cowlinator Posted February 21, 2020 Share Posted February 21, 2020 Q: How can I draw straight horizontal or vertical lines in Paint.net? A. The shift key. Select the line tool, and then hold down the shift key while creating the line via dragging with the mouse. Oddly, I couldn't find this information anywhere when googling, using the expected keywords. You'd have to google "Lock rotation to 15° increments". Which nobody will. Which is the reason I'm making this post. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted February 21, 2020 Share Posted February 21, 2020 Such information is made available in the Paint.NET documentation. https://www.getpaint.net/doc/latest/LineCurveTool.html#3 https://www.getpaint.net/doc/latest/KeyboardMouseCommands.html Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 22, 2020 Share Posted February 22, 2020 6 hours ago, cowlinator said: Oddly, I couldn't find this information anywhere when googling, using the expected keywords. You'd have to google "Lock rotation to 15° increments". Which nobody will. Which is the reason I'm making this post. 0 degrees, 180 degrees and 360 degrees are all multiples of 15 degrees (0*15=0, 12*15=180 and 24*15=360). Stands to reason the SHIFT key modifier can be used to create vertical and horizontal lines. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
