natanp123 Posted November 4, 2020 Share Posted November 4, 2020 (edited) Hello, I have been working with Paint.net a lot recently, but I have found a minor problem that bugs me a bit sometimes. Currently, when working with the line tool you only have 4 "nodes" to play around with to change the shape. I included a demonstration of a program called Pinta, which lets you freely adjust the amount of these nodes whenever and wherever. Thanks! P.S.: Maybe an option to choose between pre-generated nodes and this? Edited November 4, 2020 by natanp123 Spelling mistake Quote Link to comment Share on other sites More sharing options...
LoudSilence Posted November 4, 2020 Share Posted November 4, 2020 This plugin will suit what you are looking for 1 Quote Unofficial PDN Discord Server Link to comment Share on other sites More sharing options...
natanp123 Posted November 4, 2020 Author Share Posted November 4, 2020 True, but this requires you to export them as shapes. (or maybe I just can't read manuals properly and there is a way to export right to the canvas) Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted November 4, 2020 Share Posted November 4, 2020 22 minutes ago, natanp123 said: ... there is a way to export right to the canvas Look at the 'Draw on Canvas' checkbox. 2 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
natanp123 Posted November 4, 2020 Author Share Posted November 4, 2020 Of course thats a thing. (Thanks though!) Quote Link to comment Share on other sites More sharing options...
