Brush with Noise?
I'm looking for a brush/tool which is essentially the pencil tool, but you can define an amount of deviation for saturation, hue and lightness. Then when using it, it paints each pixel to a random color within the ranges. Is there an addon or something that has this?
Edit: Clarification
Edited by Desertdweller1
Try this:
Duplicate the layer you want to paint noise on.
On the bottom layer of those two, use the Effects > Noise > Add Noise effect.
On the top layer, "paint" using the eraser tool.
When done "painting" merge the layer down.
Click to play:
6 minutes ago, BoltBait said:
Try this:
That does achieve the affect that I'm looking for, although I was hoping there might be a quicker way of doing it, allowing for more easily changing it. I do appreciate the help however.
What I might end up looking into doing is creating the addon myself if it's possible. I've found your guides for getting started, but they seem to be only for custom effects, does there happen to be any guides for creating custom brushes?
That is outside the scope of CodeLab and therefore outside the scope of my tutorials.
Sorry.
But, I'm glad I could provide a workaround.
Click to play:
