LSDesigns 6 Posted October 11, 2020 Report Share Posted October 11, 2020 I've tried to install 5 plug-in packs and I think I did most of it correctly, but a few things appear "off". I was encouraged to post here with images. Two of the packs came with installers so I know those were done correctly. I'm unsure of the rest. Could someone look these over and let me know if anything needs to be switched to the other folder. Thanks for any and all help!! ~Laura PS - Apparently I'll have to post each image separately. Each file is under 256 KB but there are two! Quote Link to post Share on other sites
LSDesigns 6 Posted October 11, 2020 Author Report Share Posted October 11, 2020 And this one shows the FileType folder.... Quote Link to post Share on other sites
AndrewDavid 730 Posted October 11, 2020 Report Share Posted October 11, 2020 Hi @LSDesigns Welcome to the Forum You were wise to think something was Off. All *.XML files that you have in C:\Program Files\paint.net\Effects belong in C:\Program Files\paint.net\Shapes All the files you have in C:\Program Files\paint.net\FileTypes can be moved into C:\Program Files\paint.net\Effects with one exception "AnimGIF.DLL" Let us know how it goes. 1 1 Quote Link to post Share on other sites
LSDesigns 6 Posted October 11, 2020 Author Report Share Posted October 11, 2020 Thank you, @AndrewDavid! I've made all of the moved changes you request except one. I left the "Photoshop" plug-in file within FileType. This plug-in now allows me to open .psd files, at least to a limited capacity. I design ebook/print covers and have been using older software since the turn of the century! Currently I'm using PrintShop 23.1 for the bulk of my design work then I used Paint.NET and FotoSketcher when needed. Gimp is the very devil to figure out....but I'd love to just to have a program that will give me more options on text. The request I get the most is for a metalic-looking text, no matter the font. My PrintShop can't do this. I have PrintShop 2.0, but it's very limited in what it can do, nothing even close to my 23.1 version. Over the years I've learned to manipulate the images using my software and it's served me well. I've even won a few contests with it! But I do love the Paint.NET layout and now it will have even more design tools and options for me to discover! I'm very excited about the possibilities. *g* I'm attaching an ebook cover I did recently. It's getting lots of positive comments on Facebook. The girl at the top started off as a black and white image. I had to use multiple layering to get this one just right. *g* Quote Link to post Share on other sites
BoltBait 3,236 Posted October 11, 2020 Report Share Posted October 11, 2020 6 hours ago, LSDesigns said: The request I get the most is for a metalic-looking text, no matter the font. If you have my plugin pack installed, which I see you do, look at this plugin: https://forums.getpaint.net/topic/115953-creative-text-pro-v11-by-boltbait-and-welshblue-updated-february-16-2020/ After rendering your text, then apply a shadow using Effects > Object > Object Shadow... Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
LSDesigns 6 Posted October 13, 2020 Author Report Share Posted October 13, 2020 BoltBait, So, I guess it was already installed with the pack you offered. I located it and was able to do this in just a few minutes. I'm on vacation in about 2 weeks and I'm going to spend the entire time messing with this!!! So awesome!! Thank you so very much for this! See below.... 4 2 Quote Link to post Share on other sites
Ego Eram Reputo 2,762 Posted October 14, 2020 Report Share Posted October 14, 2020 ^ That's really elegant! 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
