FreshHex Posted June 3, 2020 Share Posted June 3, 2020 Hello I'm pretty new to paint.net and I'm just playing around with tools and learning how they work but every time I make a background layer, let's say a beach, and I add a new layer and paste a picture (png) of a tree with a transparent background, it still shows up with the checkered wall behind it. I've read previous forums on this and watched youtube videos but for the life of me I can't fix it. I'd really appreciate some help 🙂 Quote Link to comment Share on other sites More sharing options...
CsyeCok The Soldier Posted June 3, 2020 Share Posted June 3, 2020 Ah yes, the same problem I had with the program when I installed it. The thing is yes, it also copies transparency. You can insta-paste-n-create-a-new-layer by pressing the following: Quote Link to comment Share on other sites More sharing options...
FreshHex Posted June 3, 2020 Author Share Posted June 3, 2020 Thanks for your help but I already tried that.. Nothing seems to work Quote Link to comment Share on other sites More sharing options...
FreshHex Posted June 3, 2020 Author Share Posted June 3, 2020 Would someone be able to tell me step by step how to do it? Quote Link to comment Share on other sites More sharing options...
FreshHex Posted June 3, 2020 Author Share Posted June 3, 2020 Nevermind I figured it out Quote Link to comment Share on other sites More sharing options...
ANONYMISS Posted June 3, 2020 Share Posted June 3, 2020 (edited) 8 hours ago, FreshHex said: Nevermind I figured it out Hi @FreshHex Good to hear that you got that problem fixed. Any chance of you sharing the way that you fixed it? Sounds as if you were downloading an image showing a chequerboard background but described as 'transparent.png'. Plenty of them out there. If in doubt >right click the image>copy image andCTRL+ALT+V into Paint.Net to be sure that it is transparent... and get to know Paint.Net's distinctive chequerboard background. Edited June 3, 2020 by ANONYMISS Removed a carat for clarity Quote Link to comment Share on other sites More sharing options...
