thelonelyme Posted January 8, 2020 Share Posted January 8, 2020 I don't know why this is happening, I don't know what I did, if ANYONE can help with this, It would be greatly appreciated. btw I have tried uninstalling everything, fixing paint.net through the programs and features on Win 10, and using the paint.net fix thing in the files. Quote Link to comment Share on other sites More sharing options...
thelonelyme Posted January 8, 2020 Author Share Posted January 8, 2020 I turned off 'Hardware Accelerated Rendering', I think it fixed the bug, but what happens when I turn it off? should I turn it off? Quote Link to comment Share on other sites More sharing options...
Reptillian Posted January 8, 2020 Share Posted January 8, 2020 Right now that is a temporary solution until @Rick Brewster fixes it. So, I believe you should turn it off. That being said, that is very wacky, but there is interesting generated stuff from the bug. Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
BoltBait Posted January 8, 2020 Share Posted January 8, 2020 You have sharpening enabled in the NVIDIA Control Panel. Turn off that feature and you should be good. 1 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
thelonelyme Posted January 9, 2020 Author Share Posted January 9, 2020 @BoltBait but I use that for my games, I can turn it off if it helps, but can I keep 'hardware accelerated rendering' off? Quote Link to comment Share on other sites More sharing options...
thelonelyme Posted January 9, 2020 Author Share Posted January 9, 2020 @Reptillian so, the issue can be fixed? I dont need to change my own settings? if I do, I understand, but should I wait for a fix? Quote Link to comment Share on other sites More sharing options...
null54 Posted January 9, 2020 Share Posted January 9, 2020 46 minutes ago, thelonelyme said: so, the issue can be fixed? I dont need to change my own settings? if I do, I understand, but should I wait for a fix? The issue is caused by the sharpening feature being enabled in the global settings, which forces it to be applied to all applications. You should be able to turn it off in global settings and enable it for individual games using the program settings. On 11/7/2019 at 12:49 PM, Rick Brewster said: Yeah there will always be "issues" if you go into the NVIDIA control panel and force it to globally enable things that are really meant for games. It's a bad design on NVIDIA's part, IMO. You found the solution though: don't do that There's nothing I can do on the app side. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 9, 2020 Share Posted January 9, 2020 Don't turn on sharpening globally. Turn it on for each game. There's no possible fix on my side, you just have to avoid using global settings like this. It's just a dumb thing NVIDIA did with their driver. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
