My Paint.net just stopped working frandomly and would not work again
So, i have used Paint.net for like....2 years now, but just recently, it randomly just stopped working with this error message showing uip everytime, its the same one everytime:
Tento textový soubor byl vytvořen, protože aplikace paint.net se zhroutila. Prosím, pošlete nám jej e-mailem na adresu crashlog4@getpaint.net, abychom mohli potíže diagnostikovat a opravit.
Application version: paint.net 4.2.10 (Final 4.210.7348.40816)
Time of crash: 08.03.2020 19:03:44
Application uptime: 00:00:00.2265223
Application state: Starting
Working set: 37 160 KiB
Handles and threads: 337 handles, 19 threads, 0 gdi, 9 user
Install type: Classic
Application directory: C:\Program Files\paint.net
Current directory: C:\Program Files\paint.net
Install directory: C:\Program Files\paint.net
OS Version: Windows 10 Pro 10.0.18363.0 x64 (0x30)
.NET version: CLR 4.0.30319.42000 x64
Processor: "Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz" @ ~2703MHz (4C/8T, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2)
Physical memory: 8181 MB
Video card: AMD Radeon HD 6800 Series (v:1002, d:6739, r:0), Microsoft Basic Render Driver (v:1414, d:8C, r:0)
Hardware acceleration: True (default: True)
Pointers: none
UI animations: True
UI DPI: 96 dpi (1,00x scale)
UI theme: VisualStyleClass=Aero, EffectiveTheme=Aero, DWM=yes, AeroColorScheme=Dark, ThemeFileName=Aero.msstyles
Updates: True, 01.01.0001
Locale: pdnr.c: cs-CZ, hklm: cs-CZ, hkcu: cs-CZ, cc: cs-CZ, cuic: cs-CZ
Flags:
Exception details:
System.AggregateException: Došlo k jedné nebo více chybám. ---> System.BadImageFormatException: Nelze načíst soubor nebo sestavení PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 nebo jeden z jejich závislých prvků. Index nebyl nalezen. (Výjimka na základě hodnoty HRESULT: 0x80131124)
   v PaintDotNet.ObjectModel.PropertyPath..ctor(String path, Object[] pathParameters)
   v PaintDotNet.ObjectModel.PropertyPathUtil.Combine(String nameA, String nameB) v D:\src\pdn\src\Base\ObjectModel\PropertyPathUtil.cs:řádek 17
   v PaintDotNet.Canvas.CanvasView..ctor() v D:\src\pdn\src\PaintDotNet\Canvas\CanvasView.cs:řádek 43
   v PaintDotNet.Program.InitializeWpf() v D:\src\pdn\src\PaintDotNet\Program.cs:řádek 484
   v System.Threading.Tasks.Task.Execute()
   --- Konec trasování zásobníku pro vnitřní výjimku ---
   v System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
   v System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
   v PaintDotNet.Program.Start() v D:\src\pdn\src\PaintDotNet\Program.cs:řádek 344
   v PaintDotNet.Program.Main(String[] args) v D:\src\pdn\src\PaintDotNet\Program.cs:řádek 1743
---> (Inner Exception #0) System.BadImageFormatException: Nelze načíst soubor nebo sestavení PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 nebo jeden z jejich závislých prvků. Index nebyl nalezen. (Výjimka na základě hodnoty HRESULT: 0x80131124)
Název souboru: PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
WRN: Protokolování vazeb sestavení je VYPNUTO.
Chcete-li povolit protokolování chyb vazeb sestavení, nastavte hodnotu registru [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) na hodnotu 1.
Poznámka: Protokolování chyb vazeb sestavení ovlivňuje výkon systému.
Chcete-li tuto funkci vypnout, odeberte z registru hodnotu [HKLM\Software\Microsoft\Fusion!EnableLog].
Managed assemblies:
    mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll
    PaintDotNet, Version=4.210.7348.40816, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.exe
    PaintDotNet.SystemLayer, Version=4.210.7348.40816, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.dll
    System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
    System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll
    WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll
    System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll
    System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
    PaintDotNet.Base, Version=4.210.7348.40816, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Base.dll
    PaintDotNet.Core, Version=4.210.7348.40816, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Core.dll
    PaintDotNet.Resources, Version=4.210.7348.40816, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Resources.dll
    PaintDotNet.SystemLayer.Native.x64, Version=4.210.7348.40816, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll
    System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll
    System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll
    PaintDotNet.Data, Version=4.210.7348.40816, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Data.dll
    PaintDotNet.Framework, Version=4.210.7348.40816, Culture=neutral, PublicKeyToken=null @ C:\Program Files\paint.net\PaintDotNet.Framework.dll
    mscorlib.resources, Version=4.0.0.0, Culture=cs, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\mscorlib.resources\v4.0_4.0.0.0_cs_b77a5c561934e089\mscorlib.resources.dll
Native modules:
    C:\Program Files\paint.net\PaintDotNet.exe, version=4.210.7348.40816
    C:\Windows\SYSTEM32\ntdll.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\SYSTEM32\MSCOREE.DLL, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\System32\KERNEL32.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\KERNELBASE.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\ADVAPI32.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\msvcrt.dll, version=7.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\System32\sechost.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\System32\RPCRT4.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.8.4018.0 built by: NET48REL1LAST_C
    C:\Windows\System32\SHLWAPI.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\combase.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\ucrtbase.dll, version=10.0.18362.387 (WinBuild.160101.0800)
    C:\Windows\System32\bcryptPrimitives.dll, version=10.0.18362.295 (WinBuild.160101.0800)
    C:\Windows\System32\GDI32.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\System32\win32u.dll, version=10.0.18362.657 (WinBuild.160101.0800)
    C:\Windows\System32\gdi32full.dll, version=10.0.18362.535 (WinBuild.160101.0800)
    C:\Windows\System32\msvcp_win.dll, version=10.0.18362.387 (WinBuild.160101.0800)
    C:\Windows\System32\USER32.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\IMM32.DLL, version=10.0.18362.387 (WinBuild.160101.0800)
    C:\Windows\System32\kernel.appcore.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\SYSTEM32\VERSION.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.8.4121.0 built by: NET48REL1LAST_C
    C:\Windows\SYSTEM32\VCRUNTIME140_CLR0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM
    C:\Windows\SYSTEM32\ucrtbase_clr0400.dll, version=14.10.25028.0 built by: VCTOOLSD15RTM
    C:\Windows\System32\psapi.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\13f4543f755b32b6ebe0edeb92bb52a8\mscorlib.ni.dll, version=4.8.4121.0 built by: NET48REL1LAST_C
    C:\Windows\System32\ole32.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\system32\uxtheme.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\assembly\NativeImages_v4.0.30319_64\System\01a3608d87251d7ea99342a88d079c23\System.ni.dll, version=4.8.4001.0 built by: NET48REL1LAST_C
    C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Drawing\0f37de2ad0f0f46cb3f13829998e7275\System.Drawing.ni.dll, version=4.8.3752.0 built by: NET48REL1
    C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\7376cc5212948bb304d872ff31481521\System.Windows.Forms.ni.dll, version=4.8.4121.0 built by: NET48REL1LAST_C
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.8.4121.0 built by: NET48REL1LAST_C
    C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Core\2a6c39230fef9dfafc7ede45f99ec776\System.Core.ni.dll, version=4.8.4121.0 built by: NET48REL1LAST_C
    C:\Windows\assembly\NativeImages_v4.0.30319_64\WindowsBase\996cd1a75c20ce6e697aad199323707b\WindowsBase.ni.dll, version=4.8.4121.0 built by: NET48REL1LAST_C
    C:\Windows\System32\CRYPTSP.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\system32\rsaenh.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\System32\bcrypt.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\SYSTEM32\CRYPTBASE.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\4a032a2be4e6a7d0fb9856a473629571\PaintDotNet.SystemLayer.ni.dll, version=4.210.7348.40816
    C:\Windows\System32\shell32.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\cfgmgr32.dll, version=10.0.18362.387 (WinBuild.160101.0800)
    C:\Windows\System32\shcore.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\windows.storage.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\profapi.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\System32\powrprof.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\System32\UMPDC.dll, version=
    C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\756619b62aebaaf0929578dac3590c13\PaintDotNet.Resources.ni.dll, version=4.210.7348.40816
    C:\Program Files\paint.net\Native\X64\vcruntime140.dll, version=14.24.28127.4 built by: vcwrkspc
    C:\Program Files\paint.net\Native\X64\vcruntime140_1.dll, version=14.24.28127.4 built by: vcwrkspc
    C:\Program Files\paint.net\Native\X64\msvcp140.dll, version=14.24.28127.4 built by: vcwrkspc
    C:\Program Files\paint.net\Native\X64\msvcp140_1.dll, version=14.24.28127.4 built by: vcwrkspc
    C:\Program Files\paint.net\Native\X64\msvcp140_2.dll, version=14.24.28127.4 built by: vcwrkspc
    C:\Program Files\paint.net\Native\X64\msvcp140_codecvt_ids.dll, version=14.24.28127.4 built by: vcwrkspc
    C:\Program Files\paint.net\Native\X64\vcomp140.dll, version=14.24.28127.4 built by: vcwrkspc
    C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\c8637cddc03fbab9403801382088ba79\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.210.7348.40816
    C:\Program Files\paint.net\PaintDotNet.SystemLayer.Native.x64.dll, version=4.210.7348.40816
    C:\Windows\System32\OLEAUT32.dll, version=10.0.18362.535 (WinBuild.160101.0800)
    C:\Windows\SYSTEM32\PROPSYS.dll, version=7.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.18362.657_none_17b0a85e6da0b266\gdiplus.dll, version=10.0.18362.657 (WinBuild.160101.0800)
    C:\Windows\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Configuration\41f720dbb9d0446f9a1c3e00d795c28c\System.Configuration.ni.dll, version=4.8.3752.0 built by: NET48REL1
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.8.4121.0 built by: NET48REL1LAST_C
    C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xml\95eca487669e18143c3a7266e929ddfd\System.Xml.ni.dll, version=4.8.3752.0 built by: NET48REL1
    C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\69a38237bfff9cc7304a9dd303948cd1\PaintDotNet.Framework.ni.dll, version=4.210.7348.40816
    C:\Windows\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\ab47787c283ed817a2752bffc2e72843\PaintDotNet.Data.ni.dll, version=4.210.7348.40816
    C:\Windows\System32\MSCTF.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\SYSTEM32\dxgi.dll, version=10.0.18362.387 (WinBuild.160101.0800)
    C:\Windows\SYSTEM32\dxcore.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\System32\SetupApi.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\SYSTEM32\DEVOBJ.dll, version=10.0.18362.387 (WinBuild.160101.0800)
    C:\Windows\System32\WINTRUST.dll, version=10.0.18362.387 (WinBuild.160101.0800)
    C:\Windows\System32\MSASN1.dll, version=10.0.18362.1 (WinBuild.160101.0800)
    C:\Windows\System32\CRYPT32.dll, version=10.0.18362.653 (WinBuild.160101.0800)
    C:\Windows\SYSTEM32\dwmapi.dll, version=10.0.18362.653 (WinBuild.160101.0800)
(Im sorry its in Czech, but you could find the issue nonetheless)
I Reinstalled it Several times, tried several forum "Fixes" , and it still doesnt work. Im hopeless, please help.
Hello @Neonflame and Welcome to the forum :)
I just ran your error in the crash log, found here:
It did not give any solutions, but you should first try these steps.
Some general things you can try: (1) reboot, (2) Windows updates, (3) In the Paint.NET directory there is a program called PdnRepair.exe, run that.
Thanks, it looks like the update arrived just today, because i looked to it and installed it, but when it stopped working (several days ago) there wasnt any update.
thanks. :D
