need help with photoahop putting image in transparent background
Make sure you save your image in a format that supports transparency. The PNG format is recommended.
I'm not sure that answers your question though. Your lack of punctuation and sentence structure makes it difficult to understand accurately. Are you even using Paint.NET? Or are you using Photoshop of photoahop?
