Problem after saving a Picture
Hi All,
I have a Problem after saving a Picture as *.jpg (this works fine). But if you change something and hit again save - i get the Error below:
Application version: paint.net v4.2.12
System.ComponentModel.Win32Exception (0x80004005): ReplaceFileW() returned FALSE (5, ERROR_ACCESS_DENIED)
   bei PaintDotNet.SystemLayer.NativeUtilities.ThrowOnWin32Error(String message, Int32 lastWin32Error, Boolean alwaysThrow) in D:\src\pdn\src\SystemLayer\NativeUtilities.cs:Zeile 89.
   bei PaintDotNet.SystemLayer.FileSystem.ReplaceFile(String replacedFileName, String replacementFileName, String backupFileName) in D:\src\pdn\src\SystemLayer\FileSystem.cs:Zeile 48.
   bei PaintDotNet.IO.SaveTransaction.Commit() in D:\src\pdn\src\PaintDotNet\IO\SaveTransaction.cs:Zeile 287.
   bei PaintDotNet.Controls.DocumentWorkspace.<>c__DisplayClass246_1.<DoSaveImpl>b__6() in D:\src\pdn\src\PaintDotNet\Controls\DocumentWorkspace.cs:Zeile 2794.
   bei PaintDotNet.Functional.Func.Try(Action f) in D:\src\pdn\src\Base\Functional\Func.cs:Zeile 174.
Regards
Andres
The same thing was happening to me after switching to v4.2.12.
I could not save over an existing file. I would have to 'save as' a new filename. It's possible my problem was related to saving to a network location.
I eventually just reverted to v4.2.11 and it fixed the problem.
Here is the hotfix: https://www.getpaint.net/files/zip/test/paint.net.4.213.7466.41336.install.zip
Please install this and try saving again to the locations where you were having trouble.
... And let me know if it works OR if it doesn't!
