ivaniesta141 1 Posted November 26, 2019 Report Share Posted November 26, 2019 As it can be seen in the screenshot below, the Layers window is wrongly placed, although it is considered docked. The intended position is to the left of the Colors window (this one is currently docked to the top-right of the window), which is where it was snapped-to in previous versions of paint.net Running paint.net 4.2.7 on windows 10. Happens regardless of monitor dpi and window size. Did not happen in previous versions of paint.net (namely in 4.2.6 alpha/beta versions) Further testing: Trying to dock a window to the corner or one side of the window results in erratic movement, and offscreen window movement. Workaround: For some reason trying to reset the windows' position fixes this, although the first time trying this results in the window being placed wrongly. Quote Link to post Share on other sites
Rick Brewster 1,752 Posted November 26, 2019 Report Share Posted November 26, 2019 You have multiple monitors, I take it? Do they have different DPI/scaling settings? That will definitely cause weird docking stuff to happen. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to post Share on other sites
ivaniesta141 1 Posted November 27, 2019 Author Report Share Posted November 27, 2019 Yes, I have multiple monitors with different dpi settings. The issue I am reporting is the fact that docking was not buggy until version 4.2.7 (or maybe 4.2.6, I haven't tested it) Quote Link to post Share on other sites
