RookieTeam Posted July 23, 2020 Share Posted July 23, 2020 How can I make blurry/Transparent pixels sharp/opaque? Example: To this Example: I turns all pixels sharp and I can easily see how sharp they are (I tried the sharpen thing but it didnt do what I wanted) Quote Link to comment Share on other sites More sharing options...
BoltBait Posted July 23, 2020 Share Posted July 23, 2020 There's a plugin in my plugin pack (link in sig) that might do what you want. It's found under Adjustments > Transparency. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
RookieTeam Posted July 23, 2020 Author Share Posted July 23, 2020 I see your plugin pack helps again, you are a great guy boltbait for making it. PS: It worked Thanks! Quote Link to comment Share on other sites More sharing options...
ViniB Posted November 4, 2022 Share Posted November 4, 2022 (edited) I solved this by using the Effects > Color > Quantize tool Edited November 4, 2022 by ViniB Quote Link to comment Share on other sites More sharing options...
