Wizertex Posted December 26, 2019 Share Posted December 26, 2019 Hello! So, I am trying to make a material desing logo. I know, it's not really good, but, it's good enough for me. Basically, I made some shadows with Unfocus effect. When I save it as a png, shadows "broke". IMAGE IN PAINT (How the logo should look when saved & transparent background) IMAGE WHEN SAVED AS PNG: I would really like to fix that issue somehow, because, it looks very weird. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 26, 2019 Share Posted December 26, 2019 They look same; the shadows abruptly end in both images. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Wizertex Posted December 26, 2019 Author Share Posted December 26, 2019 (edited) 3 minutes ago, toe_head2001 said: They look same; the shadows abruptly end in both images. They don't. This is an image from PAINT.net with white background and difference is visible. In the saved image (second agove.), shadow's outlines are clearly visible, which I don't want. But yeah, how would i still improve it? Edited December 26, 2019 by Wizertex Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 26, 2019 Share Posted December 26, 2019 They are also visible in the image you just posted. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Wizertex Posted December 26, 2019 Author Share Posted December 26, 2019 2 minutes ago, toe_head2001 said: They are also visible in the image you just posted. How would I improve it? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 26, 2019 Share Posted December 26, 2019 1 minute ago, Wizertex said: How would I improve it? You need to make sure your canvas in large enough for shadow boundaries. Otherwise, the shadows will get cut off. So, Enlarge your canvas, and re-draw the shadows. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Wizertex Posted December 26, 2019 Author Share Posted December 26, 2019 3 minutes ago, toe_head2001 said: You need to make sure your canvas in large enough for shadow boundaries. Otherwise, the shadows will get cut off. So, Enlarge your canvas, and re-draw the shadows. Okay, this is much better than the previous one, what do you think? Thank you for your help! Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 26, 2019 Share Posted December 26, 2019 1 minute ago, Wizertex said: Okay, this is much better than the previous one, what do you think? I agree, much better. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 26, 2019 Share Posted December 26, 2019 4 hours ago, Wizertex said: Okay, this is much better than the previous one, what do you think? Honest opinion: I think the shadows are too heavy handed. Drop shadows want to be more subtle. The elements would also benefit from different shadow lengths and intensities to make the elements look more separated and reinforce that they are at different heights off the background. To illustrate, below I've used different shadow lengths to make the separation more obvious (original is on the left, mine on the right). On the right, the purple rectangle has a shadow length about 10px when it is over the blue disk. When the same purple rectangle is over the white background, the shadow is longer and a little more diffuse - indicating the purple element is further away from the background than the blue disk. There are some nice overlapping shadows where the purple shadow meets the blue shadow. I pulled the same trick with the NB letters. I've also made the lighting a bit more directional. The light apparently comes in slightly from the NW corner - casting longer shadows to the East and South of every element. I didn't redo GAMES with this shadow direction - but you should get the idea that it too should have a directional shadow. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
