hbiclan Posted January 1, 2021 Share Posted January 1, 2021 Hello, I need to create a costume texture with fishnet stockings but all I have is this low res texture, I was hoping to be able to create it from scratch in paint.net. I don't need the background just the "lattice" criss cross texture and transparency of course. Any help is greatly appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
MJW Posted January 1, 2021 Share Posted January 1, 2021 The basic element can be created with BoltBait's Grid/Checkerboard plugin, followed by a 45 degree rotation with Rotate/Zoom. You can then apply various adjustments, such as blurs, to get the look you want. You can create the cloth weve on another layer using the same plugin with a much tighter grid. EDIT: Probably a better plugin to create the main fishnet texture is MadJik's Hexagonal Grid. Quote Link to comment Share on other sites More sharing options...
Red ochre Posted January 1, 2021 Share Posted January 1, 2021 You could try this: Multispline Quote Red ochre Plugin pack.............. Diabolical Drawings ................Real Paintings Link to comment Share on other sites More sharing options...
ardneh Posted January 2, 2021 Share Posted January 2, 2021 (edited) Another way is to: Set secondary color to alpha. Fill a selection by Paint Bucket set to Diagonal Cross. Expand selection to fill the canvas. Duplicate Layer twice, merge all three layers. Apply AA's Assistant plugin effect. Edited June 14, 2021 by ardneh Quote Link to comment Share on other sites More sharing options...
