs): If I have more than one thumbnail image in the tabs row of the image list, only one of those images is visibly displayed. It may be the fifth image tab, the first one, or the twentieth image in the row. The areas where the tabs exist are blank, but I can click on a blank area where the tabs are usually visible, and an image I created will appear on the canvas. I have had exactly this happen to me too, perhaps three or four times over the last few months. Unlike @Hatori360, I did not check further to see how the tabs behave, nor did I check to see if there were any problems with the Layers window. Every time, I just restarted PDN and the problem disappeared. I just assumed that it's a memory problem or my ageing computer telling me it's time to retire it and let it rest. Quote Link to comment Share on other sites More sharing options...
Hatori360 Posted February 1, 2021 Author Share Posted February 1, 2021 On 1/22/2021 at 2:17 AM, Djisves said: I have had exactly this happen to me too, perhaps three or four times over the last few months. Unlike @Hatori360, I did not check further to see how the tabs behave, nor did I check to see if there were any problems with the Layers window. Every time, I just restarted PDN and the problem disappeared. I just assumed that it's a memory problem or my ageing computer telling me it's time to retire it and let it rest. Really strange behavior. My laptop is a supposedly high quality computer with good graphics, but only 16gb of memory. Technicians at Microcenter say it's plenty. Quote Link to comment Share on other sites More sharing options...
Djisves Posted February 8, 2021 Share Posted February 8, 2021 Just now it happened again. For what it may be worth: - I had two images open that I was working on. I copied a third image from this forum and pasted it as new (Ctrl+Alt+V). - The image list / tabs thumbnail for the third image did not appear. - The Layers Window displayed the layers of the image I was working on before I pasted in the new image. Clicking on anything in the Layers Window did not work. - I checked to see if I was able to work on the new image. I used the Magic Wand to create a selection, inverted the selection (Ctrl+I), added a layer (Ctrl+Shift+N), used the Outline Selection plugin. The editing worked as intended. - I hit the top-right red X to close PDN. The "Unsaved Changes" dialogue box appeared, displaying thumbnails for all three open images correctly. I clicked "Cancel" and the PDN returned to good working order, image thumbnails and Layers Window included. I now regret I did not check to see of the thumbnails and Layers Window displayed correctly before I clicked Cancel on the Unsaved Changes dialogue box. I hope I don't have the chance to but, if I do, I'll have to remember next time. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 8, 2021 Share Posted February 8, 2021 This is often caused by 3rd-party theming software (WindowBlinds), multi-monitor management software (ATI HydraVision), or sometimes GPU monitoring/overclocking software (especially EVGA Precision). You can try disabling those, or they might have a way to exclude apps from being hooked. You can also get PDN's diagnostics info, via Settings (gear icon at top right of main window) -> Diagnostics -> Copy to Clipboard. Then paste that here. There might be something it will illuminate. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Djisves Posted February 9, 2021 Share Posted February 9, 2021 I do have two monitors but not of the software mentioned. Like I said, it's not a big deal for me because I know my PC is getting old (plus I have many plugins installed) and I can work around the problem. I would not have mentioned anything if it wasn't for the the report by the OP. In any case, here is my diagnostics report. I hope it helps. Spoiler Application paint.net 4.2.15 (Final 4.215.7694.37221) Build Date 24 January 2021 Install type Classic Hardware accelerated rendering (GPU) True Animations True DPI 96 (1.00x scale) Language en-US OS Windows 10 Home x64 (10.0.19042.0) (0x65) .NET Runtime 4.0.30319.42000 Physical Memory 8,140 MB CPU Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz Speed ~2993 MHz Cores / Threads 4 / 4 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2 Video Card AMD Radeon R7 240 Dedicated Video RAM 2,029 MB Dedicated System RAM 0 MB Shared System RAM 4,070 MB Vendor ID 0x1002 Device ID 0x6611 Subsystem ID 0x3D791642 Revision 0 LUID 0x0000C061 Flags SupportMonitoredFences, KeyedMutexConformance Graphics Preemption DmaBufferBoundary Compute Preemption DmaBufferBoundary Outputs 2 Feature Level Direct3D_11_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 4,070 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000C7A1 Flags Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Managed assemblies 281 mscorlib mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PaintDotNet PaintDotNet, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Core PaintDotNet.Core, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Base PaintDotNet.Base, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null WindowsBase WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Core System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Drawing System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 PresentationCore PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Windows.Forms System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PaintDotNet.SystemLayer PaintDotNet.SystemLayer, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Framework PaintDotNet.Framework, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Resources PaintDotNet.Resources, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Effects PaintDotNet.Effects, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Data PaintDotNet.Data, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.SystemLayer.Native.x64 PaintDotNet.SystemLayer.Native.x64, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null System.Configuration System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Xml System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Xaml System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Runtime.CompilerServices.Unsafe System.Runtime.CompilerServices.Unsafe, Version=4.0.6.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a ImAGIF.FileType ImAGIF.FileType, Version=0.13.0.21358, Culture=neutral, PublicKeyToken=null ImPDF.Open.FileType ImPDF.Open.FileType, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null ImPDF.Save.FileType ImPDF.Save.FileType, Version=1.4.5187.23557, Culture=neutral, PublicKeyToken=null ImPS,EPS,AI.Open.FileType ImPS\,EPS\,AI.Open.FileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null OptiPngFileType OptiPngFileType, Version=11.1.0.0, Culture=neutral, PublicKeyToken=null PhotoShop PhotoShop, Version=2.5.0.40665, Culture=neutral, PublicKeyToken=null SvgFileType SvgFileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null OptionBasedLibrary v0.6 OptionBasedLibrary v0.6, Version=0.5.0.0, Culture=neutral, PublicKeyToken=null DdsFileTypePlus DdsFileTypePlus, Version=1.10.7.0, Culture=neutral, PublicKeyToken=null AvifFileType AvifFileType, Version=1.1.6.0, Culture=neutral, PublicKeyToken=null WebPFileType WebPFileType, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null System.Web System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Immutable System.Collections.Immutable, Version=1.2.5.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Buffers System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Memory System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 2dImageFilter 2dImageFilter, Version=1.1.3.3, Culture=neutral, PublicKeyToken=null AA's_Assistant "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null Aardvark Aardvark, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null advcolorrep advcolorrep, Version=1.3.3303.27314, Culture=neutral, PublicKeyToken=null AdvGrey AdvGrey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null AForge AForge, Version=2.2.5.0, Culture=neutral, PublicKeyToken=c1db6ff4eaa06aeb AForge.Imaging AForge.Imaging, Version=2.2.5.0, Culture=neutral, PublicKeyToken=ba8ddea9676ca48b Align Object Align Object, Version=1.0.1.9, Culture=neutral, PublicKeyToken=null Align+ Align+, Version=2.4.0.0, Culture=neutral, PublicKeyToken=null Alpha-Displacement Mask Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null Alpha2Gray Alpha2Gray, Version=4.5.6832.21862, Culture=neutral, PublicKeyToken=null AlphaBlur AlphaBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null OptionBasedLibrary v0.7.9 OptionBasedLibrary v0.7.9, Version=0.7.9.1561, Culture=neutral, PublicKeyToken=null AlphaMask AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null AlphaSpace AlphaSpace, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null AlphaThreshold AlphaThreshold, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null Apply Texture Apply Texture, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null ArgusPDN.EdgeDetect ArgusPDN.EdgeDetect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null ArtyThing ArtyThing, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null Barcode Barcode, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null BasicAntialias11 BasicAntialias11, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null Bezncurve Bezncurve, Version=4.0.1.0, Culture=neutral, PublicKeyToken=null BlackandAlpha+ BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null BlackAndWhite+ BlackAndWhite+, Version=1.1.6744.2631, Culture=neutral, PublicKeyToken=null BlurBlend BlurBlend, Version=1.1.6601.26020, Culture=neutral, PublicKeyToken=null BrushFactory BrushFactory, Version=2.0.0.29094, Culture=neutral, PublicKeyToken=null BrushFilter BrushFilter, Version=1.3.0.13866, Culture=neutral, PublicKeyToken=null CellTexture CellTexture, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null Channel Extraction.dll Channel Extraction.dll, Version=1.0.7703.23621, Culture=neutral, PublicKeyToken=null CircleText CircleText, Version=1.4.4415.32488, Culture=neutral, PublicKeyToken=null CircularText CircularText, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null ClampedGaussianBlur ClampedGaussianBlur, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null ClipWarpNew ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null CloudEffect CloudEffect, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null CodeLab CodeLab, Version=5.4.7446.1283, Culture=neutral, PublicKeyToken=null ColorBalance ColorBalance, Version=4.7.7401.17173, Culture=neutral, PublicKeyToken=null ColorClearer ColorClearer, Version=1.1.6009.41762, Culture=neutral, PublicKeyToken=null ColorRange ColorRange, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null CombinedAdjustments CombinedAdjustments, Version=1.1.7358.40688, Culture=neutral, PublicKeyToken=null ContentAwareFill ContentAwareFill, Version=1.4.3.0, Culture=neutral, PublicKeyToken=null Contour Contour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null CopyAlpha CopyAlpha, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null CreativeTextPro CreativeTextPro, Version=1.1.7358.34307, Culture=neutral, PublicKeyToken=null CurtisBlack.Common CurtisBlack.Common, Version=1.0.3736.39220, Culture=neutral, PublicKeyToken=null CurtisBlack.Effects CurtisBlack.Effects, Version=11.1.3736.39220, Culture=neutral, PublicKeyToken=null CurtisBlack.Resources CurtisBlack.Resources, Version=1.0.3490.22409, Culture=neutral, PublicKeyToken=null Curves+ Curves+, Version=4.0.6119.31044, Culture=neutral, PublicKeyToken=null deviation-to-alpha.dll deviation-to-alpha.dll, Version=1.1.7681.23746, Culture=neutral, PublicKeyToken=null DHShapeMaker DHShapeMaker, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null Diagonal Lines Diagonal Lines, Version=1.0.4800.36619, Culture=neutral, PublicKeyToken=null Diffuse Diffuse, Version=1.0.3254.27766, Culture=neutral, PublicKeyToken=null Displacement Displacement, Version=1.3.5.15773, Culture=neutral, PublicKeyToken=null DistortThis DistortThis, Version=2.9.0.0, Culture=neutral, PublicKeyToken=null dpyColorBalance dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null Droste Droste, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null DuotoneGradientMap DuotoneGradientMap, Version=1.0.7487.40422, Culture=neutral, PublicKeyToken=null DynamicContrast DynamicContrast, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null EdgeExpander EdgeExpander, Version=1.0.5863.38192, Culture=neutral, PublicKeyToken=null EdgeFader EdgeFader, Version=5.3.5.0, Culture=neutral, PublicKeyToken=null EdgeShaderMJW EdgeShaderMJW, Version=1.1.5849.39125, Culture=neutral, PublicKeyToken=null EdHarvey.Effects EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null EdHarvey.FastFx EdHarvey.FastFx, Version=4.0.5120.35262, Culture=neutral, PublicKeyToken=null Emboss+ Emboss+, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null EngraveEmboss EngraveEmboss, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null EOEffects EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null ErrorDiffusionDithering ErrorDiffusionDithering, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null IniFile IniFile, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null System.Design System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Numerics System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 FillColor FillColor, Version=1.0.6624.35366, Culture=neutral, PublicKeyToken=null FillFromClipboard FillFromClipboard, Version=4.7.7358.36519, Culture=neutral, PublicKeyToken=null FillFromFile FillFromFile, Version=4.7.7358.36581, Culture=neutral, PublicKeyToken=null Fisheye Fisheye, Version=2.2.5533.12794, Culture=neutral, PublicKeyToken=null Flip Flip, Version=4.6.7358.36953, Culture=neutral, PublicKeyToken=null FloodFillGradient FloodFillGradient, Version=1.0.7275.42186, Culture=neutral, PublicKeyToken=null FloydSteinbergDithering FloydSteinbergDithering, Version=4.6.7358.37110, Culture=neutral, PublicKeyToken=null Frames Frames, Version=1.2.5.27903, Culture=neutral, PublicKeyToken=null FurBlur FurBlur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null Gears Gears, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null Gmic Gmic, Version=2.9.5.0, Culture=neutral, PublicKeyToken=null Gossamer Gossamer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null Gradient Bars Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null Gradient Blocks Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null Gradient Grid Gradient Grid, Version=4.0.6436.36068, Culture=neutral, PublicKeyToken=null Gradient Mapping Gradient Mapping, Version=4.0.6547.33963, Culture=neutral, PublicKeyToken=null GradientsGalore GradientsGalore, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null GraphPaper GraphPaper, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null Gravity Gravity, Version=1.2.5.29548, Culture=neutral, PublicKeyToken=null Gray2Alpha Gray2Alpha, Version=4.5.6826.36897, Culture=neutral, PublicKeyToken=null Grid Warp Grid Warp, Version=4.0.6544.34496, Culture=neutral, PublicKeyToken=null GridCheckerboard GridCheckerboard, Version=4.5.6828.36789, Culture=neutral, PublicKeyToken=null GridMaker GridMaker, Version=5.2.5.29827, Culture=neutral, PublicKeyToken=null GrimColorReaper GrimColorReaper, Version=1.2.4299.5808, Culture=neutral, PublicKeyToken=null HexaGrid HexaGrid, Version=4.1.0.40699, Culture=neutral, PublicKeyToken=null Highlight Highlight, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null HighPass_rec HighPass_rec, Version=1.3.6135.23156, Culture=neutral, PublicKeyToken=null HsvEraser HsvEraser, Version=1.1.5625.39352, Culture=neutral, PublicKeyToken=null HSVGradients HSVGradients, Version=4.5.6832.41864, Culture=neutral, PublicKeyToken=null HsvScrambler HsvScrambler, Version=1.1.5675.38718, Culture=neutral, PublicKeyToken=null ImageDistortion ImageDistortion, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null isolate isolate, Version=1.0.3303.3202, Culture=neutral, PublicKeyToken=null PDNPI_IndirectUI PDNPI_IndirectUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Jitter Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null Kaleidoscope Kaleidoscope, Version=1.6.1.27167, Culture=neutral, PublicKeyToken=null Kill Color Keeper Kill Color Keeper, Version=1.0.6641.13453, Culture=neutral, PublicKeyToken=null Landscape Landscape, Version=4.6.7358.37463, Culture=neutral, PublicKeyToken=null LaplacianPyramidFilter LaplacianPyramidFilter, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null LightRays LightRays, Version=2.1.5.14276, Culture=neutral, PublicKeyToken=null LinesGrid LinesGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null Liquify Liquify, Version=4.0.5873.25113, Culture=neutral, PublicKeyToken=null ListOfPalettes ListOfPalettes, Version=1.0.0.32564, Culture=neutral, PublicKeyToken=null Microsoft.VisualBasic Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a LookAtIt.Effect LookAtIt.Effect, Version=0.6.0.779, Culture=neutral, PublicKeyToken=null Majority Majority, Version=1.2.5.14328, Culture=neutral, PublicKeyToken=null Melting Melting, Version=1.3.6550.31783, Culture=neutral, PublicKeyToken=null Metallize Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null Mise En Abyme Mise En Abyme, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null MultiColorGradient MultiColorGradient, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null MultiSpline MultiSpline, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null MultiThreshold MultiThreshold, Version=1.1.4330.38982, Culture=neutral, PublicKeyToken=null NeonEdges NeonEdges, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null NoiseChoice NoiseChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null Object Pruner Object Pruner, Version=1.0.7020.41772, Culture=neutral, PublicKeyToken=null Object2Colour Object2Colour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null ObjectBevel ObjectBevel, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null ObjectEdge ObjectEdge, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null ObjectShadowPro ObjectShadowPro, Version=1.0.7421.614, Culture=neutral, PublicKeyToken=null ObjectTools ObjectTools, Version=5.0.7502.21624, Culture=neutral, PublicKeyToken=null Oblique Oblique, Version=1.2.5.15730, Culture=neutral, PublicKeyToken=null OilPaintingPlus OilPaintingPlus, Version=4.6.7358.38406, Culture=neutral, PublicKeyToken=null Feather Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null OutlinedGradientText OutlinedGradientText, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null Overblur Overblur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null Paneling Paneling, Version=1.2.5.23448, Culture=neutral, PublicKeyToken=null ParallelLines.Effect ParallelLines.Effect, Version=1.6.0.575, Culture=neutral, PublicKeyToken=null Paste Warp Plus Paste Warp Plus, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null PasteAlpha PasteAlpha, Version=4.6.7358.38804, Culture=neutral, PublicKeyToken=null PasteFill PasteFill, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null PasteFromClipboard PasteFromClipboard, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null Pastel Pastel, Version=4.6.7358.38877, Culture=neutral, PublicKeyToken=null PerspectiveTransformation PerspectiveTransformation, Version=1.2.5795.41799, Culture=neutral, PublicKeyToken=null PhotoAdjustments PhotoAdjustments, Version=4.6.7358.38979, Culture=neutral, PublicKeyToken=null Pixelate+ Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null Planetoid Planetoid, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null PlugInData PlugInData, Version=1.3.1.0, Culture=neutral, PublicKeyToken=null PointBlur PointBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null pointwarp pointwarp, Version=1.2.5709.42172, Culture=neutral, PublicKeyToken=null Polar Polar, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null Polygon Polygon, Version=4.5.6828.38648, Culture=neutral, PublicKeyToken=null Popcorn Fractal.dll Popcorn Fractal.dll, Version=1.0.7605.20084, Culture=neutral, PublicKeyToken=null Poster Poster, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null pxEexpansion pxEexpansion, Version=1.0.4437.36287, Culture=neutral, PublicKeyToken=null QuadrilateralCorrection QuadrilateralCorrection, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null Random Shape Fill Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null RandomLines RandomLines, Version=1.2.5.25981, Culture=neutral, PublicKeyToken=null Recolor Using Palette Recolor Using Palette, Version=1.0.6382.573, Culture=neutral, PublicKeyToken=null RecolourChoice RecolourChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null RectangleToArchimedeanSpiral.dll RectangleToArchimedeanSpiral.dll, Version=1.0.7623.289, Culture=neutral, PublicKeyToken=null RemoveDust RemoveDust, Version=4.5.6826.37862, Culture=neutral, PublicKeyToken=null RenderSphereHeightMap RenderSphereHeightMap, Version=1.0.6145.37460, Culture=neutral, PublicKeyToken=null Replace Colors Replace Colors, Version=1.1.5767.26297, Culture=neutral, PublicKeyToken=null Rotate by Torus Map.dll Rotate by Torus Map.dll, Version=1.0.7616.21151, Culture=neutral, PublicKeyToken=null RotateText RotateText, Version=1.1.4415.32628, Culture=neutral, PublicKeyToken=null Rotate_Zoom+ Rotate_Zoom+, Version=1.11.5237.17779, Culture=neutral, PublicKeyToken=null RubberStamp RubberStamp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null SaturationRGB SaturationRGB, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null SBCommon SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null Scintillate Scintillate, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null SeamlessTextureMaker SeamlessTextureMaker, Version=1.2.5.29984, Culture=neutral, PublicKeyToken=null Selection2Clear Selection2Clear, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null SelectionTools SelectionTools, Version=5.0.7502.22140, Culture=neutral, PublicKeyToken=null Shape3D Shape3D, Version=1.2.6.3, Culture=neutral, PublicKeyToken=null shapegradient shapegradient, Version=1.5.3886.6574, Culture=neutral, PublicKeyToken=null SimulateColorDepth SimulateColorDepth, Version=1.0.4211.27729, Culture=neutral, PublicKeyToken=null SinWaves SinWaves, Version=1.2.5.30582, Culture=neutral, PublicKeyToken=null Skew Skew, Version=1.0.7638.38725, Culture=neutral, PublicKeyToken=null Smudge Smudge, Version=4.0.5873.25097, Culture=neutral, PublicKeyToken=null Sound wave Sound wave, Version=2.1.3542.36435, Culture=neutral, PublicKeyToken=null SoundWave SoundWave, Version=1.0.7433.14854, Culture=neutral, PublicKeyToken=null SpacedTextPlugin SpacedTextPlugin, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null Specular Specular, Version=1.0.3254.27778, Culture=neutral, PublicKeyToken=null SpeechBubble SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null __bulge2 __bulge2, Version=1.0.7224.336, Culture=neutral, PublicKeyToken=null SpiralText SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null Stipple Stipple, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Stitch Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null StrayPixelRemover StrayPixelRemover, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null Temperature Temperature, Version=4.6.7358.39746, Culture=neutral, PublicKeyToken=null TextDistortion TextDistortion, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null TextPlus TextPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Texture Object Rounder Texture Object Rounder, Version=1.0.6464.41586, Culture=neutral, PublicKeyToken=null Texture Scaler Texture Scaler, Version=1.2.6431.28257, Culture=neutral, PublicKeyToken=null TextureMerger TextureMerger, Version=1.1.6159.40169, Culture=neutral, PublicKeyToken=null TextureShader TextureShader, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null TextureSmoother TextureSmoother, Version=1.0.6096.31689, Culture=neutral, PublicKeyToken=null Texturize Texturize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null TextWindow TextWindow, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null TGAngle TGAngle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null TGMagnitude TGMagnitude, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null Thorn Fractal.dll Thorn Fractal.dll, Version=1.0.7611.40689, Culture=neutral, PublicKeyToken=null ThreeColorDithering.dll ThreeColorDithering.dll, Version=1.0.7652.19490, Culture=neutral, PublicKeyToken=null Tiles Tiles, Version=1.2.5.13094, Culture=neutral, PublicKeyToken=null __trace __trace, Version=1.0.7198.41170, Culture=neutral, PublicKeyToken=null Trail Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null trail3d trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null Trail Blur Trail Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Transparency Transparency, Version=4.6.7358.39871, Culture=neutral, PublicKeyToken=null TransparentToTransparentBlack TransparentToTransparentBlack, Version=1.0.6479.25661, Culture=neutral, PublicKeyToken=null TransparentToTransparentWhite TransparentToTransparentWhite, Version=1.0.6963.30396, Culture=neutral, PublicKeyToken=null TRs Scatter TRs Scatter, Version=1.3.4949.23250, Culture=neutral, PublicKeyToken=null TRsAlphaCutter TRsAlphaCutter, Version=3.0.4.0, Culture=neutral, PublicKeyToken=null TRsColorReducer TRsColorReducer, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null TRsCustomRandomFill TRsCustomRandomFill, Version=1.5.1.31287, Culture=neutral, PublicKeyToken=null TRsDodgeBurn TRsDodgeBurn, Version=1.4.0.33503, Culture=neutral, PublicKeyToken=null TRsDodgeBurn.resources TRsDodgeBurn.resources, Version=1.3.26.12436, Culture=zh-CN, PublicKeyToken=null TRsMonolithic TRsMonolithic, Version=1.0.6.24412, Culture=neutral, PublicKeyToken=null TRsMorpher TRsMorpher, Version=1.1.2.15085, Culture=neutral, PublicKeyToken=null TRsStrobeMotion TRsStrobeMotion, Version=1.2.4962.30523, Culture=neutral, PublicKeyToken=null TubeOblique TubeOblique, Version=1.2.5.15697, Culture=neutral, PublicKeyToken=null TurbulentCircles TurbulentCircles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null TurbulentLines TurbulentLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null TwoToneThreshold TwoToneThreshold, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.Blurs Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.ColorAccent Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.DropShadow Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.Duotones Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.FadeEdge Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.Gradient Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.Grid Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.Monochromes Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vandermotten.PaintDotNetEffects.ObjectAlign Vandermotten.PaintDotNetEffects.ObjectAlign, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null Vanishing Trails Vanishing Trails, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null VignettePlus VignettePlus, Version=4.6.7358.40027, Culture=neutral, PublicKeyToken=null WarpTextOnPath WarpTextOnPath, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null WaterReflection WaterReflection, Version=1.2.5.15754, Culture=neutral, PublicKeyToken=null Waves Waves, Version=1.2.5.14072, Culture=neutral, PublicKeyToken=null WaveText WaveText, Version=1.2.4415.32811, Culture=neutral, PublicKeyToken=null WetFloor WetFloor, Version=1.2.5.14166, Culture=neutral, PublicKeyToken=null WhatIsIt.Effect WhatIsIt.Effect, Version=0.1.0.111, Culture=neutral, PublicKeyToken=null WhichSymbolRedux WhichSymbolRedux, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null xmario_cut_color_en xmario_cut_color_en, Version=1.0.3807.26390, Culture=neutral, PublicKeyToken=null ZoomBlurDeluxe ZoomBlurDeluxe, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null OptionBasedLibrary v0.7.8 OptionBasedLibrary v0.7.8, Version=0.7.0.1343, Culture=neutral, PublicKeyToken=null K4os.Compression.LZ4 K4os.Compression.LZ4, Version=1.1.11.0, Culture=neutral, PublicKeyToken=2186fa9121ef231d Native modules 127 PaintDotNet.exe C:\Program Files\paint.net\PaintDotNet.exe, version=4.215.7694.37221 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.662 (WinBuild.160101.0800) MSCOREE.DLL C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=10.0.19041.1 (WinBuild.160101.0800) aswhook.dll C:\Program Files (x86)\AVG\Antivirus\aswhook.dll, version=20.10.5824.0 KERNEL32.dll C:\WINDOWS\System32\KERNEL32.dll, version=10.0.19041.662 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.662 (WinBuild.160101.0800) ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800) mscoreei.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.8.4180.0 built by: NET48REL1LAST_B SHLWAPI.dll C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.800 (WinBuild.160101.0800) kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) VERSION.dll C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.19041.546 (WinBuild.160101.0800) clr.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.8.4300.0 built by: NET48REL1LAST_C USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.800 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.746 (WinBuild.160101.0800) GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.746 (WinBuild.160101.0800) gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.746 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.546 (WinBuild.160101.0800) ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.546 (WinBuild.160101.0800) VCRUNTIME140_CLR0400.dll C:\WINDOWS\SYSTEM32\VCRUNTIME140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM ucrtbase_clr0400.dll C:\WINDOWS\SYSTEM32\ucrtbase_clr0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800) psapi.dll C:\WINDOWS\System32\psapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) mscorlib.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\ed4777cae83e1fc9087ac3dc82cf23ab\mscorlib.ni.dll, version=4.8.4300.0 built by: NET48REL1LAST_C ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.1 (WinBuild.160101.0800) bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.662 (WinBuild.160101.0800) uxtheme.dll C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.800 (WinBuild.160101.0800) CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) rsaenh.dll C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) bcrypt.dll C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) CRYPTBASE.dll C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\5dd302cc18514670950e7f3fbebddb06\System.ni.dll, version=4.8.4300.0 built by: NET48REL1LAST_C System.Core.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\ce57a19cdc83705ba9aeec743bfdc62f\System.Core.ni.dll, version=4.8.4300.0 built by: NET48REL1LAST_C WindowsBase.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\fec1e81e95fa9e5ed8f8290632af79de\WindowsBase.ni.dll, version=4.8.4300.0 built by: NET48REL1LAST_C System.Drawing.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\f4b470d059025978bbe597afc6e60f7d\System.Drawing.ni.dll, version=4.8.4084.0 built by: NET48REL1 PresentationCore.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\66450953713be99c7f54d828732cb56c\PresentationCore.ni.dll, version=4.8.4300.0 built by: NET48REL1LAST_C PresentationFramework.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\95a1a26b05917f415f1754568270dea5\PresentationFramework.ni.dll, version=4.8.4300.0 PaintDotNet.Base.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\7df39cbb1dd49a097d72f5288f182d9c\PaintDotNet.Base.ni.dll, version=4.215.7694.37221 System.Windows.Forms.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\9c043df0c5a3f7b28f75021b55a8152a\System.Windows.Forms.ni.dll, version=4.8.4270.0 built by: NET48REL1LAST_C PaintDotNet.SystemLayer.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\0593fa80a5aee0fc9a6f26df9abe19de\PaintDotNet.SystemLayer.ni.dll, version=4.215.7694.37221 PaintDotNet.Core.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\a9672f69794ea888b5b3de48587ee97e\PaintDotNet.Core.ni.dll, version=4.215.7694.37221 PaintDotNet.Resources.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\521f57806ca1c0f09365a7d2d8520727\PaintDotNet.Resources.ni.dll, version=4.215.7694.37221 PaintDotNet.Framework.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\d7f762ba829f968831d7111d7c669391\PaintDotNet.Framework.ni.dll, version=4.215.7694.37221 PaintDotNet.Data.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\b5166eb43343d886d721920487a7c487\PaintDotNet.Data.ni.dll, version=4.215.7694.37221 PaintDotNet.Effects.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\80cab95b88922a6e762ff1c30999b70a\PaintDotNet.Effects.ni.dll, version=4.215.7694.37221 PaintDotNet.ni.exe C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\cd83f7b3ebd2ea4a285a91a9f246d523\PaintDotNet.ni.exe, version=4.215.7694.37221 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) wpfgfx_v0400.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.8.4300.0 built by: NET48REL1LAST_C OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.546 (WinBuild.160101.0800) MSVCP140_CLR0400.dll C:\WINDOWS\SYSTEM32\MSVCP140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM PresentationNative_v0400.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.8.4300.0 built by: NET48REL1LAST_C shell32.dll C:\WINDOWS\System32\shell32.dll, version=10.0.19041.800 (WinBuild.160101.0800) windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.800 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) SHCORE.dll C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.800 (WinBuild.160101.0800) vcruntime140.dll C:\Program Files\paint.net\Native\X64\vcruntime140.dll, version=14.28.29334.0 built by: vcwrkspc vcruntime140_1.dll C:\Program Files\paint.net\Native\X64\vcruntime140_1.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140.dll C:\Program Files\paint.net\Native\X64\msvcp140.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_1.dll C:\Program Files\paint.net\Native\X64\msvcp140_1.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_2.dll C:\Program Files\paint.net\Native\X64\msvcp140_2.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_codecvt_ids.dll C:\Program Files\paint.net\Native\X64\msvcp140_codecvt_ids.dll, version=14.28.29334.0 built by: vcwrkspc vcomp140.dll C:\Program Files\paint.net\Native\X64\vcomp140.dll, version=14.28.29334.0 built by: vcwrkspc PaintDotNet.SystemLayer.Native.x64.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\7eceac464b96d30a2a2a5c8cf1619a14\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.215.7694.37221 PaintDotNet.SystemLayer.Native.x64.dll C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.215.7694.37221 PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.800 (WinBuild.160101.0800) gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.746_none_faeda79b76159a72\gdiplus.dll, version=10.0.19041.746 (WinBuild.160101.0800) WindowsCodecs.dll C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.546 (WinBuild.160101.0800) clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) System.Configuration.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\9962fc89eda46413a40be6ede9d433fe\System.Configuration.ni.dll, version=4.8.4190.0 built by: NET48REL1LAST_B System.Xml.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\131a023309990432765d7a97ec31d6a7\System.Xml.ni.dll, version=4.8.4084.0 built by: NET48REL1 profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.Xaml.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\0ef8bfd0f4664190a99df56720291069\System.Xaml.ni.dll, version=4.8.4300.0 built by: NET48REL1LAST_C clrjit.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.8.4300.0 built by: NET48REL1LAST_C System.Runtime.CompilerServices.Unsafe.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Runtea61dfd5#\be3e121258d7e87a2074ef5bdac61ac8\System.Runtime.CompilerServices.Unsafe.ni.dll, version=4.700.20.12001 MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.800 (WinBuild.160101.0800) dxgi.dll C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.746 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.746_none_ca02b4b61b8320a4\comctl32.dll, version=6.10 (WinBuild.160101.0800) TextShaping.dll C:\WINDOWS\System32\TextShaping.dll, version= mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.800 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.546 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800) CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) Windows.StateRepositoryPS.dll C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.546 (WinBuild.160101.0800) WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.1 (WinBuild.160101.0800) d2d1.dll C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800) wtsapi32.dll C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.Web.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Web\8b841ecb4d0e1cef1579940c5b539b0d\System.Web.ni.dll, version=4.8.4250.0 built by: NET48REL1LAST_C d3d11.dll C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.746 (WinBuild.160101.0800) D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800) dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) dwmapi.dll C:\WINDOWS\SYSTEM32\dwmapi.dll, version=10.0.19041.800 (WinBuild.160101.0800) dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.746 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.746 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Collections.Immutable.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Coll4a4f96a7#\a9cc475c11172c8824cd0d18e0b678cd\System.Collections.Immutable.ni.dll, version=4.700.20.21406 textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.746 (WinBuild.160101.0800) CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 CoreMessaging.dll C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1 (WinBuild.160101.0800) ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.800 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= System.Buffers.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Buffers\d861d77f413fed84924c0db1977ced0f\System.Buffers.ni.dll, version=4.6.28619.01 winmm.dll C:\WINDOWS\SYSTEM32\winmm.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Memory.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Memory\6e9a8622af0dffa0e9f9737798ecefea\System.Memory.ni.dll, version=4.6.28619.01 explorerframe.dll C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.800 (WinBuild.160101.0800) aticfx64.dll C:\WINDOWS\SYSTEM32\aticfx64.dll, version=8.17.10.1474 atiuxp64.dll C:\WINDOWS\SYSTEM32\atiuxp64.dll, version=8.14.01.6521 atidxx64.dll C:\WINDOWS\SYSTEM32\atidxx64.dll, version=8.17.10.0682 SETUPAPI.dll C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.19041.800 (WinBuild.160101.0800) apphelp.dll C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Design.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Design\6a241a48ffe03ae5328e41f854331234\System.Design.ni.dll, version=4.8.4084.0 built by: NET48REL1 diasymreader.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.8.4084.0 built by: NET48REL1 System.Numerics.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Numerics\92acbf2f668c06e51b7ae29b448197a3\System.Numerics.ni.dll, version=4.8.4084.0 built by: NET48REL1 Microsoft.VisualBasic.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Microsoft.V9921e851#\5d628ee5d2477d5547beadc8bf0983df\Microsoft.VisualBasic.ni.dll, version=14.8.4084.0 built by: NET48REL1 K4os.Compression.LZ4.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\K4os.Compression.LZ4\0a43166728ad63c02b98ef535d81fcdf\K4os.Compression.LZ4.ni.dll, version=1.1.11 XmlLite.dll C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.546 (WinBuild.160101.0800) clrcompression.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrcompression.dll, version=4.8.4084.0 built by: NET48REL1 DEVOBJ.dll C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.546 (WinBuild.160101.0800) WINTRUST.dll C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.662 (WinBuild.160101.0800) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.800 (WinBuild.160101.0800) MSASN1.dll C:\WINDOWS\SYSTEM32\MSASN1.dll, version=10.0.19041.546 (WinBuild.160101.0800) Quote Link to comment Share on other sites More sharing options...
ardneh Posted February 14, 2021 Share Posted February 14, 2021 (edited) A few days ago. This shows a one layer image copy/pasted into a new image. Ctrl Shft C > Ctrl Alt V It shows the Layers window of the file it was copied from, sans layer names and checkmark. The Tab is absent. Don't know if the fact that Windows was waiting on current updates was a factor. Application paint.net 4.2.15 (Final 4.215.7694.37221) Build Date Sunday, January 24, 2021 Install type Classic Hardware accelerated rendering (GPU) True Animations True DPI 96 (1.00x scale) Language en-US OS Windows 10 Home x64 (10.0.19041.0) (0x65) .NET Runtime 4.0.30319.42000 Physical Memory 8,055 MB CPU Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz Speed ~2594 MHz Cores / Threads 2 / 4 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX Video Card Intel(R) HD Graphics 4000 Dedicated Video RAM 32 MB Dedicated System RAM 0 MB Shared System RAM 1,760 MB Vendor ID 0x8086 Device ID 0x0166 Subsystem ID 0x179B103C Revision 9 LUID 0x00008124 Flags SupportNonMonitoredFences, KeyedMutexConformance Graphics Preemption DmaBufferBoundary Compute Preemption ThreadGroupBoundary Outputs 1 Feature Level Direct3D_11_0 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 4,027 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000865B Flags Software, AcgCompatible, SupportMonitoredFences, SupportNonMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Managed assemblies 83 mscorlib mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PaintDotNet PaintDotNet, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Core PaintDotNet.Core, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Base PaintDotNet.Base, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null WindowsBase WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Core System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Drawing System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a PresentationFramework PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 PresentationCore PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 System.Windows.Forms System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PaintDotNet.SystemLayer PaintDotNet.SystemLayer, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Framework PaintDotNet.Framework, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Resources PaintDotNet.Resources, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Effects PaintDotNet.Effects, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.Data PaintDotNet.Data, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null PaintDotNet.SystemLayer.Native.x64 PaintDotNet.SystemLayer.Native.x64, Version=4.215.7694.37221, Culture=neutral, PublicKeyToken=null System.Configuration System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Xml System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Xaml System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Runtime.CompilerServices.Unsafe System.Runtime.CompilerServices.Unsafe, Version=4.0.6.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a AvifFileType AvifFileType, Version=1.1.6.0, Culture=neutral, PublicKeyToken=null DdsFileTypePlus DdsFileTypePlus, Version=1.10.7.0, Culture=neutral, PublicKeyToken=null WebPFileType WebPFileType, Version=1.3.4.0, Culture=neutral, PublicKeyToken=null System.Collections.Immutable System.Collections.Immutable, Version=1.2.5.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a System.Buffers System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 System.Xml.Linq System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 System.Memory System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 AA's_Assistant "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null Align Object Align Object, Version=1.0.1.9, Culture=neutral, PublicKeyToken=null Alpha-Displacement Mask Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null BasicAntialias11 BasicAntialias11, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null BrushFactory BrushFactory, Version=2.0.1.2752, Culture=neutral, PublicKeyToken=null ChopUp ChopUp, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null OptionBasedLibrary v0.4 OptionBasedLibrary v0.4, Version=0.3.0.0, Culture=neutral, PublicKeyToken=null ClampedGaussianBlur ClampedGaussianBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null ClipWarpNew ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null CodeLab CodeLab, Version=6.0.7481.36627, Culture=neutral, PublicKeyToken=null a_color_swap a_color_swap, Version=1.0.7186.9639, Culture=neutral, PublicKeyToken=null ContentAwareFill ContentAwareFill, Version=1.4.3.0, Culture=neutral, PublicKeyToken=null CreativeTextPro CreativeTextPro, Version=1.1.7358.34307, Culture=neutral, PublicKeyToken=null DistortThis DistortThis, Version=2.9.0.0, Culture=neutral, PublicKeyToken=null Droste Droste, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null EdHarvey.Effects EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null EOEffects EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null Flip Flip, Version=4.6.7358.36953, Culture=neutral, PublicKeyToken=null Gradient Mapping Gradient Mapping, Version=4.0.6547.33963, Culture=neutral, PublicKeyToken=null GradientBlur GradientBlur, Version=1.2.5.28179, Culture=neutral, PublicKeyToken=null Gravity Gravity, Version=1.2.5.29548, Culture=neutral, PublicKeyToken=null GridGrad GridGrad, Version=1.0.4172.25342, Culture=neutral, PublicKeyToken=null System.Design System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a ImageDistortion ImageDistortion, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null Kill Color Keeper Kill Color Keeper, Version=1.0.6641.13453, Culture=neutral, PublicKeyToken=null Landscape Landscape, Version=4.6.7358.37463, Culture=neutral, PublicKeyToken=null Liquify Liquify, Version=4.0.5873.25113, Culture=neutral, PublicKeyToken=null OptionBasedLibrary v0.7.9 OptionBasedLibrary v0.7.9, Version=0.7.9.1561, Culture=neutral, PublicKeyToken=null Metallize Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null ObjectTools ObjectTools, Version=5.0.7502.21624, Culture=neutral, PublicKeyToken=null PasteAlpha PasteAlpha, Version=4.6.7358.38804, Culture=neutral, PublicKeyToken=null Polar Polar, Version=1.2.5.24467, Culture=neutral, PublicKeyToken=null Untitled Untitled, Version=1.0.3969.24952, Culture=neutral, PublicKeyToken=null Popcorn Fractal.dll Popcorn Fractal.dll, Version=1.0.7605.20084, Culture=neutral, PublicKeyToken=null PSFilterPdn PSFilterPdn, Version=1.0.7.1, Culture=neutral, PublicKeyToken=null Random Shape Fill Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null RectangleToArchimedeanSpiral.dll RectangleToArchimedeanSpiral.dll, Version=1.0.7623.289, Culture=neutral, PublicKeyToken=null SelectionTools SelectionTools, Version=5.0.7502.22140, Culture=neutral, PublicKeyToken=null Shape3D Shape3D, Version=1.2.6.3, Culture=neutral, PublicKeyToken=null silhouetteplus silhouetteplus, Version=1.1.3131.17586, Culture=neutral, PublicKeyToken=null Smudge Smudge, Version=4.0.5873.25097, Culture=neutral, PublicKeyToken=null __bulge2 __bulge2, Version=1.0.7224.336, Culture=neutral, PublicKeyToken=null Table Table, Version=1.1.5847.38905, Culture=neutral, PublicKeyToken=null TextDistortion TextDistortion, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null Trail Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null trail3d trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null Transparency Transparency, Version=4.6.7358.39871, Culture=neutral, PublicKeyToken=null TRsPixelSharp TRsPixelSharp, Version=2.0.5467.31590, Culture=neutral, PublicKeyToken=null TubeOblique TubeOblique, Version=1.2.5.15697, Culture=neutral, PublicKeyToken=null TwistZ TwistZ, Version=1.2.5.13350, Culture=neutral, PublicKeyToken=null WaterReflection WaterReflection, Version=1.2.5.15754, Culture=neutral, PublicKeyToken=null WetFloor WetFloor, Version=1.2.5.14166, Culture=neutral, PublicKeyToken=null System.Numerics System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 PresentationFramework-SystemXmlLinq PresentationFramework-SystemXmlLinq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 K4os.Compression.LZ4 K4os.Compression.LZ4, Version=1.1.11.0, Culture=neutral, PublicKeyToken=2186fa9121ef231d Native modules 171 PaintDotNet.exe C:\Program Files\paint.net\PaintDotNet.exe, version=4.215.7694.37221 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.804 (WinBuild.160101.0800) MSCOREE.DLL C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=10.0.19041.1 (WinBuild.160101.0800) KERNEL32.dll C:\WINDOWS\System32\KERNEL32.dll, version=10.0.19041.804 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.804 (WinBuild.160101.0800) ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800) mscoreei.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.8.4180.0 built by: NET48REL1LAST_B SHLWAPI.dll C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) VERSION.dll C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.19041.546 (WinBuild.160101.0800) clr.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.8.4300.0 built by: NET48REL1LAST_C USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.804 (WinBuild.160101.0800) GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.746 (WinBuild.160101.0800) VCRUNTIME140_CLR0400.dll C:\WINDOWS\SYSTEM32\VCRUNTIME140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.746 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) ucrtbase_clr0400.dll C:\WINDOWS\SYSTEM32\ucrtbase_clr0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800) psapi.dll C:\WINDOWS\System32\psapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) mscorlib.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\ed4777cae83e1fc9087ac3dc82cf23ab\mscorlib.ni.dll, version=4.8.4300.0 built by: NET48REL1LAST_C ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.1 (WinBuild.160101.0800) bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.662 (WinBuild.160101.0800) uxtheme.dll C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.1 (WinBuild.160101.0800) CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) rsaenh.dll C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) bcrypt.dll C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) CRYPTBASE.dll C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\5dd302cc18514670950e7f3fbebddb06\System.ni.dll, version=4.8.4300.0 built by: NET48REL1LAST_C System.Core.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\5b420a81d9bf78ed0945d8ac1ca932b4\System.Core.ni.dll, version=4.8.4320.0 built by: NET48REL1LAST_C WindowsBase.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\1bb16f159c40eab354f8f3afdb634c07\WindowsBase.ni.dll, version=4.8.4320.0 built by: NET48REL1LAST_C System.Drawing.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\f4b470d059025978bbe597afc6e60f7d\System.Drawing.ni.dll, version=4.8.4084.0 built by: NET48REL1 PresentationCore.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\4f1be3c2c6b9de192d4f2ec23f0644c6\PresentationCore.ni.dll, version=4.8.4320.0 built by: NET48REL1LAST_C PresentationFramework.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\3cbdd925ecd09c5934ba2c073c236975\PresentationFramework.ni.dll, version=4.8.4320.0 PaintDotNet.Base.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\a3868f4755b3b565effc35fa32005b66\PaintDotNet.Base.ni.dll, version=4.215.7694.37221 System.Windows.Forms.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\4c9a810cd0c747bf8c7905df177ae92e\System.Windows.Forms.ni.dll, version=4.8.4270.0 built by: NET48REL1LAST_C PaintDotNet.SystemLayer.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\c03fe6fc3e218434daa2058c59554ec1\PaintDotNet.SystemLayer.ni.dll, version=4.215.7694.37221 PaintDotNet.Core.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\70d5a67a74402a7467b08c47f9d92309\PaintDotNet.Core.ni.dll, version=4.215.7694.37221 PaintDotNet.Resources.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\d3d736f58a748167e80400f2cc0744c3\PaintDotNet.Resources.ni.dll, version=4.215.7694.37221 PaintDotNet.Framework.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\b8226d5f32aad80f8bd616f926bdb98a\PaintDotNet.Framework.ni.dll, version=4.215.7694.37221 PaintDotNet.Data.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\b0c24732f1f63cff081849beaf7b6602\PaintDotNet.Data.ni.dll, version=4.215.7694.37221 PaintDotNet.Effects.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\4f1acfbbdf2c73c45a979809c64e0e98\PaintDotNet.Effects.ni.dll, version=4.215.7694.37221 PaintDotNet.ni.exe C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\42640755f32a45da07a992bfc83686b3\PaintDotNet.ni.exe, version=4.215.7694.37221 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) wpfgfx_v0400.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.8.4320.0 built by: NET48REL1LAST_C OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.804 (WinBuild.160101.0800) MSVCP140_CLR0400.dll C:\WINDOWS\SYSTEM32\MSVCP140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM PresentationNative_v0400.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.8.4320.0 built by: NET48REL1LAST_C shell32.dll C:\WINDOWS\System32\shell32.dll, version=10.0.19041.329 (WinBuild.160101.0800) windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) SHCORE.dll C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.1 (WinBuild.160101.0800) vcruntime140.dll C:\Program Files\paint.net\Native\X64\vcruntime140.dll, version=14.28.29334.0 built by: vcwrkspc vcruntime140_1.dll C:\Program Files\paint.net\Native\X64\vcruntime140_1.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140.dll C:\Program Files\paint.net\Native\X64\msvcp140.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_1.dll C:\Program Files\paint.net\Native\X64\msvcp140_1.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_2.dll C:\Program Files\paint.net\Native\X64\msvcp140_2.dll, version=14.28.29334.0 built by: vcwrkspc msvcp140_codecvt_ids.dll C:\Program Files\paint.net\Native\X64\msvcp140_codecvt_ids.dll, version=14.28.29334.0 built by: vcwrkspc vcomp140.dll C:\Program Files\paint.net\Native\X64\vcomp140.dll, version=14.28.29334.0 built by: vcwrkspc PaintDotNet.SystemLayer.Native.x64.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\464e1d0c668ac7199a7414861707cf1c\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.215.7694.37221 PaintDotNet.SystemLayer.Native.x64.dll C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.215.7694.37221 PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.1 (WinBuild.160101.0800) gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.789_none_faf0a7e97612e7bb\gdiplus.dll, version=10.0.19041.789 (WinBuild.160101.0800) WindowsCodecs.dll C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.546 (WinBuild.160101.0800) clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) System.Configuration.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\43245d36d271e5e3abf3742885086b10\System.Configuration.ni.dll, version=4.8.4190.0 built by: NET48REL1LAST_B System.Xml.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\131a023309990432765d7a97ec31d6a7\System.Xml.ni.dll, version=4.8.4084.0 built by: NET48REL1 profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.Xaml.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\b073e7911284b1d33baee633f22e5f62\System.Xaml.ni.dll, version=4.8.4320.0 built by: NET48REL1LAST_C clrjit.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.8.4300.0 built by: NET48REL1LAST_C System.Runtime.CompilerServices.Unsafe.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Runtea61dfd5#\be3e121258d7e87a2074ef5bdac61ac8\System.Runtime.CompilerServices.Unsafe.ni.dll, version=4.700.20.12001 MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800) dxgi.dll C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.746 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.746_none_ca02b4b61b8320a4\comctl32.dll, version=6.10 (WinBuild.160101.0800) mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.546 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800) CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) Windows.StateRepositoryPS.dll C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.789 (WinBuild.160101.0800) TextShaping.dll C:\WINDOWS\System32\TextShaping.dll, version= WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.1 (WinBuild.160101.0800) d2d1.dll C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800) wtsapi32.dll C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800) d3d11.dll C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.746 (WinBuild.160101.0800) D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800) dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.Collections.Immutable.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Coll4a4f96a7#\c1af0adf271739618056e7619dc345f5\System.Collections.Immutable.ni.dll, version=4.700.20.21406 vlmshlp.dll C:\Users\14152\Desktop\VOLUMOUSE\volumouse-x64\vlmshlp.dll, version=2.03 dwmapi.dll C:\WINDOWS\SYSTEM32\dwmapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.746 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.746 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.789 (WinBuild.160101.0800) CoreMessaging.dll C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746 CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1 (WinBuild.160101.0800) ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= System.Buffers.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Buffers\d861d77f413fed84924c0db1977ced0f\System.Buffers.ni.dll, version=4.6.28619.01 System.Xml.Linq.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml.Linq\7d5777c130d020ebe3c89b79f238ccd5\System.Xml.Linq.ni.dll, version=4.8.4084.0 built by: NET48REL1 winmm.dll C:\WINDOWS\SYSTEM32\winmm.dll, version=10.0.19041.1 (WinBuild.160101.0800) policymanager.dll C:\WINDOWS\SYSTEM32\policymanager.dll, version=10.0.19041.746 (WinBuild.160101.0800) msvcp110_win.dll C:\WINDOWS\SYSTEM32\msvcp110_win.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.Memory.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Memory\6e9a8622af0dffa0e9f9737798ecefea\System.Memory.ni.dll, version=4.6.28619.01 explorerframe.dll C:\WINDOWS\system32\explorerframe.dll, version=10.0.19041.1 (WinBuild.160101.0800) igd10iumd64.dll C:\WINDOWS\SYSTEM32\igd10iumd64.dll, version=10.18.10.4425 ncrypt.dll C:\WINDOWS\SYSTEM32\ncrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) NTASN1.dll C:\WINDOWS\SYSTEM32\NTASN1.dll, version=10.0.19041.1 (WinBuild.160101.0800) igdusc64.dll C:\WINDOWS\SYSTEM32\igdusc64.dll, version=10.18.10.4425 System.Numerics.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Numerics\92acbf2f668c06e51b7ae29b448197a3\System.Numerics.ni.dll, version=4.8.4084.0 built by: NET48REL1 diasymreader.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=14.8.4084.0 built by: NET48REL1 K4os.Compression.LZ4.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\K4os.Compression.LZ4\0a43166728ad63c02b98ef535d81fcdf\K4os.Compression.LZ4.ni.dll, version=1.1.11 clrcompression.dll C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrcompression.dll, version=4.8.4084.0 built by: NET48REL1 comdlg32.dll C:\WINDOWS\System32\comdlg32.dll, version=10.0.19041.1 (WinBuild.160101.0800) XmlLite.dll C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.546 (WinBuild.160101.0800) Windows.FileExplorer.Common.dll C:\Windows\System32\Windows.FileExplorer.Common.dll, version=10.0.19041.1 (WinBuild.160101.0800) LINKINFO.dll C:\WINDOWS\SYSTEM32\LINKINFO.dll, version=10.0.19041.546 (WinBuild.160101.0800) DUI70.dll C:\WINDOWS\System32\DUI70.dll, version=10.0.19041.1 (WinBuild.160101.0800) DUser.dll C:\WINDOWS\System32\DUser.dll, version=10.0.19041.1 (WinBuild.160101.0800) thumbcache.dll C:\Windows\System32\thumbcache.dll, version=10.0.19041.1 (WinBuild.160101.0800) Windows.UI.FileExplorer.dll C:\Windows\System32\Windows.UI.FileExplorer.dll, version=10.0.19041.488 (WinBuild.160101.0800) OLEACC.dll C:\Windows\System32\OLEACC.dll, version=7.2.19041.746 (WinBuild.160101.0800) edputil.dll C:\WINDOWS\SYSTEM32\edputil.dll, version=10.0.19041.1 (WinBuild.160101.0800) StructuredQuery.dll C:\WINDOWS\System32\StructuredQuery.dll, version=7.0.19041.746 (WinBuild.160101.0800) atlthunk.dll C:\WINDOWS\SYSTEM32\atlthunk.dll, version=10.0.19041.546 (WinBuild.160101.0800) iertutil.dll C:\Windows\System32\iertutil.dll, version=11.00.19041.1 (WinBuild.160101.0800) Windows.Storage.Search.dll C:\WINDOWS\system32\Windows.Storage.Search.dll, version=10.0.19041.1 (WinBuild.160101.0800) SspiCli.dll C:\WINDOWS\SYSTEM32\SspiCli.dll, version=10.0.19041.662 (WinBuild.160101.0800) samcli.dll C:\WINDOWS\SYSTEM32\samcli.dll, version=10.0.19041.546 (WinBuild.160101.0800) SAMLIB.dll C:\WINDOWS\SYSTEM32\SAMLIB.dll, version=10.0.19041.662 (WinBuild.160101.0800) netutils.dll C:\WINDOWS\SYSTEM32\netutils.dll, version=10.0.19041.546 (WinBuild.160101.0800) tiptsf.dll C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=10.0.19041.1 (WinBuild.160101.0800) MPR.dll C:\WINDOWS\SYSTEM32\MPR.dll, version=10.0.19041.1 (WinBuild.160101.0800) drprov.dll C:\WINDOWS\System32\drprov.dll, version=10.0.19041.1 (WinBuild.160101.0800) ntlanman.dll C:\WINDOWS\System32\ntlanman.dll, version=10.0.19041.1 (WinBuild.160101.0800) davclnt.dll C:\WINDOWS\System32\davclnt.dll, version=10.0.19041.546 (WinBuild.160101.0800) DAVHLPR.dll C:\WINDOWS\System32\DAVHLPR.dll, version=10.0.19041.546 (WinBuild.160101.0800) wkscli.dll C:\WINDOWS\System32\wkscli.dll, version=10.0.19041.546 (WinBuild.160101.0800) cscapi.dll C:\WINDOWS\SYSTEM32\cscapi.dll, version=10.0.19041.546 (WinBuild.160101.0800) twinapi.dll C:\Windows\System32\twinapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) apphelp.dll C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800) dlnashext.dll C:\Windows\System32\dlnashext.dll, version=10.0.19041.1 (WinBuild.160101.0800) PlayToDevice.dll C:\Windows\System32\PlayToDevice.dll, version=10.0.19041.1 (WinBuild.160101.0800) DevDispItemProvider.dll C:\Windows\System32\DevDispItemProvider.dll, version=10.0.19041.1 (WinBuild.160101.0800) ntshrui.dll C:\WINDOWS\SYSTEM32\ntshrui.dll, version=10.0.19041.1 (WinBuild.160101.0800) srvcli.dll C:\WINDOWS\SYSTEM32\srvcli.dll, version=10.0.19041.546 (WinBuild.160101.0800) MMDevApi.dll C:\WINDOWS\System32\MMDevApi.dll, version=10.0.19041.1 (WinBuild.160101.0800) DEVOBJ.dll C:\WINDOWS\System32\DEVOBJ.dll, version=10.0.19041.546 (WinBuild.160101.0800) PortableDeviceApi.dll C:\Windows\System32\PortableDeviceApi.dll, version=10.0.19041.1 (WinBuild.160101.0800) SETUPAPI.dll C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) WINTRUST.dll C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.804 (WinBuild.160101.0800) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800) MSASN1.dll C:\WINDOWS\System32\MSASN1.dll, version=10.0.19041.546 (WinBuild.160101.0800) EhStorShell.dll C:\Windows\System32\EhStorShell.dll, version=10.0.19041.1 (WinBuild.160101.0800) EhStorAPI.dll C:\Windows\System32\EhStorAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) urlmon.dll C:\WINDOWS\System32\urlmon.dll, version=11.00.19041.1 (WinBuild.160101.0800) FileSyncShell64.dll C:\Users\14152\AppData\Local\Microsoft\OneDrive\21.002.0104.0005\amd64\FileSyncShell64.dll, version=21.002.0104.0005 WININET.dll C:\WINDOWS\SYSTEM32\WININET.dll, version=11.00.19041.1 (WinBuild.160101.0800) USERENV.dll C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800) NetworkExplorer.dll C:\WINDOWS\system32\NetworkExplorer.dll, version=10.0.19041.1 (WinBuild.160101.0800) OneCoreUAPCommonProxyStub.dll C:\Windows\System32\OneCoreUAPCommonProxyStub.dll, version=10.0.19041.789 (WinBuild.160101.0800) sxs.dll C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800) ActXPrxy.dll C:\Windows\System32\ActXPrxy.dll, version=10.0.19041.789 (WinBuild.160101.0800) Edited February 16, 2021 by ardneh Quote Link to comment Share on other sites More sharing options...
Hatori360 Posted April 29, 2021 Author Share Posted April 29, 2021 I have noticed that when I try to switch from one application using the taskbar icons, I have to be careful to click the Paint.NET taskbar icon instead of hovering the mouse cursor over the icon. If I hover over the Paint.NET icon, the Paint.NET user interface displays on the screen and I might click on one of the image projects I have already opened, but instead of allowing me to work continue working with that project, windows switches back to whatever app I was using, such as a browser. Afterward, when I manage to carefully mouse click the Paint.NET tray icon, I can select a currently open image in the user interface, but any open Tools app has to be closed and reopened for me to use them effectively. If I don't, when I select one of the images with layers, it will show one of the other image's layers instead. After closing all open Tools, I can use them effectively. I have, to my knowledge, fully updated my system. Quote Link to comment Share on other sites More sharing options...
ardneh Posted May 25, 2021 Share Posted May 25, 2021 (edited) Similar to previous. Link Edited May 25, 2021 by ardneh Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted May 25, 2021 Share Posted May 25, 2021 On 2/14/2021 at 9:41 AM, ardneh said: igd10iumd64.dll C:\WINDOWS\SYSTEM32\igd10iumd64.dll, version=10.18.10.4425 igdusc64.dll C:\WINDOWS\SYSTEM32\igdusc64.dll, version=10.18.10.4425 It looks like your Intel graphics driver might be out-of-date. For your i5-3230M, I'm seeing version 15.33.53.5161 is available for download here: https://ark.intel.com/content/www/us/en/ark/products/72164/intel-core-i5-3230m-processor-3m-cache-up-to-3-20-ghz-rpga.html I have no idea if that will resolve your issue, but it's worth a shot. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
