Martinator Posted October 23, 2020 Share Posted October 23, 2020 Hi, is there a way to convert a specific type of pixels to another type on an image (kind of like the bucket) For example I want all the pixels on an image with a hex value of #AAAAAA to #ABC321, how do I do that? Quote Link to comment Share on other sites More sharing options...
Martinator Posted October 23, 2020 Author Share Posted October 23, 2020 (edited) I found a thread that helped to fix the problem for me. Edited October 23, 2020 by Martinator Quote Link to comment Share on other sites More sharing options...
MJW Posted October 23, 2020 Share Posted October 23, 2020 6 hours ago, Martinator said: Hi, is there a way to convert a specific type of pixels to another type on an image (kind of like the bucket) For example I want all the pixels on an image with a hex value of #AAAAAA to #ABC321, how do I do that? You may perhaps wince at the suggestion, but there is CodeLab. If you haven't programmed before, it can be intimidating, but with it you can quite easily accomplish what would otherwise be impossible. Quote Link to comment Share on other sites More sharing options...
LoudSilence Posted October 23, 2020 Share Posted October 23, 2020 This plugin could help Quote Unofficial PDN Discord Server Link to comment Share on other sites More sharing options...
