isabelle 0 Posted July 28, 2020 Share Posted July 28, 2020 (edited) when i copy something in a layer by using the rectangle select tool, it also copys the transparent part aswell. how do i fix this? Edited July 28, 2020 by isabelle Quote Link to post Share on other sites
BoltBait 3,312 Posted July 28, 2020 Share Posted July 28, 2020 Paste to a new layer. Use Ctrl-Shift-V instead of Ctrl-V. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
nooks12 0 Posted August 21, 2020 Share Posted August 21, 2020 Hi, I'm new to this program and having the same issue as OP. However, the first time I tried to copy something from one pic to another, it worked. I just selected what I wanted copied, copy, and then went to the other pic, and pasted. I might have chosen "copy to a new layer", can't remember. Voila. But when doing this a second time, I get a transparent selection. Won't work. Quote Link to post Share on other sites
toe_head2001 1,878 Posted August 21, 2020 Share Posted August 21, 2020 18 minutes ago, nooks12 said: ... I get a transparent selection ... Please ensure you've copied from the correct layer. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
nooks12 0 Posted August 21, 2020 Share Posted August 21, 2020 Hi, Thanks. As a newbie (as of yesterday) I don't know what that means. using this program to figure out colouring for exterior of house...Getting a new door, garage and wondering about trim and such... Quote Link to post Share on other sites
nooks12 0 Posted August 21, 2020 Share Posted August 21, 2020 So, I understand that I can save any creations I make in other formats, e.g. jpg. I tried that and found that I could not open it as a picture. Is this due to layering? What is the point of having it in jpg form if one cannot open it using some picture software e.g. google photos, windows photo app? What do I need to do to be able to open as a jpg and see the edits (layering) I made? Thanks. Quote Link to post Share on other sites
Ego Eram Reputo 2,838 Posted August 21, 2020 Share Posted August 21, 2020 Jpgs don't support layers or transparency. When you save as a jpg you're getting a single (combined) layer without any transparent areas. If you want to preserve the layer structure, save the image as a PDN file first, then use File > Save As to resave it as a jpg. When saving as any type do not type in the file extension. Select it from the list with the mouse. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
